Tegra X1
chiro1879
Tegra X1
Post by chiro1879 »
I have checked the GPUs.txt log and tested on device, I am unable to fold on the Tegra X1 when it's selected
I understand if it's not possible for any major reason, but it would be nice to be able to, considering I can only use the CPU on it at the moment
Re: Tegra X1
The Tegra X1 is based on an ARM processor core. There are currently no F@h folding cores that can use GPUs connected to ARM based processors. I have no idea if that will change in the future, but have not heard of any development work in that direction. Currently all GPU processing needs either an Intel or AMD 64 bit x86 processor.
chiro1879
Re: Tegra X1
Post by chiro1879 »
Joe_H wrote: Sat May 16, 2026 6:46 am The Tegra X1 is based on an ARM processor core. There are currently no F@h folding cores that can use GPUs connected to ARM based processors. I have no idea if that will change in the future, but have not heard of any development work in that direction. Currently all GPU processing needs either an Intel or AMD 64 bit x86 processor.
ah okay, that sucks but ig makes sense
thank you, I did not know that, have a good day
Re: Tegra X1
Post by muziqaz »
And X1 is ancient, so even if we get ARM environment going, X1 will not going to be supported
FAH Omega tester
