Project: 2665 (Run 3, Clone 588, Gen 40) - No credit
bp2007av123
Hi,
Can somebody check this for me?
This WU completed fine and was sent to the server, but I don't see any credit for this one.
As far as I can tell, there was not any issue with this WU and all my particulars (userID etc)
were fine too.
Thanks in advance,
bp2007av123
were fine too.
Thanks in advance,
bp2007av123
Re: Project: 2665 (Run 3, Clone 588, Gen 40)
The stats db hasn't recovered from the power outage yet ... I can't help you
Can't connect to the stats database
bp2007av123
Thanks for checking.toTOW wrote:The stats db hasn't recovered from the power outage yet ... I can't help you
Hopefully it will be up and running soon.
bp2007av123
Re: Project: 2665 (Run 3, Clone 588, Gen 40) - No credit
Help please.
I have another WU in project 2665, which was uploaded successfully, but I have not seen any credit for it.
I have these 2 WUs so far.
Project: 2665 (Run 2, Clone 419, Gen 42)
Thanks in advance for help,
bp2007av123
bp2007av123
Hi bp2007av123 (team 40727),
Your WU (P2665 R3 C588 G40) was added to the stats database on 2008-08-13 22:37:32 for 1920 points of credit.
Your WU (P2665 R3 C588 G40) was added to the stats database on 2008-08-17 22:36:55 for 0 points of credit.
Your WU (P2665 R2 C419 G42) was added to the stats database on 2008-08-21 06:38:37 for 0 points of credit.
Are you sneakernetting WU between different machines
bp2007av123
No. Actually both these WUs were hung at 100% completion and only way to get them to upload was, when I use qfix.exe and then used "-send" option from command line.toTOW wrote:Hi bp2007av123 (team 40727),
From the messages in log file, they seem to have uploaded correctly.
I have another WU too
Project: 2665 (Run 1, Clone 36, Gen 42)
Again, there is something wrong :
Your WU (P2665 R1 C36 G42) was added to the stats database on 2008-08-19 15:08:50 for 0 points of credit.
The error code says that the client sent back the result multiple times (even if it's your only report ... there is another one for full credit, but not under your username).
bp2007av123
Thanks for checking.toTOW wrote:Again, there is something wrong :
I will give it another try before giving up on this. I will uninstall everything on this computer and then do a clean install and see if it makes any difference.
Also, I have just now downloaded 6.22beta2R3 executable, so let us see if it makes any difference.
Thanks again.
I think it will help ... you were probably experiencing the ACK issue (previous client wasn't able to receive ACK (acknowledgment) packets from the server after returning a WU).bp2007av123 wrote:Also, I have just now downloaded 6.22beta2R3 executable, so let us see if it makes any difference.
