Project: 5506 (Gen 11, 32, & 22)
MDCRL
Post by MDCRL »
System without any recent problems , Completed WU 5506 (Run 3, Clone 139, Gen 21)successfully then started returning multiple unstable_machine EUE's on WU 5506
- never finished 3 WU's successfully... moved onto WU 5105: completed successfully, no system changes made...
[21:13:40] + Processing work unit
[21:13:40] Core required: FahCore_11.exe
[21:13:40] Core found.
[21:13:40] Working on queue slot 03 [August 10 21:13:40 UTC]
[21:13:40] + Working ...
[21:13:40]
[21:13:40] *------------------------------*
[21:13:40] Folding@Home GPU Core - Beta
[21:13:40] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[21:13:40]
[21:13:40] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:13:40] Build host: amoeba
[21:13:40] Board Type: Nvidia
[21:13:40] Core      :
[21:13:40] Preparing to commence simulation
[21:13:40] - Looking at optimizations...
[21:13:40] - Created dyn
[21:13:40] - Files status OK
[21:13:40] - Expanded 45549 -> 246249 (decompressed 540.6 percent)
[21:13:40] Called DecompressByteArray: compressed_data_size=45549 data_size=246249, decompressed_data_size=246249 diff=0
[21:13:40] - Digital signature verified
[21:13:40]
[21:13:40] Project: 5506 (Run 3, Clone 139, Gen 21)
[21:13:40]
[21:13:40] Assembly optimizations on if available.
[21:13:40] Entering M.D.
[21:13:46] Working on p5506_supervillin_e1
[21:13:48] Client config found, loading data.
[21:13:48] Starting GUI Server
[21:21:32] Completed 1%
[21:29:16] Completed 2%
[21:37:01] Completed 3%
[21:44:45] Completed 4%
[21:52:29] Completed 5%
[22:00:13] Completed 6%
[22:07:58] Completed 7%
[22:15:41] Completed 8%
[22:23:25] Completed 9%
[22:31:10] Completed 10%
[08:50:06] Completed 90%
[08:57:51] Completed 91%
[09:05:35] Completed 92%
[09:13:19] Completed 93%
[09:21:03] Completed 94%
[09:28:47] Completed 95%
[09:36:31] Completed 96%
[09:44:15] Completed 97%
[09:51:59] Completed 98%
[09:59:41] Completed 99%
[10:07:24] Completed 100%
[10:08:24]
[10:08:24] Finished Work Unit:
[10:08:24] - Reading up to 34800 from "work/wudata_03.trr": Read 34800
[10:08:24] trr file hash check passed.
[10:08:24] - Reading up to 1127380 from "work/wudata_03.xtc": Read 1127380
[10:08:24] xtc file hash check passed.
[10:08:24] edr file hash check passed.
[10:08:24] logfile size: 130452
[10:08:24] Leaving Run
[10:08:27] - Writing 1293704 bytes of core data to disk...
[10:08:28] Done: 1293192 -> 1155532 (compressed to 89.3 percent)
[10:08:28]   ... Done.
[10:08:28] - Shutting down core
[10:08:28]
[10:08:28] Folding@home Core Shutdown: FINISHED_UNIT
[10:08:32] CoreStatus = 64 (100)
[10:08:32] Sending work to server
[10:08:32] Project: 5506 (Run 3, Clone 139, Gen 21)
[10:08:32] - Read packet limit of 540015616... Set to 524286976.
[10:08:32] + Attempting to send results [August 11 10:08:32 UTC]
[10:08:36] + Results successfully sent
[10:08:36] Thank you for your contribution to Folding@Home.
[10:08:36] + Number of Units Completed: 76
[10:08:40] - Preparing to get new work unit...
[10:08:40] + Attempting to get work packet
[10:08:40] - Connecting to assignment server
[10:08:41] - Successful: assigned to (171.64.65.106).
[10:08:41] + News From Folding@Home: GPU folding beta
[10:08:41] Loaded queue successfully.
[10:08:42] + Closed connections
[10:08:42]
[10:08:42] + Processing work unit
[10:08:42] Core required: FahCore_11.exe
[10:08:42] Core found.
[10:08:42] Working on queue slot 04 [August 11 10:08:42 UTC]
[10:08:42] + Working ...
[10:08:42]
[10:08:42] *------------------------------*
[10:08:42] Folding@Home GPU Core - Beta
[10:08:42] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[10:08:42]
[10:08:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:08:42] Build host: amoeba
[10:08:42] Board Type: Nvidia
[10:08:42] Core      :
[10:08:42] Preparing to commence simulation
[10:08:42] - Looking at optimizations...
[10:08:42] - Created dyn
[10:08:42] - Files status OK
[10:08:43] - Expanded 45495 -> 246249 (decompressed 541.2 percent)
[10:08:43] Called DecompressByteArray: compressed_data_size=45495 data_size=246249, decompressed_data_size=246249 diff=0
[10:08:43] - Digital signature verified
[10:08:43]
[10:08:43] Project: 5506 (Run 0, Clone 547, Gen 11)
[10:08:43]
[10:08:43] Assembly optimizations on if available.
[10:08:43] Entering M.D.
[10:08:49] Working on p5506_supervillin_e1
[10:08:50] Client config found, loading data.
[10:08:51] Starting GUI Server
[10:16:34] Completed 1%
[10:24:17] Completed 2%
[10:32:00] Completed 3%
[10:39:43] Completed 4%
[10:47:26] Completed 5%
[10:55:09] Completed 6%
[11:02:52] Completed 7%
[11:10:35] Completed 8%
[11:18:18] Completed 9%
[11:26:01] Completed 10%
[15:26:40] Completed 40%
[15:34:23] Completed 41%
[15:42:07] Completed 42%
[15:49:50] Completed 43%
[15:57:33] Completed 44%
[16:05:16] Completed 45%
[16:13:00] Completed 46%
[16:20:43] Completed 47%
[16:28:26] Completed 48%
[16:36:09] Completed 49%
[16:43:52] Completed 50%
[16:45:06] Gromacs cannot continue further.
[16:45:06] Going to send back what have done.
[16:45:07] logfile size: 68662 info=68662 bed=0 hdr=23
[16:45:07] - Writing 69198 bytes of core data to disk...
[16:45:07] Done: 68686 -> 8764 (compressed to 12.7 percent)
[16:45:07]   ... Done.
[16:45:07]
[16:45:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:45:11] CoreStatus = 7A (122)
[16:45:11] Sending work to server
[16:45:11] Project: 5506 (Run 0, Clone 547, Gen 11)
[16:45:11] - Read packet limit of 540015616... Set to 524286976.
[16:45:11] + Attempting to send results [August 11 16:45:11 UTC]
[16:45:12] + Results successfully sent
[16:45:12] Thank you for your contribution to Folding@Home.
[16:45:16] - Preparing to get new work unit...
[16:45:16] + Attempting to get work packet
[16:45:16] - Connecting to assignment server
[16:45:16] - Successful: assigned to (171.64.65.106).
[16:45:16] + News From Folding@Home: GPU folding beta
[16:45:16] Loaded queue successfully.
[16:45:17] + Closed connections
[16:45:22]
[16:45:22] + Processing work unit
[16:45:22] Core required: FahCore_11.exe
[16:45:22] Core found.
[16:45:22] Working on queue slot 05 [August 11 16:45:22 UTC]
[16:45:22] + Working ...
[16:45:22]
[16:45:22] *------------------------------*
[16:45:22] Folding@Home GPU Core - Beta
[16:45:22] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[16:45:22]
[16:45:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:45:22] Build host: amoeba
[16:45:22] Board Type: Nvidia
[16:45:22] Core      :
[16:45:22] Preparing to commence simulation
[16:45:22] - Looking at optimizations...
[16:45:22] - Created dyn
[16:45:22] - Files status OK
[16:45:22] - Expanded 45588 -> 246249 (decompressed 540.1 percent)
[16:45:22] Called DecompressByteArray: compressed_data_size=45588 data_size=246249, decompressed_data_size=246249 diff=0
[16:45:22] - Digital signature verified
[16:45:22]
[16:45:22] Project: 5506 (Run 6, Clone 130, Gen 32)
[16:45:22]
[16:45:22] Assembly optimizations on if available.
[16:45:22] Entering M.D.
[16:45:29] Working on p5506_supervillin_e1
[16:45:30] Client config found, loading data.
[16:45:31] Starting GUI Server
[16:53:14] Completed 1%
[17:00:57] Completed 2%
[17:08:40] Completed 3%
[17:16:23] Completed 4%
[17:24:06] Completed 5%
[17:31:49] Completed 6%
[17:39:32] Completed 7%
[17:47:16] Completed 8%
[17:54:59] Completed 9%
[18:02:42] Completed 10%
[00:28:43] Completed 60%
[00:36:27] Completed 61%
[00:44:10] Completed 62%
[00:51:54] Completed 63%
[00:59:37] Completed 64%
[01:03:59] Gromacs cannot continue further.
[01:03:59] Going to send back what have done.
[01:04:00] logfile size: 85429 info=85429 bed=0 hdr=23
[01:04:00] - Writing 85965 bytes of core data to disk...
[01:04:00] Done: 85453 -> 9684 (compressed to 11.3 percent)
[01:04:00]   ... Done.
[01:04:01]
[01:04:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:04:03] CoreStatus = 7A (122)
[01:04:03] Sending work to server
[01:04:03] Project: 5506 (Run 6, Clone 130, Gen 32)
[01:04:03] - Read packet limit of 540015616... Set to 524286976.
