Trouble getting wu's again
Ravage7779
Hardware configuration: .
6x Intel i3-4130 (4) @ 3.400GHz
Apple M1 (8) @ 3.2 GHz
AMD Ryzen 5 5500U (12) @ 4.06 GHz
Intel Core i7-9700 (8) @ 4.70 GHz
AMD Ryzen 7 5700G (16) @ 4.67 GHz
Post by Ravage7779 »
Seeing a whole bunch of assignment errors on my 4 core cpu clients again
08:45:25:I1:WU921:Uploading WU results
08:45:25:I1:WU922:Requesting WU assignment for user Ravage team 1971
08:45:25:I1:OUT208:> POST https://ds01.scs.illinois.edu/api/results HTTP/1.1
08:45:25:I1:OUT209:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
08:46:17:E :OUT209:Failed response: EOF
08:46:17:I1:WU922:Retry #1 in 2 secs
08:46:19:I1:WU922:Requesting WU assignment for user Ravage team 1971
08:46:19:I1:OUT210:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
08:46:27:E :OUT208:Failed response: EOF
08:46:27:I1:WU921:Uploading WU results
08:46:27:I1:OUT211:> POST https://ds03.scs.illinois.edu/api/results HTTP/1.1
08:47:10:E :OUT210:Failed response: EOF
08:47:10:I1:WU922:Retry #2 in 4 secs
08:47:14:I1:WU922:Requesting WU assignment for user Ravage team 1971
08:47:14:I1:OUT212:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
08:47:28:E :OUT211:Failed response: EOF
08:47:28:I1:WU921:Uploading WU results
08:47:28:I1:OUT213:> POST https://vav24.fah.temple.edu/api/results HTTP/1.1
08:48:05:E :OUT212:Failed response: EOF
08:48:05:I1:WU922:Retry #3 in 8 secs
08:48:13:I1:WU922:Requesting WU assignment for user Ravage team 1971
08:48:13:I1:OUT214:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
08:48:29:E :OUT213:Failed response: EOF
08:48:29:I1:WU921:Uploading WU results
08:48:29:I1:OUT215:> POST https://highland3.seas.upenn.edu/api/results HTTP/1.1
08:49:04:E :OUT214:Failed response: EOF
08:49:04:I1:WU922:Retry #4 in 16 secs
08:49:20:I1:WU922:Requesting WU assignment for user Ravage team 1971
08:49:20:I1:OUT216:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
08:49:30:E :OUT215:Failed response: EOF
08:49:30:I1:WU921:Uploading WU results
08:49:30:I1:OUT217:> POST https://highland4.seas.upenn.edu/api/results HTTP/1.1
08:50:11:E :OUT216:Failed response: EOF
08:50:11:I1:WU922:Retry #5 in 32 secs
08:50:34:E :OUT217:Failed response: EOF
08:50:34:I1:WU921:Uploading WU results
08:50:34:I1:OUT218:> POST https://ds01.scs.illinois.edu/api/results HTTP/1.1
08:50:35:I1:WU921:UPLOAD 23% 2.79MiB of 12.01MiB
08:50:36:I1:WU921:UPLOAD 48% 5.75MiB of 12.01MiB
08:50:37:I1:WU921:UPLOAD 70% 8.46MiB of 12.01MiB
08:50:38:I1:WU921:UPLOAD 95% 11.41MiB of 12.01MiB
08:50:39:I1:OUT218:< HTTP/1.1 200 HTTP_OK
08:50:39:I1:WU921:Credited
08:50:43:I1:WU922:Requesting WU assignment for user Ravage team 1971
08:50:43:I1:OUT219:> POST https://assign6.foldingathome.org/api/assign HTTP/1.1
08:51:34:E :OUT219:Failed response: EOF
08:51:34:I1:WU922:Retry #6 in 1 min 4 secs
08:52:38:I1:WU922:Requesting WU assignment for user Ravage team 1971
08:52:38:I1:OUT220:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
08:52:38:I1:OUT220:< HTTP/1.1 200 HTTP_OK
