Please allow use of my Asus Gforce 1030 again, it crunched data well on the last version.
it did a great job compared to my Zotac Gforce 4060 TI, I got into the top 10k easily with my old 1030 helping....
Re: Please allow use of my Asus Gforce 1030 again, it crunched data well on the last version.
1030 was never removed from gpu whitelist.
However, projects change, and hardware requirement which can safely complete the projects in time, change. Seeing how 1030 is ultra low end, there will be times when it will not have work for it, since it might be too slow for current crop of projects
The GT 1030 was sold using either a Kepler GPU chip or more often a Pascal chip. In either case the card was about the bare minimum to successfully process GPU WUs, but there were not always projects small enough to be assigned to them. In the case of cards based on the Kepler chip, those are an old enough microarchitecture that processing is done only using OpenCL, CUDA is not supported by the current GPU folding cores in use.
All 3 variants listed in the GPUs file are whitelisted, so there may just not be any projects currently running that can be assigned to your GT 1030. The variant using the Kepler chip is in a lower species classification due to the lack of CUDA during WU processing.
Buick350X
- Hardware configuration: Processor AMD Ryzen 9 5950X
MB AsRock B550M Pro4
RAM HP V6 DDR4 3000mhz 32.0 GB
Zotac Gforce 5060 TI 16GB TwinEdge OC - Contact:
Copy, in the $200 range I could get a 3050 or a 5050 to boost the crunch
