Project: 2665 (Run 0, Clone 652, Gen 39)
mikeb12
Post by mikeb12 »
just reporting, already on a new wu....
6.22 mpich Vista64
Quit 101 - NaN detected: (ener[20])
Client-core communications error: ERROR 0x7b
[12:16:53] Completed 247500 out of 250000 steps  (99 percent)
[12:36:11] Writing local files
[12:36:11] Completed 250000 out of 250000 steps  (100 percent)
[12:36:11] Writing final coordinates.
[12:36:13] Past main M.D. loop
[12:36:14] Will end MPI now
[12:37:14]
[12:37:14] Finished Work Unit:
[12:37:14] - Reading up to 21421872 from "work/wudata_09.arc": Read 21421872
[12:37:14] - Reading up to 589572 from "work/wudata_09.xtc": Read 589572
[12:37:14] goefile size: 0
[12:37:14] logfile size: 212426
[12:37:14] Leaving Run
[12:37:18] - Writing 22230242 bytes of core data to disk...
[12:37:18]   ... Done.
[12:37:18] - Failed to delete work/wudata_09.sas
[12:37:18] - Failed to delete work/wudata_09.goe
[12:37:18] Warning:  check for stray files
[12:37:18] - Shutting down core
[12:39:18]
[12:39:18] Folding@home Core Shutdown: FINISHED_UNIT
[12:39:18]
[12:39:25] CoreStatus = 64 (100)
[12:39:25] Sending work to server
[12:39:25] Project: 2665 (Run 2, Clone 503, Gen 40)
[12:39:25] + Attempting to send results [August 12 12:39:25 UTC]
[12:53:43] + Results successfully sent
[12:53:43] Thank you for your contribution to Folding@Home.
[12:53:43] + Number of Units Completed: 9
[12:53:44] Using generic mpiexec calls
[12:55:47] - Preparing to get new work unit...
[12:55:47] + Attempting to get work packet
[12:55:47] - Connecting to assignment server
[12:55:47] - Successful: assigned to (171.64.65.64).
[12:55:47] + News From Folding@Home: Welcome to Folding@Home
[12:55:47] Loaded queue successfully.
[12:55:57] + Closed connections
[12:55:57]
[12:55:57] + Processing work unit
[12:55:57] Work type a1 not eligible for variable processors
[12:55:57] Core required: FahCore_a1.exe
[12:55:57] Core found.
[12:55:57] Using generic mpiexec calls
[12:55:57] Working on queue slot 00 [August 12 12:55:57 UTC]
[12:55:57] + Working ...
[12:55:57]
[12:55:57] *------------------------------*
[12:55:57] Folding@Home Gromacs SMP Core
[12:55:57] Version 1.74 (March 10, 2007)
[12:55:57]
[12:55:57] Preparing to commence simulation
[12:55:57] - Ensuring status. Please wait.
[12:56:03] - Starting from initial work packet
[12:56:03]
[12:56:03] Project: 2665 (Run 0, Clone 652, Gen 39)
[12:56:03]
[12:56:03] Assembly optimizations on if available.
[12:56:03] Entering M.D.
[12:56:24]  percent)
[12:56:25] - Starting from initial work packet
[12:56:25]
[12:56:25] Project: 2665 (Run 0, Clone 652, Gen 39)
[12:56:25]
[12:56:26] Entering M.D.
[12:56:33] Rejecting checkpoint
[12:56:34]
[12:56:34] Writing local files
[12:56:35]
[12:56:35] Writing local files
[12:56:45] Extra SSE boost OK.
