Project: 3064 (Run 4, Clone 69, Gen 61)
kRa2y_kArMa
Post by kRa2y_kArMa »
This WU has had problems multiple times and at multiple points of the WU. I tried pausing and restarting it before it usually erred at 18%, deleted the unit and looked for a new one (usually got the same one again). It managed to make it past the 18% when I did this but completely hung the client at 32% now.
I have posted a backup of the WU stopped at 17% at:
http://www.risingrain.com/download/fah/folding.zip
The log for the file is below as well:
Last login: Tue Aug 12 00:12:33 on ttys001
ben-bartholomews-mac-pro:~ benbartholomew$ cd ~/Library/folding@home3
ben-bartholomews-mac-pro:folding@home3 benbartholomew$ ./fah6 -smp -local -forceasm -verbosity 9 -oneunit
Using local directory for configuration
Note: Please read the license agreement (fah6 -license). Further
use of this software requires that you have read and accepted this agreement.
Using local directory for work files
8 cores detected
--- Opening Log file [August 12 14:42:06]
# SMP Client ##################################################################
                       Folding@Home Client Version 6.02
                          http://folding.stanford.edu
Launch directory: /Users/benbartholomew/Library/folding@home3
Executable: ./fah6
Arguments: -smp -local -forceasm -verbosity 9 -oneunit
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[14:42:06] - Ask before connecting: No
[14:42:06] - User name: kRa2y_kArMa (Team 99661)
[14:42:06] - User ID: 6FF2C70674316DCD
[14:42:06] - Machine ID: 4
[14:42:06]
[14:42:06] Loaded queue successfully.
[14:42:06]
[14:42:06] + Processing work unit
[14:42:06] Core required: FahCore_a1.exe
[14:42:06] Core found.
[14:42:06] - Autosending finished units...
[14:42:06] Trying to send all finished work units
[14:42:06] + No unsent completed units remaining.
[14:42:06] - Autosend completed
[14:42:06] Working on Unit 05 [August 12 14:42:06]
[14:42:06] + Working ...
[14:42:06] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 05 -checkpoint 5 -forceasm -verbose -lifeline 1452 -version 602'
[14:42:06]
[14:42:06] *------------------------------*
[14:42:06] Folding@Home Gromacs SMP Core
[14:42:06] Version 1.74 (September 24, 2007)
[14:42:06]
[14:42:06] Preparing to commence simulation
[14:42:06] - Assembly optimizations manually forced on.
[14:42:06] - Not checking prior termination.
[14:42:07] - Expanded 607972 -> 3255941 (decompressed 535.5 percent)
[14:42:07]
[14:42:07] Project: 3064 (Run 4, Clone 69, Gen 61)
[14:42:07]
[14:42:07] Assembly optimizations on if available.
[14:42:07] Entering M.D.
NNODES=4, MYRANK=1, HOSTNAME=ben-bartholomews-mac-pro.local
NNODES=4, MYRANK=3, HOSTNAME=ben-bartholomews-mac-pro.local
NNODES=4, MYRANK=0, HOSTNAME=ben-bartholomews-mac-pro.local
NNODES=4, MYRANK=2, HOSTNAME=ben-bartholomews-mac-pro.local
NODEID=1 argc=15
NODEID=2 argc=15
NODEID=3 argc=15
NODEID=0 argc=15
      Written by David van der Spoel, Erik Lindahl, Berk Hess, and others.
       Copyright (c) 1991-2000, University of Groningen, The Netherlands.
             Copyright (c) 2001-2004, The GROMACS development team,
            check out http://www.gromacs.org for more information.
        This inclusion of Gromacs code in the Folding@Home Core is under
        a special license (see http://folding.stanford.edu/gromacs.html)
         specially granted to Stanford by the copyright holders. If you
          are interested in using Gromacs, visit www.gromacs.org where
                you can download a free version of Gromacs under
         the terms of the GNU General Public License (GPL) as published
       by the Free Software Foundation; either version 2 of the License,
                     or (at your option) any later version.
[14:42:13] mdrunner cpfilename:
[14:42:13] Calling FAH init
(single precision)
starting mdrun 'p3064_lambda5_2003'
5000000 steps,  10000.0 ps.
