Project: 2665 (Run 3, Clone 320, Gen 40) EUE
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
Post by SKeptical_Thinker »
I'm getting all sorts of problems with this project. This is a representative log. When will the server stop giving me this WU?
Edit: I reverted to 5.92 and got a different WU after this one failed, again.
--- Opening Log file [August 11 13:09:58 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2
                          http://folding.stanford.edu
Launch directory: C:\TEMP\FAH-SMP
Executable: C:\TEMP\FAH-SMP\FAH-SMP-shm.exe
Arguments: -verbosity 9 -smp -deino -advmethods
[13:09:58] - Ask before connecting: No
[13:09:58] - User name: SKeptical_Thinker (Team 31574)
[13:09:58] - User ID: 2760EF321933EEDA
[13:09:58] - Machine ID: 1
[13:09:58]
[13:09:58] Work directory not found. Creating...
[13:09:58] Could not open work queue, generating new queue...
[13:09:58] - Preparing to get new work unit...
[13:09:58] - Autosending finished units... [August 11 13:09:58 UTC]
[13:09:58] Trying to send all finished work units
[13:09:58] + No unsent completed units remaining.
[13:09:58] + Attempting to get work packet
[13:09:58] - Autosend completed
[13:09:58] - Will indicate memory of 2046 MB
[13:09:58] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[13:09:58] - Connecting to assignment server
[13:09:58] Connecting to http://assign.stanford.edu:8080/
[13:09:58] Posted data.
[13:09:58] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[13:09:58] + News From Folding@Home: Welcome to Folding@Home
[13:09:58] Loaded queue successfully.
[13:09:58] Connecting to http://171.64.65.64:8080/
[13:10:04] Posted data.
[13:10:04] Initial: 0000; - Receiving payload (expected size: 4758473)
[13:10:07] - Downloaded at ~1548 kB/s
[13:10:07] - Averaged speed for that direction ~1548 kB/s
[13:10:07] + Received work.
[13:10:07] + Closed connections
[13:10:07]
[13:10:07] + Processing work unit
[13:10:07] Work type a1 not eligible for variable processors
[13:10:07] Core required: FahCore_a1.exe
[13:10:07] Core not found.
[13:10:07] - Core is not present or corrupted.
[13:10:07] - Attempting to download new core...
[13:10:07] + Downloading new core: FahCore_a1.exe
[13:10:07] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[13:10:16] Initial: AFDE; + 10240 bytes downloaded
[13:10:17] Initial: 10F0; + 20480 bytes downloaded
[13:10:17] Initial: DB70; + 30720 bytes downloaded
[13:10:17] Initial: 865E; + 40960 bytes downloaded
[13:10:17] Initial: 8F87; + 51200 bytes downloaded
[13:10:17] Initial: C48B; + 61440 bytes downloaded
[13:10:17] Initial: 92B3; + 71680 bytes downloaded
[13:10:17] Initial: C102; + 81920 bytes downloaded
[13:10:17] Initial: 1996; + 92160 bytes downloaded
[13:10:17] Initial: BFFE; + 102400 bytes downloaded
[13:10:17] Initial: 1810; + 112640 bytes downloaded
[13:10:17] Initial: 0626; + 122880 bytes downloaded
[13:10:17] Initial: 7B53; + 133120 bytes downloaded
[13:10:17] Initial: 0441; + 143360 bytes downloaded
[13:10:17] Initial: FECE; + 153600 bytes downloaded
[13:10:17] Initial: D346; + 163840 bytes downloaded
[13:10:17] Initial: 2DE8; + 174080 bytes downloaded
[13:10:17] Initial: B3F0; + 184320 bytes downloaded