[01:04:03] + Attempting to send results [August 12 01:04:03 UTC]
[01:04:04] + Results successfully sent
[01:04:04] Thank you for your contribution to Folding@Home.
[01:04:08] - Preparing to get new work unit...
[01:04:08] + Attempting to get work packet
[01:04:08] - Connecting to assignment server
[01:04:08] - Successful: assigned to (171.64.65.106).
[01:04:08] + News From Folding@Home: GPU folding beta
[01:04:08] Loaded queue successfully.
[01:04:09] + Closed connections
[01:04:14]
[01:04:14] + Processing work unit
[01:04:14] Core required: FahCore_11.exe
[01:04:14] Core found.
[01:04:14] Working on queue slot 06 [August 12 01:04:14 UTC]
[01:04:14] + Working ...
[01:04:14]
[01:04:14] *------------------------------*
[01:04:14] Folding@Home GPU Core - Beta
[01:04:14] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[01:04:14]
[01:04:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:04:14] Build host: amoeba
[01:04:14] Board Type: Nvidia
[01:04:14] Core      :
[01:04:14] Preparing to commence simulation
[01:04:14] - Looking at optimizations...
[01:04:14] - Created dyn
[01:04:14] - Files status OK
[01:04:14] - Expanded 45520 -> 246249 (decompressed 540.9 percent)
[01:04:14] Called DecompressByteArray: compressed_data_size=45520 data_size=246249, decompressed_data_size=246249 diff=0
[01:04:14] - Digital signature verified
[01:04:14]
[01:04:14] Project: 5506 (Run 7, Clone 526, Gen 22)
[01:04:14]
[01:04:15] Assembly optimizations on if available.
[01:04:15] Entering M.D.
[01:04:21] Working on p5506_supervillin_e1
[01:04:22] Client config found, loading data.
[01:04:23] Starting GUI Server
[01:12:06] Completed 1%
[01:19:50] Completed 2%
[01:27:33] Completed 3%
[01:35:17] Completed 4%
[01:43:01] Completed 5%
[01:50:44] Completed 6%
[01:58:28] Completed 7%
[02:06:12] Completed 8%
[02:13:55] Completed 9%
[02:21:39] Completed 10%
[03:38:54] Completed 20%
[03:46:38] Completed 21%
[03:54:21] Completed 22%
[04:02:05] Completed 23%
[04:09:48] Completed 24%
[04:17:32] Completed 25%
[04:25:15] Completed 26%
[04:32:59] Completed 27%
[04:40:42] Completed 28%
[04:48:26] Completed 29%
[04:54:01] Gromacs cannot continue further.
[04:54:01] Going to send back what have done.
[04:54:02] logfile size: 44935 info=44935 bed=0 hdr=23
[04:54:02] - Writing 45471 bytes of core data to disk...
[04:54:02] Done: 44959 -> 6924 (compressed to 15.4 percent)
[04:54:02]   ... Done.
[04:54:02]
[04:54:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:54:05] CoreStatus = 7A (122)
[04:54:05] Sending work to server
[04:54:05] Project: 5506 (Run 7, Clone 526, Gen 22)
[04:54:05] - Read packet limit of 540015616... Set to 524286976.
[04:54:05] + Attempting to send results [August 12 04:54:05 UTC]
[04:54:05] + Results successfully sent
[04:54:05] Thank you for your contribution to Folding@Home.
[04:54:09] - Preparing to get new work unit...
[04:54:09] + Attempting to get work packet
[04:54:09] - Connecting to assignment server
[04:54:10] - Successful: assigned to (171.64.65.20).
[04:54:10] + News From Folding@Home: GPU folding beta
[04:54:10] Loaded queue successfully.
[04:54:11] + Closed connections
[04:54:16]
[04:54:16] + Processing work unit
[04:54:16] Core required: FahCore_11.exe
[04:54:16] Core found.
[04:54:16] Working on queue slot 07 [August 12 04:54:16 UTC]
[04:54:16] + Working ...
[04:54:16]
[04:54:16] *------------------------------*
[04:54:16] Folding@Home GPU Core - Beta
[04:54:16] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[04:54:16]
[04:54:16] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:54:16] Build host: amoeba
[04:54:16] Board Type: Nvidia
[04:54:16] Core      :
[04:54:16] Preparing to commence simulation
[04:54:16] - Looking at optimizations...
[04:54:16] - Created dyn
[04:54:16] - Files status OK
[04:54:16] - Expanded 44111 -> 244433 (decompressed 554.1 percent)
[04:54:16] Called DecompressByteArray: compressed_data_size=44111 data_size=244433, decompressed_data_size=244433 diff=0
[04:54:16] - Digital signature verified
[04:54:16]
[04:54:16] Project: 5015 (Run 7, Clone 17, Gen 11)
[04:54:16]
[04:54:16] Assembly optimizations on if available.
[04:54:16] Entering M.D.
[04:54:22] Working on 576 p5005_supervillin_e1
[04:54:24] Client config found, loading data.
[04:54:24] Starting GUI Server
[05:02:07] Completed 1%
[05:09:50] Completed 2%
[05:17:33] Completed 3%
[05:25:15] Completed 4%
[05:32:58] Completed 5%
[05:40:41] Completed 6%
[05:48:24] Completed 7%
[05:56:06] Completed 8%
[06:03:49] Completed 9%
[06:11:32] Completed 10%
[16:28:33] Completed 90%
[16:36:15] Completed 91%
[16:43:57] Completed 92%
[16:51:40] Completed 93%
[16:59:22] Completed 94%
[17:07:04] Completed 95%
[17:14:47] Completed 96%
[17:22:29] Completed 97%
[17:30:12] Completed 98%
[17:37:54] Completed 99%
[17:45:37] Completed 100%
[17:46:37]
[17:46:37] Finished Work Unit:
[17:46:37] - Reading up to 34800 from "work/wudata_07.trr": Read 34800
[17:46:37] trr file hash check passed.
[17:46:37] - Reading up to 1126868 from "work/wudata_07.xtc": Read 1126868
[17:46:37] xtc file hash check passed.
[17:46:37] edr file hash check passed.
[17:46:37] logfile size: 129974
[17:46:37] Leaving Run
[17:46:41] - Writing 1292714 bytes of core data to disk...
[17:46:42] Done: 1292202 -> 1154655 (compressed to 89.3 percent)
[17:46:42]   ... Done.
[17:46:43] - Shutting down core
[17:46:43]
[17:46:43] Folding@home Core Shutdown: FINISHED_UNIT
[17:46:46] CoreStatus = 64 (100)
[17:46:46] Sending work to server
[17:46:46] Project: 5015 (Run 7, Clone 17, Gen 11)
[17:46:46] - Read packet limit of 540015616... Set to 524286976.
[17:46:46] + Attempting to send results [August 12 17:46:46 UTC]
[17:46:51] + Results successfully sent
[17:46:51] Thank you for your contribution to Folding@Home.
[17:46:51] + Number of Units Completed: 77
working on another 5506 (Run 6, Clone 497, Gen 17) now and has made it to 45% .... will update if it also fails to finish.
MDCRL
Re: Project: 5506: (Gen11, 32, & 22)
Post by MDCRL »
More 5506 WU problems - some finishing, others failing....
--- Opening Log file [August 13 21:04:54 UTC]
                       Folding@Home Client Version 6.20
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Administrator\Application Data\Folding@home-gpu
[21:04:54] - Ask before connecting: No
[21:04:54] - User name: MDCRL (Team 35275)
[21:04:54] - User ID: 4FAF4E9A54835700
[21:04:54] - Machine ID: 2
[21:04:54]
[21:04:54] Loaded queue successfully.
[21:04:54] Initialization complete
[21:04:54]
[21:04:54] + Processing work unit
[21:04:54] Core required: FahCore_11.exe
[21:04:54] Core found.
[21:04:54] Working on queue slot 03 [August 13 21:04:54 UTC]
[21:04:54] + Working ...
[21:04:54]
[21:04:54] *------------------------------*
[21:04:54] Folding@Home GPU Core - Beta
[21:04:54] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[21:04:54]
[21:04:54] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:04:54] Build host: amoeba
[21:04:54] Board Type: Nvidia
[21:04:54] Core      :
[21:04:54] Preparing to commence simulation
[21:04:54] - Ensuring status. Please wait.
[21:05:04] - Looking at optimizations...
[21:05:04] - Working with standard loops on this execution.
[21:05:04] - Previous termination of core was improper.
[21:05:04] - Files status OK
[21:05:04] - Expanded 45534 -> 246249 (decompressed 540.8 percent)
[21:05:04] Called DecompressByteArray: compressed_data_size=45534 data_size=246249, decompressed_data_size=246249 diff=0
[21:05:04] - Digital signature verified
[21:05:04]
[21:05:04] Project: 5506 (Run 2, Clone 706, Gen 15)
[21:05:04]
[21:05:04] Entering M.D.
[21:05:10] Will resume from checkpoint file
[21:05:10] Working on p5506_supervillin_e1
[21:05:11] Client config found, loading data.
