Resources not available
dhcernese
Post by dhcernese »
I built a nice PC in 2016 and have been running FAH client 7.4.4 since 2017 on and off. Mostly off in recent years. I restarted it late last year (I have a GTX 1070 SC). As usual, I rec'd CPU + GPU work units, no problem.
My 1070 died and I replaced it with a 1080 temporarily. I upgraded my PC to Windows 11 and then also upgraded to an NVIDIA RTX 5060 Ti.
I installed the latest FAH client 8.5.5 and ever since then, I only get CPU work units.. ..nothing for GPU.
Reading the welcome/troubleshooting topics I found this example
18:38:44:WU01:FS01:Assigned to work server 192.0.2.1
"This means that your system configuration is not supported by F@H. If in doubt, create a new thread with your log file for verification."
My log file has that message. I also says I might need to update drivers, but I had already done that multiple times.
I have reinstalled the FAH client.. ..and oddly on recent runs, the log.txt file is not written at all, so my next step is to reboot entirely.
My previous run log file extra has this:
22:44:53:Enabled folding slot 00: PAUSED cpu:2 (by user)
22:44:53:Enabled folding slot 01: PAUSED gpu:0:GB206 [GeForce RTX 5060 Ti] (by user)
22:44:53:ERROR:No compute devices matched GPU #0 NVIDIA:10 GB206 [GeForce RTX 5060 Ti].  You may need to update your graphics drivers.
02:59:03:FS00:Unpaused
02:59:03:FS01:Unpaused
02:59:04:WU00:FS01:Connecting to 13.59.134.176:8080
02:59:04:WU00:FS01:Assigned to work server 192.0.2.1
02:59:04:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GB206 [GeForce RTX 5060 Ti] from 192.0.2.1
02:59:04:WU00:FS01:Connecting to 192.0.2.1:8080
02:59:25:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
02:59:25:WU00:FS01:Connecting to 192.0.2.1:80
02:59:46:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:59:46:WU00:FS01:Connecting to 13.59.134.176:8080
02:59:47:WU00:FS01:Assigned to work server 192.0.2.1
02:59:47:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GB206 [GeForce RTX 5060 Ti] from 192.0.2.1
02:59:47:WU00:FS01:Connecting to 192.0.2.1:8080
03:00:04:Removing old file 'configs/config-20250516-131108.xml'
03:00:04:Saving configuration to config.xml
03:00:04:<config>
03:00:04:  <!-- Network -->
03:00:04:  <proxy v=':8080'/>
03:00:04:
03:00:04:  <!-- Slot Control -->
03:00:04:  <power v='full'/>
03:00:04:
03:00:04:  <!-- User Information -->
03:00:04:  <team v='170774'/>
03:00:04:  <user v='cernese'/>
03:00:04:
03:00:04:  <!-- Folding Slots -->
03:00:04:  <slot id='0' type='CPU'>
03:00:04:    <cpus v='2'/>
03:00:04:    <idle v='true'/>
03:00:04:  </slot>
03:00:04:  <slot id='1' type='GPU'/>
03:00:04:</config>
03:00:08:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:00:08:WU00:FS01:Connecting to 192.0.2.1:80
03:00:29:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:00:47:WU00:FS01:Connecting to 13.59.134.176:8080
03:00:47:WU00:FS01:Assigned to work server 192.0.2.1
03:00:47:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GB206 [GeForce RTX 5060 Ti] from 192.0.2.1
03:00:47:WU00:FS01:Connecting to 192.0.2.1:8080
03:01:08:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:01:08:WU00:FS01:Connecting to 192.0.2.1:80
03:01:29:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:02:24:WU00:FS01:Connecting to 13.59.134.176:8080
03:02:24:WU00:FS01:Assigned to work server 192.0.2.1
03:02:24:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GB206 [GeForce RTX 5060 Ti] from 192.0.2.1
03:02:24:WU00:FS01:Connecting to 192.0.2.1:8080
03:02:45:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:02:45:WU00:FS01:Connecting to 192.0.2.1:80
03:03:06:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:03:17:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
03:03:27:13:127.0.0.1:New Web connection
03:03:49:WU00:FS01:Connecting to 13.59.134.176:8080
03:03:49:WU00:FS01:Assigned to work server 192.0.2.1
03:03:49:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GB206 [GeForce RTX 5060 Ti] from 192.0.2.1
03:03:49:WU00:FS01:Connecting to 192.0.2.1:8080
03:03:49:WU01:FS00:Connecting to 13.59.134.176:8080
03:03:50:WU01:FS00:Assigned to work server 129.32.209.205
03:03:50:WU01:FS00:Requesting new work unit for slot 00: READY cpu:2 from 129.32.209.205
03:03:50:WU01:FS00:Connecting to 129.32.209.205:8080
03:03:50:WU01:FS00:Downloading 1.46MiB
03:03:50:WU01:FS00:Download complete
03:03:50:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16969 run:28 clone:899 gen:864 core:0xa8 unit:0x60030000830300001c00000049420000
03:03:50:WU01:FS00:Starting
03:03:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 705 -lifeline 3580 -checkpoint 15 -np 2
03:03:51:WU01:FS00:Started FahCore on PID 24960
03:03:51:WU01:FS00:Core PID:22716
03:03:51:WU01:FS00:FahCore 0xa8 started
https://imgur.com/0duHk56
I don't seem to understand how to post a screen shot (not much there, just the error).
dhcernese
Re: Resources not available
Post by dhcernese »
I don't understand. Reinstalled; rebooted. FAH client running. The log file is not getting written (dated a few days ago) and now not even CPU work units.
dhcernese
Post by dhcernese »
Improvement. I completely uninstalled. Installed fresh. This time, I had to enable the GPU! ...and it seems to be working. So lesson learned; can't upgrade from decade-old client ;-)
dhcernese
Post by dhcernese »
In the older client, I could say only use the CPUs when idle. It seems the new client the 'when idle' applies to both CPU and GPU?
Post by calxalot »
You can create resource groups to control cpu and gpu separately.
Please see the guide on the download page.
