p3062 (Run 5 Clone 100 Gen 60) multiple 0x0 @ 91%
parkut
Project: 3062 (Run 5, Clone 100, Gen 60) 0x0 @91%
Post by parkut »
Failed at 91% four times in a row, started on the 5th run
Tag: P3062R5C100G60
model name : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
cpu MHz : 1596.000
cache size : 4096 KB
Memory: 976.11 MB physical, 1.94 GB virtual
[06:52:10] Completed 4550000 out of 5000000 steps (91 percent)
[06:54:54] Warning: long 1-4 interactions
[06:54:58] CoreStatus = 0 (0)
[06:54:58] Client-core communications error: ERROR 0x0
parkut
Post by parkut »
This particular WU has failed seven (7) times in a row at 91%, and has started on it's 8th run...
cpu MHz : 1596.000
[16:32:23] Completed 4500000 out of 5000000 steps  (90 percent)
[16:42:29] Writing local files
[16:42:29] Completed 4550000 out of 5000000 steps  (91 percent)
[16:45:14] Warning:  long 1-4 interactions
[16:45:18] CoreStatus = 0 (0)
[16:45:18] Client-core communications error: ERROR 0x0
Download time: August 11 01:16:38
Download time: August 11 16:49:50
Download time: August 12 08:21:47
Download time: August 12 23:53:29
Download time: August 13 15:25:32
Download time: August 14 06:59:29
and today
Current Work Unit
Tag: P3062R5C100G60
Download time: August 14 22:30:56
Due time: August 18 10:30:56
Progress: 91% [|||||||||_]
parkut
Re: p3062 (Run 5 Clone 100 Gen 60) multiple 0x0 @ 91%
Post by parkut »
Failed at the same place again, now starting the ninth (9th) run.
Download time: August 16 05:35:55
Apparently, you completed it once :
Hi parkut (team 4),
Your WU (P3062 R5 C100 G60) was added to the stats database on 2008-08-16 16:25:28 for 1732 points of credit.