[21:05:11] Resuming from checkpoint
[21:05:11] Verified work/wudata_03.log
[21:05:11] Verified work/wudata_03.edr
[21:05:11] Starting GUI Server
[21:05:11] Verified work/wudata_03.trr
[21:05:11] Verified work/wudata_03.xtc
[23:42:47] Completed 95%
[23:47:02] Completed 96%
[23:51:18] Completed 97%
[23:55:34] Completed 98%
[23:59:49] Completed 99%
[00:04:05] Completed 100%
[00:05:05]
[00:05:05] Finished Work Unit:
[00:05:05] - Reading up to 34800 from "work/wudata_03.trr": Read 34800
[00:05:05] trr file hash check passed.
[00:05:05] - Reading up to 1130764 from "work/wudata_03.xtc": Read 1130764
[00:05:05] xtc file hash check passed.
[00:05:05] edr file hash check passed.
[00:05:05] logfile size: 130092
[00:05:05] Leaving Run
[00:05:09] - Writing 1296728 bytes of core data to disk...
[00:05:09] Done: 1296216 -> 1159278 (compressed to 89.4 percent)
[00:05:09]   ... Done.
[00:05:10] - Shutting down core
[00:05:10]
[00:05:10] Folding@home Core Shutdown: FINISHED_UNIT
[00:05:13] CoreStatus = 64 (100)
[00:05:13] Sending work to server
[00:05:13] Project: 5506 (Run 2, Clone 706, Gen 15)
[00:05:13] - Read packet limit of 540015616... Set to 524286976.
[00:05:13] + Attempting to send results [August 14 00:05:13 UTC]
[00:05:17] + Results successfully sent
[00:05:17] Thank you for your contribution to Folding@Home.
[00:05:17] + Number of Units Completed: 157
[00:05:21] - Preparing to get new work unit...
[00:05:21] + Attempting to get work packet
[00:05:21] - Connecting to assignment server
[00:05:22] - Successful: assigned to (171.64.65.20).
[00:05:22] + News From Folding@Home: GPU folding beta
[00:05:22] Loaded queue successfully.
[00:05:23] + Closed connections
[00:05:23]
[00:05:23] + Processing work unit
[00:05:23] Core required: FahCore_11.exe
[00:05:23] Core found.
[00:05:23] Working on queue slot 04 [August 14 00:05:23 UTC]
[00:05:23] + Working ...
[00:05:23]
[00:05:23] *------------------------------*
[00:05:23] Folding@Home GPU Core - Beta
[00:05:23] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[00:05:23]
[00:05:23] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:05:23] Build host: amoeba
[00:05:23] Board Type: Nvidia
[00:05:23] Core      :
[00:05:23] Preparing to commence simulation
[00:05:23] - Looking at optimizations...
[00:05:23] - Created dyn
[00:05:23] - Files status OK
[00:05:23] - Expanded 41615 -> 244433 (decompressed 587.3 percent)
[00:05:23] Called DecompressByteArray: compressed_data_size=41615 data_size=244433, decompressed_data_size=244433 diff=0
[00:05:23] - Digital signature verified
[00:05:23]
[00:05:23] Project: 5014 (Run 7, Clone 14, Gen 0)
[00:05:23]
[00:05:23] Assembly optimizations on if available.
[00:05:23] Entering M.D.
[00:05:29] Working on 576 p5005_supervillin_e1
[00:05:30] Client config found, loading data.
[00:05:30] Starting GUI Server
[00:09:44] Completed 1%
[00:13:59] Completed 2%
[00:18:13] Completed 3%
[00:22:28] Completed 4%
[00:26:42] Completed 5%
[06:48:27] Completed 95%
[06:52:41] Completed 96%
[06:56:56] Completed 97%
[07:01:10] Completed 98%
[07:05:25] Completed 99%
[07:09:39] Completed 100%
[07:10:39]
[07:10:39] Finished Work Unit:
[07:10:39] - Reading up to 34800 from "work/wudata_04.trr": Read 34800
[07:10:39] trr file hash check passed.
[07:10:39] - Reading up to 1128704 from "work/wudata_04.xtc": Read 1128704
[07:10:39] xtc file hash check passed.
[07:10:39] edr file hash check passed.
[07:10:39] logfile size: 130373
[07:10:39] Leaving Run
[07:10:43] - Writing 1294949 bytes of core data to disk...
[07:10:43] Done: 1294437 -> 1157434 (compressed to 89.4 percent)
[07:10:43]   ... Done.
[07:10:43] - Shutting down core
[07:10:43]
[07:10:43] Folding@home Core Shutdown: FINISHED_UNIT
[07:10:47] CoreStatus = 64 (100)
[07:10:47] Sending work to server
[07:10:47] Project: 5014 (Run 7, Clone 14, Gen 0)
[07:10:47] - Read packet limit of 540015616... Set to 524286976.
[07:10:47] + Attempting to send results [August 14 07:10:47 UTC]
[07:10:51] + Results successfully sent
[07:10:51] Thank you for your contribution to Folding@Home.
[07:10:51] + Number of Units Completed: 158
[07:10:56] - Preparing to get new work unit...
[07:10:56] + Attempting to get work packet
[07:10:56] - Connecting to assignment server
[07:10:56] - Successful: assigned to (171.64.65.20).
[07:10:56] + News From Folding@Home: GPU folding beta
[07:10:56] Loaded queue successfully.
[07:10:57] + Closed connections
[07:10:57]
[07:10:57] + Processing work unit
[07:10:57] Core required: FahCore_11.exe
[07:10:57] Core found.
[07:10:57] Working on queue slot 05 [August 14 07:10:57 UTC]
[07:10:57] + Working ...
[07:10:57]
[07:10:57] *------------------------------*
[07:10:57] Folding@Home GPU Core - Beta
[07:10:57] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[07:10:57]
[07:10:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:10:57] Build host: amoeba
[07:10:57] Board Type: Nvidia
[07:10:57] Core      :
[07:10:57] Preparing to commence simulation
[07:10:57] - Looking at optimizations...
[07:10:57] - Created dyn
[07:10:57] - Files status OK
[07:10:57] - Expanded 44022 -> 244433 (decompressed 555.2 percent)
[07:10:57] Called DecompressByteArray: compressed_data_size=44022 data_size=244433, decompressed_data_size=244433 diff=0
[07:10:57] - Digital signature verified
[07:10:57]
[07:10:57] Project: 5015 (Run 3, Clone 292, Gen 9)
[07:10:57]
[07:10:57] Assembly optimizations on if available.
[07:10:57] Entering M.D.
[07:11:04] Working on 576 p5005_supervillin_e1
[07:11:04] Client config found, loading data.
[07:11:05] Starting GUI Server
[07:15:20] Completed 1%
[07:19:35] Completed 2%
[07:23:50] Completed 3%
[07:28:05] Completed 4%
[07:32:20] Completed 5%
[13:54:58] Completed 95%
[13:59:14] Completed 96%
[14:03:29] Completed 97%
[14:07:44] Completed 98%
[14:11:59] Completed 99%
[14:16:14] Completed 100%
[14:17:14]
[14:17:14] Finished Work Unit:
[14:17:14] - Reading up to 34800 from "work/wudata_05.trr": Read 34800
[14:17:14] trr file hash check passed.
[14:17:14] - Reading up to 1127684 from "work/wudata_05.xtc": Read 1127684
[14:17:14] xtc file hash check passed.
[14:17:14] edr file hash check passed.
[14:17:14] logfile size: 129950
[14:17:14] Leaving Run
[14:17:17] - Writing 1293506 bytes of core data to disk...
[14:17:18] Done: 1292994 -> 1155993 (compressed to 89.4 percent)
[14:17:18]   ... Done.
[14:17:18] - Shutting down core
[14:17:18]
[14:17:18] Folding@home Core Shutdown: FINISHED_UNIT
[14:17:21] CoreStatus = 64 (100)
[14:17:21] Sending work to server
[14:17:21] Project: 5015 (Run 3, Clone 292, Gen 9)
[14:17:21] - Read packet limit of 540015616... Set to 524286976.
[14:17:21] + Attempting to send results [August 14 14:17:21 UTC]
[14:17:27] + Results successfully sent
[14:17:27] Thank you for your contribution to Folding@Home.
[14:17:27] + Number of Units Completed: 159
[19:48:28] + Processing work unit
[19:48:28] Core required: FahCore_11.exe
[19:48:28] Core found.
[19:48:28] Working on queue slot 07 [August 14 19:48:28 UTC]
[19:48:28] + Working ...
[19:48:28]
[19:48:28] *------------------------------*
[19:48:28] Folding@Home GPU Core - Beta
[19:48:28] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[19:48:28]
[19:48:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:48:28] Build host: amoeba
[19:48:28] Board Type: Nvidia
[19:48:28] Core      :
[19:48:28] Preparing to commence simulation
[19:48:28] - Looking at optimizations...
[19:48:28] - Created dyn
[19:48:28] - Files status OK
[19:48:28] - Expanded 44152 -> 244433 (decompressed 553.6 percent)
[19:48:28] Called DecompressByteArray: compressed_data_size=44152 data_size=244433, decompressed_data_size=244433 diff=0
[19:48:28] - Digital signature verified
[19:48:28]
[19:48:28] Project: 5015 (Run 0, Clone 818, Gen 4)
[19:48:28]
[19:48:28] Assembly optimizations on if available.
[19:48:28] Entering M.D.
[19:48:35] Working on 576 p5005_supervillin_e1
[19:48:35] Client config found, loading data.
