Some help here appreciated,signature
Locked
a3ke
Post by a3ke »
Possibly just something stupid but I really cant get my foldinfstats into my signature here
tried 5 times different codes from different other boards to but nothing really works
TIA
Re: Some help here appreciated,signature
It my not work until you have posted a few more times, or have been on the forum a little longer. There are anti-spam tools here that prevent URLs from being posted when you first join. That may carry over in to the .sigs as well.
Someone else using a sig will probably come along shortly to answer...
Do not use html code ... use BBcode instead ...
The [] in your link ([UB]a3ke) might also confuse the BBcode parsing ... use html replacement codes instead (with % codes).
uncle_fungus
Post by uncle_fungus »
Sig fixed. The image wasn't working because you didn't have the right URL, combined with the fact that [ and ] are invalid literal characters in URLs.
I've converted the link and the image both to use your EOC userids, which are much simpler.
a3ke
Post by a3ke »
Ah thx verry much all , will try to contribute on the CPU/GPU folding scene as much as possible
Locked
