p18245, slow?
Breach
p18245, slow?
Post by Breach »
On p18245 I'm usually getting around 21 secs TPF. All of a sudden I have this WU (RCG 18215,2,0) that has a TPF of 1m 57s... GPU is barely loaded. Not sure what's going on.
Thanks.
Re: p18245, slow?
Post by muziqaz »
Your GPU might have popped into power saving mode
FAH Omega tester
Breach
Re: p18245, slow?
Post by Breach »
I don't think so. GPU boosts to max freq and hits VRel, GPU load is at max, it's just that the power usage stays super low... The previous WU was at 46,517,776 PPD, this one is at 2,754,802.
[Yeah, something wrong with that WU, picked up another one and all is as expected].
Re: p18245, slow?
Post by muziqaz »
Breach wrote: Fri Feb 13, 2026 11:38 pm I don't think so. GPU boosts to max freq and hits VRel, GPU load is at max, it's just that the power usage stays super low... The previous WU was at 46,517,776 PPD, this one is at 2,754,802.
Thanks
Asking questions now
FAH Omega tester
Breach
Re: p18245, slow?
Post by Breach »
Two more offenders (which I processed in 3 hours each, to the detriment of other better-behaving WUs ;-):
18205,2,1
18217,0,1
Lem
Re: p18245, slow?
Post by Lem »
The same is happening here with:
18273,2,0
18203,2,2
TPF from 60 to 135 sec.
Bye, Lem
Re: p18245, slow?
Post by muziqaz »
Hi, can you post the WU numbers which are folding fine. (18245 series only)
FAH Omega tester
Lem
Re: p18245, slow?
Post by Lem »
For me, fine wus have been (for instance):
2848,2,10
16186,2,9
The differences are in TPF (from 60 to 135 sec) and so in PPDs (from 9.5M to 2.8M) and in Watts (from 175-180 to 90). Interestingly enough my poor 5060ti performs on pair with a 5090 with the slow wus... :-)
Bye, Lem
Breach
Re: p18245, slow?
Post by Breach »
Here are a few WUs that are OK:
3339,2,10
11527,2,9
1512,2,10
9556,2,9
6360,2,9
3767,2,9
Re: p18245, slow?
Post by muziqaz »
Thanks, the offenders have been pulled. Let us know if you still receive some slow one of this series
FAH Omega tester