[12:56:46] Writing local files
[12:56:46] Completed 0 out of 250000 steps  (0 percent)
[13:18:01] Writing local files
[13:18:01] Completed 2500 out of 250000 steps  (1 percent)
[13:36:19] Writing local files
[13:36:19] Completed 5000 out of 250000 steps  (2 percent)
[13:55:13] Writing local files
[13:55:13] Completed 7500 out of 250000 steps  (3 percent)
[14:14:03] Writing local files
[14:14:03] Completed 10000 out of 250000 steps  (4 percent)
[14:32:57] Writing local files
[14:32:58] Completed 12500 out of 250000 steps  (5 percent)
[14:51:52] Writing local files
[14:51:53] Completed 15000 out of 250000 steps  (6 percent)
[15:10:49] Writing local files
[15:10:49] Completed 17500 out of 250000 steps  (7 percent)
[15:29:45] Writing local files
[15:29:45] Completed 20000 out of 250000 steps  (8 percent)
[15:48:45] Writing local files
[15:48:45] Completed 22500 out of 250000 steps  (9 percent)
[16:07:41] Writing local files
[16:07:42] Completed 25000 out of 250000 steps  (10 percent)
[16:26:39] Writing local files
[16:26:39] Completed 27500 out of 250000 steps  (11 percent)
[16:45:30] Writing local files
[16:45:31] Completed 30000 out of 250000 steps  (12 percent)
[17:04:26] Writing local files
[17:04:26] Completed 32500 out of 250000 steps  (13 percent)
[17:23:22] Writing local files
[17:23:22] Completed 35000 out of 250000 steps  (14 percent)
[17:42:15] Writing local files
[17:42:15] Completed 37500 out of 250000 steps  (15 percent)
[18:01:07] Writing local files
[18:01:07] Completed 40000 out of 250000 steps  (16 percent)
[18:19:58] Writing local files
[18:19:58] Completed 42500 out of 250000 steps  (17 percent)
[18:38:51] Writing local files
[18:38:51] Completed 45000 out of 250000 steps  (18 percent)
[18:57:28] Writing local files
[18:57:28] Completed 47500 out of 250000 steps  (19 percent)
[19:14:55] Writing local files
[19:14:56] Completed 50000 out of 250000 steps  (20 percent)
[19:32:23] Writing local files
[19:32:23] Completed 52500 out of 250000 steps  (21 percent)
[19:49:52] Writing local files
[19:49:52] Completed 55000 out of 250000 steps  (22 percent)
[20:07:32] Writing local files
[20:07:32] Completed 57500 out of 250000 steps  (23 percent)
[20:26:25] Writing local files
[20:26:26] Completed 60000 out of 250000 steps  (24 percent)
[20:45:19] Writing local files
[20:45:19] Completed 62500 out of 250000 steps  (25 percent)
[21:04:12] Writing local files
[21:04:13] Completed 65000 out of 250000 steps  (26 percent)
[21:23:01] Writing local files
[21:23:01] Completed 67500 out of 250000 steps  (27 percent)
[21:41:52] Writing local files
[21:41:52] Completed 70000 out of 250000 steps  (28 percent)
[22:00:43] Writing local files
[22:00:43] Completed 72500 out of 250000 steps  (29 percent)
[22:19:35] Writing local files
[22:19:35] Completed 75000 out of 250000 steps  (30 percent)
[22:38:25] Writing local files
[22:38:25] Completed 77500 out of 250000 steps  (31 percent)
[22:57:15] Writing local files
[22:57:16] Completed 80000 out of 250000 steps  (32 percent)
[23:16:06] Writing local files
[23:16:06] Completed 82500 out of 250000 steps  (33 percent)
[23:34:52] Writing local files
[23:34:52] Completed 85000 out of 250000 steps  (34 percent)
[23:53:44] Writing local files
[23:53:44] Completed 87500 out of 250000 steps  (35 percent)
[00:12:34] Writing local files
[00:12:34] Completed 90000 out of 250000 steps  (36 percent)
[00:31:27] Writing local files
[00:31:27] Completed 92500 out of 250000 steps  (37 percent)
[00:50:18] Writing local files
[00:50:18] Completed 95000 out of 250000 steps  (38 percent)
[01:09:08] Writing local files
[01:09:08] Completed 97500 out of 250000 steps  (39 percent)
