Issue with uploading WUs
kwerboom
Post by kwerboom »
I can't seem to upload WUs or download a new WU.
*********************** Log Started 2026-01-15T05:32:39Z ***********************
05:32:39:I1:*********************** Folding@home Client ***********************
05:32:39:I1:    Version: 8.5.5
05:32:39:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:32:39:I1:        Org: foldingathome.org
05:32:39:I1:  Copyright: 2023-2025, foldingathome.org
05:32:39:I1:   Homepage: https://foldingathome.org/
05:32:39:I1:    License: GPL-3.0-or-later
05:32:39:I1:        URL: https://v8-5.foldingathome.org/
05:32:39:I1:       Date: Dec 1 2025
05:32:39:I1:       Time: 13:40:46
05:32:39:I1:   Revision: 2c6fbaa45e4ee4854195a9f0d4b86300975b6543
05:32:39:I1:     Branch: master
05:32:39:I1:   Compiler: Visual C++
05:32:39:I1:    Options: $( /TP $) /std:c++17 /nologo /EHa /wd4297 /wd4103 /O2
05:32:39:I1:             /Zc:throwingNew /MT
05:32:39:I1:   Platform: win32 10
05:32:39:I1:       Bits: 64
05:32:39:I1:       Mode: Release
05:32:39:I1:****************************** CBang ******************************
05:32:39:I1:    Version: 1.7.2
05:32:39:I1:        Org: Cauldron Development
05:32:39:I1:  Copyright: Cauldron Development, 2003-2025
05:32:39:I1:   Homepage: https://cauldrondevelopment.com/
05:32:39:I1:    License: LGPL-2.1-or-later
05:32:39:I1:       Date: Dec 3 2025
05:32:39:I1:       Time: 11:44:07
05:32:39:I1:   Revision: 83a4be55c1b21d5383650f51a7887fd9c25b836c
05:32:39:I1:***************************** System ******************************
05:32:39:I1:        CPU: AMD Ryzen 5 7600X 6-Core Processor
05:32:39:I1:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
05:32:39:I1:       CPUs: 12
05:32:39:I1:     Memory: 31.16GiB
05:32:39:I1:Free Memory: 18.58GiB
05:32:39:I1: OS Version: 6.2
05:32:39:I1:Has Battery: false
05:32:39:I1: On Battery: false
05:32:39:I1:   Hostname: DESKTOP-6608UU8
05:32:39:I1: UTC Offset: -6
05:32:39:I1:        PID: 37612
05:32:39:I1:        CWD: C:\ProgramData\FAHClient
05:32:39:I1:       Exec: C:\Program Files\FAHClient\FAHClient.exe
05:32:39:I1:*******************************************************************
05:32:39:I2:<config/>
05:32:39:I1:Opening Database
05:32:39:I1:F@H ID = 8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y
05:32:39:I3:Loading default resource group
05:32:39:I2:Listening for HTTP on 127.0.0.1:7396
05:32:39:I3:WU1524:Loading work unit 1524 with ID 8SmtH2Bf8wWLQwW9w0G2dpDuJFBmlLb5Jx9DQoLosPU
05:32:39:I3:Loaded 1 wus.
05:32:39:I2:Loading gpus.json
05:32:39:I1:Started Windows systray control
05:32:39:I3:gpus = {
05:32:39:I3:  "gpu:03:00:00": {
05:32:39:I3:    "vendor": 4098,
05:32:39:I3:    "type": "amd",
05:32:39:I3:    "description": "gfx1201",
05:32:39:I3:    "opencl": {"platform": 1, "device": 1, "compute": "2.0", "driver": "3652.0"},
05:32:39:I3:    "uuid": "30303030-3030-3033-3030-303030303030",
05:32:39:I3:    "hip": {"platform": 0, "device": 0, "compute": "12.0", "driver": "4515.38"},
05:32:39:I3:    "device": 30032,
05:32:39:I3:    "supported": true
05:32:39:I3:  },
05:32:39:I3:  "gpu:15:00:00": {
05:32:39:I3:    "description": "gfx1036",
05:32:39:I3:    "opencl": {"platform": 1, "device": 0, "compute": "2.0", "driver": "3652.0"},
05:32:39:I3:    "device": 5710,
05:32:39:I3:  }
05:32:39:I3:}
05:32:39:I2:OUT1:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
05:32:39:I2:OUT1:< HTTP/1.1 200 HTTP_OK
05:32:39:I2:OUT2:> GET /ws/client HTTP/1.1
05:32:40:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:32:40:I1:Logging into node account
05:32:44:I2:REQ3:< GET /api/websocket HTTP/1.1
05:32:46:I1:Machine state fold
05:32:47:I1:Loaded cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe
05:32:47:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe -dir 8SmtH2Bf8wWLQwW9w0G2dpDuJFBmlLb5Jx9DQoLosPU -suffix 01 -version 8.5.5 -lifeline 37612 -gpu-uuid 30303030-3030-3033-3030-303030303030 -gpu-platform opencl -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0 -hip-device 0 -gpu 1
05:32:47:I3:WU1524:Started FahCore on PID 16552
05:32:47:I1:WU1524:*********************** Log Started 2026-01-15T05:32:47Z ***********************
05:32:47:I1:WU1524:*************************** Core27 Folding@home Core ***************************
05:32:47:I1:WU1524:       Core: Core27
05:32:47:I1:WU1524:       Type: 0x27
05:32:47:I1:WU1524:    Version: 8.2.1
05:32:47:I1:WU1524:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:32:47:I1:WU1524:  Copyright: 2022 foldingathome.org
05:32:47:I1:WU1524:   Homepage: https://foldingathome.org/
05:32:47:I1:WU1524:       Date: Mar 27 2025
05:32:47:I1:WU1524:       Time: 04:46:58
05:32:47:I1:WU1524:   Revision: 84019442387121f2bed4ed52e05c53b7b7b52a72
05:32:47:I1:WU1524:     Branch: HEAD
05:32:47:I1:WU1524:   Compiler: Visual C++
05:32:47:I1:WU1524:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
05:32:47:I1:WU1524:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
05:32:47:I1:WU1524:   Platform: win32 10
05:32:47:I1:WU1524:       Bits: 64
05:32:47:I1:WU1524:       Mode: Release
05:32:47:I1:WU1524:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
05:32:47:I1:WU1524:             <peastman@stanford.edu>
05:32:47:I1:WU1524:       Args: -dir 8SmtH2Bf8wWLQwW9w0G2dpDuJFBmlLb5Jx9DQoLosPU -suffix 01
05:32:47:I1:WU1524:             -version 8.5.5 -lifeline 37612 -gpu-uuid
05:32:47:I1:WU1524:             30303030-3030-3033-3030-303030303030 -gpu-platform opencl
05:32:47:I1:WU1524:             -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0
05:32:47:I1:WU1524:             -hip-device 0 -gpu 1
05:32:47:I1:WU1524:************************************ libFAH ************************************
05:32:47:I1:WU1524:       Time: 04:30:44
05:32:47:I1:WU1524:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
05:32:47:I1:WU1524:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:32:47:I1:WU1524:************************************ CBang *************************************
05:32:47:I1:WU1524:    Version: 1.7.2
05:32:47:I1:WU1524:        Org: Cauldron Development LLC
05:32:47:I1:WU1524:  Copyright: Cauldron Development LLC, 2003-2024
05:32:47:I1:WU1524:   Homepage: https://cauldrondevelopment.com/
05:32:47:I1:WU1524:    License: LGPL-2.1-or-later
05:32:47:I1:WU1524:       Time: 04:29:12
05:32:47:I1:WU1524:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
05:32:47:I1:WU1524:************************************ System ************************************
05:32:47:I1:WU1524:        CPU: AMD Ryzen 5 7600X 6-Core Processor
05:32:47:I1:WU1524:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
05:32:47:I1:WU1524:       CPUs: 12
05:32:47:I1:WU1524:     Memory: 31.16GiB
05:32:47:I1:WU1524:Free Memory: 16.95GiB
05:32:47:I1:WU1524: OS Version: 10.0
05:32:47:I1:WU1524:Has Battery: false
05:32:47:I1:WU1524: On Battery: false
05:32:47:I1:WU1524:   Hostname: DESKTOP-6608UU8
05:32:47:I1:WU1524: UTC Offset: -6
05:32:47:I1:WU1524:        PID: 16552
05:32:47:I1:WU1524:        CWD: C:\ProgramData\FAHClient\work
05:32:47:I1:WU1524:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
05:32:47:I1:WU1524:************************************ OpenMM ************************************
05:32:47:I1:WU1524:    Version: 8.2.0
05:32:47:I1:WU1524:********************************************************************************
05:32:47:I1:WU1524:Project: 18263 (Run 223, Clone 9, Gen 93)
05:32:47:I1:WU1524:Digital signatures verified
05:32:47:I1:WU1524:Folding@home GPU Core27 Folding@home Core
05:32:47:I1:WU1524:Version 8.2.1
05:32:47:I1:WU1524:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
05:32:47:I1:WU1524:  GPU info: PlatformIndex: 0
05:32:47:I1:WU1524:  GPU info: Device: gfx1201
05:32:47:I1:WU1524:  GPU info: DeviceIndex: 0
05:32:47:I1:WU1524:  GPU info: Vendor: 0x1002
05:32:47:I1:WU1524:  GPU info: PCI: 03:00:00
05:32:47:I1:WU1524:  GPU info: Compute: 2.0
05:32:47:I1:WU1524:  GPU info: Driver: 3661.0
05:32:47:I1:WU1524:  GPU info: GPU: true
05:32:47:I1:WU1524:  GPU info: PlatformIndex: 1
05:32:47:I1:WU1524:  GPU info: Device: gfx1036
05:32:47:I1:WU1524:  GPU info: PCI: 15:00:00
05:32:47:I1:WU1524:  GPU info: Driver: 3652.0
05:32:47:I1:WU1524:  GPU info: DeviceIndex: 1
05:32:47:I1:WU1524:  Checkpoint write interval: 25000 steps (2%) [50 total]
05:32:47:I1:WU1524:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
05:32:47:I1:WU1524:  XTC frame write interval: 5000 steps (0.4%) [250 total]
05:32:47:I1:WU1524:  TRR frame write interval: disabled
05:32:47:I1:WU1524:  Global context and integrator variables write interval: disabled
05:32:47:I1:WU1524:There are 3 platforms available.
