2170 (Run 58, Clone 427, Gen 5) - CoreStatus = 75 (117)
thenoclist
Post by thenoclist »
2nd Problem with this WU on a different machine: foldingforum[dot]org/viewtopic.php?f=19&t=4514
Doing nothing different from any other time! - CoreStatus = 75 (117)
Checked the Error Codes and Both this Issue and the other Checksum Issue under same error code! I know it's not the computer and I can stress test them to be absolutely sure!
Computer Specs: 1.6GHz AMD Turion(tm) 64 X2 Dual Core Processor Notebook w/ 1GB RAM on Win XP Home SP3 running the Client Version 5.04beta
... and the latest full log:
--- Opening Log file [July 27 00:55:30]
# Windows Console Edition #####################################################
                       Folding@Home Client Version 5.04beta
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
Executable: FAH504-Console-6.exe
Arguments: -verbosity 7 -local -forceasm
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[00:55:30] - Ask before connecting: No
[00:55:30] - User name: ms.slamy (Team 120342)
[00:55:30] - User ID: 5EDE5A243DE72835
[00:55:30] - Machine ID: 1
[00:55:30]
[00:55:30] Loaded queue successfully.
[00:55:30] + Benchmarking ...
[00:55:32] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
--- Opening Log file [July 28 20:24:40]
Warning:
 use of the flag.
[20:24:40] - Ask before connecting: No
[20:24:40] - User name: ms.slamy (Team 120342)
[20:24:40] - User ID: 5EDE5A243DE72835
[20:24:40] - Machine ID: 1
[20:24:40]
[20:24:40] Loaded queue successfully.
[20:24:40] + Benchmarking ...
[20:24:43] The benchmark result is 5136
[20:24:43]
[20:24:43] + Processing work unit
[20:24:43] - Autosending finished units...
[20:24:43] Core required: FahCore_82.exe
[20:24:43] Trying to send all finished work units
[20:24:43] Core found.
[20:24:43] + No unsent completed units remaining.
[20:24:43] - Autosend completed
[20:24:43] Working on Unit 00 [July 28 20:24:43]
[20:24:43] + Working ...
[20:24:46]
[20:24:46] *------------------------------*
[20:24:46] Folding@Home PMD Core
[20:24:46] Version 1.03 (September 7, 2005)
[20:24:46]
[20:24:46] Preparing to commence simulation
[20:24:46] - Assembly optimizations manually forced on.
[20:24:46] - Not checking prior termination.
[20:24:46] - Expanded 93236 -> 599777 (decompressed 643.2 percent)
[20:24:46]
[20:24:46] Project: 2170 (Run 58, Clone 427, Gen 5)
[20:24:46]
[20:24:46] Assembly optimizations on if available.
[20:24:46] Entering M.D.
[20:27:50] Protein: p2170_lambda_obc_300K
[20:27:50]
[20:27:50] Completed 159550 out of 500000 steps  (31)
[20:31:13] Writing local files
[20:31:13] Completed 160000 out of 500000 steps  (32)
[20:35:51] Writing checkpoint files
[20:46:51] Writing checkpoint files
--- Opening Log file [July 28 20:57:36]
Warning:
 use of the flag.
[20:57:36] - Ask before connecting: No
[20:57:36] - User name: ms.slamy (Team 120342)
[20:57:36] - User ID: 5EDE5A243DE72835
[20:57:36] - Machine ID: 1
[20:57:36]
[20:57:36] Loaded queue successfully.
[20:57:36] + Benchmarking ...
[20:57:39] The benchmark result is 5136
[20:57:39]
[20:57:39] + Processing work unit
[20:57:39] - Autosending finished units...
[20:57:39] Core required: FahCore_82.exe
[20:57:39] Trying to send all finished work units
[20:57:39] + No unsent completed units remaining.
[20:57:39] Core found.
[20:57:39] - Autosend completed
[20:57:39] Working on Unit 00 [July 28 20:57:39]
[20:57:39] + Working ...
[20:57:42] ***** Got a SIGTERM signal (2)
--- Opening Log file [July 29 04:10:43]
Warning:
 use of the flag.
[04:10:43] - Ask before connecting: No
[04:10:43] - User name: ms.slamy (Team 120342)
[04:10:43] - User ID: 5EDE5A243DE72835
[04:10:43] - Machine ID: 1
[04:10:43]
[04:10:43] Loaded queue successfully.
[04:10:43] + Benchmarking ...
[04:10:46] The benchmark result is 5348
[04:10:46]
[04:10:46] + Processing work unit
[04:10:46] Core required: FahCore_82.exe
[04:10:46] - Autosending finished units...
[04:10:46] Core found.
[04:10:46] Trying to send all finished work units
[04:10:46] Working on Unit 00 [July 29 04:10:46]
[04:10:46] + Working ...
[04:10:46] + No unsent completed units remaining.
[04:10:46] - Autosend completed
[04:10:46] CoreStatus = 75 (117)
[04:11:13] Error opening or reading from a file.
[04:11:13] Deleting current work unit & continuing...
[04:11:17] Trying to send all finished work units
[04:11:17] + No unsent completed units remaining.
[04:11:17] - Preparing to get new work unit...
[04:11:17] + Attempting to get work packet
[04:11:17] - Will indicate memory of 894 MB
[04:11:17] - Connecting to assignment server
[04:11:17] Connecting to http://assign.stanford.edu:8080/
[04:11:18] - Successful: assigned to (171.65.103.160).
[04:11:18] + News From Folding@Home: Welcome to Folding@Home
[04:11:18] Loaded queue successfully.