[19:48:36] Starting GUI Server
[19:52:50] Completed 1%
[19:57:06] Completed 2%
[20:01:21] Completed 3%
[20:05:36] Completed 4%
[20:09:51] Completed 5%
[02:32:21] Completed 95%
[02:36:36] Completed 96%
[02:40:51] Completed 97%
[02:45:06] Completed 98%
[02:49:21] Completed 99%
[02:53:36] Completed 100%
[02:54:36]
[02:54:36] Finished Work Unit:
[02:54:36] - Reading up to 34800 from "work/wudata_07.trr": Read 34800
[02:54:36] trr file hash check passed.
[02:54:36] - Reading up to 1129528 from "work/wudata_07.xtc": Read 1129528
[02:54:36] xtc file hash check passed.
[02:54:36] edr file hash check passed.
[02:54:36] logfile size: 129955
[02:54:36] Leaving Run
[02:54:39] - Writing 1295355 bytes of core data to disk...
[02:54:39] Done: 1294843 -> 1157733 (compressed to 89.4 percent)
[02:54:39]   ... Done.
[02:54:39] - Shutting down core
[02:54:39]
[02:54:39] Folding@home Core Shutdown: FINISHED_UNIT
[02:54:43] CoreStatus = 64 (100)
[02:54:43] Sending work to server
[02:54:43] Project: 5015 (Run 0, Clone 818, Gen 4)
[02:54:43] - Read packet limit of 540015616... Set to 524286976.
[02:54:43] + Attempting to send results [August 15 02:54:43 UTC]
[02:54:47] + Results successfully sent
[02:54:47] Thank you for your contribution to Folding@Home.
[02:54:47] + Number of Units Completed: 160
[02:54:51] - Preparing to get new work unit...
[02:54:51] + Attempting to get work packet
[02:54:51] - Connecting to assignment server
[02:54:52] - Successful: assigned to (171.64.65.106).
[02:54:52] + News From Folding@Home: GPU folding beta
[02:54:52] Loaded queue successfully.
[02:54:53] + Closed connections
[02:54:53]
[02:54:53] + Processing work unit
[02:54:53] Core required: FahCore_11.exe
[02:54:53] Core found.
[02:54:53] Working on queue slot 08 [August 15 02:54:53 UTC]
[02:54:53] + Working ...
[02:54:53]
[02:54:53] *------------------------------*
[02:54:53] Folding@Home GPU Core - Beta
[02:54:53] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[02:54:53]
[02:54:53] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:54:53] Build host: amoeba
[02:54:53] Board Type: Nvidia
[02:54:53] Core      :
[02:54:53] Preparing to commence simulation
[02:54:53] - Looking at optimizations...
[02:54:53] - Created dyn
[02:54:53] - Files status OK
[02:54:53] - Expanded 45568 -> 246249 (decompressed 540.3 percent)
[02:54:53] Called DecompressByteArray: compressed_data_size=45568 data_size=246249, decompressed_data_size=246249 diff=0
[02:54:53] - Digital signature verified
[02:54:53]
[02:54:53] Project: 5506 (Run 9, Clone 26, Gen 49)
[02:54:53]
[02:54:53] Assembly optimizations on if available.
[02:54:53] Entering M.D.
[02:54:59] Working on p5506_supervillin_e1
[02:55:00] Client config found, loading data.
[02:55:00] Starting GUI Server
[02:59:15] Completed 1%
[03:03:31] Completed 2%
[03:04:54] + Working...
[03:07:47] Completed 3%
[03:12:02] Completed 4%
[03:16:18] Completed 5%
[09:39:26] Completed 95%
[09:43:41] Completed 96%
[09:47:57] Completed 97%
[09:52:12] Completed 98%
[09:56:28] Completed 99%
[10:00:43] Completed 100%
[10:01:43]
[10:01:43] Finished Work Unit:
[10:01:43] - Reading up to 34800 from "work/wudata_08.trr": Read 34800
[10:01:43] trr file hash check passed.
[10:01:43] - Reading up to 1127884 from "work/wudata_08.xtc": Read 1127884
[10:01:43] xtc file hash check passed.
[10:01:43] edr file hash check passed.
[10:01:43] logfile size: 130467
[10:01:43] Leaving Run
[10:01:43] - Writing 1294223 bytes of core data to disk...
[10:01:44] Done: 1293711 -> 1156010 (compressed to 89.3 percent)
[10:01:44]   ... Done.
[10:01:44] - Shutting down core
[10:01:44]
[10:01:44] Folding@home Core Shutdown: FINISHED_UNIT
[10:01:47] CoreStatus = 64 (100)
[10:01:47] Sending work to server
[10:01:47] Project: 5506 (Run 9, Clone 26, Gen 49)
[10:01:47] - Read packet limit of 540015616... Set to 524286976.
[10:01:47] + Attempting to send results [August 15 10:01:47 UTC]
[10:01:51] + Results successfully sent
[10:01:51] Thank you for your contribution to Folding@Home.
[10:01:51] + Number of Units Completed: 161
[10:01:56] - Preparing to get new work unit...
[10:01:56] + Attempting to get work packet
[10:01:56] - Connecting to assignment server
[10:01:56] - Successful: assigned to (171.64.65.106).
[10:01:56] + News From Folding@Home: GPU folding beta
[10:01:56] Loaded queue successfully.
[10:01:57] + Closed connections
[10:01:57]
[10:01:57] + Processing work unit
[10:01:57] Core required: FahCore_11.exe
[10:01:57] Core found.
[10:01:57] Working on queue slot 09 [August 15 10:01:57 UTC]
[10:01:57] + Working ...
[10:01:57]
[10:01:57] *------------------------------*
[10:01:57] Folding@Home GPU Core - Beta
[10:01:57] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[10:01:57]
[10:01:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:01:57] Build host: amoeba
[10:01:57] Board Type: Nvidia
[10:01:57] Core      :
[10:01:57] Preparing to commence simulation
[10:01:57] - Looking at optimizations...
[10:01:57] - Created dyn
[10:01:57] - Files status OK
[10:01:57] - Expanded 45543 -> 246249 (decompressed 540.6 percent)
[10:01:57] Called DecompressByteArray: compressed_data_size=45543 data_size=246249, decompressed_data_size=246249 diff=0
[10:01:57] - Digital signature verified
[10:01:57]
[10:01:57] Project: 5506 (Run 1, Clone 40, Gen 45)
[10:01:57]
[10:01:57] Assembly optimizations on if available.
[10:01:57] Entering M.D.
[10:02:04] Working on p5506_supervillin_e1
[10:02:04] Client config found, loading data.
[10:02:05] Starting GUI Server
[10:06:20] Completed 1%
[10:10:35] Completed 2%
[10:14:51] Completed 3%
[10:19:06] Completed 4%
[10:23:22] Completed 5%
[16:46:31] Completed 95%
[16:50:47] Completed 96%
[16:55:02] Completed 97%
[16:59:18] Completed 98%
[17:03:33] Completed 99%
[17:07:49] Completed 100%
[17:08:49]
[17:08:49] Finished Work Unit:
[17:08:49] - Reading up to 34800 from "work/wudata_09.trr": Read 34800
[17:08:49] trr file hash check passed.
[17:08:49] - Reading up to 1128556 from "work/wudata_09.xtc": Read 1128556
[17:08:49] xtc file hash check passed.
[17:08:49] edr file hash check passed.
[17:08:49] logfile size: 130416
[17:08:49] Leaving Run
[17:08:52] - Writing 1294844 bytes of core data to disk...
[17:08:53] Done: 1294332 -> 1156510 (compressed to 89.3 percent)
[17:08:53]   ... Done.
[17:08:53] - Shutting down core
[17:08:53]
[17:08:53] Folding@home Core Shutdown: FINISHED_UNIT
[17:08:56] CoreStatus = 64 (100)
[17:08:56] Sending work to server
[17:08:56] Project: 5506 (Run 1, Clone 40, Gen 45)
[17:08:56] - Read packet limit of 540015616... Set to 524286976.
[17:08:56] + Attempting to send results [August 15 17:08:56 UTC]
[17:09:00] + Results successfully sent
[17:09:00] Thank you for your contribution to Folding@Home.
[17:09:00] + Number of Units Completed: 162
[17:09:04] - Preparing to get new work unit...
[17:09:04] + Attempting to get work packet
[17:09:04] - Connecting to assignment server
[17:09:04] - Successful: assigned to (171.64.65.106).
[17:09:04] + News From Folding@Home: GPU folding beta
[17:09:05] Loaded queue successfully.
[17:09:06] + Closed connections
[17:09:06]
[17:09:06] + Processing work unit
[17:09:06] Core required: FahCore_11.exe
[17:09:06] Core found.
[17:09:06] Working on queue slot 00 [August 15 17:09:06 UTC]
[17:09:06] + Working ...
[17:09:06]
[17:09:06] *------------------------------*
[17:09:06] Folding@Home GPU Core - Beta
[17:09:06] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[17:09:06]
[17:09:06] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:09:06] Build host: amoeba
[17:09:06] Board Type: Nvidia
[17:09:06] Core      :
[17:09:06] Preparing to commence simulation
[17:09:06] - Looking at optimizations...
[17:09:06] - Created dyn
[17:09:06] - Files status OK
[17:09:06] - Expanded 45485 -> 246249 (decompressed 541.3 percent)
[17:09:06] Called DecompressByteArray: compressed_data_size=45485 data_size=246249, decompressed_data_size=246249 diff=0
[17:09:06] - Digital signature verified
[17:09:06]
[17:09:06] Project: 5506 (Run 7, Clone 88, Gen 27)
[17:09:06]
[17:09:06] Assembly optimizations on if available.
