Project: 3062 (Run 3, Clone 138, Gen 33)
bollix47
Post by bollix47 »
FYI
17:24:20] Project: 3062 (Run 3, Clone 138, Gen 33)
[17:24:20]
[17:24:20] Assembly optimizations on if available.
[17:24:20] Entering M.D.
[17:24:37]  on if available.
[17:24:37] Entering M.D.
[17:24:43] 062_lambda5_99sb
[17:24:43] Writing local files
[17:24:43] Extra SSE boost OK.
[17:24:43] Completed 0 out of 5000000 steps  (0 percent)
[17:34:31] Writing local files
[17:34:31] Completed 50000 out of 5000000 steps  (1 percent)
[17:44:15] Writing local files
[17:44:15] Completed 100000 out of 5000000 steps  (2 percent)
[17:54:03] Writing local files
[17:54:03] Completed 150000 out of 5000000 steps  (3 percent)
[18:04:03] Writing local files
[18:04:03] Completed 200000 out of 5000000 steps  (4 percent)
[18:14:08] Writing local files
[18:14:08] Completed 250000 out of 5000000 steps  (5 percent)
[18:22:51] - Autosending finished units...
[18:22:51] Trying to send all finished work units
[18:22:51] + Attempting to send results
[18:22:51] - Reading file work/wuresults_03.dat from core
[18:22:51]   (Read 22070375 bytes from disk)
[18:22:51] Connecting to http://171.64.65.64:8080/
[18:22:51] - Couldn't send HTTP request to server
[18:22:51] + Could not connect to Work Server (results)
[18:22:51]     (171.64.65.64:8080)
[18:22:51] - Error: Could not transmit unit 03 (completed July 30) to work server.
[18:22:51] - 4 failed uploads of this unit.
[18:22:51] Connecting to http://171.64.122.86:8080/
[18:22:51]     (171.64.122.86:8080)
[18:22:51]   Could not transmit unit 03 to Collection server; keeping in queue.
[18:22:51] + Sent 0 of 1 completed units to the server
[18:22:51] - Autosend completed
[18:24:12] Writing local files
[18:24:12] Completed 300000 out of 5000000 steps  (6 percent)
[18:33:59] Writing local files
[18:33:59] Completed 350000 out of 5000000 steps  (7 percent)
[18:43:47] Writing local files
[18:43:47] Completed 400000 out of 5000000 steps  (8 percent)
[18:53:46] Writing local files
[18:53:46] Completed 450000 out of 5000000 steps  (9 percent)
[19:03:31] Writing local files
[19:03:31] Completed 500000 out of 5000000 steps  (10 percent)
[19:13:14] Writing local files
[19:13:14] Completed 550000 out of 5000000 steps  (11 percent)
[19:22:59] Writing local files
[19:22:59] Completed 600000 out of 5000000 steps  (12 percent)
[19:32:43] Writing local files
[19:32:43] Completed 650000 out of 5000000 steps  (13 percent)
[19:42:24] Writing local files
[19:42:24] Completed 700000 out of 5000000 steps  (14 percent)
[19:52:08] Writing local files
[19:52:08] Completed 750000 out of 5000000 steps  (15 percent)
[20:01:50] Writing local files
[20:01:50] Completed 800000 out of 5000000 steps  (16 percent)
[20:11:37] Writing local files
[20:11:38] Completed 850000 out of 5000000 steps  (17 percent)
[20:21:25] Writing local files
[20:21:25] Completed 900000 out of 5000000 steps  (18 percent)
[20:31:11] Writing local files
[20:31:11] Completed 950000 out of 5000000 steps  (19 percent)
[20:40:56] Writing local files
[20:40:56] Completed 1000000 out of 5000000 steps  (20 percent)
[20:50:42] Writing local files
[20:50:42] Completed 1050000 out of 5000000 steps  (21 percent)
[21:00:32] Writing local files
[21:00:32] Completed 1100000 out of 5000000 steps  (22 percent)
[21:10:18] Writing local files
[21:10:18] Completed 1150000 out of 5000000 steps  (23 percent)
[21:20:13] Writing local files
[21:20:13] Completed 1200000 out of 5000000 steps  (24 percent)
[21:29:57] Writing local files
[21:29:57] Completed 1250000 out of 5000000 steps  (25 percent)
[21:39:45] Writing local files
[21:39:45] Completed 1300000 out of 5000000 steps  (26 percent)
[21:49:38] Writing local files
[21:49:38] Completed 1350000 out of 5000000 steps  (27 percent)
[21:59:20] Writing local files
[21:59:20] Completed 1400000 out of 5000000 steps  (28 percent)
[22:09:21] Writing local files
[22:09:21] Completed 1450000 out of 5000000 steps  (29 percent)
[22:19:08] Writing local files
[22:19:08] Completed 1500000 out of 5000000 steps  (30 percent)
[22:28:56] Writing local files
[22:28:56] Completed 1550000 out of 5000000 steps  (31 percent)
[22:38:41] Writing local files
[22:38:41] Completed 1600000 out of 5000000 steps  (32 percent)
[22:48:24] Writing local files
[22:48:24] Completed 1650000 out of 5000000 steps  (33 percent)
[22:58:18] Writing local files
[22:58:18] Completed 1700000 out of 5000000 steps  (34 percent)
[23:08:10] Writing local files
[23:08:10] Completed 1750000 out of 5000000 steps  (35 percent)
[23:16:44] Warning:  long 1-4 interactions
[23:16:48] CoreStatus = 0 (0)
[23:16:48] Client-core communications error: ERROR 0x0
[23:16:48] Deleting current work unit & continuing...
[23:21:14] - Warning: Could not delete all work unit files (4): Core returned invalid code
[23:21:14] Trying to send all finished work units
Stopped at same frame twice then went on to a different WU.
Re: Project: 3062 (Run 3, Clone 138, Gen 33)
No record for that WU in the database ... it might be a bad one :(