05:32:47:I1:WU1524:Platform 0: Reference
05:32:47:I1:WU1524:Platform 1: CPU
05:32:47:I1:WU1524:Platform 2: OpenCL
05:32:47:I1:WU1524:  opencl-device 1 specified
05:34:10:I1:WU1524:Attempting to create OpenCL context:
05:34:10:I1:WU1524:  Configuring platform OpenCL
05:34:30:I1:WU1524:  Using OpenCL on OpenCL platformId 1 and gpu 1
05:34:30:I1:WU1524:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
05:34:30:I1:WU1524:  GPU info: PlatformIndex: 1
05:34:30:I1:WU1524:  GPU info: Device: gfx1036
05:34:30:I1:WU1524:  GPU info: DeviceIndex: 0
05:34:30:I1:WU1524:  GPU info: Vendor: 0x1002
05:34:30:I1:WU1524:  GPU info: PCI: 15:00:00
05:34:30:I1:WU1524:  GPU info: Compute: 2.0
05:34:30:I1:WU1524:  GPU info: Driver: 3652.0
05:34:30:I1:WU1524:  GPU info: GPU: true
07:49:43:I2:REQ63:< GET /api/websocket HTTP/1.1
07:50:12:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
07:50:16:I2:OUT64:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
07:50:24:I1:WU1526:Completed 150000 out of 250000 steps (60%)
07:50:25:I2:OUT64:< HTTP/1.1 200 HTTP_OK
07:50:30:I2:OUT2:> GET /ws/client HTTP/1.1
07:50:32:I1:WU1526:Checkpoint completed at step 150000
07:50:35:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
07:50:35:I1:Logging into node account
07:51:42:I1:WU1526:Completed 152500 out of 250000 steps (61%)
07:52:18:E :OUT62:Failed response: EOF
07:52:18:I1:WU1524:Uploading WU results
07:52:19:I2:OUT65:> POST /api/results HTTP/1.1
07:52:29:I1:WU1524:UPLOAD 1% 1.12MiB of 99.76MiB
07:52:36:I1:WU1524:UPLOAD 2% 1.99MiB of 99.76MiB
07:52:46:I1:WU1524:UPLOAD 3% 3.01MiB of 99.76MiB
07:52:51:I1:WU1526:Completed 155000 out of 250000 steps (62%)
07:52:51:I1:WU1524:UPLOAD 4% 4.01MiB of 99.76MiB
07:53:01:I1:WU1524:UPLOAD 5% 4.94MiB of 99.76MiB
07:53:13:I1:WU1524:UPLOAD 6% 5.94MiB of 99.76MiB
07:53:23:I1:WU1524:UPLOAD 7% 7.00MiB of 99.76MiB
07:53:59:I1:WU1526:Completed 157500 out of 250000 steps (63%)
07:55:07:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
07:55:08:I1:WU1526:Completed 160000 out of 250000 steps (64%)
07:55:08:I2:OUT66:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
07:55:08:I2:OUT66:< HTTP/1.1 200 HTTP_OK
07:55:08:I2:OUT2:> GET /ws/client HTTP/1.1
07:55:09:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
07:55:09:I1:Logging into node account
07:56:17:I1:WU1526:Completed 162500 out of 250000 steps (65%)
07:56:24:I1:WU1526:Checkpoint completed at step 162500
07:57:33:E :OUT65:Failed response: EOF
07:57:33:I1:WU1524:Uploading WU results
07:57:33:I2:OUT67:> POST /api/results HTTP/1.1
07:57:34:I1:WU1526:Completed 165000 out of 250000 steps (66%)
07:58:08:I1:WU1524:UPLOAD 1% 1.03MiB of 99.76MiB
07:58:16:I1:WU1524:UPLOAD 2% 2.25MiB of 99.76MiB
07:58:23:I1:WU1524:UPLOAD 3% 2.97MiB of 99.76MiB
07:58:29:I1:WU1524:UPLOAD 4% 4.00MiB of 99.76MiB
07:58:38:I1:WU1524:UPLOAD 5% 4.96MiB of 99.76MiB
07:58:44:I1:WU1526:Completed 167500 out of 250000 steps (67%)
07:58:48:I1:WU1524:UPLOAD 6% 6.03MiB of 99.76MiB
07:59:00:I1:WU1524:UPLOAD 7% 7.15MiB of 99.76MiB
07:59:53:I1:WU1526:Completed 170000 out of 250000 steps (68%)
08:01:03:I1:WU1526:Completed 172500 out of 250000 steps (69%)
08:01:21:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:01:21:I2:OUT68:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:01:21:I2:OUT68:< HTTP/1.1 200 HTTP_OK
08:01:22:I2:OUT2:> GET /ws/client HTTP/1.1
08:01:22:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:01:22:I1:Logging into node account
08:02:12:I1:WU1526:Completed 175000 out of 250000 steps (70%)
08:02:19:I1:WU1526:Checkpoint completed at step 175000
08:02:55:E :OUT67:Failed response: EOF
08:02:55:I1:WU1524:Uploading WU results
08:02:55:I2:OUT69:> POST /api/results HTTP/1.1
08:03:03:I1:WU1524:UPLOAD 1% 978.38KiB of 99.76MiB
08:03:13:I1:WU1524:UPLOAD 2% 2.19MiB of 99.76MiB
08:03:22:I1:WU1524:UPLOAD 3% 3.04MiB of 99.76MiB
08:03:26:I1:WU1524:UPLOAD 4% 3.97MiB of 99.76MiB
08:03:28:I1:WU1526:Completed 177500 out of 250000 steps (71%)
08:03:35:I1:WU1524:UPLOAD 5% 4.95MiB of 99.76MiB
08:03:50:I1:WU1524:UPLOAD 6% 6.23MiB of 99.76MiB
08:03:56:I1:WU1524:UPLOAD 7% 6.97MiB of 99.76MiB
08:04:37:I1:WU1526:Completed 180000 out of 250000 steps (72%)
08:05:33:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:05:34:I2:OUT70:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:05:35:I2:OUT70:< HTTP/1.1 200 HTTP_OK
08:05:35:I2:OUT2:> GET /ws/client HTTP/1.1
08:05:36:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:05:36:I1:Logging into node account
08:05:46:I1:WU1526:Completed 182500 out of 250000 steps (73%)
08:06:54:I1:WU1526:Completed 185000 out of 250000 steps (74%)
08:07:56:E :OUT69:Failed response: EOF
08:07:56:I1:WU1524:Uploading WU results
08:07:57:I2:OUT71:> POST /api/results HTTP/1.1
08:08:03:I1:WU1526:Completed 187500 out of 250000 steps (75%)
08:08:06:I1:WU1524:UPLOAD 1% 1.03MiB of 99.76MiB
08:08:10:I1:WU1526:Checkpoint completed at step 187500
08:08:12:I1:WU1524:UPLOAD 2% 2.04MiB of 99.76MiB
08:08:22:I1:WU1524:UPLOAD 3% 3.01MiB of 99.76MiB
08:08:27:I1:WU1524:UPLOAD 4% 4.03MiB of 99.76MiB
08:08:36:I1:WU1524:UPLOAD 5% 4.99MiB of 99.76MiB
08:08:46:I1:WU1524:UPLOAD 6% 5.96MiB of 99.76MiB
08:09:02:I1:WU1524:UPLOAD 7% 7.41MiB of 99.76MiB
08:09:07:I1:WU1524:UPLOAD 8% 7.95MiB of 99.76MiB
08:09:20:I1:WU1526:Completed 190000 out of 250000 steps (76%)
08:10:29:I1:WU1526:Completed 192500 out of 250000 steps (77%)
08:11:05:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:11:05:I2:OUT72:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:11:06:I2:OUT72:< HTTP/1.1 200 HTTP_OK
08:11:06:I2:OUT2:> GET /ws/client HTTP/1.1
08:11:06:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:11:06:I1:Logging into node account
08:11:39:I1:WU1526:Completed 195000 out of 250000 steps (78%)
08:12:48:I1:WU1526:Completed 197500 out of 250000 steps (79%)
08:13:33:E :OUT71:Failed response: EOF
08:13:33:I1:WU1524:Uploading WU results
08:13:34:I2:OUT73:> POST /api/results HTTP/1.1
08:13:43:I1:WU1524:UPLOAD 1% 1.03MiB of 99.76MiB
08:13:50:I1:WU1524:UPLOAD 2% 2.14MiB of 99.76MiB
08:13:58:I1:WU1524:UPLOAD 3% 3.00MiB of 99.76MiB