[17:09:06] Entering M.D.
[17:09:12] Working on p5506_supervillin_e1
[17:09:13] Client config found, loading data.
[17:09:13] Starting GUI Server
[17:13:28] Completed 1%
[17:17:44] Completed 2%
[17:21:59] Completed 3%
[17:26:15] Completed 4%
[17:30:30] Completed 5%
[23:53:39] Completed 95%
[23:57:55] Completed 96%
[00:02:10] Completed 97%
[00:06:25] Completed 98%
[00:10:41] Completed 99%
[00:14:56] Completed 100%
[00:15:56]
[00:15:56] Finished Work Unit:
[00:15:56] - Reading up to 34800 from "work/wudata_00.trr": Read 34800
[00:15:56] trr file hash check passed.
[00:15:56] - Reading up to 1127608 from "work/wudata_00.xtc": Read 1127608
[00:15:56] xtc file hash check passed.
[00:15:56] edr file hash check passed.
[00:15:56] logfile size: 130368
[00:15:56] Leaving Run
[00:16:01] - Writing 1293848 bytes of core data to disk...
[00:16:01] Done: 1293336 -> 1155752 (compressed to 89.3 percent)
[00:16:01]   ... Done.
[00:16:01] - Shutting down core
[00:16:01]
[00:16:01] Folding@home Core Shutdown: FINISHED_UNIT
[00:16:04] CoreStatus = 64 (100)
[00:16:04] Sending work to server
[00:16:04] Project: 5506 (Run 7, Clone 88, Gen 27)
[00:16:04] - Read packet limit of 540015616... Set to 524286976.
[00:16:04] + Attempting to send results [August 16 00:16:04 UTC]
[00:16:08] + Results successfully sent
[00:16:08] Thank you for your contribution to Folding@Home.
[00:16:08] + Number of Units Completed: 163
[00:16:12] - Preparing to get new work unit...
[00:16:12] + Attempting to get work packet
[00:16:12] - Connecting to assignment server
[00:16:13] - Successful: assigned to (171.64.65.20).
[00:16:13] + News From Folding@Home: GPU folding beta
[00:16:13] Loaded queue successfully.
[00:16:14] + Closed connections
[00:16:14]
[00:16:14] + Processing work unit
[00:16:14] Core required: FahCore_11.exe
[00:16:14] Core found.
[00:16:14] Working on queue slot 01 [August 16 00:16:14 UTC]
[00:16:14] + Working ...
[00:16:14]
[00:16:14] *------------------------------*
[00:16:14] Folding@Home GPU Core - Beta
[00:16:14] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[00:16:14]
[00:16:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:16:14] Build host: amoeba
[00:16:14] Board Type: Nvidia
[00:16:14] Core      :
[00:16:14] Preparing to commence simulation
[00:16:14] - Looking at optimizations...
[00:16:14] - Created dyn
[00:16:14] - Files status OK
[00:16:14] - Expanded 44068 -> 244433 (decompressed 554.6 percent)
[00:16:14] Called DecompressByteArray: compressed_data_size=44068 data_size=244433, decompressed_data_size=244433 diff=0
[00:16:14] - Digital signature verified
[00:16:14]
[00:16:14] Project: 5015 (Run 3, Clone 265, Gen 13)
[00:16:14]
[00:16:14] Assembly optimizations on if available.
[00:16:14] Entering M.D.
[00:16:21] Working on 576 p5005_supervillin_e1
[00:16:21] Client config found, loading data.
[00:16:22] Starting GUI Server
[00:20:36] Completed 1%
[00:24:51] Completed 2%
[00:29:06] Completed 3%
[00:33:21] Completed 4%
[00:37:36] Completed 5%
[07:00:05] Completed 95%
[07:04:21] Completed 96%
[07:08:36] Completed 97%
[07:12:51] Completed 98%
[07:17:06] Completed 99%
[07:21:21] Completed 100%
[07:22:21]
[07:22:21] Finished Work Unit:
[07:22:21] - Reading up to 34800 from "work/wudata_01.trr": Read 34800
[07:22:21] trr file hash check passed.
[07:22:21] - Reading up to 1127084 from "work/wudata_01.xtc": Read 1127084
[07:22:21] xtc file hash check passed.
[07:22:21] edr file hash check passed.
[07:22:21] logfile size: 129960
[07:22:21] Leaving Run
[07:22:24] - Writing 1292916 bytes of core data to disk...
[07:22:25] Done: 1292404 -> 1155070 (compressed to 89.3 percent)
[07:22:25]   ... Done.
[07:22:25] - Shutting down core
[07:22:25]
[07:22:25] Folding@home Core Shutdown: FINISHED_UNIT
[07:22:28] CoreStatus = 64 (100)
[07:22:28] Sending work to server
[07:22:28] Project: 5015 (Run 3, Clone 265, Gen 13)
[07:22:28] - Read packet limit of 540015616... Set to 524286976.
[07:22:28] + Attempting to send results [August 16 07:22:28 UTC]
[07:22:33] + Results successfully sent
[07:22:33] Thank you for your contribution to Folding@Home.
[07:22:33] + Number of Units Completed: 164
[07:22:37] - Preparing to get new work unit...
[07:22:37] + Attempting to get work packet
[07:22:37] - Connecting to assignment server
[07:22:37] - Successful: assigned to (171.64.65.106).
[07:22:37] + News From Folding@Home: GPU folding beta
[07:22:37] Loaded queue successfully.
[07:22:38] + Closed connections
[07:22:38]
[07:22:38] + Processing work unit
[07:22:38] Core required: FahCore_11.exe
[07:22:38] Core found.
[07:22:38] Working on queue slot 02 [August 16 07:22:38 UTC]
[07:22:38] + Working ...
[07:22:38]
[07:22:38] *------------------------------*
[07:22:38] Folding@Home GPU Core - Beta
[07:22:38] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[07:22:38]
[07:22:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:22:38] Build host: amoeba
[07:22:38] Board Type: Nvidia
[07:22:38] Core      :
[07:22:38] Preparing to commence simulation
[07:22:38] - Looking at optimizations...
[07:22:38] - Created dyn
[07:22:38] - Files status OK
[07:22:38] - Expanded 45407 -> 246249 (decompressed 542.3 percent)
[07:22:38] Called DecompressByteArray: compressed_data_size=45407 data_size=246249, decompressed_data_size=246249 diff=0
[07:22:38] - Digital signature verified
[07:22:38]
[07:22:38] Project: 5506 (Run 7, Clone 131, Gen 53)
[07:22:38]
[07:22:38] Assembly optimizations on if available.
[07:22:38] Entering M.D.
[07:22:45] Working on p5506_supervillin_e1
[07:22:45] Client config found, loading data.
[07:22:45] Starting GUI Server
[07:27:01] Completed 1%
[07:31:16] Completed 2%
[07:35:32] Completed 3%
[07:39:47] Completed 4%
[07:44:03] Completed 5%
[10:34:19] Completed 45%
[10:38:35] Completed 46%
[10:42:50] Completed 47%
[10:47:06] Completed 48%
[10:51:21] Completed 49%
[10:55:36] Completed 50%
[10:59:52] Completed 51%
[11:03:31] Gromacs cannot continue further.
[11:03:31] Going to send back what have done.
[11:03:32] logfile size: 70736 info=70736 bed=0 hdr=23
[11:03:32] - Writing 71272 bytes of core data to disk...
[11:03:32] Done: 70760 -> 8732 (compressed to 12.3 percent)
[11:03:32]   ... Done.
[11:03:32]
[11:03:32] Folding@home Core Shutdown: EARLY_UNIT_END
[11:03:35] CoreStatus = 72 (114)
[11:03:35] Sending work to server
[11:03:35] Project: 5506 (Run 7, Clone 131, Gen 53)
[11:03:35] - Read packet limit of 540015616... Set to 524286976.
[11:03:35] + Attempting to send results [August 16 11:03:35 UTC]
[11:03:35] + Results successfully sent
[11:03:35] Thank you for your contribution to Folding@Home.
[11:03:39] - Preparing to get new work unit...
[11:03:39] + Attempting to get work packet
[11:03:39] - Connecting to assignment server
[11:03:40] - Successful: assigned to (171.64.65.106).
[11:03:40] + News From Folding@Home: GPU folding beta
[11:03:40] Loaded queue successfully.
[11:03:41] + Closed connections
[11:03:46]
[11:03:46] + Processing work unit
[11:03:46] Core required: FahCore_11.exe
[11:03:46] Core found.
[11:03:46] Working on queue slot 03 [August 16 11:03:46 UTC]
[11:03:46] + Working ...
[11:03:46]
[11:03:46] *------------------------------*
[11:03:46] Folding@Home GPU Core - Beta
[11:03:46] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[11:03:46]
[11:03:46] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:03:46] Build host: amoeba
[11:03:46] Board Type: Nvidia
[11:03:46] Core      :
[11:03:46] Preparing to commence simulation
[11:03:46] - Looking at optimizations...
[11:03:46] - Created dyn
[11:03:46] - Files status OK
[11:03:46] - Expanded 45515 -> 246249 (decompressed 541.0 percent)
[11:03:46] Called DecompressByteArray: compressed_data_size=45515 data_size=246249, decompressed_data_size=246249 diff=0
[11:03:46] - Digital signature verified
[11:03:46]
[11:03:46] Project: 5506 (Run 7, Clone 228, Gen 43)
[11:03:46]
[11:03:46] Assembly optimizations on if available.
