Project: 3064 (Run 1, Clone 65, Gen 83)
DocJonz
Post by DocJonz »
I expect this WU will delete itself a third time at the same place ....
[15:01:42] + Attempting to send results
[15:02:56] + Results successfully sent
[15:02:56] Thank you for your contribution to Folding@Home.
[15:02:56] + Number of Units Completed: 148
[15:07:01] - Preparing to get new work unit...
[15:07:01] + Attempting to get work packet
[15:07:01] - Connecting to assignment server
[15:07:01] - Successful: assigned to (171.64.65.63).
[15:07:01] + News From Folding@Home: Welcome to Folding@Home
[15:07:01] Loaded queue successfully.
[15:07:20] + Closed connections
[15:07:20]
[15:07:20] + Processing work unit
[15:07:20] Core required: FahCore_a1.exe
[15:07:20] Core found.
[15:07:21] Working on Unit 01 [August 14 15:07:21]
[15:07:21] + Working ...
[15:07:21]
[15:07:21] *------------------------------*
[15:07:21] Folding@Home Gromacs SMP Core
[15:07:21] Version 1.74 (November 27, 2006)
[15:07:21]
[15:07:21] Preparing to commence simulation
[15:07:21] - Ensuring status. Please wait.
[15:07:38] - Assembly optimizations manually forced on.
[15:07:38] - Not checking prior termination.
[15:07:38] - Expanded 610296 -> 3266341 (decompressed 535.2 percent)
[15:07:38] - Starting from initial work packet
[15:07:38]
[15:07:38] Project: 3064 (Run 1, Clone 65, Gen 83)
[15:07:38]
[15:07:38] Assembly optimizations on if available.
[15:07:38] Entering M.D.
[15:07:44] Protein: p3064_lambdaProtein: p3064_lambda5_2003Extra SSE boost OK.
[15:07:44]
[15:07:44] Extra SSE boost OK.
[15:07:44] Writing local files
[15:07:44] Completed 0 out of 5000000 steps  (0 percent)
[15:22:14] Writing local files
[15:22:14] Completed 50000 out of 5000000 steps  (1 percent)
[15:36:43] Writing local files
[15:36:43] Completed 100000 out of 5000000 steps  (2 percent)
[15:51:14] Writing local files
[15:51:14] Completed 150000 out of 5000000 steps  (3 percent)
[16:05:43] Writing local files
[16:05:43] Completed 200000 out of 5000000 steps  (4 percent)
[16:20:09] Writing local files
[16:20:09] Completed 250000 out of 5000000 steps  (5 percent)
[16:34:36] Writing local files
[16:34:36] Completed 300000 out of 5000000 steps  (6 percent)
[16:49:04] Writing local files
[16:49:04] Completed 350000 out of 5000000 steps  (7 percent)
[17:03:31] Writing local files
[17:03:31] Completed 400000 out of 5000000 steps  (8 percent)
[17:18:00] Writing local files
[17:18:00] Completed 450000 out of 5000000 steps  (9 percent)
[17:18:58] Warning:  long 1-4 interactions
[17:19:02] CoreStatus = 1 (1)
[17:19:02] Client-core communications error: ERROR 0x1
[17:19:02] Deleting current work unit & continuing...
[17:23:24] - Preparing to get new work unit...
[17:23:24] + Attempting to get work packet
[17:23:24] - Connecting to assignment server
[17:23:27] - Successful: assigned to (171.64.65.63).
[17:23:27] + News From Folding@Home: Welcome to Folding@Home
[17:23:27] Loaded queue successfully.
[17:23:48] + Closed connections
[17:23:53]
[17:23:53] + Processing work unit
[17:23:53] Core required: FahCore_a1.exe
[17:23:53] Core found.
[17:23:54] Working on Unit 02 [August 14 17:23:54]
[17:23:54] + Working ...
[17:23:54]
[17:23:54] *------------------------------*
[17:23:54] Folding@Home Gromacs SMP Core
[17:23:54] Version 1.74 (November 27, 2006)
[17:23:54]
[17:23:54] Preparing to commence simulation
[17:23:54] - Ensuring status. Please wait.
[17:24:11] - Assembly optimizations manually forced on.
