Project: 2665 (Run 2, Clone 198, Gen 22)
Zagen30
Post by Zagen30 »
Running 6.22 with -smp. EUE'd at 98% :evil:
[00:18:52] Completed 245000 out of 250000 steps  (98 percent)
[00:44:47] Warning:  long 1-4 interactions
[00:44:47] Gromacs cannot continue further.
[00:44:47] Going to send back what have done.
[00:44:47] logfile size: 211001
[00:44:47] - Writing 211537 bytes of core data to disk...
[00:44:47]   ... Done.
[00:44:47] - Failed to delete work/wudata_00.arc
[00:44:47] - Failed to delete work/wudata_00.sas
[00:44:47] - Failed to delete work/wudata_00.goe
[00:44:47] Warning:  check for stray files
[00:44:48]
[00:44:48] Folding@home Core Shutdown: EARLY_UNIT_END
[00:44:48]
[00:44:55] CoreStatus = 7B (123)
[00:44:55] Client-core communications error: ERROR 0x7b
[00:44:55] This is a sign of more serious problems, shutting down.
Used qfix (it said File is OK), ran with -send all, gave me this:
[02:01:51] - Ask before connecting: No
[02:01:51] - User name: Zagen30 (Team 0)
[02:01:51] - User ID: 4B0CBF697DF8B48F
[02:01:51] - Machine ID: 2
[02:01:51]
[02:01:51] Loaded queue successfully.
[02:01:51] Attempting to return result(s) to server...
Folding@Home Client Shutdown.
Tried with -send 00 (was in slot 00), gave me
[02:02:40] - Ask before connecting: No
[02:02:40] - User name: Zagen30 (Team 0)
[02:02:40] - User ID: 4B0CBF697DF8B48F
[02:02:40] - Machine ID: 2
[02:02:40]
[02:02:40] Loaded queue successfully.
[02:02:40] Attempting to return result(s) to server...
[02:02:40] Project: 2665 (Run 2, Clone 198, Gen 22)
[02:02:40] - Failed to send unit 00 to server
Not sure if this is because qfix actually worked and the partial result was uploaded, or if it didn't upload at all. Does the client write something to the log if a qfixed WU is uploaded successfully?
I don't want to restart my client in case it overwrites what work I already did.
What's odd is that I've been running SMP since February, and have never had this issue (only issues I have are the random bluescreens that wipe what work I've done). I've also done at least 1 WU with 6.22 successfully.
[EDIT]
Didn't get credited for anything on the next update, so I guess it didn't upload. Actually managed to delete it, though, which is a rarity for me.
Re: Project: 2665 (Run 2, Clone 198, Gen 22)
I see reports for that WU, but not from Zagen30 ... what is your FAH username :?:
Zagen30
Post by Zagen30 »
Um, Zagen30...
When do these reports come from? Before I messed around with the work folder* and somehow deleted my work on this WU, FahMon said that I had downloaded the WU about 2 days ago and had more than 3 days to complete it.
*I was trying to move the data from this WU to a different location so I could safely download a new WU instead of redoing this one, but the client didn't like that I had removed the work folder, and when I finally put the old work folder back, it got rid of the 2665 data. Currently working on a 3064.
These reports comes from a moderator-only tool ... it allows us to check WU in the database to unload this work from Pande Group.
Zagen30
Post by Zagen30 »
Sorry, what I meant to ask was: Did someone else finish this WU, or have it EUE on them, before I got it?
Yes, the same guy finished it two times : one with full credit, and one with 0 credits.
Zagen30
Post by Zagen30 »
Er, shouldn't I have not gotten it, then? I thought that WUs weren't sent out again unless the preferred deadline was passed, and on 2665s the preferred and final deadlines are the same.