08:13:59:I1:WU1526:Completed 200000 out of 250000 steps (80%)
08:14:03:I1:WU1524:UPLOAD 4% 4.04MiB of 99.76MiB
08:14:05:I1:WU1526:Checkpoint completed at step 200000
08:14:18:I1:WU1524:UPLOAD 5% 5.06MiB of 99.76MiB
08:14:23:I1:WU1524:UPLOAD 6% 6.04MiB of 99.76MiB
08:14:37:I1:WU1524:UPLOAD 7% 6.95MiB of 99.76MiB
08:14:43:I1:WU1524:UPLOAD 8% 7.97MiB of 99.76MiB
08:15:14:I1:WU1526:Completed 202500 out of 250000 steps (81%)
08:16:22:I1:WU1526:Completed 205000 out of 250000 steps (82%)
08:16:44:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:16:44:I2:OUT74:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:16:44:I2:OUT74:< HTTP/1.1 200 HTTP_OK
08:16:45:I2:OUT2:> GET /ws/client HTTP/1.1
08:16:45:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:16:45:I1:Logging into node account
08:17:31:I1:WU1526:Completed 207500 out of 250000 steps (83%)
08:18:15:E :OUT73:Failed response: EOF
08:18:15:I1:WU1524:Uploading WU results
08:18:15:I2:OUT75:> POST /api/results HTTP/1.1
08:18:25:I1:WU1524:UPLOAD 1% 1.04MiB of 99.76MiB
08:18:32:I1:WU1524:UPLOAD 2% 2.18MiB of 99.76MiB
08:18:40:I1:WU1524:UPLOAD 3% 3.04MiB of 99.76MiB
08:18:40:I1:WU1526:Completed 210000 out of 250000 steps (84%)
08:18:44:I1:WU1524:UPLOAD 4% 3.97MiB of 99.76MiB
08:18:53:I1:WU1524:UPLOAD 5% 4.95MiB of 99.76MiB
08:19:12:I1:WU1524:UPLOAD 7% 6.68MiB of 99.76MiB
08:19:16:I1:WU1524:UPLOAD 7% 7.04MiB of 99.76MiB
08:19:29:I1:WU1524:UPLOAD 8% 8.26MiB of 99.76MiB
08:19:50:I1:WU1526:Completed 212500 out of 250000 steps (85%)
08:19:56:I1:WU1526:Checkpoint completed at step 212500
08:21:06:I1:WU1526:Completed 215000 out of 250000 steps (86%)
08:21:11:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:21:14:I2:OUT76:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:21:25:I2:OUT76:< HTTP/1.1 200 HTTP_OK
08:21:27:I2:OUT2:> GET /ws/client HTTP/1.1
08:21:29:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:21:29:I1:Logging into node account
08:22:14:I1:WU1526:Completed 217500 out of 250000 steps (87%)
08:22:40:E :OUT75:Failed response: EOF
08:22:40:I1:WU1524:Uploading WU results
08:22:41:I2:OUT77:> POST /api/results HTTP/1.1
08:22:51:I1:WU1524:UPLOAD 1% 1.03MiB of 99.76MiB
08:22:58:I1:WU1524:UPLOAD 2% 2.10MiB of 99.76MiB
08:23:07:I1:WU1524:UPLOAD 3% 2.95MiB of 99.76MiB
08:23:12:I1:WU1524:UPLOAD 4% 4.01MiB of 99.76MiB
08:23:21:I1:WU1524:UPLOAD 5% 4.94MiB of 99.76MiB
08:23:24:I1:WU1526:Completed 220000 out of 250000 steps (88%)
08:23:33:I1:WU1524:UPLOAD 6% 6.12MiB of 99.76MiB
08:23:42:I1:WU1524:UPLOAD 7% 6.96MiB of 99.76MiB
08:24:34:I1:WU1526:Completed 222500 out of 250000 steps (89%)
08:25:37:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:25:37:I2:OUT78:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:25:38:I2:OUT78:< HTTP/1.1 200 HTTP_OK
08:25:38:I2:OUT2:> GET /ws/client HTTP/1.1
08:25:38:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:25:38:I1:Logging into node account
08:25:42:I1:WU1526:Completed 225000 out of 250000 steps (90%)
08:25:49:I1:WU1526:Checkpoint completed at step 225000
08:26:57:I1:WU1526:Completed 227500 out of 250000 steps (91%)
08:28:03:E :OUT77:Failed response: EOF
08:28:03:I1:WU1524:Uploading WU results
08:28:05:I2:OUT79:> POST /api/results HTTP/1.1
08:28:05:I1:WU1526:Completed 230000 out of 250000 steps (92%)
08:29:08:I1:WU1524:UPLOAD 1% 1.00MiB of 99.76MiB
08:29:13:I1:WU1526:Completed 232500 out of 250000 steps (93%)
08:29:15:I1:WU1524:UPLOAD 2% 2.00MiB of 99.76MiB
08:29:24:I1:WU1524:UPLOAD 3% 3.36MiB of 99.76MiB
08:29:30:I1:WU1524:UPLOAD 4% 3.99MiB of 99.76MiB
08:29:40:I1:WU1524:UPLOAD 5% 5.03MiB of 99.76MiB
08:29:58:I1:WU1524:UPLOAD 7% 6.69MiB of 99.76MiB
08:30:01:I1:WU1524:UPLOAD 7% 7.03MiB of 99.76MiB
08:30:21:I1:WU1526:Completed 235000 out of 250000 steps (94%)
08:31:29:I1:WU1526:Completed 237500 out of 250000 steps (95%)
08:31:38:I1:WU1526:Checkpoint completed at step 237500
08:31:59:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:31:59:I2:OUT80:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:32:00:I2:OUT80:< HTTP/1.1 200 HTTP_OK
08:32:00:I2:OUT2:> GET /ws/client HTTP/1.1
08:32:00:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:32:00:I1:Logging into node account
08:32:46:I1:WU1526:Completed 240000 out of 250000 steps (96%)
08:33:54:I1:WU1526:Completed 242500 out of 250000 steps (97%)
08:34:12:E :OUT79:Failed response: EOF
08:34:12:I1:WU1524:Uploading WU results
08:34:14:I2:OUT81:> POST /api/results HTTP/1.1
08:34:23:I1:WU1524:UPLOAD 1% 1.03MiB of 99.76MiB
08:34:30:I1:WU1524:UPLOAD 2% 2.16MiB of 99.76MiB
08:34:39:I1:WU1524:UPLOAD 3% 3.01MiB of 99.76MiB
08:34:43:I1:WU1524:UPLOAD 4% 3.95MiB of 99.76MiB
08:34:53:I1:WU1524:UPLOAD 5% 5.03MiB of 99.76MiB
08:35:02:I1:WU1526:Completed 245000 out of 250000 steps (98%)
08:35:02:I1:WU1524:UPLOAD 6% 6.00MiB of 99.76MiB
08:35:12:I1:WU1524:UPLOAD 7% 6.98MiB of 99.76MiB
08:35:27:I1:WU1524:UPLOAD 8% 8.33MiB of 99.76MiB
08:36:11:I1:WU1526:Completed 247500 out of 250000 steps (99%)
08:37:20:I1:WU1526:Completed 250000 out of 250000 steps (100%)
08:37:20:I1:WU1526:Average performance: 12.6686 ns/day
08:37:26:I1:WU1526:Checkpoint completed at step 250000
08:37:32:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:37:32:I2:OUT82:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:37:33:I2:OUT82:< HTTP/1.1 200 HTTP_OK
08:37:33:I2:OUT2:> GET /ws/client HTTP/1.1
08:37:33:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:37:33:I1:Logging into node account
08:37:52:I1:WU1526:Saving result file ..\logfile_01.txt
08:37:52:I1:WU1526:Saving result file checkpointIntegrator.xml
08:37:52:I1:WU1526:Saving result file checkpointState.xml.bz2
08:37:52:I1:WU1526:Saving result file positions.xtc
08:37:52:I1:WU1526:Saving result file science.log
08:37:52:I1:WU1526:Saving result file xtcAtoms.csv.bz2
08:37:52:I1:WU1526:Folding@home Core Shutdown: FINISHED_UNIT
08:37:55:I1:WU1526:Core returned FINISHED_UNIT (100)
08:37:56:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
08:37:56:I1:WU1526:Uploading WU results
08:37:56:I1:WU1527:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
08:37:56:I2:OUT83:> POST /api/results HTTP/1.1