[14:42:13] mbda5_2003
[14:42:13] Writing local files
[14:42:13] Completed 850000 out of 5000000 steps  (17 percent)
[14:42:13] Extra SSE boost OK.
[14:42:13] s
[14:47:13] Timered checkpoint triggered.
[14:52:14] Timered checkpoint triggered.
[14:54:22] Writing local files
[14:54:22] Completed 900000 out of 5000000 steps  (18 percent)
[14:59:21] Timered checkpoint triggered.
[15:04:22] Timered checkpoint triggered.
[15:05:09] Writing local files
[15:05:10] Completed 950000 out of 5000000 steps  (19 percent)
[15:10:09] Timered checkpoint triggered.
[15:15:10] Timered checkpoint triggered.
[15:16:06] Writing local files
[15:16:06] Completed 1000000 out of 5000000 steps  (20 percent)
[15:21:06] Timered checkpoint triggered.
[15:26:07] Timered checkpoint triggered.
[15:27:03] Writing local files
[15:27:03] Completed 1050000 out of 5000000 steps  (21 percent)
[15:32:04] Timered checkpoint triggered.
[15:37:04] Timered checkpoint triggered.
[15:37:59] Writing local files
[15:37:59] Completed 1100000 out of 5000000 steps  (22 percent)
[15:43:00] Timered checkpoint triggered.
[15:48:00] Timered checkpoint triggered.
[15:48:57] Writing local files
[15:48:57] Completed 1150000 out of 5000000 steps  (23 percent)
[15:53:58] Timered checkpoint triggered.
[15:58:57] Timered checkpoint triggered.
[15:59:54] Writing local files
[15:59:54] Completed 1200000 out of 5000000 steps  (24 percent)
[16:04:55] Timered checkpoint triggered.
[16:09:54] Timered checkpoint triggered.
[16:10:50] Writing local files
[16:10:50] Completed 1250000 out of 5000000 steps  (25 percent)
[16:15:51] Timered checkpoint triggered.
[16:20:51] Timered checkpoint triggered.
[16:21:45] Writing local files
[16:21:45] Completed 1300000 out of 5000000 steps  (26 percent)
[16:26:46] Timered checkpoint triggered.
[16:31:46] Timered checkpoint triggered.
[16:32:43] Writing local files
[16:32:43] Completed 1350000 out of 5000000 steps  (27 percent)
[16:37:44] Timered checkpoint triggered.
[16:42:44] Timered checkpoint triggered.
[16:43:25] Writing local files
[16:43:25] Completed 1400000 out of 5000000 steps  (28 percent)
[16:48:26] Timered checkpoint triggered.
[16:53:26] Timered checkpoint triggered.
[16:53:58] Writing local files
[16:53:58] Completed 1450000 out of 5000000 steps  (29 percent)
[16:58:59] Timered checkpoint triggered.
[17:03:59] Timered checkpoint triggered.
[17:04:30] Writing local files
[17:04:30] Completed 1500000 out of 5000000 steps  (30 percent)
[17:09:31] Timered checkpoint triggered.
[17:14:31] Timered checkpoint triggered.
[17:15:01] Writing local files
[17:15:01] Completed 1550000 out of 5000000 steps  (31 percent)
[17:20:02] Timered checkpoint triggered.
[17:25:03] Timered checkpoint triggered.
[17:25:31] Writing local files
[17:25:31] Completed 1600000 out of 5000000 steps  (32 percent)
[17:28:01] Warning:  long 1-4 interactions
[20:42:06] - Autosending finished units...
[20:42:06] Trying to send all finished work units
[20:42:06] + No unsent completed units remaining.
[20:42:06] - Autosend completed
^C[21:24:38] ***** Got an Activate signal (2)
[21:24:38] Killing all core threads
Folding@Home Client Shutdown.
ben-bartholomews-mac-pro:folding@home3 benbartholomew$ [0]0:Return code = 102
[0]1:Return code = 0, signaled with Quit
[0]2:Return code = 0, signaled with Quit
[0]3:Return code = 0, signaled with Quit
Note: Running on a 2008 Mac Pro, 8 cores at 2.8Ghz, 2GB 800Mhz FBDIMM ram, and 3 ATI HD2600XT video cards.
Re: Project: 3064 (Run 4, Clone 69, Gen 61)
No one was able to return this WU yet :(
