Project: 2451 (Run 3, Clone 19, Gen 14)
Leoslocks
Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870
GPU2 Version 6.20| CPU three 6.20 Clients
Post by Leoslocks »
This core hangs at Writing Local Files.
If left alone it will kill the client. The service appears to be running but no CPU usage.
I have tried deleting the Work folder, queue, unitfo and 78 core but keep getting the same WU.
-- Opening Log file [August 17 02:48:08 UTC]
                       Folding@Home Client Version 6.20
                          http://folding.stanford.edu
Launch directory: C:\F@H\Core3
Service: C:\F@H\Core3\6.20
Arguments: -svcstart -d C:\F@H\Core3
Launched as a service.
Entered C:\F@H\Core3 to do work.
[02:48:08] - Ask before connecting: No
[02:48:08] - User name: Leoslocks (Team 34878)
[02:48:08] - User ID: 55D1766C1DD70416
[02:48:08] - Machine ID: 3
[02:48:08]
[02:48:08] Loaded queue successfully.
[02:48:08]
[02:48:08] + Processing work unit
[02:48:08] Core required: FahCore_78.exe
[02:48:08] Core found.
[02:48:08] Working on queue slot 09 [August 17 02:48:08 UTC]
[02:48:08] + Working ...
[02:48:08]
[02:48:08] *------------------------------*
[02:48:08] Folding@Home Gromacs Core
[02:48:08] Version 1.90 (March 8, 2006)
[02:48:08]
[02:48:08] Preparing to commence simulation
[02:48:08] - Looking at optimizations...
[02:48:08] - Files status OK
[02:48:09] - Expanded 398558 -> 6680577 (decompressed 1676.1 percent)
[02:48:09]
[02:48:09] Project: 2451 (Run 3, Clone 19, Gen 14)
[02:48:09]
[02:48:09] Assembly optimizations on if available.
[02:48:09] Entering M.D.
[02:48:16] Protein: p2451_Fragment-Receptor HDQ
[02:48:16]
[02:48:16] Writing local files
[03:31:38]
[03:31:38] Folding@home Core Shutdown: INTERRUPTED
[03:31:40] CoreStatus = 66 (102)
[03:31:40] + Shutdown requested by user. Exiting.
Folding@Home Client Shutdown.
--- Opening Log file [August 17 03:33:11 UTC]
[03:33:11] - Ask before connecting: No
[03:33:11] - User name: Leoslocks (Team 34878)
[03:33:11] - User ID: 55D1766C1DD70416
[03:33:11] - Machine ID: 3
[03:33:11]
[03:33:12] Loaded queue successfully.
[03:33:12]
[03:33:12] + Processing work unit
[03:33:12] Core required: FahCore_78.exe
[03:33:12] Core found.
[03:33:12] Working on queue slot 09 [August 17 03:33:12 UTC]
[03:33:12] + Working ...
[03:33:12]
[03:33:12] *------------------------------*
[03:33:12] Folding@Home Gromacs Core
[03:33:12] Version 1.90 (March 8, 2006)
[03:33:12]
[03:33:12] Preparing to commence simulation
[03:33:12] - Looking at optimizations...
[03:33:12] - Files status OK
[03:33:13] - Expanded 398558 -> 6680577 (decompressed 1676.1 percent)
[03:33:13]
[03:33:13] Project: 2451 (Run 3, Clone 19, Gen 14)
[03:33:13]
[03:33:13] Assembly optimizations on if available.
[03:33:13] Entering M.D.
[03:33:20] Protein: p2451_Fragment-Receptor HDQ
[03:33:20]
[03:33:20] Writing local files
[04:31:04] Gromacs error.
[04:31:04]
[04:31:04] Folding@home Core Shutdown: UNKNOWN_ERROR
[04:31:08] CoreStatus = 79 (121)
[04:31:08] Client-core communications error: ERROR 0x79
[04:31:08] This is a sign of more serious problems, shutting down.
Re: Project: 2451 (Run 3, Clone 19, Gen 14)
Just for your information, here is what we know about ERROR 0x79 : http://fahwiki.net/index.php/CoreStatus_codes#79
