I had two machines working on the same work unit with a slightly different project number, is that cool?
Now one of my machines finished that project and downloaded it again, is this right?
Machine 001
Project number: 2170 (25-52-14)
Work unit: p2170_lambda_obc_300K
Machine 002
Project number: 2170 (77-426-10)
2 PC's same WU: p2170_lambda_obc_300K
Baowoulf
- Hardware configuration: Pentium 4 2.8 GHz, 512MB DDR Ram, 128MB Radeon 9800, Creative Soundblaster Audigy 4 Pro
Re: 2 PC's same WU: p2170_lambda_obc_300K
It's normal. Each Project will have many different WU's. As long as they don't have the same RCG numbers it's fine if they have the same project number.
thanks man, that clears things up.
