Project: P4432 (Run 188, Clone 1, Gen 15)
Baowoulf
Hardware configuration: Pentium 4 2.8 GHz, 512MB DDR Ram, 128MB Radeon 9800, Creative Soundblaster Audigy 4 Pro
Post by Baowoulf »
[05:06:37] Working on Unit 04 [August 8 05:06:37]
[05:06:37] + Working ...
[05:06:39]
[05:06:39] *------------------------------*
[05:06:39] Folding@Home Gromacs Core
[05:06:39] Version 1.90 (March 8, 2006)
[05:06:39]
[05:06:39] Preparing to commence simulation
[05:06:39] - Looking at optimizations...
[05:06:39] - Created dyn
[05:06:39] - Files status OK
[05:06:39] - Expanded 238269 -> 1168241 (decompressed 490.3 percent)
[05:06:39] - Starting from initial work packet
[05:06:39]
[05:06:39] Project: 4432 (Run 188, Clone 1, Gen 15)
[05:06:39]
[05:06:39] Assembly optimizations on if available.
[05:06:39] Entering M.D.
[05:06:45] Protein: p4432_Seq41_Amber03
I finished this project sometime yesterday August 10, 2008 but for the first two times it wouldn't send and I got this.
[20:16:48] Folding@home Core Shutdown: FINISHED_UNIT
[20:16:51] CoreStatus = 64 (100)
[20:16:51] Sending work to server
[20:16:51] + Attempting to send results
[20:16:51] - Couldn't send HTTP request to server
[20:16:51] + Could not connect to Work Server (results)
[20:16:51]     (171.64.122.78:8080)
[20:16:51] - Error: Could not transmit unit 04 (completed August 10) to work server.
[20:16:51]   Keeping unit 04 in queue.
[20:17:07] - Server does not have record of this unit. Will try again later.
[20:17:07]   Could not transmit unit 04 to Collection server; keeping in queue.
[20:17:07] - Preparing to get new work unit...
[20:17:07] + Attempting to get work packet
[20:17:07] - Connecting to assignment server
[20:17:07] - Successful: assigned to (171.65.103.160).
[20:17:07] + News From Folding@Home: Welcome to Folding@Home
[20:17:08] Loaded queue successfully.
[20:17:09] + Attempting to send results
[20:17:09] - Couldn't send HTTP request to server
[20:17:09] + Could not connect to Work Server (results)
[20:17:09]     (171.64.122.78:8080)
[20:17:09] - Error: Could not transmit unit 04 (completed August 10) to work server.
[20:17:25] - Server does not have record of this unit. Will try again later.
[20:17:25]   Could not transmit unit 04 to Collection server; keeping in queue.
[20:17:25] + Closed connections
[20:17:25]
[20:17:25] + Processing work unit
So I saw that it said server does not have a record of this unit twice so figured the server must be down but later on it successfully sent the finished WU after the next two failures.
[04:20:38] + Attempting to send results
[04:20:54] + Results successfully sent
[04:20:54] Thank you for your contribution to Folding@Home.
[04:20:54] + Number of Units Completed: 202
But so far I've seen no credit for 225points which is what the WU is worth so I'm wondering if there is any record for it. Or if the unit was lost/ the server that is it on is busy? It's not in queue anymore either.
I did restart the computer but the WU was already finished and in queue and I didn't pause it before restarting so it should have caused no problems at all. I'm running version 5.03 on the computer this WU was finished on.
Re: Project: P4432 (Run 188, Clone 1, Gen 15)
There's no record for that WU ... I don't know what happened to it :(
Baowoulf
Post by Baowoulf »
toTOW wrote:There's no record for that WU ... I don't know what happened to it :(
Thanks. No problem then. I just wanted to check like with all missing WU's. Better to be one of the few that go missing instead of finding out I have a problem with my computer. I had another one which may be because of the outage but I'll ask anyways to be sure.
P4010 (R=0, C=270, G=137) 295Points
It was completed Mon 3:17AM CST my time maybe just before the power outage. Got all my missing WU's accounted for accept this one. Was the first of the ones that I was waiting on.
Baowoulf wrote:P4010 (R=0, C=270, G=137) 295Points
Hi Baowoulf (team 48759),
Your WU (P4010 R0 C270 G137) was added to the stats database on 2008-08-18 02:25:55 for 295 points of credit.
Baowoulf
Post by Baowoulf »
Weird I must have screwed up my adding somewhere maybe it's the P4019 (R=1 C=242, G=49) if not I have no idea.
I was curious if there was a way maybe people could check their own missing WU's like they could put in the info and their name when logged into the forums or would Standford not like such an automated system? It could decrease the small fry problems, since users could check say up to 5 a day or something, unless Standford has it the way it is for security reasons or to catch as many bad WU's as they can?
Or do people usually ignore the odd WU that doesn't show up unless the log file shows something weird?