[13:10:17] Initial: 2881; + 194560 bytes downloaded
[13:10:17] Initial: 9507; + 204800 bytes downloaded
[13:10:17] Initial: 1BAF; + 215040 bytes downloaded
[13:10:17] Initial: 717C; + 225280 bytes downloaded
[13:10:17] Initial: 23FD; + 235520 bytes downloaded
[13:10:17] Initial: 915F; + 245760 bytes downloaded
[13:10:17] Initial: CE52; + 256000 bytes downloaded
[13:10:17] Initial: ED88; + 266240 bytes downloaded
[13:10:17] Initial: 2579; + 276480 bytes downloaded
[13:10:17] Initial: 3396; + 286720 bytes downloaded
[13:10:17] Initial: 410C; + 296960 bytes downloaded
[13:10:17] Initial: 56D1; + 307200 bytes downloaded
[13:10:17] Initial: 1EBD; + 317440 bytes downloaded
[13:10:17] Initial: 6AD9; + 327680 bytes downloaded
[13:10:17] Initial: F931; + 337920 bytes downloaded
[13:10:17] Initial: 1C40; + 348160 bytes downloaded
[13:10:17] Initial: C4AE; + 358400 bytes downloaded
[13:10:17] Initial: 57E4; + 368640 bytes downloaded
[13:10:17] Initial: 1843; + 378880 bytes downloaded
[13:10:17] Initial: B0C0; + 389120 bytes downloaded
[13:10:17] Initial: AAAA; + 399360 bytes downloaded
[13:10:17] Initial: D737; + 409600 bytes downloaded
[13:10:17] Initial: 762A; + 419840 bytes downloaded
[13:10:17] Initial: 8685; + 430080 bytes downloaded
[13:10:17] Initial: 25B1; + 440320 bytes downloaded
[13:10:17] Initial: 44F1; + 450560 bytes downloaded
[13:10:18] Initial: EF81; + 460800 bytes downloaded
[13:10:18] Initial: 900E; + 471040 bytes downloaded
[13:10:18] Initial: 906E; + 481280 bytes downloaded
[13:10:18] Initial: D59F; + 491520 bytes downloaded
[13:10:18] Initial: 2406; + 501760 bytes downloaded
[13:10:18] Initial: 9777; + 512000 bytes downloaded
[13:10:18] Initial: 7783; + 522240 bytes downloaded
[13:10:18] Initial: AEC5; + 532480 bytes downloaded
[13:10:18] Initial: B8A1; + 542720 bytes downloaded
[13:10:18] Initial: D50E; + 552960 bytes downloaded
[13:10:18] Initial: BDEE; + 563200 bytes downloaded
[13:10:18] Initial: E433; + 573440 bytes downloaded
[13:10:18] Initial: 667A; + 583680 bytes downloaded
[13:10:18] Initial: C413; + 593920 bytes downloaded
[13:10:18] Initial: DB64; + 604160 bytes downloaded
[13:10:18] Initial: 313C; + 614400 bytes downloaded
[13:10:18] Initial: 4B8A; + 624640 bytes downloaded
[13:10:18] Initial: 1B3A; + 634880 bytes downloaded
[13:10:18] Initial: E39B; + 645120 bytes downloaded
[13:10:18] Initial: F9FD; + 655360 bytes downloaded
[13:10:18] Initial: BFF6; + 665600 bytes downloaded
[13:10:18] Initial: 0552; + 675840 bytes downloaded
[13:10:18] Initial: 14A7; + 686080 bytes downloaded
[13:10:18] Initial: 99A6; + 696320 bytes downloaded
[13:10:18] Initial: 06B2; + 706560 bytes downloaded
[13:10:18] Initial: 445D; + 716800 bytes downloaded
[13:10:18] Initial: 62C1; + 727040 bytes downloaded
[13:10:18] Initial: 0E27; + 737280 bytes downloaded
[13:10:18] Initial: EF9A; + 747520 bytes downloaded
[13:10:18] Initial: C105; + 757760 bytes downloaded
[13:10:18] Initial: 46D3; + 768000 bytes downloaded
[13:10:18] Initial: 33C7; + 778240 bytes downloaded
[13:10:18] Initial: 7E92; + 788480 bytes downloaded
[13:10:18] Initial: 24B3; + 795847 bytes downloaded
[13:10:18] Verifying core Core_a1.fah...
