Project: 2665 (Run 3, Clone 11, Gen 23)
Foxery
Hardware configuration: Intel Core2 Quad Q9300 (Intel P35 chipset)
Radeon 3850, 512MB model (Catalyst 8.10)
Windows XP, SP2
Post by Foxery »
"No C.P. to delete."
WinSMP 6.22, kasson's Deino build. QFix did not find anything to fix, so I was unable to submit a partial result.
[10:38:09] + Processing work unit
[10:38:09] Work type a1 not eligible for variable processors
[10:38:09] Core required: FahCore_a1.exe
[10:38:09] Core found.
[10:38:09] Working on queue slot 04 [August 9 10:38:09 UTC]
[10:38:09] + Working ...
[10:38:09] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 16 -verbose -lifeline 2616 -version 622'
[10:38:09]
[10:38:09] *------------------------------*
[10:38:09] Folding@Home Gromacs SMP Core
[10:38:09] Version 1.76 (February 23, 2008)
[10:38:09]
[10:38:09] Preparing to commence simulation
[10:38:09] - Ensuring status. Please wait.
[10:38:13] - Starting from initial work packet
[10:38:14]
[10:38:14] Project: 2665 (Run 3, Clone 11, Gen 23)
[10:38:14]
[10:38:14] Assembly optimizations on if available.
[10:38:14] Entering M.D.
[10:38:35] ial work packet
[10:38:35]
[10:38:35] Project: 2665 (Run 3, Clone 11, Gen 23)
[10:38:35]
[10:38:37] Entering M.D.
[10:38:43] Rejecting checkpoint
[10:38:44] Protein: HGG in water
[10:38:44] Writing local files
[10:38:51] Extra SSE boost OK.
[10:38:52] Writing local files
[10:38:52] Completed 0 out of 250000 steps  (0 percent)
[10:52:46] Writing local files
[10:52:46] Completed 2500 out of 250000 steps  (1 percent)
[11:06:39] Writing local files
[11:06:39] Completed 5000 out of 250000 steps  (2 percent)
[11:08:47] No C.P. to delete.
[11:08:47] - Failed to delete work/wudata_04.sa
[11:08:47] Folding@home Core Shutdown: EARLY_UNIT_END
[11:08:47] Finalizing output
[11:08:47] ray files
[11:08:47] isk...
[11:08:47]   ... Done.
[11:08:47] - Failed to delete work/wudata_04.sas
[11:08:47] - Failed to delete work/wudata_04.goe
[11:08:47] Warning:  check for stray files
[11:10:47]
[11:10:47] Folding@home Core Shutdown: EARLY_UNIT_END
[11:10:47]
[11:10:51] CoreStatus = 63 (99)
[11:10:51] + Error starting Folding@Home core.
[11:10:56]
[11:10:56] + Processing work unit
[11:10:56] Work type a1 not eligible for variable processors
[11:10:56] Core required: FahCore_a1.exe
[11:10:56] Core found.
[11:10:56] Working on queue slot 04 [August 9 11:10:56 UTC]
[11:10:56] + Working ...
[11:10:56] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 16 -verbose -lifeline 2616 -version 622'
[11:10:57]
[11:10:57] *------------------------------*
[11:10:57] Folding@Home Gromacs SMP Core
[11:10:57] Version 1.76 (February 23, 2008)
[11:10:57]
[11:10:57] Preparing to commence simulation
[11:10:57] - Looking at optimizations...
[11:10:57] - Created dyn
[11:10:57] - Files status OK
[11:10:57]  this Warning:  c- Created dyn
[11:10:57] yn
[11:10:57] - FWarning:  check
[11:10:57] Folding@home Cor- Created dyn
[11:10:57] inalizing output
[11:12:57] e Shutdown: MISSING_WORK_FILES
[11:12:57] Finalizing output
[11:13:01] CoreStatus = 1 (1)
[11:13:01] Client-core communications error: ERROR 0x1
[11:13:01] This is a sign of more serious problems, shutting down.
[12:01:41] - Autosending finished units... [August 9 12:01:41 UTC]
[12:01:41] Trying to send all finished work units
[12:01:41] + No unsent completed units remaining.
[12:01:41] - Autosend completed
Core2 Quad/Q9300, Radeon 3850/512MB (WinXP SP2)
Re: Project: 2665 (Run 3, Clone 11, Gen 23)
We have multiple reports for partial credits for this WU, but no full completion.
