Hello,
How long for Donar Statistics to update to a new name?
So ive been folding on and off for many years, but ive just returned.
Ive changed my username, email account so i have a new passkey, and ive uninstalled fah-client_8.4.9_AMD64.exe, and installed the new beta version fah-client_8.5.3_AMD64.exe.
How long does the server take before it links jobs to the new username and team number, because at the moment when i load the https://stats.foldingathome.org/ page, its displaying my previous profile as "My Donar Profile", regardless of ctrl+F5 page reload, and i don't seem to be logged in to that site?
Ive already completed one large WU in the last few hours, does the server update and perform changes at mid night?
Also ive noticed over the last couple of days, that the Web Control stats page "https://v8-5.foldingathome.org/stats" wont display any stats of the username does not match, but i wondering once again how long this takes to link.
My last WU was downloaded and started with the current username and configuration set.
It seems a bit like a bug, but im hoping someone can clarify since im bit new with the current setup.
Many thanks,
David
Re: How long for Donar Statistics to update to a new name?
Should take less than a day
See also
https://apps.foldingathome.org/
https://folding.extremeoverclocking.com/
Note: https://v8-5.foldingathome.org/stats only shows stats for current user+passkey
See also
Hi,
Yes, i believe that is correct.
I have also worked out why "My Donar Profile" was not changing on the "https://stats.foldingathome.org/" statistics page.
To change your "My Donar Profile", left click the "Edit Name", and instead of rename your name, it will give you the option to "Look up my Donar Name", and after you have found a valid name, it will select it and show the your Donar statitics for the select profile every time you load the page.
David
David
