Hey guys, just wondering what this project is and its points. Seems to be either a new or beta project since it isn't listed on the project summary.
Thanks in advance!
Project: 892 (Run 9, Clone 748, Gen 27), what is this?
- Hardware configuration: Only my piece of crap machines (I don't have any others! :D)
AMD Athlon 3800+
1.5GB RAM
250GB Hard Drive
nVidia 6150LE Onboard...
AND!
Intel P4 3.2Ghz
1.5GB RAM
120GB Hard Drive
nVidia 5600FX.
AMD Turion FX-56X2
2GB RAM
100GB Hard Drive
Nvidia 7000M
Yes, they own hard. - Location: The 718.
Re: Project: 892 (Run 9, Clone 748, Gen 27), what is this?
Hi Beremat,
Let me find out for you. Please, check again in the next couple of days. Thanks for reporting.
Paula
Paula
Best I can do...
http://fah-web.stanford.edu/cgi-bin/fahproject?p=892
I believe it belongs to L. ltchong
Oppps, Paula is on it.
-=MB=-
AMD Athlon 3800+
1.5GB RAM
250GB Hard Drive
AND!
Intel P4 3.2Ghz
1.5GB RAM
120GB Hard Drive
nVidia 5600FX.
AMD Turion FX-56X2
2GB RAM
100GB Hard Drive
Nvidia 7000M
I could swear that wasn't there yesterday ;_;
Any idea on credits?
The reporting of this is VERY glitchy. THe FAHlog says p892, the total steps when you mouseover the systray keeps changing from 5,000 to 2,500 and back again, and when I click "View Fahlog" on the systray menu, it opens some different FAHlog with p4594 in it. FAHmon also thinks it is p4594.
This is running on the uniproc client version 6.20.
Edit: I should note that the FAHlog in the app directory shows the proper p892.
p892 has been around for a very long time but it hasn't been on psummary for a while either.
http://fahinfo.org/index.php?WULookup=true&project=892
AMD Athlon 3800+
1.5GB RAM
250GB Hard Drive
AND!
Intel P4 3.2Ghz
1.5GB RAM
120GB Hard Drive
nVidia 5600FX.
AMD Turion FX-56X2
2GB RAM
100GB Hard Drive
Nvidia 7000M
Thank you very much!uncle_fungus wrote:p892 has been around for a very long time but it hasn't been on psummary for a while either.
LOL... It never occured to me to look in FAHmon benchmarks... I did find it there, so I have done at least one.
Strange that I don't find it on the list that a script generates from the psummary page. I have been doing it for a very long time, and the list is quite extensive. It must be in the FAHmon list though. Too bad I can view it. or I could add it in manually. :/Project : 892
Core : Amber
Frames : 100
Credit : 165
-=MB=-