[11:03:46] Entering M.D.
[11:03:52] Working on p5506_supervillin_e1
[11:03:53] Client config found, loading data.
[11:03:53] Starting GUI Server
[11:08:08] Completed 1%
[11:12:24] Completed 2%
[11:16:39] Completed 3%
[11:20:55] Completed 4%
[11:25:10] Completed 5%
[17:48:19] Completed 95%
[17:52:35] Completed 96%
[17:56:50] Completed 97%
[18:01:05] Completed 98%
[18:05:21] Completed 99%
[18:09:36] Completed 100%
[18:10:36]
[18:10:36] Finished Work Unit:
[18:10:36] - Reading up to 34800 from "work/wudata_03.trr": Read 34800
[18:10:36] trr file hash check passed.
[18:10:36] - Reading up to 1126816 from "work/wudata_03.xtc": Read 1126816
[18:10:36] xtc file hash check passed.
[18:10:36] edr file hash check passed.
[18:10:36] logfile size: 130399
[18:10:36] Leaving Run
[18:10:41] - Writing 1293087 bytes of core data to disk...
[18:10:41] Done: 1292575 -> 1154856 (compressed to 89.3 percent)
[18:10:41]   ... Done.
[18:10:41] - Shutting down core
[18:10:41]
[18:10:41] Folding@home Core Shutdown: FINISHED_UNIT
[18:10:44] CoreStatus = 64 (100)
[18:10:44] Sending work to server
[18:10:44] Project: 5506 (Run 7, Clone 228, Gen 43)
[18:10:44] - Read packet limit of 540015616... Set to 524286976.
[18:10:44] + Attempting to send results [August 16 18:10:44 UTC]
[18:11:05] - Couldn't send HTTP request to server
[18:11:05] + Could not connect to Work Server (results)
[18:11:05]     (171.64.65.106:8080)
[18:11:05] + Retrying using alternative port
[18:11:26] - Couldn't send HTTP request to server
[18:11:26] + Could not connect to Work Server (results)
[18:11:26]     (171.64.65.106:80)
[18:11:26] - Error: Could not transmit unit 03 (completed August 16) to work server.
[18:11:26]   Keeping unit 03 in queue.
[18:11:26] Project: 5506 (Run 7, Clone 228, Gen 43)
[18:11:26] - Read packet limit of 540015616... Set to 524286976.
[18:11:26] + Attempting to send results [August 16 18:11:26 UTC]
[18:11:47] - Couldn't send HTTP request to server
[18:11:47] + Could not connect to Work Server (results)
[18:11:47]     (171.64.65.106:8080)
[18:11:47] + Retrying using alternative port
[18:12:08] - Couldn't send HTTP request to server
[18:12:08] + Could not connect to Work Server (results)
[18:12:08]     (171.64.65.106:80)
[18:12:08] - Error: Could not transmit unit 03 (completed August 16) to work server.
[18:12:08] - Read packet limit of 540015616... Set to 524286976.
[18:12:08] + Attempting to send results [August 16 18:12:08 UTC]
[18:12:08]   (Got status 503)
[18:12:08]     (171.64.122.76:8080)
[18:12:08] + Retrying using alternative port
[18:12:09] - Couldn't send HTTP request to server
[18:12:09]   (Got status 503)
[18:12:09] + Could not connect to Work Server (results)
[18:12:09]     (171.64.122.76:80)
[18:12:09]   Could not transmit unit 03 to Collection server; keeping in queue.
[18:12:09] - Preparing to get new work unit...
[18:12:09] + Attempting to get work packet
[18:12:09] - Connecting to assignment server
[18:12:09] - Successful: assigned to (171.64.122.74).
[18:12:09] + News From Folding@Home: GPU folding beta
[18:12:09] Loaded queue successfully.
[18:12:10] Project: 5506 (Run 7, Clone 228, Gen 43)
[18:12:10] - Read packet limit of 540015616... Set to 524286976.
[18:12:10] + Attempting to send results [August 16 18:12:10 UTC]
[18:12:31] - Couldn't send HTTP request to server
[18:12:31] + Could not connect to Work Server (results)
[18:12:31]     (171.64.65.106:8080)
[18:12:31] + Retrying using alternative port
[18:12:52] - Couldn't send HTTP request to server
[18:12:52] + Could not connect to Work Server (results)
[18:12:52]     (171.64.65.106:80)
[18:12:52] - Error: Could not transmit unit 03 (completed August 16) to work server.
[18:12:52] - Read packet limit of 540015616... Set to 524286976.
[18:12:52] + Attempting to send results [August 16 18:12:52 UTC]
[18:12:52]     (171.64.122.76:8080)
[18:12:52] + Retrying using alternative port
[18:12:52]   (Got status 503)
[18:12:52]     (171.64.122.76:80)
[18:12:52]   Could not transmit unit 03 to Collection server; keeping in queue.
[18:12:52] + Closed connections
[21:04:45] + Processing work unit
[21:04:45] Core required: FahCore_11.exe
[21:04:45] Core found.
[21:04:45] Working on queue slot 05 [August 16 21:04:45 UTC]
[21:04:45] + Working ...
[21:04:45]
[21:04:45] *------------------------------*
[21:04:45] Folding@Home GPU Core - Beta
[21:04:45] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[21:04:45]
[21:04:45] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:04:45] Build host: amoeba
[21:04:45] Board Type: Nvidia
[21:04:45] Core      :
[21:04:45] Preparing to commence simulation
[21:04:45] - Looking at optimizations...
[21:04:45] - Created dyn
[21:04:45] - Files status OK
[21:04:45] - Expanded 45529 -> 246249 (decompressed 540.8 percent)
[21:04:45] Called DecompressByteArray: compressed_data_size=45529 data_size=246249, decompressed_data_size=246249 diff=0
[21:04:45] - Digital signature verified
[21:04:45]
[21:04:45] Project: 5506 (Run 9, Clone 67, Gen 37)
[21:04:45]
[21:04:45] Assembly optimizations on if available.
[21:04:45] Entering M.D.
[21:04:52] Working on p5506_supervillin_e1
[21:04:52] Client config found, loading data.
[21:04:53] Starting GUI Server
[21:04:54] + Working...
[21:09:08] Completed 1%
[21:13:23] Completed 2%
[21:17:39] Completed 3%
[21:21:54] Completed 4%
[21:26:09] Completed 5%
[01:20:18] Completed 60%
[01:24:34] Completed 61%
[01:28:49] Completed 62%
[01:33:05] Completed 63%
[01:37:20] Completed 64%
[01:41:13] Gromacs cannot continue further.
[01:41:13] Going to send back what have done.
[01:41:14] logfile size: 85770 info=85770 bed=0 hdr=23
[01:41:14] - Writing 86306 bytes of core data to disk...
[01:41:14] Done: 85794 -> 9844 (compressed to 11.4 percent)
[01:41:14]   ... Done.
[01:41:14]
[01:41:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:41:17] CoreStatus = 7A (122)
[01:41:17] Sending work to server
[01:41:17] Project: 5506 (Run 9, Clone 67, Gen 37)
[01:41:17] - Read packet limit of 540015616... Set to 524286976.
[01:41:17] + Attempting to send results [August 17 01:41:17 UTC]
[01:41:19] - Couldn't send HTTP request to server
[01:41:19] + Could not connect to Work Server (results)
[01:41:19]     (171.64.65.106:8080)
[01:41:19] + Retrying using alternative port
[01:41:20] - Couldn't send HTTP request to server
[01:41:20] + Could not connect to Work Server (results)
[01:41:20]     (171.64.65.106:80)
[01:41:20] - Error: Could not transmit unit 05 (completed August 17) to work server.
[01:41:20]   Keeping unit 05 in queue.
[01:41:20] Project: 5506 (Run 9, Clone 67, Gen 37)
[01:41:20] - Read packet limit of 540015616... Set to 524286976.
[01:41:20] + Attempting to send results [August 17 01:41:20 UTC]
[01:41:21] - Couldn't send HTTP request to server
[01:41:21] + Could not connect to Work Server (results)
[01:41:21]     (171.64.65.106:8080)
[01:41:21] + Retrying using alternative port
[01:41:22] - Couldn't send HTTP request to server
[01:41:22] + Could not connect to Work Server (results)
[01:41:22]     (171.64.65.106:80)
[01:41:22] - Error: Could not transmit unit 05 (completed August 17) to work server.
[01:41:22] - Read packet limit of 540015616... Set to 524286976.
[01:41:22] + Attempting to send results [August 17 01:41:22 UTC]
[01:41:22]     (171.64.122.76:8080)
[01:41:22] + Retrying using alternative port
[01:41:22]   (Got status 503)
[01:41:22]     (171.64.122.76:80)
[01:41:22]   Could not transmit unit 05 to Collection server; keeping in queue.
[01:41:22] - Preparing to get new work unit...
[01:41:22] + Attempting to get work packet
[01:41:22] - Connecting to assignment server
[01:41:23] - Successful: assigned to (171.64.65.20).
[01:41:23] + News From Folding@Home: GPU folding beta
[01:41:23] Loaded queue successfully.
[01:41:24] Project: 5506 (Run 9, Clone 67, Gen 37)
[01:41:24] - Read packet limit of 540015616... Set to 524286976.
