Project: 4415 (Run 29, Clone 15, Gen 195)
paramonks
Hardware configuration: Win 7, Intel i5 650 @ 3.20 Ghz, 4 Gb Ram, ASUSTeK P5GPL-X, NVidia GeForce 6200 Turbo Cache (yeah it's old - but it works)
Sys tray client
Post by paramonks »
Hello folks
I wish to enquire if the above WU has been noted as received and completed. It is not showing up on my stats.
Could someone with access to that information kindly look it up for me. I think something has gone wrong with this WU.
Yep lucky me 2 completed WU's appear to have gone missing in a row. :?
regards - paramonks
Re: Project: 4415 (Run 29, Clone 15, Gen 195)
No data for this WU.
I suspect there is something wrong with p44xx or the server handling them. I alerted the PandeGroup.
paramonks
Sys tray client
Post by paramonks »
Thank you toTOW for the reply. I can supply the log file like the other missing WU if needed. This WU was one with a quick turn around and as it is now 9 days since I orginally completed it, I suspect they will have rescheduled it for someone else to do.
regards - paramonks
paramonks
Sys tray client
Post by paramonks »
Hello
Can someone please advise if there is any further information on what happened to this completed WU that was uploaded on the 10th of August?
Thank you very much
paramonks
Baowoulf
Hardware configuration: Pentium 4 2.8 GHz, 512MB DDR Ram, 128MB Radeon 9800, Creative Soundblaster Audigy 4 Pro
Post by Baowoulf »
It might be coming soon. I recently got 225points out of nowhere and I was missing a 4432 which is worth 25points which finished on August 10. And I think 7im said in a post on the 6.20 CPU section that some people might be credited in the next few days because of a server problem that was fixed.
paramonks
Sys tray client
Post by paramonks »
Hello Baowoulf
Thank you for the information. I don't run the 6.20 version, perhaps credit is still coming for the WU.
I'm not having much luck with completed WU's of late, 3 units out of the 9 I have completed have gone missing in 17 days. It's just frustrating.
paramonks
Baowoulf
Post by Baowoulf »
I don't think it was limited to 6.20. Just that 6.20 is the latest CPU version out atm. I'll see if I can find a link to his post and post his quote here as well.
Edit: viewtopic.php?f=47&t=5080
7im wrote:Actually, the work server sending out project 441x work units wasn't crediting work units correctly. Stanford is currently running a recrediting script to get those points credited. You'll probably see a slight jump in points in a day or so when those hit your account.
There is an ongoing recredit for these WU ...
