Project 15209 (RCG 1,6,0)
EL_HAM
Post by EL_HAM »
Looks like WU of the same project but different RCG previously reported on this day, a fix was attempted by the researcher, but still results in bad WU.
The other post: "Project: 15209 (RCG 4,0,0)"
viewtopic.php?t=43409
Failed 3k59d1dpgx6r 234980 0 2025-12-18 11:20:02 2025-12-18 11:25:05
Failed szpeti40 239968 0 2025-12-18 11:23:53 2025-12-18 11:25:05
Failed RUSTINPEACE 35780 0 2025-12-18 11:46:17 2025-12-18 11:54:55
Failed amirarsyad97 2999 0 2025-12-18 11:49:11 2025-12-18 11:54:55
Failed [My Username] 238272 0 2025-12-18 11:51:05 2025-12-18 11:54:55
Another zero (0.0%) percent progress, also 43 seconds, and immediately failed.
All 5 attempts from multi-users (again) failed with this new RCG.
This is the 3rd failure (3rd different project and WU) I had in one day (in a 3-hour span) after 17 days without issues.
First topic: viewtopic.php?t=43410 (15205 (RCG 4,4,0))
Second topic: viewtopic.php?p=372782 (Project 15216 (RCG 0,7,0))
My percentage drops to 90%. I hope this won't worsen because just assigned 61 WU in total.
Currently, got yet another 18245 project without issues (33rd time, in progress, was set to priority).
This is a bit related, I think, because I didn't believe it was an undervolting issue, IIRC same researcher, but I don't have the details (other username, lost): Project 15225 (unknown RCG, should be different each) failed 4x in while 10x other WU (3 different projects) had no issues:
viewtopic.php?t=43378
I hope that in the future, everything can go smoothly on the researcher's end; this multi-project WU problem seems quite painstaking to fix/troubleshoot.
Re: Project 15209 (RCG 1,6,0)
Post by muziqaz »
thanks
FAH Omega tester