[04:11:18] Connecting to http://171.65.103.160:8080/
[04:11:19] - Downloaded at ~91 kB/s
[04:11:19] - Averaged speed for that direction ~192 kB/s
[04:11:19] + Received work.
[04:11:19] + Closed connections
[04:11:24]
[04:11:24] + Processing work unit
[04:11:24] Core required: FahCore_82.exe
[04:11:24] Core found.
[04:11:24] Working on Unit 01 [July 29 04:11:24]
[04:11:24] + Working ...
[04:11:24]
[04:11:24] *------------------------------*
[04:11:24] Folding@Home PMD Core
[04:11:24] Version 1.03 (September 7, 2005)
[04:11:24]
[04:11:24] Preparing to commence simulation
[04:11:24] - Assembly optimizations manually forced on.
[04:11:24] - Not checking prior termination.
[04:11:24] - Expanded 93236 -> 599777 (decompressed 643.2 percent)
[04:11:24]
[04:11:24] Project: 2170 (Run 58, Clone 427, Gen 5)
[04:11:24]
[04:11:25] Assembly optimizations on if available.
[04:11:25] Entering M.D.
[04:12:08] Protein: p2170_lambda_obc_300K
[04:12:08]
[04:12:08] Completed 0 out of 500000 steps  (0)
[04:22:25] Writing checkpoint files
[04:33:32] Writing checkpoint files
[04:44:43] Writing checkpoint files
[04:55:44] Writing checkpoint files
[05:07:02] Writing checkpoint files
[05:18:04] Writing checkpoint files
[05:23:42] Writing local files
[05:23:42] Completed 5000 out of 500000 steps  (1)
[05:26:40] ***** Got a SIGTERM signal (2)
--- Opening Log file [August 4 19:52:26]
Warning:
 use of the flag.
[19:52:26] - Ask before connecting: No
[19:52:26] - User name: ms.slamy (Team 120342)
[19:52:26] - User ID: 5EDE5A243DE72835
[19:52:26] - Machine ID: 1
[19:52:26]
[19:52:27] Loaded queue successfully.
[19:52:27] + Benchmarking ...
[19:52:30] The benchmark result is 4992
[19:52:30]
[19:52:30] + Processing work unit
[19:52:30] - Autosending finished units...
[19:52:30] Core required: FahCore_82.exe
[19:52:30] Trying to send all finished work units
[19:52:30] Core found.
[19:52:30] + No unsent completed units remaining.
[19:52:30] - Autosend completed
[19:52:30] Working on Unit 01 [August 4 19:52:30]
[19:52:30] + Working ...
[19:52:34]
[19:52:34] *------------------------------*
[19:52:34] Folding@Home PMD Core
[19:52:34] Version 1.03 (September 7, 2005)
[19:52:34]
[19:52:34] Preparing to commence simulation
[19:52:34] - Assembly optimizations manually forced on.
[19:52:34] - Not checking prior termination.
[19:52:35] - Expanded 93236 -> 599777 (decompressed 643.2 percent)
[19:52:35]
[19:52:35] Project: 2170 (Run 58, Clone 427, Gen 5)
[19:52:35]
[19:52:35] Assembly optimizations on if available.
[19:52:35] Entering M.D.
[19:52:49] Protein: p2170_lambda_obc_300K
[19:52:49]
[19:52:50] Completed 4625 out of 500000 steps  (0)
[19:55:28] Writing local files
[19:55:28] Completed 5000 out of 500000 steps  (1)
[20:03:44] Writing checkpoint files
Note: the -forceasm flag has been added because for a while now, this client had seemed to slow down, apparently not using SSE! But it's been like this for the longest.
Trivolve
Hardware configuration: Core 2 Duo E6300@3.36Ghz/Scythe Ninja Plus
Asus Commando
2x2GB Corsair XMS2 DHX @ 960Mhz 5/5/5/18
Leadtek Nvidia 8800GTS 320mb @ 621/1438/999
2x250GB Seagate 7200.10 RAID 0
Samsung 931BF
Microsoft Wireless Desktop 3000
Re: 2170 (Run 58, Clone 427, Gen 5) - CoreStatus = 75 (117)
Post by Trivolve »
Try turning off -forceasm
Team 134888 - Team Trivolve.
I see a full credit for this WU in the DB.
Partial credit for thenoclist :
Hi ms.slamy (team 120342),
Your WU (P2170 R58 C427 G5) was added to the stats database on 2008-08-15 16:18:01 for 105.19 points of credit.
Repost of the same WU from thenoclist :
Your WU (P2170 R58 C427 G5) was added to the stats database on 2008-08-20 20:18:35 for 0 points of credit.
arfyness
Hardware configuration: 5 x WinXP (console version installed as service)
1 x Linux (manually, until I figure out what's wrong)
Asus nForce2 Mobo (A7N8X-E) w/ AMD AthlonXP 3200+ :: 1.0GB RAM :: Ubuntu Hardy 8.04.1
Post by arfyness »
Where is this database? Is it publicly accessible?
-- Nate
:: ./fah6 v6.02 :: Ubuntu Hardy 8.04.1 :: Asus A7N8X-E (nForce2) :: AMD AthlonXP 3200+ :: 1.0GB RAM :: 1 cpu ::
codysluder
Post by codysluder »
arfyness wrote:Where is this database? Is it publicly accessible?
-- Nate
No. Only the forum moderators have access to it. I'm not even sure the Pande Group uses it, although they probably have other methods of discovering the same things. The questions we ask are always about whether a WU got credit or not and the people doing the science are interested in whether the data got there or not, even if something bad happened in the crediting process. (Luckily, those two things are almost always equivalent.)
