Dual GPU doesn't work right
Buick350X
Hardware configuration: Processor AMD Ryzen 9 5950X
MB AsRock B550M Pro4
RAM HP V6 DDR4 3000mhz 32.0 GB
Zotac Gforce 5060 TI 16GB TwinEdge OC
Post by Buick350X »
5060ti 16GB & 4060TI 16GB, suddenly the 4060TI is doing tiny small mirco units like the CPU, not being utilized like it should at all or even close.
It was my main GPU 2 weeks ago, it did 5-7mill PPD per day, suddenly its 500-900K PPD per day like the GPU. 4060Ti had a TPF of 1min same as the 5060TI but now its 4-5min TPF like the CPU,
Older version worked so much better at dual GPU, fix it.
Re: Dual GPU doesn't work right
Your assumption is that you will always get the same type of WUs. There may not be any WUs like you were getting a couple weeks ago available to assign to your 4060Ti, so you might be getting WUs from available projects as opposed to getting nothing to work on.
Or your system could have had a video driver reset for some reason, that can include overheating. Prior experience some people have had was the GPU would operate at a reduced clock until the system it was in was rebooted and cycled the power to the GPU.
Albuquerquefx
Hardware configuration: AMD 9800X3D + 5090, Windows 11
AMD 5950X + 4070 Super, Docker + Ubuntu 22.04 LTS VM on Proxmox 9.1
AMD 5800XT + RTX Pro 6000 Blackwell Wkstn + 4090, Fedora 43 + Cuda MPS
Intel 3930K + 4070 Super + 3080Ti, Fedora 43
Post by Albuquerquefx »
I have two dual-GPU configs: an RTX 4090 paired up with an RTX Pro 6000 Blackwell Workstation, and a 3080Ti paired up with a 4070 Super.
The former crushes about 80MPPD and the latter produces about 20MPPD. These figures are well in line with their expected output, as all cards appear to be pulling their respective weights.
These are both Fedora 43 rigs with the NVIDIA blackbox 580 drivers.