[13:10:18] Signature is VALID
[13:10:18]
[13:10:18] Trying to unzip core FahCore_a1.exe
[13:10:18] Decompressed FahCore_a1.exe (2117632 bytes) successfully
[13:10:23] + Core successfully engaged
[13:10:28]
[13:10:28] + Processing work unit
[13:10:28] Work type a1 not eligible for variable processors
[13:10:28] Core required: FahCore_a1.exe
[13:10:28] Core found.
[13:10:28] Working on queue slot 01 [August 11 13:10:28 UTC]
[13:10:28] + Working ...
[13:10:28] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -cpu 98 -checkpoint 15 -verbose -lifeline 4204 -version 622'
[13:10:30]
[13:10:30] *------------------------------*
[13:10:30] Folding@Home Gromacs SMP Core
[13:10:30] Version 1.76 (February 23, 2008)
[13:10:30]
[13:10:30] Preparing to commence simulation
[13:10:30] - Ensuring status. Please wait- Created dyn
[13:10:30] - Files status OK
[13:10:30]  this execution.
[13:10:30] - Created dyn
[13:10:43] - Expanded 4757961 -> 24426905 (decompressed 513.3 percent)
[13:10:43] - Starting from initial work packet
[13:10:47]
[13:10:47] Project: 2665 (Run 3, Clone 320, Gen 40)
[13:10:47]
[13:10:56] Entering M.D.
[13:10:58] acket
[13:10:58]
[13:10:58] Project: 2665 (Run 3, Clone 320, Gen 40)
[13:10:58]
[13:10:59] Entering M.D.
[13:11:08] Protein: HGG in water
[13:11:08] Writing local files
[13:11:11] Extra SSE boost OK.
[13:11:22] 000 steps  (0 percent)
[13:26:24] Timered checkpoint triggered.
[13:39:56]  disk...
[13:39:56]   ... Done.
[13:39:56] .. Done.
[13:39:56] - Failed to delete work/wudata_01.arc
[13:39:56] ng to send back what have done.
[13:39:56] logfile size: 10630
[13:39:56] - Writing 11166 bytes of core data to disk...
[13:39:56] No C.P. to delete.
[13:39:56] - Failed to delete work/wudata_01.sas
[13:39:56] - Failed to delete work/wudata_01.goe
[13:39:56] - Failed to delete work/wudata_01.pdo
[13:39:56] Warning:  check for stray files
[13:39:56]
[13:39:56] Folding@home Core Shutdown: EARLY_UNIT_END
[13:39:56]
[13:40:01] CoreStatus = 63 (99)
[13:40:01] + Error starting Folding@Home core.
[13:40:06]
[13:40:06] + Processing work unit
[13:40:06] Work type a1 not eligible for variable processors
[13:40:06] Core required: FahCore_a1.exe
[13:40:06] Core found.
[13:40:06] Working on queue slot 01 [August 11 13:40:06 UTC]
[13:40:06] + Working ...
[13:40:06] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -cpu 98 -checkpoint 15 -verbose -lifeline 4204 -version 622'
[13:40:07]
[13:40:07] *------------------------------*
[13:40:07] Folding@Home Gromacs SMP Core
[13:40:07] Version 1.76 (February 23, 2008)
[13:40:07]
[13:40:07] Preparing to commence simulation
[13:40:07] - Ensuring status. Please wait.
[13:40:24] - Looking at optimizations...
[13:40:24] - Working with standard loops on this execution.
[13:40:24] - Previous termination of core was improper.
[13:40:24] - Going to use standard loops.
[13:40:24] - Files status OK
[13:42:24] SSING_WORK_FILES
[13:42:24] Finalizing output
[13:42:24] G_WORK_FILES
[13:42:28] CoreStatus = 1 (1)
[13:42:28] Client-core communications error: ERROR 0x1
[13:42:28] This is a sign of more serious problems, shutting down.
Re: Project: 2665 (Run 3, Clone 320, Gen 40) EUE
Someone else completed this WU successfully ...
Is there a good reason for you to run the client from C:\TEMP folder :?:
