1 smp and 1 gpu2 client on my rig sucks... help please
nuttcase21
Hardware configuration: Rig 1: Asus P5E-VM HDMI mobo
Xeon X3350 @ 3.4 gigs
4 gigs of gskill pc2-8500 ram
ATI 3870 vid card
74 gig Raptor HDD
Vista Ultimate 64 bit
Custom water cooling in a Lian pc-350 case
Post by nuttcase21 »
here's my rig stats:
ati 3870 vid card max clocked in catalyst
asus p5e-vm hdmi board
xeon x3350 quad cpu clocked to 3.4 ghz
4 gigs memory
raptor hd
running vista ultimate 64-bit
all running on custom water
normally i run 2 smp clients on this rig and make roughly 3400-3500 ppd, but i wanted to try the new 6.20 gpu client out. so i dropped the second smp client and started running the gpu client and i'm only getting about 2900 ppd now. is it because the single 3870 just isnt as good as 2 cores running an smp client? or am i doing something wrong? i set the core priority of the gpu client to low so as not to disturb the smp client (it wouldnt run without errors until i did this). as a side note, when i look in catalyst to see my card temps, it shows that the gpu is only loaded at about 29-37%. any help would be greatly appreciated guys. thanx.
nuttcase21
ATI 3870 vid card
74 gig Raptor HDD
why low gpu usage in catalyst when running 6.20?
when i use catalyst control center to check the temp of my 3870 card while folding with the new 6.20 console client, why does it show that the gpu load is always less than 40%? does this sound wrong or is this the norm? thanx guys.
I guessing this might all be related, so I merged the two threads. -7im
nuttcase21
ATI 3870 vid card
74 gig Raptor HDD
Re: 1 smp and 1 gpu2 client on my rig sucks... help please
yes they are, just thought they'd fit in separate topics. thanx!!
Foxery
Hardware configuration: Intel Core2 Quad Q9300 (Intel P35 chipset)
Radeon 3850, 512MB model (Catalyst 8.10)
Windows XP, SP2
Post by Foxery »
2900 isn't right at all for this hardware. You should be seeing 4000+. Make sure you have set your GPU client to run at "Slightly Higher Priority" in the configuration. It sounds like it isn't being fed properly.
Core2 Quad/Q9300, Radeon 3850/512MB (WinXP SP2)
nuttcase21
ATI 3870 vid card
74 gig Raptor HDD
i do that by running the -configonly flag from the administrator comand prompt and changing the advanced options correct?
EvilAlchemist
Hardware configuration: 2 x X5550 Xeons - SuperMicro MBD-X8DAi-O
Server 2008 R2 x64 - 12GB Crucial DDR3 ECC Ram
PCP&C 910 Silencer - 1 x HIS 4850 ICEQ Turbo Edition
6 x E5530 Xeons (3 Systems) - SUPERMICRO MBD-X8DTL-i-O
Server 2008 RS x64 - 8GB DDR3 GSkill Non-ECC Ram
Seasonic 80+ Bronze 380w PSU
2 x E5504 - SUPERMICRO MBD-X8DTL-i-O
Server 2008 R2 x64 - 6GB DDR3 GSkill Non-ECC Ram
2.3 TB Raid 5 Array - Corsair 520 Power Supply
E5504 - EVGA X58 ATX Motherboard
Windows 7 x64 - 6GB DDR3 GSkill Non-ECC Ram
Seasonic 300 Power Supply
Intel X5550 CPU - EVGA X58 Micro ATX Motherboard
Windows 7 x64 - 3GB Corsair DDR3-1600
Corsair 550 Power Supply - ATI 4350
Dell Vostro 1500 Laptop - Intel T9300 C2D CPU
Windows 7 x64 - 4 GB DDR2-6400 - nVidia 8400m GS
Xeon 3075 C2D - Intel P35 Motherboard - 4GB DDR2 Non-ECC Ram
Server 2008 R2 x64- Seasonic 300 Power Supply
Post by EvilAlchemist »
For Some reason, the SMP client and GPU2 don't play nice in Vista.
Your GPU2 client is stalling your SMP.
One core is trying to run two clients ... which henders preformance.
I would suggest running a VMServer on your system.
That will load Core 0 & 1 with SMP ... then run GPU2 on Core 3 ... and a core to spare .... to run what ever else you want (Standard Client)
Running VMServer is very easy ...... esp if you run "notfred" distro in there.
I did this and my SMP points went from 3000 -> to 5000 PPD .... well worth the effort.
The other way is to run 3 x Standard Clients and 1 x GPU2 to max the quad core.