08:37:56:I2:OUT84:> POST /api/assign HTTP/1.1
08:37:56:I2:OUT84:< HTTP/1.1 200 HTTP_OK
08:37:56:I1:WU1527:Received WU assignment oVhAHxnJwXCBNGmnFsxWHRtRqXzMEzkdXa8zUeWnnuY
08:37:56:I1:WU1527:Downloading WU
08:37:57:I2:OUT85:> POST /api/assign HTTP/1.1
08:38:02:I1:WU1527:DOWNLOAD 100% 221B of 221B
08:38:04:I1:WU1527:DOWNLOAD 2% 3.17MiB of 138.05MiB
08:38:07:E :OUT81:Failed response: EOF
08:38:07:I1:WU1524:Uploading WU results
08:38:09:I1:WU1526:UPLOAD 1% 819.32KiB of 77.13MiB
08:38:10:I2:OUT86:> POST /api/results HTTP/1.1
08:38:12:I1:WU1527:DOWNLOAD 3% 4.13MiB of 138.05MiB
08:38:17:I1:WU1526:UPLOAD 2% 1.55MiB of 77.13MiB
08:38:23:I1:WU1526:UPLOAD 3% 2.36MiB of 77.13MiB
08:38:32:I1:WU1526:UPLOAD 5% 3.62MiB of 77.13MiB
08:38:35:I1:WU1526:UPLOAD 5% 3.91MiB of 77.13MiB
08:38:39:I1:WU1527:DOWNLOAD 4% 5.53MiB of 138.05MiB
08:38:51:I1:WU1526:UPLOAD 7% 5.41MiB of 77.13MiB
08:39:00:I1:WU1526:UPLOAD 8% 6.18MiB of 77.13MiB
08:39:30:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:39:45:W :CON87:DNS lookup failed for api.foldingathome.org
08:39:45:E :OUT87:Failed response: CONNECT
08:40:15:W :CON88:DNS lookup failed for api.foldingathome.org
08:40:15:E :OUT88:Failed response: CONNECT
08:40:37:I2:OUT89:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:40:37:I2:OUT89:< HTTP/1.1 200 HTTP_OK
08:40:37:I2:OUT2:> GET /ws/client HTTP/1.1
08:40:37:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:40:37:I1:Logging into node account
08:43:04:E :OUT83:Failed response: EOF
08:43:04:I1:WU1526:Uploading WU results
08:43:05:I2:OUT90:> POST /api/results HTTP/1.1
08:43:10:I1:WU1526:UPLOAD 1% 811.36KiB of 77.13MiB
08:43:17:I1:WU1526:UPLOAD 2% 1.55MiB of 77.13MiB
08:43:19:E :OUT86:Failed response: EOF
08:43:19:I1:WU1524:Uploading WU results
08:43:22:I1:WU1526:UPLOAD 3% 2.33MiB of 77.13MiB
08:43:28:I2:OUT91:> POST /api/results HTTP/1.1
08:43:29:I1:WU1526:UPLOAD 5% 3.60MiB of 77.13MiB
08:43:33:I1:WU1526:UPLOAD 5% 3.92MiB of 77.13MiB
08:43:40:I1:WU1526:UPLOAD 6% 4.68MiB of 77.13MiB
08:43:47:I1:WU1526:UPLOAD 7% 5.44MiB of 77.13MiB
08:43:54:I1:WU1526:UPLOAD 8% 6.21MiB of 77.13MiB
08:44:02:I1:WU1526:UPLOAD 9% 6.95MiB of 77.13MiB
08:44:06:E :OUT85:Failed response: EOF
08:44:06:I1:WU1527:Retry #1 in 2 secs
08:44:08:I1:WU1527:Downloading WU
08:44:09:I1:WU1526:UPLOAD 10% 7.70MiB of 77.13MiB
08:44:29:I2:OUT92:> POST /api/assign HTTP/1.1
08:44:29:E :OUT92:Failed response: EOF
08:44:29:I1:WU1527:Retry #2 in 4 secs
08:44:32:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:44:33:I1:WU1527:Downloading WU
08:44:47:W :CON93:DNS lookup failed for api.foldingathome.org
08:44:47:E :OUT93:Failed response: CONNECT
08:44:54:I2:OUT94:> POST /api/assign HTTP/1.1
08:44:54:E :OUT94:Failed response: EOF
08:44:54:I1:WU1527:Retry #3 in 8 secs
08:45:02:I1:WU1527:Downloading WU
08:45:17:W :CON95:DNS lookup failed for api.foldingathome.org
08:45:17:E :OUT95:Failed response: CONNECT
08:45:23:I2:OUT96:> POST /api/assign HTTP/1.1
08:45:23:E :OUT96:Failed response: EOF
08:45:23:I1:WU1527:Retry #4 in 16 secs
08:45:39:I1:WU1527:Downloading WU
08:45:39:I2:OUT97:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:45:39:I2:OUT98:> POST /api/assign HTTP/1.1
08:45:39:I1:WU1527:DOWNLOAD 100% 233B of 233B
08:45:39:I2:OUT98:< HTTP/1.1 500 HTTP_INTERNAL_SERVER_ERROR
08:45:39:E :OUT98:HTTP_INTERNAL_SERVER_ERROR: {"error":{"message":"Can't dereference NULL pointer!"}}
08:45:39:I2:OUT97:< HTTP/1.1 200 HTTP_OK
08:45:40:I2:OUT2:> GET /ws/client HTTP/1.1
08:45:40:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:45:40:I1:Logging into node account
08:45:43:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
08:45:43:I1:WU1528:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
08:45:43:I2:OUT99:> POST /api/assign HTTP/1.1
08:45:43:I2:OUT99:< HTTP/1.1 200 HTTP_OK
08:45:43:I1:WU1528:Received WU assignment b222jmT5OmAzwfPRLK1UKRgxV11uMPB1L2NUpbVx9Gg
08:45:43:I1:WU1528:Downloading WU
08:45:43:I2:OUT100:> POST /api/assign HTTP/1.1
08:45:53:I1:WU1528:DOWNLOAD 100% 221B of 221B
08:45:55:I1:WU1528:DOWNLOAD 2% 2.54MiB of 122.77MiB
08:45:56:I1:WU1528:DOWNLOAD 3% 3.88MiB of 122.77MiB
08:45:57:I1:WU1528:DOWNLOAD 5% 5.62MiB of 122.77MiB
08:45:58:I1:WU1528:DOWNLOAD 6% 7.52MiB of 122.77MiB
08:45:59:I1:WU1528:DOWNLOAD 8% 9.45MiB of 122.77MiB
08:46:00:I1:WU1528:DOWNLOAD 9% 11.29MiB of 122.77MiB
08:46:03:I1:WU1528:DOWNLOAD 11% 14.05MiB of 122.77MiB
08:46:04:I1:WU1528:DOWNLOAD 13% 15.98MiB of 122.77MiB
08:46:05:I1:WU1528:DOWNLOAD 15% 17.91MiB of 122.77MiB
08:46:06:I1:WU1528:DOWNLOAD 16% 19.77MiB of 122.77MiB
08:46:07:I1:WU1528:DOWNLOAD 18% 21.71MiB of 122.77MiB
08:46:08:I1:WU1528:DOWNLOAD 19% 23.47MiB of 122.77MiB
08:46:09:I1:WU1528:DOWNLOAD 20% 25.00MiB of 122.77MiB
08:46:10:I1:WU1528:DOWNLOAD 22% 26.66MiB of 122.77MiB
08:46:11:I1:WU1528:DOWNLOAD 23% 28.44MiB of 122.77MiB
08:46:12:I1:WU1528:DOWNLOAD 25% 30.34MiB of 122.77MiB
08:46:13:I1:WU1528:DOWNLOAD 26% 32.26MiB of 122.77MiB
08:46:14:I1:WU1528:DOWNLOAD 28% 34.17MiB of 122.77MiB
08:46:15:I1:WU1528:DOWNLOAD 29% 35.76MiB of 122.77MiB
08:46:16:I1:WU1528:DOWNLOAD 31% 37.65MiB of 122.77MiB
08:46:17:I1:WU1528:DOWNLOAD 32% 39.59MiB of 122.77MiB
08:46:18:I1:WU1528:DOWNLOAD 34% 41.39MiB of 122.77MiB
08:46:19:I1:WU1528:DOWNLOAD 35% 42.93MiB of 122.77MiB
08:46:20:I1:WU1528:DOWNLOAD 36% 44.49MiB of 122.77MiB
08:46:21:I1:WU1528:DOWNLOAD 38% 46.13MiB of 122.77MiB
08:46:22:I1:WU1528:DOWNLOAD 39% 47.63MiB of 122.77MiB
08:46:23:I1:WU1528:DOWNLOAD 40% 49.24MiB of 122.77MiB
08:46:24:I1:WU1528:DOWNLOAD 41% 50.71MiB of 122.77MiB
08:46:25:I1:WU1528:DOWNLOAD 43% 52.25MiB of 122.77MiB
08:46:26:I1:WU1528:DOWNLOAD 44% 54.09MiB of 122.77MiB
08:46:27:I1:WU1528:DOWNLOAD 46% 55.99MiB of 122.77MiB
08:46:28:I1:WU1528:DOWNLOAD 47% 57.92MiB of 122.77MiB
08:46:29:I1:WU1528:DOWNLOAD 49% 59.86MiB of 122.77MiB
08:46:30:I1:WU1528:DOWNLOAD 50% 61.64MiB of 122.77MiB
08:46:31:I1:WU1528:DOWNLOAD 52% 63.35MiB of 122.77MiB
08:46:32:I1:WU1528:DOWNLOAD 53% 65.11MiB of 122.77MiB
08:46:33:I1:WU1528:DOWNLOAD 54% 66.73MiB of 122.77MiB
08:46:34:I1:WU1528:DOWNLOAD 56% 68.66MiB of 122.77MiB
08:46:35:I1:WU1528:DOWNLOAD 57% 70.59MiB of 122.77MiB
