This might be an unpopular opinion, but as much as folding uses compute power for a good cause, the combined co2 emissions from folding are also immense!
Some suggestions on how to make folding more efficienct, to reduce carbon emissions, lower energy prices, and reduce foreign energy dependency:
Using AI to calculate an efficiency score, to compare performance per watt between devices, users, and teams.
Promoting and increasing ARM hardware support (Android, snapdragon laptop chips, apple silicon), to make people switch from x86 and discrete GPU's, which are more inefficiency in terms of performance per watt.
Ending support for the oldest and most inefficient hardware, to make people upgrade and switch to newer more energy efficienct hardware.
If CPU's and GPU's are doing the same tasks, only GPU's, especially iGPU's, should run those tasks instead of CPU's, since they are much faster and way more efficient per watt than CPU's doing the same tasks.
Just not seeing anybody talking about this, and I think the Folding community should contribute to reducing carbon emissions and saving the environment, like everyone else.
Folding efficiency improvements - reducing carbon footprint
Re: Folding efficiency improvements - reducing carbon footprint
FAH will not influence energy price adjustments
FAH is not single country project, so dependency on foreign energy makes no sense. What is foreign country? FAH is worldwide project.
Android is not a compute platform, and I don't care what everyone's feelings about it are. Phones simply are the most terrible platform for compute tasks. And best fire hazard in your house, if you fold on your phone. Believe me, we tried
FAH will not influence better adoption of ARM. ARM should influence better adoption of ARM hardware.
Qualcomm is the next intel with their "innovations". Snapdragon can stay in its niche market. Folding on laptops in general is terrible idea.
Apple chips, while very impressive, are walled garden, no thank you. User will not just simply go for Mac, just because folding...
Ending support for old hardware makes you a consumerist. World DOES NOT need another project pushing people to needlessly upgrade to latest and greatest. We have enough of this sh*t with company car policies across the globe, pushing people buy into brand new cars every 6 years, just to comply with company policies.
Keep AI out of FAH (Yes, Yes, some FAH projects use AI generated starting positions, etc). The world is falling into oblivion with those two letters, no thank you. And, since when AI is synonymous with efficiency?
Last I checked power stations are being built dedicated to AI datacenters. GPU chip manufacturers forgot what efficiency is, as long as it has AI in its name, and arrow goes up and to the right, everything is awesome. The more you buy, the more ... yeah, nah. Keep that boiling rot far away from FAH
That's not how FAH works. FAH does not create CPU projects and GPU projects just for diversity. CPU projects exit, because GPUs cannot do them, which means CPUs are the most efficient way of folding those projects. Do you think that researcher would create their project for CPUs only, if their simulations were compatible with the GPU? "Let's fold our project in 6 months with CPU, instead of 2 weeks on GPU" - said no one ever.If CPU's and GPU's are doing the same tasks, only GPU's, especially iGPU's, should run those tasks instead of CPU's, since they are much faster and way more efficient per watt than CPU's doing the same tasks.
appepi
- Hardware configuration: HP Z600 (5) HP Z800 (3) HP Z440 (3) HP Z4G4 (3) ASUS Turbo GTX 1060, 1070, 1080, RTX 2060 (3) Dell GTX 1080 NVIDIA P1000 (2) K1200
My personal view is just that the benefits of Fah to the world ecosystem - not just the potential health benefits of the science, but the visible demonstration of the possibility of civil international collaboration by ordinary folk - well, OK, maybe slightly geekish folk - justifies the carbon footprint, and this is just as true for any collaborative investment that any participant makes, whether "efficient" by the notional (and basically unquantifiable) metric of "Science Increment per Tonne of CO2" or "Disability Adjusted Human Life Years gained per Science increment per Tonne of C02", let alone by the simplified notion "PPD per kWh per day" ignoring capital costs etc.Just not seeing anybody talking about this, ...
And although the "efficiency" debate is worthwhile, it is only one of many worthwhile things that folk talk about in these forums - see for example the very interesting discussion at viewtopic.php?p=359128#p359128.
Why AI? Calculating power requirements has nothing to do with natural language processing. I have to note the irony of using something as energy-intensive as AI, boiling lakes and sucking up the power of entire cities, if your goal is to reduce energy usage.
You're very wrong here. Those lower power embedded processors use less power, but they also fold less efficiently. And discrete GPUs, unless they are more than a decade old, fold the most efficiently by far. Per watt, a discrete GPU will absolutely blow away anything else. An RTX 5090 gobbling up nearly 600 watts is going to do immensely more work than a hundred 6 watt ARM CPUs combined. If you want to increase efficiency per watt, the best advice I can give you is get an RTX 5090 and cap the power to 450 watts or so (which is probably close to the sweet spot).
Not everyone can upgrade. Most people running older hardware are either doing that because it's all they have and would rather stop folding than upgrade, or because they are using the cards to generate heat in the winter. For people who care about energy efficiency, sure, it's best to upgrade.
No. iGPUs are much, much less efficient per watt. Also, there are some features required for certain simulations that are currently only supported on the CPU code and are not supported on the GPU code. They aren't running the exact same thing, because the CPU runs a simulation library called GROMACS and the GPU runs a simulation library called OpenMM. This might change in the future, but for now, research that requires certain types of simulations (specifically, those that require "virtual sites") are limited to using CPUs only.
Compared to the AI slop farms that are literally draining lakes for cooling, we're using almost nothing and we're helping researchers while we're at it.
