finishes work units, then errors and won't restart..with a twist
exeter_acres
So... System up and running... GPU and CPU will do their work unit, but as soon as they finish I get the error
"16:08:35:I1:OUT12:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
16:08:35:E :OUT12:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}"
etc...
but the twist... If i just quit F@H and restart it... it would load work units and then work just fine....until it finishes these.. and then again... error, quit F@H, restart it... it works...
any ideas?
etc...
any ideas?
Re: finishes work units, then errors and won't restart..with a twist
There is no work for your hardware.
Restarting the client just resets the request delay timer and asks server for work immediately instead much less often before the restart. You don't need to restart, you just need to pause the client, and resume again, and it will do the same thing
No appropriate assignment - means no work available
exeter_acres
there IS work for the unit... as when i restart it....even if it just polled the server 30 seconds ago... it downloads work and starts......well either way what you are saying is it seems to need manual intervention every time...and that doesn't seem right
It does not need manual intervention. If it did, you wouldn't be the only one complaining about this.exeter_acres wrote: ↑Wed Dec 17, 2025 4:59 pm there IS work for the unit... as when i restart it....even if it just polled the server 30 seconds ago... it downloads work and starts......well either way what you are saying is it seems to need manual intervention every time...and that doesn't seem right
As I said the message tells you that there is no work for your hardware. Since these days people think that those who will help them have mind reading abilities, and just don't bother posting full system specs, the answer is simple and blunt: no work available for your hardware. If you decide to tell us what system specs are, then we can discuss deeper, on why you are getting this message of work not being available to your hardware specs
exeter_acres
werds are hard... if I do not RESTART folding... it NEVER downloads another WU... it just shows that error... it has gone two days like that.... as soon as I restart F@H it works perfectly.... this is repeatable multiple times now,muziqaz wrote: ↑Wed Dec 17, 2025 5:05 pmIt does not need manual intervention. If it did, you wouldn't be the only one complaining about this.exeter_acres wrote: ↑Wed Dec 17, 2025 4:59 pm there IS work for the unit... as when i restart it....even if it just polled the server 30 seconds ago... it downloads work and starts......well either way what you are saying is it seems to need manual intervention every time...and that doesn't seem right
You still don't get the concept of asking for help on internetexeter_acres wrote: ↑Wed Dec 17, 2025 5:14 pmwerds are hard... if I do not RESTART folding... it NEVER downloads another WU... it just shows that error... it has gone two days like that.... as soon as I restart F@H it works perfectly.... this is repeatable multiple times now,muziqaz wrote: ↑Wed Dec 17, 2025 5:05 pmIt does not need manual intervention. If it did, you wouldn't be the only one complaining about this.exeter_acres wrote: ↑Wed Dec 17, 2025 4:59 pm there IS work for the unit... as when i restart it....even if it just polled the server 30 seconds ago... it downloads work and starts......well either way what you are saying is it seems to need manual intervention every time...and that doesn't seem right
Help us to help you. Coming here and saying stuff don't work and keep telling us that stuff don't work, will not get you anywhere.
Devil is in the detail. What are your system specs and OS, which client version you are running, how is your client set up (have you created separate resource groups for each of your folding device, or you have them bunched up in one place)?
Again, mind reading is hard these days
exeter_acres
amd 9800x3d, RTX 5080, Win 11
client 8.4.9
ran the installer, allowing all defaults.. and ran it.. like I always have...
and just did it again.... finished GPU and CPU WU's no problem.... getting the error..
FOr two hours now.....
quit F@H manually... restarted it... and Poof... WU's downloaded immediately for both the GPU and CPU and running perfectly.....
client 8.4.9
Please try latest beta
https://foldingathome.org/beta/
If you still have the problem, try making separate resource groups to isolate CPU and GPU WUs.
Please read the guide if you haven't
https://foldingathome.org/guides/v8-4-client-guide/
exeter_acres
fixed it...... I installed F@H with defaults... I ran the installer and that's it... have no idea about setting up various resorources, etc. etc..
well.. seems there was a mystery GPU listed... didn't know if that was onboard or what... but it never actually started and just kept trying to download...
Disabled that one and poof.. there are lots of WU's to download and the CPU and GPU work as they should and download new units as they should... hopefully this pic works and shows it
exeter_acres
any idea why the installer added another GPU?
9800x3d cpu comes with iGPU
exeter_acres
There is a bug with default set up without resource groups. If one of the devices is not getting work, sometimes all of the other devices also get stuck in the same state. Enabling Advanced settings and creating separate resource groups for each individual device fixes the issueexeter_acres wrote: ↑Wed Jan 14, 2026 10:00 pmany idea why that one wouldn't work then? that one kept trying to download... and that created the issue I mentioned above...
The iGPU in the 9800X3D is on the low end with 2 Compute Units providing 128 shaders. Whether it will get work assigned will depend if there are WUs available from small enough projects. It not getting an assignment would block other requests going forward. Configuring the CPU and the GPUs into resource groups isolates the interaction. But in this case you may still not get work for the iGPU and it operates under the same TDP as the CPU which may slow it down. Probably best to just disable it for folding.