08:46:36:I1:WU1528:DOWNLOAD 59% 72.53MiB of 122.77MiB
08:46:37:I1:WU1528:DOWNLOAD 61% 74.41MiB of 122.77MiB
08:46:38:I1:WU1528:DOWNLOAD 62% 76.35MiB of 122.77MiB
08:46:38:E :OUT91:Failed response: EOF
08:46:38:I1:WU1524:Uploading WU results
08:46:39:I2:OUT101:> POST /api/results HTTP/1.1
08:46:39:I1:WU1528:DOWNLOAD 63% 77.85MiB of 122.77MiB
08:46:40:I1:WU1528:DOWNLOAD 64% 78.62MiB of 122.77MiB
08:46:43:I1:WU1528:DOWNLOAD 65% 79.96MiB of 122.77MiB
08:46:47:I1:WU1528:DOWNLOAD 66% 81.01MiB of 122.77MiB
08:46:49:I1:WU1524:UPLOAD 1% 978.38KiB of 99.76MiB
08:46:56:I1:WU1524:UPLOAD 2% 2.02MiB of 99.76MiB
08:46:58:I1:WU1528:DOWNLOAD 67% 82.61MiB of 122.77MiB
08:47:06:I1:WU1524:UPLOAD 3% 3.01MiB of 99.76MiB
08:47:12:I1:WU1524:UPLOAD 4% 4.03MiB of 99.76MiB
08:47:21:I1:WU1524:UPLOAD 5% 4.99MiB of 99.76MiB
08:47:26:I1:WU1528:DOWNLOAD 68% 83.47MiB of 122.77MiB
08:47:39:I1:WU1524:UPLOAD 6% 6.24MiB of 99.76MiB
08:47:42:I1:WU1524:UPLOAD 7% 7.01MiB of 99.76MiB
08:47:51:I1:WU1524:UPLOAD 8% 7.95MiB of 99.76MiB
08:48:24:E :OUT90:Failed response: EOF
08:48:24:I1:WU1526:Uploading WU results
08:48:46:I2:OUT102:> POST /api/results HTTP/1.1
08:48:46:E :OUT102:Failed response: EOF
08:48:46:I1:WU1526:Uploading WU results
08:49:07:I2:OUT103:> POST /api/results HTTP/1.1
08:49:07:E :OUT103:Failed response: EOF
08:49:07:I1:WU1526:Uploading WU results
08:49:17:I2:OUT104:> POST /api/results HTTP/1.1
08:49:24:I1:WU1526:UPLOAD 1% 755.69KiB of 77.13MiB
08:49:33:I1:WU1526:UPLOAD 2% 1.81MiB of 77.13MiB
08:49:38:I1:WU1526:UPLOAD 3% 2.30MiB of 77.13MiB
08:49:45:I1:WU1526:UPLOAD 4% 3.44MiB of 77.13MiB
08:49:47:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:49:49:I1:WU1526:UPLOAD 5% 3.85MiB of 77.13MiB
08:49:56:I1:WU1526:UPLOAD 6% 4.61MiB of 77.13MiB
08:50:02:W :CON105:DNS lookup failed for api.foldingathome.org
08:50:02:E :OUT105:Failed response: CONNECT
08:50:04:I1:WU1526:UPLOAD 7% 5.47MiB of 77.13MiB
08:50:11:I1:WU1526:UPLOAD 8% 6.22MiB of 77.13MiB
08:50:32:W :CON106:DNS lookup failed for api.foldingathome.org
08:50:32:E :OUT106:Failed response: CONNECT
08:51:09:W :CON107:DNS lookup failed for api.foldingathome.org
08:51:09:E :OUT107:Failed response: CONNECT
08:51:42:I2:OUT108:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:51:43:I2:OUT108:< HTTP/1.1 200 HTTP_OK
08:51:44:I2:OUT2:> GET /ws/client HTTP/1.1
08:51:44:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
08:51:44:I1:Logging into node account
08:51:58:E :OUT101:Failed response: EOF
08:51:58:I1:WU1524:Uploading WU results
08:51:59:I2:OUT109:> POST /api/results HTTP/1.1
08:52:06:I1:WU1524:UPLOAD 1% 1018.14KiB of 99.76MiB
08:52:14:I1:WU1524:UPLOAD 2% 2.00MiB of 99.76MiB
08:52:23:I1:WU1524:UPLOAD 3% 2.97MiB of 99.76MiB
08:52:28:I1:WU1524:UPLOAD 4% 4.00MiB of 99.76MiB
08:52:37:I1:WU1524:UPLOAD 5% 4.97MiB of 99.76MiB
08:52:45:I1:WU1524:UPLOAD 7% 6.72MiB of 99.76MiB
08:52:46:E :OUT100:Failed response: EOF
08:52:46:I1:WU1528:Retry #1 in 2 secs
08:52:47:I1:WU1524:UPLOAD 7% 6.94MiB of 99.76MiB
08:52:48:I1:WU1528:Downloading WU
08:52:57:I2:OUT110:> POST /api/assign HTTP/1.1
08:53:05:I1:WU1524:UPLOAD 8% 8.26MiB of 99.76MiB
08:53:14:I1:WU1524:UPLOAD 9% 8.94MiB of 99.76MiB
08:54:21:E :OUT104:Failed response: EOF
08:54:21:I1:WU1526:Uploading WU results
08:54:37:I2:OUT111:> POST /api/results HTTP/1.1
08:55:03:I1:WU1526:UPLOAD 1% 819.32KiB of 77.13MiB
08:55:06:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
08:55:08:I1:WU1526:UPLOAD 2% 1.60MiB of 77.13MiB
08:55:10:I1:WU1526:UPLOAD 3% 2.33MiB of 77.13MiB
08:55:16:I2:OUT112:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:55:18:I1:WU1526:UPLOAD 4% 3.11MiB of 77.13MiB
08:55:25:I1:WU1526:UPLOAD 5% 3.88MiB of 77.13MiB
08:55:30:I1:WU1526:UPLOAD 7% 5.41MiB of 77.13MiB
08:55:44:I2:OUT112:< HTTP/1.1 200 HTTP_OK
08:55:46:I1:WU1526:UPLOAD 8% 6.23MiB of 77.13MiB
08:55:52:I2:OUT2:> GET /ws/client HTTP/1.1
08:55:58:I1:WU1526:UPLOAD 10% 7.51MiB of 77.13MiB
08:56:00:I1:WU1526:UPLOAD 10% 7.74MiB of 77.13MiB
08:56:10:I1:WU1526:UPLOAD 11% 8.64MiB of 77.13MiB
08:57:22:E :OUT109:Failed response: EOF
08:57:22:I1:WU1524:Uploading WU results
08:57:30:I2:OUT113:> POST /api/results HTTP/1.1
08:57:47:I1:WU1524:UPLOAD 1% 1.03MiB of 99.76MiB
08:57:48:I1:Account websocket closed: NONE msg=Connection failed: error=EOF code=HTTP_UNKNOWN
08:57:52:I2:OUT114:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:57:54:I1:WU1524:UPLOAD 2% 2.05MiB of 99.76MiB
08:57:57:E :OUT110:Failed response: EOF
08:57:57:I1:WU1528:Retry #2 in 4 secs
08:58:01:I1:WU1528:Downloading WU
08:58:03:I1:WU1524:UPLOAD 3% 3.04MiB of 99.76MiB
08:58:03:I2:OUT114:< HTTP/1.1 200 HTTP_OK
08:58:06:I2:OUT115:> POST /api/assign HTTP/1.1
08:58:08:I1:WU1524:UPLOAD 4% 3.95MiB of 99.76MiB
08:58:19:W :CON116:DNS lookup failed for node1.foldingathome.org
08:58:19:I1:Account websocket closed: NONE msg=Connection failed: error=CONNECT code=HTTP_UNKNOWN
08:58:27:I1:WU1524:UPLOAD 5% 4.95MiB of 99.76MiB
08:58:27:I2:OUT117:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
08:58:28:I1:WU1524:UPLOAD 6% 5.94MiB of 99.76MiB
08:58:35:I1:WU1528:DOWNLOAD 100% 233B of 233B
08:58:35:I2:OUT115:< HTTP/1.1 500 HTTP_INTERNAL_SERVER_ERROR
08:58:35:E :OUT115:HTTP_INTERNAL_SERVER_ERROR: {"error":{"message":"Can't dereference NULL pointer!"}}
08:58:38:I1:WU1524:UPLOAD 7% 6.99MiB of 99.76MiB
08:58:41:I2:OUT117:< HTTP/1.1 200 HTTP_OK
08:58:43:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
08:58:43:I1:WU1529:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
08:58:56:W :CON118:DNS lookup failed for node1.foldingathome.org
08:58:56:I1:Account websocket closed: NONE msg=Connection failed: error=CONNECT code=HTTP_UNKNOWN
08:58:58:W :CON119:DNS lookup failed for assign5.foldingathome.org
08:58:58:E :OUT119:Failed response: CONNECT
08:58:58:I1:WU1529:Retry #1 in 2 secs
08:59:00:I1:WU1529:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
08:59:11:W :CON120:DNS lookup failed for api.foldingathome.org
08:59:11:E :OUT120:Failed response: CONNECT
08:59:15:W :CON121:DNS lookup failed for assign6.foldingathome.org
08:59:15:E :OUT121:Failed response: CONNECT