[17:24:11] - Not checking prior termination.
[17:24:11] - Expanded 610296 -> 3266341 (decompressed 535.2 percent)
[17:24:11] - Starting from initial work packet
[17:24:11]
[17:24:11] Project: 3064 (Run 1, Clone 65, Gen 83)
[17:24:11]
[17:24:11] Assembly optimizations on if available.
[17:24:11] Entering M.D.
[17:24:17] Protein: p3064_lambdaProtein: p3064_lambda5_2003Extra SSE boost OK.
[17:24:17]
[17:24:17] Extra SSE boost OK.
[17:24:17] Writing local files
[17:24:17] Completed 0 out of 5000000 steps  (0 percent)
[17:38:44] Writing local files
[17:38:44] Completed 50000 out of 5000000 steps  (1 percent)
[17:53:12] Writing local files
[17:53:12] Completed 100000 out of 5000000 steps  (2 percent)
[18:07:43] Writing local files
[18:07:43] Completed 150000 out of 5000000 steps  (3 percent)
[18:22:09] Writing local files
[18:22:09] Completed 200000 out of 5000000 steps  (4 percent)
[18:36:34] Writing local files
[18:36:34] Completed 250000 out of 5000000 steps  (5 percent)
[18:51:01] Writing local files
[18:51:01] Completed 300000 out of 5000000 steps  (6 percent)
[19:05:29] Writing local files
[19:05:29] Completed 350000 out of 5000000 steps  (7 percent)
[19:19:56] Writing local files
[19:19:56] Completed 400000 out of 5000000 steps  (8 percent)
[19:34:26] Writing local files
[19:34:26] Completed 450000 out of 5000000 steps  (9 percent)
[19:35:25] Warning:  long 1-4 interactions
[19:35:29] CoreStatus = 1 (1)
[19:35:29] Client-core communications error: ERROR 0x1
[19:35:29] Deleting current work unit & continuing...
[19:39:50] - Preparing to get new work unit...
[19:39:50] + Attempting to get work packet
[19:39:50] - Connecting to assignment server
[19:39:51] - Successful: assigned to (171.64.65.63).
[19:39:51] + News From Folding@Home: Welcome to Folding@Home
[19:39:51] Loaded queue successfully.
[19:40:07] + Closed connections
[19:40:12]
[19:40:12] + Processing work unit
[19:40:12] Core required: FahCore_a1.exe
[19:40:12] Core found.
[19:40:12] Working on Unit 03 [August 14 19:40:12]
[19:40:12] + Working ...
[19:40:13]
[19:40:13] *------------------------------*
[19:40:13] Folding@Home Gromacs SMP Core
[19:40:13] Version 1.74 (November 27, 2006)
[19:40:13]
[19:40:13] Preparing to commence simulation
[19:40:13] - Ensuring status. Please wait.
[19:40:30] - Assembly optimizations manually forced on.
[19:40:30] - Not checking prior termination.
[19:40:30] - Expanded 610296 -> 3266341 (decompressed 535.2 percent)
[19:40:30] - Starting from initial work packet
[19:40:30]
[19:40:30] Project: 3064 (Run 1, Clone 65, Gen 83)
[19:40:30]
[19:40:30] Assembly optimizations on if available.
[19:40:30] Entering M.D.
[19:40:36] Protein: p3064_lambdaProtein: p3064_lambda5_2003Extra SSE boost OK.
[19:40:36]
[19:40:36] Extra SSE boost OK.
[19:40:36] Writing local files
[19:40:36] Completed 0 out of 5000000 steps  (0 percent)
[19:55:02] Writing local files
[19:55:02] Completed 50000 out of 5000000 steps  (1 percent)
[20:09:27] Writing local files
[20:09:27] Completed 100000 out of 5000000 steps  (2 percent)
[20:23:55] Writing local files
[20:23:55] Completed 150000 out of 5000000 steps  (3 percent)
[20:38:22] Writing local files
[20:38:22] Completed 200000 out of 5000000 steps  (4 percent)
EDIT - and it did fail a third time at the same place - now downloading a new WU .....
Re: Project: 3064 (Run 1, Clone 65, Gen 83)
Someone else completed it successfully ...