[01:41:24] + Attempting to send results [August 17 01:41:24 UTC]
[01:41:25] - Couldn't send HTTP request to server
[01:41:25] + Could not connect to Work Server (results)
[01:41:25]     (171.64.65.106:8080)
[01:41:25] + Retrying using alternative port
[01:41:26] - Couldn't send HTTP request to server
[01:41:26] + Could not connect to Work Server (results)
[01:41:26]     (171.64.65.106:80)
[01:41:26] - Error: Could not transmit unit 05 (completed August 17) to work server.
[01:41:26] - Read packet limit of 540015616... Set to 524286976.
[01:41:26] + Attempting to send results [August 17 01:41:26 UTC]
[01:41:27] - Couldn't send HTTP request to server
[01:41:27]   (Got status 503)
[01:41:27] + Could not connect to Work Server (results)
[01:41:27]     (171.64.122.76:8080)
[01:41:27] + Retrying using alternative port
[01:41:27]     (171.64.122.76:80)
[01:41:27]   Could not transmit unit 05 to Collection server; keeping in queue.
[01:41:27] + Closed connections
-------------------------------------------------Machine turned off to check for problems - none found--- -------------
[05:06:50] + Processing work unit
[05:06:50] Core required: FahCore_11.exe
[05:06:50] Core found.
[05:06:50] Working on queue slot 08 [August 17 05:06:50 UTC]
[05:06:50] + Working ...
[05:06:51]
[05:06:51] *------------------------------*
[05:06:51] Folding@Home GPU Core - Beta
[05:06:51] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[05:06:51]
[05:06:51] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:06:51] Build host: amoeba
[05:06:51] Board Type: Nvidia
[05:06:51] Core      :
[05:06:51] Preparing to commence simulation
[05:06:51] - Looking at optimizations...
[05:06:51] - Created dyn
[05:06:51] - Files status OK
[05:06:51] - Expanded 45462 -> 246249 (decompressed 541.6 percent)
[05:06:51] Called DecompressByteArray: compressed_data_size=45462 data_size=246249, decompressed_data_size=246249 diff=0
[05:06:51] - Digital signature verified
[05:06:51]
[05:06:51] Project: 5506 (Run 8, Clone 234, Gen 34)
[05:06:51]
[05:06:51] Assembly optimizations on if available.
[05:06:51] Entering M.D.
[05:06:57] Working on p5506_supervillin_e1
[05:06:58] Client config found, loading data.
[05:06:58] Starting GUI Server
[05:11:13] Completed 1%
[05:15:29] Completed 2%
[05:19:44] Completed 3%
[05:24:00] Completed 4%
[05:28:15] Completed 5%
[06:32:06] Completed 20%
[06:36:22] Completed 21%
[06:40:37] Completed 22%
[06:44:52] Completed 23%
[06:49:08] Completed 24%
[06:53:23] Completed 25%
[06:57:39] Completed 26%
[07:01:41] Gromacs cannot continue further.
[07:01:41] Going to send back what have done.
[07:01:42] logfile size: 41640 info=41640 bed=0 hdr=23
[07:01:42] - Writing 42176 bytes of core data to disk...
[07:01:42] Done: 41664 -> 6641 (compressed to 15.9 percent)
[07:01:42]   ... Done.
[07:01:42]
[07:01:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:01:45] CoreStatus = 7A (122)
[07:01:45] Sending work to server
[07:01:45] Project: 5506 (Run 8, Clone 234, Gen 34)
[07:01:45] - Read packet limit of 540015616... Set to 524286976.
[07:01:45] + Attempting to send results [August 17 07:01:45 UTC]
[07:01:45] + Results successfully sent
[07:01:45] Thank you for your contribution to Folding@Home.
[07:01:49] - Preparing to get new work unit...
[07:01:49] + Attempting to get work packet
[07:01:49] - Connecting to assignment server
[07:01:50] - Successful: assigned to (171.64.65.106).
[07:01:50] + News From Folding@Home: GPU folding beta
[07:01:50] Loaded queue successfully.
[07:01:51] + Closed connections
[07:01:56]
[07:01:56] + Processing work unit
[07:01:56] Core required: FahCore_11.exe
[07:01:56] Core found.
[07:01:56] Working on queue slot 09 [August 17 07:01:56 UTC]
[07:01:56] + Working ...
[07:01:56]
[07:01:56] *------------------------------*
[07:01:56] Folding@Home GPU Core - Beta
[07:01:56] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[07:01:56]
[07:01:56] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:01:56] Build host: amoeba
[07:01:56] Board Type: Nvidia
[07:01:56] Core      :
[07:01:56] Preparing to commence simulation
[07:01:56] - Looking at optimizations...
[07:01:56] - Created dyn
[07:01:56] - Files status OK
[07:01:56] - Expanded 45434 -> 246249 (decompressed 541.9 percent)
[07:01:56] Called DecompressByteArray: compressed_data_size=45434 data_size=246249, decompressed_data_size=246249 diff=0
[07:01:56] - Digital signature verified
[07:01:56]
[07:01:56] Project: 5506 (Run 8, Clone 93, Gen 26)
[07:01:56]
[07:01:56] Assembly optimizations on if available.
[07:01:56] Entering M.D.
[07:02:02] Working on p5506_supervillin_e1
[07:02:03] Client config found, loading data.
[07:02:03] Starting GUI Server
[07:06:18] Completed 1%
[07:10:34] Completed 2%
[07:14:49] Completed 3%
[07:19:05] Completed 4%
[07:23:20] Completed 5%
[13:46:28] Completed 95%
[13:50:43] Completed 96%
[13:54:59] Completed 97%
[13:59:14] Completed 98%
[14:03:30] Completed 99%
[14:07:46] Completed 100%
[14:08:46]
[14:08:46] Finished Work Unit:
[14:08:46] - Reading up to 34800 from "work/wudata_09.trr": Read 34800
[14:08:46] trr file hash check passed.
[14:08:46] - Reading up to 1127072 from "work/wudata_09.xtc": Read 1127072
[14:08:46] xtc file hash check passed.
[14:08:46] edr file hash check passed.
[14:08:46] logfile size: 130455
[14:08:46] Leaving Run
[14:08:46] - Writing 1293399 bytes of core data to disk...
[14:08:47] Done: 1292887 -> 1155214 (compressed to 89.3 percent)
[14:08:47]   ... Done.
[14:08:47] - Shutting down core
[14:08:47]
[14:08:47] Folding@home Core Shutdown: FINISHED_UNIT
[14:08:50] CoreStatus = 64 (100)
[14:08:50] Sending work to server
[14:08:50] Project: 5506 (Run 8, Clone 93, Gen 26)
[14:08:50] - Read packet limit of 540015616... Set to 524286976.
[14:08:50] + Attempting to send results [August 17 14:08:50 UTC]
[14:08:55] + Results successfully sent
[14:08:55] Thank you for your contribution to Folding@Home.
[14:08:55] + Number of Units Completed: 166
[14:08:59] - Preparing to get new work unit...
[14:08:59] + Attempting to get work packet
[14:08:59] - Connecting to assignment server
[14:08:59] - Successful: assigned to (171.64.65.106).
[14:08:59] + News From Folding@Home: GPU folding beta
[14:08:59] Loaded queue successfully.
[14:09:00] + Closed connections
[14:09:00]
[14:09:00] + Processing work unit
[14:09:00] Core required: FahCore_11.exe
[14:09:00] Core found.
[14:09:00] Working on queue slot 00 [August 17 14:09:00 UTC]
[14:09:00] + Working ...
[14:09:00]
[14:09:00] *------------------------------*
[14:09:00] Folding@Home GPU Core - Beta
[14:09:00] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[14:09:00]
[14:09:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:09:00] Build host: amoeba
[14:09:00] Board Type: Nvidia
[14:09:00] Core      :
[14:09:00] Preparing to commence simulation
[14:09:00] - Looking at optimizations...
[14:09:00] - Created dyn
[14:09:00] - Files status OK
[14:09:00] - Expanded 45547 -> 246249 (decompressed 540.6 percent)
[14:09:00] Called DecompressByteArray: compressed_data_size=45547 data_size=246249, decompressed_data_size=246249 diff=0
[14:09:00] - Digital signature verified
[14:09:00]
[14:09:00] Project: 5506 (Run 2, Clone 896, Gen 10)
[14:09:00]
[14:09:00] Assembly optimizations on if available.
[14:09:00] Entering M.D.
[14:09:07] Working on p5506_supervillin_e1
[14:09:07] Client config found, loading data.
[14:09:08] Starting GUI Server
[14:13:23] Completed 1%
[14:17:38] Completed 2%
[14:21:54] Completed 3%
[14:26:09] Completed 4%
[14:30:24] Completed 5%
[18:24:33] Completed 60%
[18:28:48] Completed 61%
[18:33:03] Completed 62%
[18:37:19] Completed 63%
[18:41:34] Completed 64%
[18:45:50] Completed 65%
[18:50:05] Completed 66%
[18:51:32] Gromacs cannot continue further.
[18:51:32] Going to send back what have done.
[18:51:33] logfile size: 87251 info=87251 bed=0 hdr=23
[18:51:33] - Writing 87787 bytes of core data to disk...
[18:51:33] Done: 87275 -> 10022 (compressed to 11.4 percent)
[18:51:33]   ... Done.
[18:51:33]
[18:51:33] Folding@home Core Shutdown: EARLY_UNIT_END
[18:51:37] CoreStatus = 72 (114)
[18:51:37] Sending work to server
[18:51:37] Project: 5506 (Run 2, Clone 896, Gen 10)
[18:51:37] - Read packet limit of 540015616... Set to 524286976.
