[tuto], opensuse Tumbleweed, Fah 8.5.5, installation
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
promeneur
Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
Post by promeneur »
0. download fah-client_8.4.9-64bit-release.tar.bz2
from https://foldingathome.org/start-folding/ from Debian/Mint/Ubuntu
1. uninstall the previous version
In the menu "Sciences and Mathematics", launch "Folding@home client"
pause all jobs
then execute the following commands
sudo  systemctl stop fah-client
sudo systemctl disable fah-client
check that fah-client.service file is deleted in /etc/systemd/system/multi-user.target.wants/
If not delete it with root rights
go to /etc/systemd/system
delete fahclient.service file with root rights
then extract /home/<id>/<path to>/fah-client_8.4.9-64bit-release.tar.bz2 in /home/id/<path to>/
go to /home/<id>/<path to>/
then execute
sudo cp /home/<id>/<path to>/fah-client  /usr/bin/
sudo cp /home/<id>/<path to>/fah-client.service /etc/systemd/system/
sudo systemctl start fah-client.service
*Check all is right
sudo systemctl status fah-client.service
*ask for starting fah-client at PC startup
sudo systemctl enable fah-client.service
In the menu "Sciences and Mathematics" for "Folding@home client" in "general" tab modify the field "command line argument"
change "https://v8-4.foldingathome.org/" to "https://v8-5.foldingathome.org/"
Launch "Folding@home client"
then click on "connect" to login
return to "https://v8-5.foldingathome.org/machines"
then click on "Fold All"
Check all is right
Restart you PC to check fah-client starts at PC startup.
Enjoy
Re: [tuto], opensuse Tumnleweed, Fah 8.5.5, installation
Post by muziqaz »
Boys are working on pre-built rpm to be published, so hopefully we won't need tutorials on how to install the client from tarballs :D
FAH Omega tester
promeneur
Post by promeneur »
We are impatient.
