Project: 2665 (Run 0, Clone 879, Gen 36)
Foxery
Hardware configuration: Intel Core2 Quad Q9300 (Intel P35 chipset)
Radeon 3850, 512MB model (Catalyst 8.10)
Windows XP, SP2
Post by Foxery »
[03:54:54] Warning: long 1-4 interactions
[03:54:55] Quit 101 - NaN detected: (ener[20])
(client hung, waiting for user input)
[11:57:21] Folding@home Core Shutdown: MISSING_WORK_FILES
[11:57:21] Finalizing output
[11:59:25] CoreStatus = 1 (1)
WinSMP 6.22, kasson's Deino build. QFix did not find anything to fix, so I was unable to submit a partial result.
Full log:
[20:32:26] Core required: FahCore_a1.exe
[20:32:26] Core found.
[20:32:26] Working on queue slot 09 [August 5 20:32:26 UTC]
[20:32:26] + Working ...
[20:32:26] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 09 -checkpoint 16 -verbose -lifeline 3812 -version 622'
[20:32:27]
[20:32:27] *------------------------------*
[20:32:27] Folding@Home Gromacs SMP Core
[20:32:27] Version 1.76 (February 23, 2008)
[20:32:27]
[20:32:27] Preparing to commence simulation
[20:32:27] - Ensuring status. Please wait.
[20:32:27] Created dyn
[20:32:27] - Files status OK
[20:32:27]  this execution.
[20:32:27] - Previous termination of core was improper.
[20:32:33] ial work packet
[20:32:33]
[20:32:33] Project: 2665 (Run 0, Clone 879, Gen 36)
[20:32:33]
[20:32:33]
[20:32:33] - Starting from initial work packet
[20:32:33]
[20:32:33]
[20:32:34] Entering M.D.
[20:32:50] acket
[20:32:50]
[20:32:50] Project: 2665 (Run 0, Clone 879, Gen 36)
[20:32:50]
[20:32:51] Entering M.D.
[20:32:57] Rejecting checkpoint
[20:32:59] Protein: HGG in water
[20:32:59] Writing local files
[20:33:06] Extra SSE boost OK.
[20:33:06] Writing local files
[20:33:06] Completed 0 out of 250000 steps  (0 percent)
[20:47:17] Writing local files
[20:47:17] Completed 2500 out of 250000 steps  (1 percent)
[21:01:28] Writing local files
[21:01:28] Completed 5000 out of 250000 steps  (2 percent)
[21:15:38] Writing local files
[21:15:39] Completed 7500 out of 250000 steps  (3 percent)
[21:29:49] Writing local files
[21:29:49] Completed 10000 out of 250000 steps  (4 percent)
[21:44:01] Writing local files
[21:44:02] Completed 12500 out of 250000 steps  (5 percent)
[21:56:50] - Autosending finished units... [August 5 21:56:50 UTC]
[21:56:50] Trying to send all finished work units
[21:56:50] + No unsent completed units remaining.
[21:56:50] - Autosend completed
[21:58:14] Writing local files
[21:58:14] Completed 15000 out of 250000 steps  (6 percent)
[22:12:25] Writing local files
[22:12:26] Completed 17500 out of 250000 steps  (7 percent)
[22:26:39] Writing local files
[22:26:39] Completed 20000 out of 250000 steps  (8 percent)
[22:40:48] Writing local files
[22:40:48] Completed 22500 out of 250000 steps  (9 percent)
[22:55:08] Writing local files
[22:55:09] Completed 25000 out of 250000 steps  (10 percent)
[23:09:46] Writing local files
[23:09:46] Completed 27500 out of 250000 steps  (11 percent)
[23:24:21] Writing local files
[23:24:21] Completed 30000 out of 250000 steps  (12 percent)
[23:38:43] Writing local files
[23:38:43] Completed 32500 out of 250000 steps  (13 percent)
[23:53:05] Writing local files
[23:53:05] Completed 35000 out of 250000 steps  (14 percent)
[00:07:25] Writing local files
[00:07:25] Completed 37500 out of 250000 steps  (15 percent)
[00:21:46] Writing local files
[00:21:46] Completed 40000 out of 250000 steps  (16 percent)
[00:36:08] Writing local files
[00:36:08] Completed 42500 out of 250000 steps  (17 percent)
[00:50:19] Writing local files
[00:50:19] Completed 45000 out of 250000 steps  (18 percent)
[01:04:29] Writing local files
[01:04:29] Completed 47500 out of 250000 steps  (19 percent)
[01:18:51] Writing local files
[01:18:51] Completed 50000 out of 250000 steps  (20 percent)
[01:32:52] Writing local files
[01:32:52] Completed 52500 out of 250000 steps  (21 percent)
[01:46:54] Writing local files
[01:46:55] Completed 55000 out of 250000 steps  (22 percent)
[02:01:00] Writing local files
[02:01:01] Completed 57500 out of 250000 steps  (23 percent)
[02:15:05] Writing local files
[02:15:05] Completed 60000 out of 250000 steps  (24 percent)
[02:29:15] Writing local files
[02:29:16] Completed 62500 out of 250000 steps  (25 percent)
[02:43:25] Writing local files
[02:43:25] Completed 65000 out of 250000 steps  (26 percent)
[02:57:35] Writing local files
[02:57:35] Completed 67500 out of 250000 steps  (27 percent)
[03:12:04] Writing local files
[03:12:04] Completed 70000 out of 250000 steps  (28 percent)
[03:27:06] Writing local files
[03:27:07] Completed 72500 out of 250000 steps  (29 percent)
[03:42:09] Writing local files
[03:42:09] Completed 75000 out of 250000 steps  (30 percent)
[03:54:55]
[03:54:55] Simulation instability has been encountered. The run has entered a
[03:54:55]   state from which no further progress can be made.