Also seeing DNS errors
07:10:45:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
07:10:56:W :CON193:DNS lookup failed for api.foldingathome.org
07:10:56:E :OUT193:Failed response: CONNECT
07:11:22:W :CON194:DNS lookup failed for api.foldingathome.org
07:11:22:E :OUT194:Failed response: CONNECT
07:11:59:W :CON195:DNS lookup failed for api.foldingathome.org
07:11:59:E :OUT195:Failed response: CONNECT
07:12:47:W :CON196:DNS lookup failed for api.foldingathome.org
07:12:47:E :OUT196:Failed response: CONNECT
07:13:52:W :CON197:DNS lookup failed for api.foldingathome.org
07:13:52:E :OUT197:Failed response: CONNECT
07:15:17:W :CON198:DNS lookup failed for api.foldingathome.org
07:15:17:E :OUT198:Failed response: CONNECT
07:15:21:I1:WU921:Completed 200000 out of 500000 steps (40%)
07:17:25:W :CON199:DNS lookup failed for api.foldingathome.org
07:17:25:E :OUT199:Failed response: CONNECT
07:20:30:W :CON200:DNS lookup failed for api.foldingathome.org
07:20:30:E :OUT200:Failed response: CONNECT
07:24:45:W :CON201:DNS lookup failed for api.foldingathome.org
07:24:45:E :OUT201:Failed response: CONNECT
07:28:45:I1:OUT202:> GET https://api.foldingathome.org/machine/gHoBZRTzvyl6lRqXsbVJ0Odomo2Asklynpqos82BYeI HTTP/1.1
07:29:45:E :OUT202:Failed response: EOF
Ravage7779
Re: Trouble getting wu's again
This is a new one for me. No idea what this one means. Network barfed for a split second?
This is from an 8 core apple m1 with a little over 1100 wu's on it.
05:15:51:I1:WU1120:Requesting WU assignment for user Ravage team 1971
05:15:51:I1:OUT1241:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
05:15:51:I1:OUT1240:> POST https://vav17.fah.temple.edu/api/results HTTP/1.1
05:15:51:I1:OUT1241:< HTTP/1.1 200 HTTP_OK
05:15:51:I1:WU1120:Received WU assignment _j9spVUCSgw6FWv9WNvxiQx4CGQLf7vAOuDw_dYlSqY
05:15:51:I1:WU1120:Downloading WU
05:15:51:E :OUT1240:Failed response: EOF
05:15:51:I1:WU1119:Uploading WU results
05:15:51:E :WU1119:Exception: Invalid IP address range '*.local'
05:15:51:E :WU1119:Caused by: Invalid socket address: *.local
05:15:51:I1:OUT1242:> POST https://highland1.seas.upenn.edu/api/assign HTTP/1.1
05:15:51:I1:OUT1246:> POST https://highland4.seas.upenn.edu/api/results HTTP/1.1
05:15:52:I1:OUT1242:< HTTP/1.1 200 HTTP_OK
05:15:53:I1:WU1120:Received WU P18240 R554 C1 G666
Post by calxalot »
Do you have *.local in your config.xml?
Allow should only have numeric IPs and ranges.
Example:
<http-addresses v='0.0.0.0:7396'/>
<allow v='127.0.0.1 10.0.0.0/8 192.168.0.0/16 172.16.0.0/12 169.254.0.0/16'/>
Post by calxalot »
What version of client and macOS?
Ravage7779
calxalot wrote: Tue Nov 11, 2025 7:24 pm What version of client and macOS?
Sequoia Version 15.3.2
Client 8.4.9
Haven't touched the config since the initial setup a couple years ago. I've never messed with it by hand. I don't see a config.xml in any of the usual places. /etc/fahclient doesn't exist. Nothing in /Library/Application Support/FAHClient either. /var/lib isn't really a thing on a Mac...
