Unable to download core
SoulReaper
Post by SoulReaper »
Hey guys
16:08:34:WU01:FS01:Connecting to cores.foldingathome.org:80
16:08:55:ERROR:WU01:FS01:Exception: Failed to connect to cores.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:10:12:WU01:FS01:Downloading core from http://cores.foldingathome.org/openmm-core-27/windows-10-64bit/release/0x27-8.2.1/Core_27.fah
16:10:12:WU01:FS01:Connecting to cores.foldingathome.org:80
16:10:17:ERROR:WU01:FS01:Exception: Failed to connect to cores.foldingathome.org:80: An established connection was aborted by the software in your host machine.
16:12:49:WU01:FS01:Downloading core from http://cores.foldingathome.org/openmm-core-27/windows-10-64bit/release/0x27-8.2.1/Core_27.fah
16:12:49:WU01:FS01:Connecting to cores.foldingathome.org:80
16:13:10:ERROR:WU01:FS01:Exception: Failed to connect to cores.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:17:03:WU01:FS01:Downloading core from http://cores.foldingathome.org/openmm-core-27/windows-10-64bit/release/0x27-8.2.1/Core_27.fah
16:17:03:WU01:FS01:Connecting to cores.foldingathome.org:80
16:17:24:ERROR:WU01:FS01:Exception: Failed to connect to cores.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:23:54:WU01:FS01:Downloading core from http://cores.foldingathome.org/openmm-core-27/windows-10-64bit/release/0x27-8.2.1/Core_27.fah
16:23:54:WU01:FS01:Connecting to cores.foldingathome.org:80
16:24:15:ERROR:WU01:FS01:Exception: Failed to connect to cores.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
I am constantly getting this error. The WU has been downloaded but the core fails to download. This has been going on since a few days now. What are your thoughts?
Regards
Re: Unable to download core
Post by muziqaz »
Try using cloudflare DNS, try not to use wi fi
FAH Omega tester
I have sent a message to have that server checked. But also check to see if your anti-malware software is blocking the download of the executable. Some by default will do that for connections over HTTP by applications other than known browsers.
Gary480six
Post by Gary480six »
I had the same problem four days ago. Started up an old Folding box I had not used in a while. Running version 7.6.21. Same issue. Would not download core 27. Same error message as seen in the OP.
My solution (though I was not happy about it), was to install Folding version 8.4 on top of the non-working 7.6.21 client. That worked - and the box is Folding.
That tower is still on WiFi and still using the default DNS servers. So I have to assume it's an issue at http://cores.foldingathome.org:80.
Post by muziqaz »
Yeah, admins have been notified
Thanks
FAH Omega tester
PhilTheNet
Post by PhilTheNet »
Same pb with an old Ubuntu :
14:39:14:WU00:FS00:Connecting to cores.foldingathome.org:80
14:41:30:ERROR:WU00:FS00:Exception: Failed to connect to cores.foldingathome.org:80: Connection timed out
And in wget :
--2025-11-17 11:52:14-- (try:19) http://cores.foldingathome.org/lin/64bi ... ore_a8.fah
Connecting to cores.foldingathome.org|158.130.118.155|:80... failed: Operation timed out.
Retrying.
:oops:
Toasty_MacNickels
Post by Toasty_MacNickels »
Garsh, wanted to get back into FAH for a while, but have this error. Diehard fan of the old Advanced Control client; hate web clients.
Seems there's no fix quite yet.
Post by muziqaz »
It should be fixed for now
FAH Omega tester
PhilTheNet
It's good for me now
Thks
