Disabling beta GPU slot
DocJonz
Post by DocJonz »
Did a routine update this morning (Ubuntu 24.04 LTS) and now my GPUs have been disabled across all machines, indicating some beta GPU issue (which has never been set up on these clients);
*********************** Log Started 2026-04-16T08:15:55Z ***********************
08:15:55:******************************* libFAH ********************************
08:15:55:           Date: Oct 20 2020
08:15:55:           Time: 20:36:39
08:15:55:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
08:15:55:         Branch: master
08:15:55:       Compiler: GNU 8.3.0
08:15:55:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
08:15:55:                 -fdata-sections -O3 -funroll-loops -fno-pie
08:15:55:       Platform: linux2 5.8.0-1-amd64
08:15:55:           Bits: 64
08:15:55:           Mode: Release
08:15:55:****************************** FAHClient ******************************
08:15:55:        Version: 7.6.21
08:15:55:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:15:55:      Copyright: 2020 foldingathome.org
08:15:55:       Homepage: https://foldingathome.org/
08:15:55:           Time: 20:39:00
08:15:55:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
08:15:55:           Bits: 64
08:15:55:           Args: --child /etc/fahclient/config.xml --run-as fahclient
08:15:55:                 --pid-file=/var/run/fahclient.pid --daemon
08:15:55:         Config: /etc/fahclient/config.xml
08:15:55:******************************** CBang ********************************
08:15:55:           Time: 18:37:59
08:15:55:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
08:15:55:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
08:15:55:           Bits: 64
08:15:55:******************************* System ********************************
08:15:55:            CPU: Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz
08:15:55:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
08:15:55:           CPUs: 8
08:15:55:         Memory: 15.54GiB
08:15:55:    Free Memory: 12.92GiB
08:15:55:        Threads: POSIX_THREADS
08:15:55:     OS Version: 6.8
08:15:55:    Has Battery: false
08:15:55:     On Battery: false
08:15:55:     UTC Offset: 1
08:15:55:            PID: 3335
08:15:55:            CWD: /var/lib/fahclient
08:15:55:             OS: Linux 6.8.0-110-generic x86_64
08:15:55:        OS Arch: AMD64
08:15:55:           GPUs: 1
08:15:55:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
08:15:55:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.9 Driver:13.1
08:15:55:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:590.48
08:15:55:***********************************************************************
08:15:55:<config>
08:15:55:  <!-- Client Control -->
08:15:55:  <fold-anon v='true'/>
08:15:55:
08:15:55:  <!-- Folding Slot Configuration -->
08:15:55:  <gpu v='false'/>
08:15:55:
08:15:55:  <!-- HTTP Server -->
08:15:55:  <allow v='127.0.0.1,192.168.1.0/24'/>
08:15:55:
08:15:55:  <!-- Network -->
08:15:55:  <proxy v=':8080'/>
08:15:55:
08:15:55:  <!-- Remote Command Server -->
08:15:55:  <password v='*****'/>
08:15:55:
08:15:55:  <!-- Slot Control -->
08:15:55:  <power v='full'/>
08:15:55:
08:15:55:  <!-- User Information -->
08:15:55:  <passkey v='*****'/>
08:15:55:  <team v='35947'/>
08:15:55:  <user v='DocJonz'/>
08:15:55:
08:15:55:  <!-- Folding Slots -->
08:15:55:  <slot id='1' type='GPU'>
08:15:55:    <pci-bus v='1'/>
08:15:55:    <pci-slot v='0'/>
08:15:55:  </slot>
08:15:55:</config>
08:15:55:Trying to access database...
08:15:55:Successfully acquired database lock
08:15:55:WARNING:FS01:Disabling beta GPU slot 01: gpu:1:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
08:15:55:ERROR:No valid folding configuration
Has the GPUs.txt file been incorrectly changed?
Re: Disabling beta GPU slot
Post by muziqaz »
No changes to GPU.txt
I would advise updating your client to the latest version to avoid these type of issues
FAH Omega tester
