installed adguard Home - SBC no longer connect?
nada391
Post by nada391 »
Hello ,
today have installed Adguard Home on SBC and noticed that it said that something port already in use;
bind: adress already in use
afterwards , too avoid the error , did disable
sudo systemctl stop systemd-resolved
found out however, that now the SBC no longer connect.
tried to circumvent the error as shown in tutorial
https://github.com/AdguardTeam/AdGuardH ... #bindinuse
however, even after re-starting service "systemd-resolved", the SBC wont connect.
with error like
20:34:59:I1:WU1:Steps: first=-1797467296 total=-1794967296
20:35:13:W :CON2:DNS lookup failed for api.foldingathome.org
20:35:13:E :OUT2:Failed response: CONNECT
20:35:14:I1:WU1:Completed 306802 out of 2500000 steps (12%)
20:35:35:W :CON3:DNS lookup failed for api.foldingathome.org
20:35:35:E :OUT3:Failed response: CONNECT
20:36:08:W :CON4:DNS lookup failed for api.foldingathome.org
20:36:08:E :OUT4:Failed response: CONNECT
20:36:58:W :CON5:DNS lookup failed for api.foldingathome.org
20:36:58:E :OUT5:Failed response: CONNECT
20:38:13:W :CON6:DNS lookup failed for api.foldingathome.org
20:38:13:E :OUT6:Failed response: CONNECT
20:40:06:W :CON7:DNS lookup failed for api.foldingathome.org
20:40:06:E :OUT7:Failed response: CONNECT
20:42:56:W :CON8:DNS lookup failed for api.foldingathome.org
20:42:56:E :OUT8:Failed response: CONNECT
thanks
EDIT>
it seems to be crunching, but there are errors
22:15:57:E :OUT26:Failed response: CONNECT
22:19:05:I1:WU1:Completed 325000 out of 2500000 steps (13%)
22:19:57:W :CON27:DNS lookup failed for api.foldingathome.org
22:19:57:E :OUT27:Failed response: CONNECT
22:23:57:W :CON28:DNS lookup failed for api.foldingathome.org
nada391
Re: installed adguard Home - SBC no longer connect?
Post by nada391 »
it seem the problem can be avoided by installing adguard first, and then fah-client;
not very much knoweledgeable in networking;
also had some issues with the softwae (dlna no longer connecting etc.) that can probbably be solved easily, but for the moment just uninstalled the software.
please consider issue solved;
thanks.
jonault
Post by jonault »
I have found that anytime I enable or disable my VPN I need to stop & restart the client, otherwise it will eventually get hung up in a similar fashion and unable to download a new WU.
