Project: 3064 (Run 5, Clone 90, Gen 57)
Zagen30
Post by Zagen30 »
EUE'd as such:
[05:44:50] Completed 4600000 out of 5000000 steps  (92 percent)
[06:07:48] Warning:  long 1-4 interactions
[06:07:49] Quit 101 - NaN detected: (ener[20])
[06:07:49]
[06:07:49] Simulation instability has been encountered. The run has entered a
[06:07:49]   state from which no further progress can be made.
[06:07:49] This may be the correct result of the simulation, however if you
[06:07:49]   often see other project units terminating early like this
[06:07:49]   too, you may wish to check the stability of your computer (issues
[06:07:49]   such as high temperature, overclocking, etc.).
[06:07:49] Going to send back what have done.
[06:07:49] logfile size: 120639
[06:07:49] - Writing 121189 bytes of core data to disk...
[06:07:49]   ... Done.
[06:07:49] - Failed to delete work/wudata_01.chk
[06:07:49] - Failed to delete work/wudata_01.xvg
[06:07:49] Warning:  check for stray files
[06:09:49]
[06:09:49] Folding@home Core Shutdown: EARLY_UNIT_END
[06:09:49]
[06:09:54] CoreStatus = 7B (123)
[06:09:54] Client-core communications error: ERROR 0x7b
[06:09:54] This is a sign of more serious problems, shutting down.
Running Vista 32-bit, 6.22 MPICH, T7300 (2.0 Ghz C2D)
Tried qfix, which repaired the previous WU that had EUE'd on me, and was able to send that one back, but it couldn't find any issues with this one.
I'm starting to become concerned, because I've now had 2 SMP WUs in a row EUE, when I hadn't had that happen in nearly 100 WUs. I've also had a lot of problems with the GPU client EUEing on almost every WU. I'm beginning to wonder if I've overheated and damaged my laptop (although I haven't been running the GPu client that long).
Re: Project: 3064 (Run 5, Clone 90, Gen 57)
Someone else has been able to complete this WU.
