General Error
Locked
MoneyGuyBK
General Error
Post by MoneyGuyBK »
For the last hour or so, every time I switch from thread to thread, I get this Error Message: :shock:
General Error
SQL ERROR [ mysql4 ]
Too many connections [1040]
An sql error occurred while fetching this page. Please contact an administrator if this problem persists.
I don't see but 2 people on the forum !!!
Very annoying indeed, Hope All is well? :roll: Happy Holidays.
Peace
T.E.A.M. “Together Everyone Accomplishes Miracles!”
OC, S. California ... God Bless All
Re: General Error
Maybe a global server issue if they don't use a dedicated server ;)
uncle_fungus
Re: General Error
Post by uncle_fungus »
Hmm, there's something a little wrong with the server. I got the same errors as you this morning, although I'm pretty sure it was because the host was restarting the database server, as I couldn't get to the databases from the host control panel either.
It maybe just my location, but the site seems to be running slower than usual at the moment too.
Re: General Error
It's still working fine here :)
Just a little question, not related to the issues here but important for performance : do you have gzip compression enabled :?:
uncle_fungus
Re: General Error
toTOW wrote:It's still working fine here :)
No since that increases server and client-side load, although it would decrease the bandwidth used, I'd prefer less load on the server.
Re: General Error
But it's transferring a lot of data for my traveller's poor 56k connection :(
codysluder
Re: General Error
Post by codysluder »
Can gzip be a user-configuration setting?
uncle_fungus
Re: General Error
No, it's site-wide.
v00d00
Hardware configuration: FX8320e (6 cores enabled) @ stock,
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Ran Seti@Home prior to that.
Re: General Error
Post by v00d00 »
Does phpbb3 have a print view mode that removes all icons and basically allows modem users to retain access without downloading masses of data. Basically a text only version of the forum.
That could be the way around the modem issue, but if it doesnt exist also increase UF's workload (which shouldnt happen).
Maybe there is a text mode theme for phpbb available, that would allow modem users to bypass downloading all the icons and other images on the site. That should also as a side effect cut down on data transfers and hopefully server loads.
Something like this maybe?
http://www.phpbb-design.com/phpBB2_styl ... eme/?s=362
or
http://www.andrewcharron.com/styles_demo/index.php?s=39
Locked