08:59:15:I1:WU1529:Retry #2 in 4 secs
08:59:19:I1:WU1529:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
08:59:29:W :CON123:DNS lookup failed for api.foldingathome.org
08:59:29:E :OUT123:Failed response: CONNECT
08:59:29:W :CON122:DNS lookup failed for assign1.foldingathome.org
08:59:29:E :OUT122:Failed response: CONNECT
08:59:29:I1:WU1529:Retry #3 in 8 secs
08:59:37:I1:WU1529:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
08:59:52:W :CON124:DNS lookup failed for assign2.foldingathome.org
08:59:52:E :OUT124:Failed response: CONNECT
08:59:52:I1:WU1529:Retry #4 in 16 secs
09:00:06:W :CON125:DNS lookup failed for api.foldingathome.org
09:00:06:E :OUT125:Failed response: CONNECT
09:00:08:I1:WU1529:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:00:08:I2:OUT126:> POST /api/assign HTTP/1.1
09:00:09:I2:OUT126:< HTTP/1.1 200 HTTP_OK
09:00:09:I1:WU1529:Received WU assignment qEJjntr9wqhoQEIJFL3hCWcBxKl1wh1_6Oh2vKKvwrY
09:00:09:I1:WU1529:Downloading WU
09:00:09:I2:OUT127:> POST /api/assign HTTP/1.1
09:00:12:I1:WU1529:DOWNLOAD 100% 220B of 220B
09:00:15:I1:WU1529:DOWNLOAD 1% 524.91KiB of 40.49MiB
09:00:16:I1:WU1529:DOWNLOAD 3% 1.10MiB of 40.49MiB
09:00:17:I1:WU1529:DOWNLOAD 5% 2.15MiB of 40.49MiB
09:00:18:I1:WU1529:DOWNLOAD 9% 3.51MiB of 40.49MiB
09:00:19:I1:WU1529:DOWNLOAD 13% 5.10MiB of 40.49MiB
09:00:20:I1:WU1529:DOWNLOAD 17% 6.93MiB of 40.49MiB
09:00:21:I1:WU1529:DOWNLOAD 22% 8.71MiB of 40.49MiB
09:00:22:I1:WU1529:DOWNLOAD 26% 10.50MiB of 40.49MiB
09:00:23:I1:WU1529:DOWNLOAD 31% 12.41MiB of 40.49MiB
09:00:24:I1:WU1529:DOWNLOAD 35% 14.35MiB of 40.49MiB
09:00:25:I1:WU1529:DOWNLOAD 40% 16.11MiB of 40.49MiB
09:00:26:I1:WU1529:DOWNLOAD 45% 18.04MiB of 40.49MiB
09:00:27:I1:WU1529:DOWNLOAD 49% 19.98MiB of 40.49MiB
09:00:28:E :OUT111:Failed response: EOF
09:00:28:I1:WU1526:Uploading WU results
09:00:28:I1:WU1529:DOWNLOAD 55% 22.19MiB of 40.49MiB
09:00:28:I2:OUT128:> POST /api/results HTTP/1.1
09:00:29:I1:WU1529:DOWNLOAD 58% 23.31MiB of 40.49MiB
09:00:30:I1:WU1529:DOWNLOAD 59% 23.91MiB of 40.49MiB
09:00:31:I1:WU1529:DOWNLOAD 60% 24.43MiB of 40.49MiB
09:00:32:I1:WU1529:DOWNLOAD 61% 24.88MiB of 40.49MiB
09:00:33:I1:WU1529:DOWNLOAD 62% 25.26MiB of 40.49MiB
09:00:34:I1:WU1529:DOWNLOAD 63% 25.62MiB of 40.49MiB
09:00:35:I1:WU1529:DOWNLOAD 64% 25.91MiB of 40.49MiB
09:00:36:I1:WU1526:UPLOAD 1% 898.85KiB of 77.13MiB
09:00:38:I1:WU1529:DOWNLOAD 65% 26.40MiB of 40.49MiB
09:00:41:I1:WU1529:DOWNLOAD 66% 26.74MiB of 40.49MiB
09:00:42:I1:WU1526:UPLOAD 2% 1.51MiB of 77.13MiB
09:00:43:I2:OUT129:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
09:00:45:I1:WU1529:DOWNLOAD 67% 27.19MiB of 40.49MiB
09:00:47:I1:WU1526:UPLOAD 3% 2.29MiB of 77.13MiB
09:00:53:I1:WU1529:DOWNLOAD 68% 27.66MiB of 40.49MiB
09:00:55:I1:WU1526:UPLOAD 5% 3.65MiB of 77.13MiB
09:00:55:I2:OUT129:< HTTP/1.1 200 HTTP_OK
09:00:57:I1:WU1526:UPLOAD 5% 3.85MiB of 77.13MiB
09:01:04:I1:WU1529:DOWNLOAD 69% 27.98MiB of 40.49MiB
09:01:04:I1:WU1526:UPLOAD 6% 4.61MiB of 77.13MiB
09:01:10:W :CON130:DNS lookup failed for node1.foldingathome.org
09:01:10:I1:Account websocket closed: NONE msg=Connection failed: error=CONNECT code=HTTP_UNKNOWN
09:01:13:I1:WU1526:UPLOAD 7% 5.47MiB of 77.13MiB
09:01:25:W :CON131:DNS lookup failed for api.foldingathome.org
09:01:25:E :OUT131:Failed response: CONNECT
09:01:26:I1:WU1529:DOWNLOAD 70% 28.50MiB of 40.49MiB
09:01:26:I1:WU1526:UPLOAD 8% 6.56MiB of 77.13MiB
09:01:27:I1:WU1529:DOWNLOAD 71% 28.81MiB of 40.49MiB
09:01:27:I1:WU1526:UPLOAD 9% 6.92MiB of 77.13MiB
09:01:36:I1:WU1526:UPLOAD 10% 7.78MiB of 77.13MiB
09:01:55:W :CON132:DNS lookup failed for api.foldingathome.org
09:01:55:E :OUT132:Failed response: CONNECT
09:02:32:W :CON133:DNS lookup failed for api.foldingathome.org
09:02:32:E :OUT133:Failed response: CONNECT
09:02:49:E :OUT113:Failed response: EOF
09:02:49:I1:WU1524:Uploading WU results
09:03:05:I2:OUT134:> POST /api/results HTTP/1.1
09:03:05:I2:OUT135:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
09:03:06:I2:OUT135:< HTTP/1.1 200 HTTP_OK
09:03:06:I2:OUT136:> GET /ws/client HTTP/1.1
09:03:06:I2:OUT136:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
09:03:06:I1:Logging into node account
09:03:16:I1:WU1524:UPLOAD 1% 978.38KiB of 99.76MiB
09:03:25:I1:WU1524:UPLOAD 2% 1.98MiB of 99.76MiB
09:03:32:I1:WU1524:UPLOAD 3% 3.01MiB of 99.76MiB
09:03:37:I1:WU1524:UPLOAD 4% 4.06MiB of 99.76MiB
09:03:46:I1:WU1524:UPLOAD 5% 4.94MiB of 99.76MiB
09:03:56:I1:WU1524:UPLOAD 6% 6.00MiB of 99.76MiB
09:04:13:I1:WU1524:UPLOAD 8% 7.76MiB of 99.76MiB
09:04:15:I1:WU1524:UPLOAD 8% 7.97MiB of 99.76MiB
09:05:41:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
09:05:42:I2:OUT137:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
09:05:42:I2:OUT137:< HTTP/1.1 200 HTTP_OK
09:05:42:I2:OUT136:> GET /ws/client HTTP/1.1
09:05:43:I2:OUT136:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
09:05:43:I1:Logging into node account
09:05:49:E :OUT128:Failed response: EOF
09:05:49:I1:WU1526:Uploading WU results
09:05:49:I2:OUT138:> POST /api/results HTTP/1.1
09:05:54:I1:WU1526:UPLOAD 1% 827.27KiB of 77.13MiB
09:06:02:I1:WU1526:UPLOAD 2% 1.57MiB of 77.13MiB
09:06:07:I1:WU1526:UPLOAD 3% 2.36MiB of 77.13MiB
09:06:14:I1:WU1526:UPLOAD 4% 3.12MiB of 77.13MiB
09:06:16:I1:WU1526:UPLOAD 5% 3.84MiB of 77.13MiB
09:06:23:I1:WU1526:UPLOAD 6% 4.59MiB of 77.13MiB
09:06:38:E :OUT127:Failed response: EOF
09:06:38:I1:WU1529:Retry #5 in 32 secs
09:06:40:I1:WU1526:UPLOAD 8% 6.18MiB of 77.13MiB
09:06:47:I1:WU1526:UPLOAD 9% 6.94MiB of 77.13MiB
09:06:54:I1:WU1526:UPLOAD 10% 7.69MiB of 77.13MiB
09:07:10:I1:WU1529:Downloading WU
09:07:31:I2:OUT139:> POST /api/assign HTTP/1.1
09:07:31:E :OUT139:Failed response: EOF
09:07:31:I1:WU1529:Retry #6 in 1 min 4 secs
09:08:07:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
09:08:22:W :CON140:DNS lookup failed for api.foldingathome.org
09:08:22:E :OUT140:Failed response: CONNECT
09:08:27:E :OUT134:Failed response: EOF
09:08:27:I1:WU1524:Uploading WU results
09:08:27:I2:OUT141:> POST /api/results HTTP/1.1
09:08:34:I1:WU1524:UPLOAD 1% 986.33KiB of 99.76MiB