[18:51:37] + Attempting to send results [August 17 18:51:37 UTC]
[18:51:37] + Results successfully sent
[18:51:37] Thank you for your contribution to Folding@Home.
[18:51:41] - Preparing to get new work unit...
[18:51:41] + Attempting to get work packet
[18:51:41] - Connecting to assignment server
[18:51:42] - Successful: assigned to (171.64.65.106).
[18:51:42] + News From Folding@Home: GPU folding beta
[18:51:42] Loaded queue successfully.
[18:51:43] + Closed connections
[18:51:48]
[18:51:48] + Processing work unit
[18:51:48] Core required: FahCore_11.exe
[18:51:48] Core found.
[18:51:48] Working on queue slot 01 [August 17 18:51:48 UTC]
[18:51:48] + Working ...
[18:51:48]
[18:51:48] *------------------------------*
[18:51:48] Folding@Home GPU Core - Beta
[18:51:48] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[18:51:48]
[18:51:48] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:51:48] Build host: amoeba
[18:51:48] Board Type: Nvidia
[18:51:48] Core      :
[18:51:48] Preparing to commence simulation
[18:51:48] - Looking at optimizations...
[18:51:48] - Created dyn
[18:51:48] - Files status OK
[18:51:48] - Expanded 45504 -> 246249 (decompressed 541.1 percent)
[18:51:48] Called DecompressByteArray: compressed_data_size=45504 data_size=246249, decompressed_data_size=246249 diff=0
[18:51:48] - Digital signature verified
[18:51:48]
[18:51:48] Project: 5506 (Run 4, Clone 257, Gen 40)
[18:51:48]
[18:51:48] Assembly optimizations on if available.
[18:51:48] Entering M.D.
[18:51:54] Working on p5506_supervillin_e1
[18:51:55] Client config found, loading data.
[18:51:55] Starting GUI Server
[18:56:10] Completed 1%
Folding@Home Client Shutdown.
Please check to see what is going on w/ this WU please..
This is the only machine I am having problems with WU 5506
All other GPU's are finishing 5506 OK - I'm asuming it is a machine specific problem - but why does it complete some and not the others....?
Thank You
tmoble
Post by tmoble »
what is 5506 anyway? My 8800 is is running these constantly, no issues but the WU is not listed that I see in the project summaries?
To your point, I haven't had any crashes on it yet, hope it doesn't start. Looks to be a 480 point WU, my fahmon sez it's running at 4937.14* PPD, the * means it's guessing since it can't find the WU on the summary page.
ppetrone
Pande Group Member
Post by ppetrone »
Thanks to all.
Let me do a little research to find out whose and what is 5506. I will forward this post to whoever is in charge.
Thanks,
Paula
These are NV GPU WUs ;)
DanEnsign
Pande Group Member
Post by DanEnsign »
tmoble wrote:what is 5506 anyway? My 8800 is is running these constantly, no issues but the WU is not listed that I see in the project summaries?
Thanks for pointing this out -- I've put up a project description for the 5500-5599 series. If you have more specific (scientific) questions feel free to ask me.
As far as the EUE reports, I'll keep a closer eye on this project. It seems to work well for most people, but hopefully we'll have a more stable core vsn out within a couple of days.
Dan
ei57
Post by ei57 »
DanEnsign wrote:As far as the EUE reports, I'll keep a closer eye on this project. It seems to work well for most people, but hopefully we'll have a more stable core vsn out within a couple of days.
Dan
It works OK most of the time, but not always. Prior to this EUE, there was at least 11 completed WU's.
[16:14:34] Completed 61%
[16:15:46] Completed 62%
[16:16:53] Gromacs cannot continue further.
[16:16:53] Going to send back what have done.
[16:16:54] logfile size: 83220 info=83220 bed=0 hdr=23
[16:16:54] - Writing 83756 bytes of core data to disk...
[16:16:54] Done: 83244 -> 9698 (compressed to 11.6 percent)
[16:16:54]   ... Done.
[16:16:54]
[16:16:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:16:57] CoreStatus = 7A (122)
[16:16:57] Sending work to server
[16:16:57] Project: 5506 (Run 6, Clone 820, Gen 32)
[16:16:57] - Read packet limit of 540015616... Set to 524286976.
I can't remember having an EUE on the 8800 gts, but the very moderate overclocked 9800 gtx+ gets EUE's a couple of times a week.
9800 gtx+@760/1120/1889 (stock 740/1100/1836), temp 66C.
ZVdP
Re: Project: 5506 (Gen 11, 32, & 22)
Post by ZVdP »
Probably it is not very useful information, but you never know:
I have folded quite a few 5506's without problems; only one small issue: after one finished it couldn't send ("couldn't send HTTP request to server"), it couldn't send either when the next WU was completed (which itself was sent without error). However, it was finally the WU after that.
5506's completed: (run,clone,gen)
(8,338,29),(0,205,24),(0,665,26),(7,848,29),(2,429,45),(5,206,34),(3,350,31),(0,819,16),(0,441,46),(5,337,31),(9,726,26),(1,854,15),(0,133,36),(1,198,27)
(The last one was the one that had the temporary sending error)
All 5506's folded very stable: the majoity of the time 58 seconds per 1%, with sometimes small deviations of only 1 (occasionaly 2) seconds.
(I seem to get alot of 5506, 21 so far (and one being folded right now) while only 9 of another project)
ulric
Post by ulric »
Quadro FX 4600, driver 177.35, Vista 64-bit, of course no over-clocking or anything
17:55:10] Project: 5506 (Run 1, Clone 612, Gen 29)
[17:55:10]
[17:55:10] Assembly optimizations on if available.
[17:55:10] Entering M.D.
[17:55:16] Working on p5506_supervillin_e1
20:10:23] Completed 71%
[20:12:23] Gromacs cannot continue further.
[20:12:23] Going to send back what have done.
[20:12:24] logfile size: 82151 info=82151 bed=0 hdr=23
[20:12:24] - Writing 82687 bytes of core data to disk...
[20:12:24] Done: 82175 -> 9572 (compressed to 11.6 percent)
[20:12:24]   ... Done.
[20:12:25]
[20:12:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:12:27] CoreStatus = 7A (122)
[20:12:27] Sending work to server
[20:12:39]
[20:12:39] Project: 5506 (Run 5, Clone 649, Gen 16)
[20:12:39]
[20:12:39] Assembly optimizations on if available.
[20:12:39] Entering M.D.
[20:12:45] Working on p5506_supervillin_e1
[20:12:46] Client config found, loading data.
[20:12:46] Starting GUI Server
[20:15:44] Gromacs cannot continue further.
[20:15:44] Going to send back what have done.
[20:15:45] logfile size: 0 info=0 bed=0 hdr=23
[20:15:45] - Writing 556 bytes of core data to disk...
[20:15:45] Done: 44 -> 87 (compressed to 197.7 percent)
[20:15:45]   ... Done.
[20:15:46]
[20:15:46] Folding@home Core Shutdown: EARLY_UNIT_END
[20:15:49] CoreStatus = 72 (114)
[20:15:49] Sending work to server
[20:15:49] Project: 5506 (Run 5, Clone 649, Gen 16)
[20:15:49] - Read packet limit of 540015616... Set to 524286976.
[20:16:01] Project: 5506 (Run 3, Clone 399, Gen 25)
[20:16:01]
[20:16:01] Assembly optimizations on if available.
[20:16:01] Entering M.D.
[20:16:07] Working on p5506_supervillin_e1
[20:16:08] Client config found, loading data.
[20:16:08] Starting GUI Server
[20:18:45] Gromacs cannot continue further.
[20:18:45] Going to send back what have done.
[20:18:46] logfile size: 0 info=0 bed=0 hdr=23
[20:18:46] - Writing 556 bytes of core data to disk...
[20:18:46] Done: 44 -> 87 (compressed to 197.7 percent)
[20:18:46]   ... Done.
[20:18:47]
[20:18:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:18:50] CoreStatus = 7A (122)
[20:18:50] Sending work to server
[20:18:50] Project: 5506 (Run 3, Clone 399, Gen 25)
[20:18:50] - Read packet limit of 540015616... Set to 524286976.
(similiar entries deleted)
[20:27:59] Project: 5506 (Run 5, Clone 725, Gen 22)
[20:27:59]
[20:27:59] Assembly optimizations on if available.
[20:27:59] Entering M.D.
[20:28:06] Working on p5506_supervillin_e1
[20:28:06] Client config found, loading data.
[20:28:06] Starting GUI Server
[20:31:26] Gromacs cannot continue further.
[20:31:26] Going to send back what have done.
[20:31:27] logfile size: 0 info=0 bed=0 hdr=23
[20:31:27] - Writing 556 bytes of core data to disk...
[20:31:27] Done: 44 -> 87 (compressed to 197.7 percent)
[20:31:27]   ... Done.
[20:31:29]
[20:31:29] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:31:33] CoreStatus = 7A (122)
[20:31:33] Sending work to server
[20:31:33] Project: 5506 (Run 5, Clone 725, Gen 22)
[20:31:33] - Read packet limit of 540015616... Set to 524286976.
I came this morning and my machine had a bluescreen (my first blue screen ever). could be a Cuda driver leak or other problem, perhaps?
You might want to try a newer driver ... if your Quadro is using a G80 chip (sorry I don't know Quadro well), it should help.
