Project: 4596 (Run 37, Clone 53, Gen 40)
Pette Broad
Hardware configuration: CPU folding on only one machine a laptop
GPU Hardware..
3 x 460
1 X 260
4 X 250
+ 1 X 9800GT (3 days a week)
Post by Pette Broad »
Instant EUE. I've had a small number of these on 4593/4/6 all failing after 6-10 seconds. Can be difficult to spot as I've always been assigned a different RCG after each failure.
[21:55:44] - Calling 'FahCore_82.exe -dir work/ -suffix 07 -priority 96 -checkpoint 6 -forceasm -verbose -lifeline 1816 -version 504'
[21:55:44]
[21:55:44] *------------------------------*
[21:55:44] Folding@Home PMD Core
[21:55:44] Version 1.03 (September 7, 2005)
[21:55:44]
[21:55:44] Preparing to commence simulation
[21:55:44] - Assembly optimizations manually forced on.
[21:55:44] - Not checking prior termination.
[21:55:44] - Expanded 16635 -> 105052 (decompressed 631.5 percent)
[21:55:44]
[21:55:44] Project: 4596 (Run 37, Clone 53, Gen 40)
[21:55:44]
[21:55:44] Assembly optimizations on if available.
[21:55:44] Entering M.D.
[21:55:50] Going to send back what have done.
[21:55:50] logfile size: 5649
[21:55:50] - Writing 6169 bytes of core data to disk...
[21:55:50]   ... Done.
[21:55:50]
[21:55:50] Folding@home Core Shutdown: EARLY_UNIT_END
[21:55:54] CoreStatus = 72 (114)
[21:55:54] Sending work to server
[21:55:54] + Attempting to send results
[21:55:54] - Reading file work/wuresults_07.dat from core
[21:55:54]   (Read 6169 bytes from disk)
[21:55:54] Connecting to http://169.230.26.30:8080/
[21:55:56] Posted data.
[21:55:56] Initial: 0000; - Uploaded at ~3 kB/s
[21:55:56] - Averaged speed for that direction ~32 kB/s
[21:55:56] + Results successfully sent
[21:55:56] Thank you for your contribution to Folding@Home.
[21:56:00] Trying to send all finished work units
[21:56:00] + No unsent completed units remaining.
[21:56:00] - Preparing to get new work unit...
[21:56:00] + Attempting to get work packet
[21:56:00] - Will indicate memory of 2047 MB
[21:56:00] - Connecting to assignment server
[21:56:00] Connecting to http://assign.stanford.edu:8080/
[21:56:00] Posted data.
[21:56:00] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[21:56:00] + News From Folding@Home: Welcome to Folding@Home
[21:56:00] Loaded queue successfully.
[21:56:00] Connecting to http://169.230.26.30:8080/
[21:56:01] Posted data.
[21:56:01] Initial: 0000; - Receiving payload (expected size: 18610)
[21:56:02] - Downloaded at ~18 kB/s
[21:56:02] - Averaged speed for that direction ~35 kB/s
[21:56:02] + Received work.
[21:56:02] Trying to send all finished work units
[21:56:02] + No unsent completed units remaining.
[21:56:02] + Closed connections
Pete
Re: Project: 4596 (Run 37, Clone 53, Gen 40)
There is multiple reports for 0 point for this WU ... probably a bad one :(