09:08:35:I1:WU1529:Downloading WU
09:08:36:I2:OUT142:> POST /api/assign HTTP/1.1
09:08:42:I1:WU1524:UPLOAD 2% 1.99MiB of 99.76MiB
09:08:42:I2:OUT143:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
09:08:48:I1:WU1529:DOWNLOAD 100% 233B of 233B
09:08:48:I2:OUT142:< HTTP/1.1 500 HTTP_INTERNAL_SERVER_ERROR
09:08:48:E :OUT142:HTTP_INTERNAL_SERVER_ERROR: {"error":{"message":"Can't dereference NULL pointer!"}}
09:08:51:I1:WU1524:UPLOAD 3% 2.94MiB of 99.76MiB
09:08:56:I1:WU1524:UPLOAD 4% 3.98MiB of 99.76MiB
09:08:57:I2:OUT143:< HTTP/1.1 200 HTTP_OK
09:09:04:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
09:09:04:I1:WU1530:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:09:05:I1:WU1524:UPLOAD 5% 4.96MiB of 99.76MiB
09:09:12:W :CON136:DNS lookup failed for node1.foldingathome.org
09:09:12:I1:Account websocket closed: NONE msg=Connection failed: error=CONNECT code=HTTP_UNKNOWN
09:09:17:I1:WU1524:UPLOAD 6% 6.17MiB of 99.76MiB
09:09:21:I2:OUT145:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
09:09:24:I2:OUT144:> POST /api/assign HTTP/1.1
09:09:25:I1:WU1524:UPLOAD 7% 6.95MiB of 99.76MiB
09:09:33:E :OUT144:Failed response: EOF
09:09:33:I1:WU1530:Retry #1 in 2 secs
09:09:35:I1:WU1530:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:09:43:I1:WU1524:UPLOAD 8% 8.23MiB of 99.76MiB
09:09:50:W :CON146:DNS lookup failed for assign5.foldingathome.org
09:09:50:E :OUT146:Failed response: CONNECT
09:09:50:I1:WU1530:Retry #2 in 4 secs
09:09:54:I1:WU1530:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:10:09:W :CON147:DNS lookup failed for assign6.foldingathome.org
09:10:09:E :OUT147:Failed response: CONNECT
09:10:09:I1:WU1530:Retry #3 in 8 secs
09:10:17:I1:WU1530:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:10:32:W :CON148:DNS lookup failed for assign1.foldingathome.org
09:10:32:E :OUT148:Failed response: CONNECT
09:10:32:I1:WU1530:Retry #4 in 16 secs
09:10:48:I1:WU1530:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:11:03:W :CON149:DNS lookup failed for assign2.foldingathome.org
09:11:03:E :OUT149:Failed response: CONNECT
09:11:03:I1:WU1530:Retry #5 in 32 secs
09:11:06:E :OUT138:Failed response: EOF
09:11:06:I1:WU1526:Uploading WU results
09:11:07:I2:OUT150:> POST /api/results HTTP/1.1
09:11:15:I1:WU1526:UPLOAD 1% 779.55KiB of 77.13MiB
09:11:21:I1:WU1526:UPLOAD 2% 1.52MiB of 77.13MiB
09:11:26:I1:WU1526:UPLOAD 3% 2.29MiB of 77.13MiB
09:11:34:I1:WU1526:UPLOAD 5% 3.56MiB of 77.13MiB
09:11:35:I1:WU1530:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:11:37:I1:WU1526:UPLOAD 5% 3.88MiB of 77.13MiB
09:11:44:I1:WU1526:UPLOAD 6% 4.64MiB of 77.13MiB
09:11:50:W :CON151:DNS lookup failed for assign3.foldingathome.org
09:11:50:E :OUT151:Failed response: CONNECT
09:11:50:I1:WU1530:Retry #6 in 1 min 4 secs
09:12:01:I1:WU1526:UPLOAD 8% 6.14MiB of 77.13MiB
09:12:07:I1:WU1526:UPLOAD 9% 6.97MiB of 77.13MiB
09:12:14:I1:WU1526:UPLOAD 10% 7.70MiB of 77.13MiB
09:12:54:I1:WU1530:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:13:04:W :CON152:DNS lookup failed for assign4.foldingathome.org
09:13:04:E :OUT152:Failed response: CONNECT
09:13:04:I1:WU1530:Retry #7 in 2 mins 8 secs
09:13:42:E :OUT141:Failed response: EOF
09:13:42:I1:WU1524:Uploading WU results
09:13:42:I2:OUT153:> POST /api/results HTTP/1.1
09:13:52:I1:WU1524:UPLOAD 1% 1.04MiB of 99.76MiB
09:14:03:I1:WU1524:UPLOAD 2% 1.98MiB of 99.76MiB
09:14:13:I1:WU1524:UPLOAD 3% 3.39MiB of 99.76MiB
09:14:19:I1:WU1524:UPLOAD 4% 4.02MiB of 99.76MiB
09:14:28:I1:WU1524:UPLOAD 5% 4.96MiB of 99.76MiB
09:14:42:E :OUT145:Failed response: EOF
09:15:12:I1:WU1530:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:15:12:W :CON154:DNS lookup failed for api.foldingathome.org
09:15:12:E :OUT154:Failed response: CONNECT
09:15:27:W :CON155:DNS lookup failed for assign5.foldingathome.org
09:15:27:E :OUT155:Failed response: CONNECT
09:15:27:I1:WU1530:Retry #8 in 4 mins 16 secs
09:15:49:W :CON156:DNS lookup failed for api.foldingathome.org
09:15:49:E :OUT156:Failed response: CONNECT
09:15:53:I1:Machine state pause
09:16:22:I2:OUT157:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
09:16:23:I2:OUT157:< HTTP/1.1 200 HTTP_OK
09:16:23:I2:OUT158:> GET /ws/client HTTP/1.1
09:16:23:I2:OUT158:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
09:16:23:I1:Logging into node account
09:16:23:E :OUT150:Failed response: EOF
09:18:50:E :OUT153:Failed response: EOF
09:38:26:I1:Machine state fold
09:38:27:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
09:38:27:I1:WU1524:Uploading WU results
09:38:27:I1:WU1526:Uploading WU results
09:38:28:I1:WU1531:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
09:38:28:I2:OUT159:> POST /api/results HTTP/1.1
09:38:28:I2:OUT160:> POST /api/results HTTP/1.1
09:38:28:I2:OUT161:> POST /api/assign HTTP/1.1
09:38:28:I2:OUT161:< HTTP/1.1 200 HTTP_OK
09:38:28:I1:WU1531:Received WU assignment 94OT07TvhlhjRw2X50y9DXn0zmRdGTUESWrcGnv6Kjo
09:38:28:I1:WU1531:Downloading WU
09:38:29:I2:OUT162:> POST /api/assign HTTP/1.1
09:38:34:I1:WU1526:UPLOAD 1% 819.32KiB of 77.13MiB
09:38:43:I1:WU1526:UPLOAD 2% 1.75MiB of 77.13MiB
09:38:50:I1:WU1524:UPLOAD 1% 1.17MiB of 99.76MiB
09:38:52:I1:WU1526:UPLOAD 3% 2.31MiB of 77.13MiB
09:38:59:I1:WU1526:UPLOAD 4% 3.30MiB of 77.13MiB
09:39:09:I1:WU1526:UPLOAD 5% 3.92MiB of 77.13MiB
09:39:13:I1:WU1524:UPLOAD 2% 2.04MiB of 99.76MiB
09:39:17:I1:WU1531:DOWNLOAD 100% 221B of 221B
09:39:28:I1:WU1526:UPLOAD 6% 4.77MiB of 77.13MiB
09:39:31:I1:WU1526:UPLOAD 7% 5.45MiB of 77.13MiB
09:39:38:I1:WU1524:UPLOAD 3% 2.95MiB of 99.76MiB
09:40:00:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
09:40:15:W :CON163:DNS lookup failed for api.foldingathome.org
09:40:15:E :OUT163:Failed response: CONNECT
09:40:45:W :CON164:DNS lookup failed for api.foldingathome.org
09:40:45:E :OUT164:Failed response: CONNECT
09:41:08:I2:OUT165:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
09:41:09:I2:OUT165:< HTTP/1.1 200 HTTP_OK
09:41:09:I2:OUT158:> GET /ws/client HTTP/1.1
09:41:09:I2:OUT158:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
09:41:09:I1:Logging into node account