[01:27:58] Writing local files
[01:27:59] Completed 100000 out of 250000 steps  (40 percent)
[01:46:51] Writing local files
[01:46:51] Completed 102500 out of 250000 steps  (41 percent)
[02:05:36] Writing local files
[02:05:36] Completed 105000 out of 250000 steps  (42 percent)
[02:24:25] Writing local files
[02:24:26] Completed 107500 out of 250000 steps  (43 percent)
[02:43:14] Writing local files
[02:43:14] Completed 110000 out of 250000 steps  (44 percent)
[03:02:03] Writing local files
[03:02:03] Completed 112500 out of 250000 steps  (45 percent)
[03:20:52] Writing local files
[03:20:52] Completed 115000 out of 250000 steps  (46 percent)
[03:39:41] Writing local files
[03:39:41] Completed 117500 out of 250000 steps  (47 percent)
[03:58:30] Writing local files
[03:58:30] Completed 120000 out of 250000 steps  (48 percent)
[04:17:15] Writing local files
[04:17:16] Completed 122500 out of 250000 steps  (49 percent)
[04:36:05] Writing local files
[04:36:05] Completed 125000 out of 250000 steps  (50 percent)
[04:53:13] Writing local files
[04:53:13] Completed 127500 out of 250000 steps  (51 percent)
[05:11:53] Writing local files
[05:11:53] Completed 130000 out of 250000 steps  (52 percent)
[05:29:35] Writing local files
[05:29:35] Completed 132500 out of 250000 steps  (53 percent)
[05:47:06] Writing local files
[05:47:06] Completed 135000 out of 250000 steps  (54 percent)
[06:04:34] Writing local files
[06:04:34] Completed 137500 out of 250000 steps  (55 percent)
[06:22:02] Writing local files
[06:22:02] Completed 140000 out of 250000 steps  (56 percent)
[06:39:26] Writing local files
[06:39:27] Completed 142500 out of 250000 steps  (57 percent)
[06:56:56] Writing local files
[06:56:57] Completed 145000 out of 250000 steps  (58 percent)
[07:14:25] Writing local files
[07:14:25] Completed 147500 out of 250000 steps  (59 percent)
[07:31:56] Writing local files
[07:31:56] Completed 150000 out of 250000 steps  (60 percent)
[07:49:27] Writing local files
[07:49:27] Completed 152500 out of 250000 steps  (61 percent)
[08:06:57] Writing local files
[08:06:57] Completed 155000 out of 250000 steps  (62 percent)
[08:24:24] Writing local files
[08:24:24] Completed 157500 out of 250000 steps  (63 percent)
[08:41:54] Writing local files
[08:41:54] Completed 160000 out of 250000 steps  (64 percent)
[08:59:19] Writing local files
[08:59:19] Completed 162500 out of 250000 steps  (65 percent)
[09:07:15] Warning:  long 1-4 interactions
[09:07:15] Quit 101 - NaN detected: (ener[20])
[09:07:15]
[09:07:15] Simulation instability has been encountered. The run has entered a
[09:07:15]   state from which no further progress can be made.
[09:07:15] This may be the correct result of the simulation, however if you
[09:07:15]   often see other project units terminating early like this
[09:07:15]   too, you may wish to check the stability of your computer (issues
[09:07:15]   such as high temperature, overclocking, etc.).
[09:07:15] Going to send back what have done.
[09:07:16] logfile size: 0
[09:07:16] Warning: Core could not open logfile.
[09:07:16] - Writing 550 bytes of core data to disk...
[09:07:16]   ... Done.
[09:07:16] - Failed to delete work/wudata_00.sas
[09:07:16] - Failed to delete work/wudata_00.goe
[09:07:16] Warning:  check for stray files
[09:09:16]
[09:09:16] Folding@home Core Shutdown: EARLY_UNIT_END
[09:09:16]
[09:09:24] CoreStatus = 7B (123)
[09:09:24] Client-core communications error: ERROR 0x7b
[09:09:24] This is a sign of more serious problems, shutting down.
Re: Project: 2665 (Run 0, Clone 652, Gen 39)
Someone else completed it successfully ...