[03:54:55] This may be the correct result of the simulation, however if you
[03:54:55]   often see other project units terminating early like this
[03:54:55]   too, you may wish to check the stability of your computer (issues
[03:54:55]   such as high temperature, overclocking, etc.).
[03:54:55] Going to send back what have done.
[03:54:55] logfile size: 65224
[03:54:55] - Writing 65774 bytes of core data to disk...
[03:54:55]   ... Done.
[03:54:55] - Failed to delete work/wudata_09.arc
[03:54:55] Warning:  check for stray files
[03:56:50] - Autosending finished units... [August 6 03:56:50 UTC]
[03:56:50] Trying to send all finished work units
[03:56:50] + No unsent completed units remaining.
[03:56:50] - Autosend completed
[03:56:55]
[03:56:55] Folding@home Core Shutdown: EARLY_UNIT_END
[03:56:55]
[03:56:59] CoreStatus = 63 (99)
[03:56:59] + Error starting Folding@Home core.
[03:57:04]
[03:57:04] + Processing work unit
[03:57:04] Work type a1 not eligible for variable processors
[03:57:04] Core required: FahCore_a1.exe
[03:57:04] Core found.
[03:57:04] Working on queue slot 09 [August 6 03:57:04 UTC]
[03:57:04] + Working ...
[03:57:04] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 09 -checkpoint 16 -verbose -lifeline 3812 -version 622'
[03:57:04]
[03:57:04] *------------------------------*
[03:57:04] Folding@Home Gromacs SMP Core
[03:57:04] Version 1.76 (February 23, 2008)
[03:57:04]
[03:57:04] Preparing to commence simulation
[03:57:04] - Ensuring status. Please wait.
[03:57:21] - Looking at optimizations...
[03:57:21] - Working with standard loops on this execution.
[03:57:21] - Previous termination of core was improper.
[03:57:21] - Going to use standard loops.
[03:57:21] - Files status OK
[03:59:21]
[03:59:21] Folding@home Core Shutdown: MISSING_WORK_FILES
[03:59:21] Finalizing output
[03:59:24] CoreStatus = 1 (1)
[03:59:24] Client-core communications error: ERROR 0x1
[03:59:24] This is a sign of more serious problems, shutting down.
[09:56:50] - Autosending finished units... [August 6 09:56:50 UTC]
[09:56:50] Trying to send all finished work units
[09:56:50] + No unsent completed units remaining.
[09:56:50] - Autosend completed
--- Opening Log file [August 6 11:57:04 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home Windows SMP Client V1.01
Executable: C:\Program Files\Folding@Home Windows SMP Client V1.01\FAH6.22beta2-SMP-shm.exe
Arguments: -local -deino -smp 4 -verbosity 9
[11:57:04] - Ask before connecting: No
[11:57:04] - User name: Foxery (Team 198)
[11:57:04] - User ID: 2102BD015E3C6C0F
[11:57:04] - Machine ID: 1
[11:57:04]
[11:57:04] Loaded queue successfully.
[11:57:04]
[11:57:04] - Autosending finished units... [August 6 11:57:04 UTC]
[11:57:04] + Processing work unit
[11:57:04] Trying to send all finished work units
[11:57:04] + No unsent completed units remaining.
[11:57:04] Work type a1 not eligible for variable processors
[11:57:04] Core required: FahCore_a1.exe
[11:57:04] - Autosend completed
[11:57:04] Core found.
[11:57:04] Working on queue slot 09 [August 6 11:57:04 UTC]
[11:57:04] + Working ...
[11:57:04] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 09 -checkpoint 16 -verbose -lifeline 3344 -version 622'
[11:57:04]
[11:57:04] *------------------------------*
[11:57:04] Folding@Home Gromacs SMP Core
[11:57:04] Version 1.76 (February 23, 2008)
[11:57:04]
[11:57:04] Preparing to commence simulation
[11:57:04] - Ensuring status. Please wait.
[11:57:21] - Looking at optimizations...
[11:57:21] - Working with standard loops on this execution.
[11:57:21] - Previous termination of core was improper.
[11:57:21] - Going to use standard loops.
[11:57:21] - Files status OK
[11:57:21]
[11:59:25] Client-core communications error: ERROR 0x1
[11:59:25] This is a sign of more serious problems, shutting down.
Core2 Quad/Q9300, Radeon 3850/512MB (WinXP SP2)
Re: Project: 2665 (Run 0, Clone 879, Gen 36)
No report for this WU.
When you see the EUE error, qfix should be able to help.
Foxery
Windows XP, SP2
Post by Foxery »
Nope, qfix did not modify my files. (-send 9 therefore found nothing to send) It may have something to do with the second error, when I tried to restart the client. Hopefully the next machine will be able to send an EUE... Given that this is Run 0, maybe the input is just bad.