09:43:51:E :OUT159:Failed response: EOF
09:43:51:I1:WU1524:Uploading WU results
09:43:52:I2:OUT166:> POST /api/results HTTP/1.1
09:43:55:E :OUT160:Failed response: EOF
09:43:55:I1:WU1526:Uploading WU results
09:43:56:I2:OUT167:> POST /api/results HTTP/1.1
09:44:00:I1:WU1524:UPLOAD 1% 986.33KiB of 99.76MiB
09:44:06:I1:WU1524:UPLOAD 2% 2.00MiB of 99.76MiB
09:44:15:I1:WU1524:UPLOAD 4% 3.49MiB of 99.76MiB
09:44:20:I1:WU1524:UPLOAD 4% 4.02MiB of 99.76MiB
09:44:30:I1:WU1524:UPLOAD 5% 4.97MiB of 99.76MiB
09:44:38:I1:WU1524:UPLOAD 7% 6.83MiB of 99.76MiB
09:44:39:I1:WU1524:UPLOAD 7% 6.94MiB of 99.76MiB
09:44:40:E :OUT162:Failed response: EOF
09:44:40:I1:WU1531:Retry #1 in 2 secs
09:44:42:I1:WU1531:Downloading WU
09:44:52:I2:OUT168:> POST /api/assign HTTP/1.1
09:45:00:I1:WU1524:UPLOAD 8% 7.98MiB of 99.76MiB
Re: Issue with uploading WUs
Post by muziqaz »
Try using Google DNS alongside cloudflare one
FAH Omega tester
kwerboom
Post by kwerboom »
I'm already using Google DNS, because the one provided my local provider (Brightspeed) sucks.
kwerboom
Post by kwerboom »
OK. This is a problem on your end.
1. I checked my Brightspeed modem. The last time it was my Internet service provider, my modem blinked blue and red and right now the light is green.
2. I've posted to Internet Forums.
3. I've watched YouTube videos.
4. I changed my DNS from Google to Cloudflare.
5. I'm still getting the same error trying to upload WUs.
Sample of latest log file:
21:57:20:I1:WU1540:Completed 775000 out of 2500000 steps (31%)
21:57:21:I2:OUT158:> POST /api/results HTTP/1.1
21:57:21:E :OUT158:Failed response: EOF
21:57:21:I1:WU1526:Uploading WU results
21:57:21:I2:OUT159:> POST /api/results HTTP/1.1
21:57:26:I1:WU1526:UPLOAD 1% 787.50KiB of 77.13MiB
21:57:35:I1:WU1526:UPLOAD 2% 1.57MiB of 77.13MiB
21:57:40:I1:WU1526:UPLOAD 3% 2.31MiB of 77.13MiB
21:57:48:I1:WU1526:UPLOAD 5% 3.63MiB of 77.13MiB
21:57:52:I1:WU1526:UPLOAD 5% 3.91MiB of 77.13MiB
21:57:58:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
21:57:59:I1:WU1526:UPLOAD 6% 4.61MiB of 77.13MiB
21:58:04:E :OUT152:Failed response: EOF
21:58:04:I1:WU1534:Uploading WU results
21:58:07:I1:WU1526:UPLOAD 7% 5.41MiB of 77.13MiB
21:58:13:W :CON160:DNS lookup failed for api.foldingathome.org
21:58:13:E :OUT160:Failed response: CONNECT
21:58:14:I2:OUT161:> POST /api/results HTTP/1.1
21:58:20:I1:WU1526:UPLOAD 8% 6.47MiB of 77.13MiB
21:58:23:I1:WU1540:Completed 800000 out of 2500000 steps (32%)
21:58:23:I1:WU1526:UPLOAD 9% 6.90MiB of 77.13MiB
21:58:23:I1:WU1540:Checkpoint completed at step 800000
21:58:32:I1:WU1526:UPLOAD 10% 7.75MiB of 77.13MiB
21:58:43:W :CON162:DNS lookup failed for api.foldingathome.org
21:58:43:E :OUT162:Failed response: CONNECT
21:59:20:W :CON163:DNS lookup failed for api.foldingathome.org
21:59:20:E :OUT163:Failed response: CONNECT
21:59:28:I1:WU1540:Completed 825000 out of 2500000 steps (33%)
21:59:58:I2:OUT164:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
21:59:59:I2:OUT164:< HTTP/1.1 200 HTTP_OK
21:59:59:I2:OUT155:> GET /ws/client HTTP/1.1
21:59:59:I2:OUT155:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
21:59:59:I1:Logging into node account
22:00:08:E :OUT156:Failed response: EOF
22:00:08:I1:WU1524:Uploading WU results
22:00:09:I2:OUT165:> POST /api/results HTTP/1.1
22:00:20:I1:WU1524:UPLOAD 1% 1002.23KiB of 99.76MiB
22:00:27:I1:WU1524:UPLOAD 2% 1.98MiB of 99.76MiB
22:00:32:I1:WU1540:Completed 850000 out of 2500000 steps (34%)
22:00:39:I1:WU1524:UPLOAD 3% 2.99MiB of 99.76MiB
22:00:51:I1:Machine state pause
22:00:52:I1:WU1540:WARNING:Console control signal 1 on PID 31604
22:00:52:I1:WU1540:Exiting, please wait. . .
22:00:52:I1:WU1540:Folding@home Core Shutdown: INTERRUPTED
22:00:52:I1:WU1540:Core returned INTERRUPTED (102)
22:01:07:E :OUT161:Failed response: EOF
22:01:13:I1:WU1524:UPLOAD 4% 4.05MiB of 99.76MiB
22:01:28:I1:WU1524:UPLOAD 5% 4.95MiB of 99.76MiB
22:01:48:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
22:02:03:W :CON166:DNS lookup failed for api.foldingathome.org
22:02:03:E :OUT166:Failed response: CONNECT
22:02:33:W :CON167:DNS lookup failed for api.foldingathome.org
22:02:33:E :OUT167:Failed response: CONNECT
22:02:50:E :OUT159:Failed response: EOF
22:02:55:I2:OUT168:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
22:02:56:I2:OUT168:< HTTP/1.1 200 HTTP_OK
22:02:56:I2:OUT155:> GET /ws/client HTTP/1.1
22:02:56:I2:OUT155:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
22:02:56:I1:Logging into node account
22:04:39:E :OUT165:Failed response: EOF
JWhy
Post by JWhy »
I had this issue once (same "websocked closed" msg, same "dns lookup failed" error, etc...)
Everything else on the computer / internet was working fine.
I had to reboot my internet box to fix this.
maybe try this , if not already done ?
kwerboom
Post by kwerboom »
JWhy wrote: Fri Jan 16, 2026 5:02 am I had this issue once (same "websocked closed" msg, same "dns lookup failed" error, etc...)
Thank you so very much! This was exactly my problem! As a former Centurylink customer before Centurylink sold most of its holdings east of the Mississippi River to Brightspeed, my modem is a holdover from my former service provider. Last year, when Brightspeed was doing network updates and my modem got bricked, the Brightspeed technician the company sent to unbrick it said Brightspeed was doing constant improvements (Centurylink had left both the modem firmware and the network untouched since they mailed the modem to me as a replacement/upgrade). I logged into the modem to perform a factory reset like you recommended and much to my surprise, the firmware looked completely different. All the Centurylink branding was replaced with Brightspeed logos. After performing the factory reset, all the WUs that were unable to upload all started uploading successfully. I still find it strange how F@H broke when everything else kept working. If F@H hadn't broken, I would have never known my modem's firmware had been updated.
Post by muziqaz »
Possibly DNS cache got flushed on the router if there is even one
FAH Omega tester
