Please add XFX 9070
Locked
Malique2
Please add XFX 9070
Post by Malique2 »
AMD Radeon RX 9070
Device ID: 1002 7550-1EAE 8710
23:08:19:I1:WU29: Bits: 64
23:08:19:I1:WU29: Mode: Release
23:08:19:I1:WU29:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:08:19:I1:WU29: <peastman@stanford.edu>
23:08:19:I1:WU29: Args: -dir lJdswBCfLrdhlJ75iVpqseSHXiIsczOy9eMrhEZ1sEQ -suffix 01
23:08:19:I1:WU29: -version 8.5.3 -lifeline 16524 -gpu-uuid
23:08:19:I1:WU29: 30303030-3030-3130-3030-303030303030 -gpu-platform opencl
23:08:19:I1:WU29: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -hip-platform 0
23:08:19:I1:WU29: -hip-device 0 -gpu 0
23:08:19:I1:WU29:************************************ libFAH ************************************
23:08:19:I1:WU29: Date: Mar 27 2025
23:08:19:I1:WU29: Time: 04:30:44
23:08:19:I1:WU29: Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
23:08:19:I1:WU29: Branch: HEAD
23:08:19:I1:WU29: Compiler: Visual C++
23:08:19:I1:WU29: Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:08:19:I1:WU29: Platform: win32 10
23:08:19:I1:WU29:************************************ CBang *************************************
23:08:19:I1:WU29: Version: 1.7.2
23:08:19:I1:WU29: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:08:19:I1:WU29: Org: Cauldron Development LLC
23:08:19:I1:WU29: Copyright: Cauldron Development LLC, 2003-2024
23:08:19:I1:WU29: Homepage: https://cauldrondevelopment.com/
23:08:19:I1:WU29: License: LGPL-2.1-or-later
23:08:19:I1:WU29: Time: 04:29:12
23:08:19:I1:WU29: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
23:08:19:I1:WU29:************************************ System ************************************
23:08:19:I1:WU29: CPU: AMD Ryzen 9 5900X 12-Core Processor
23:08:19:I1:WU29: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
23:08:19:I1:WU29: CPUs: 24
23:08:19:I1:WU29: Memory: 31.91GiB
23:08:19:I1:WU29:Free Memory: 17.58GiB
23:08:19:I1:WU29: OS Version: 10.0
23:08:19:I1:WU29:Has Battery: false
23:08:19:I1:WU29: On Battery: false
23:08:19:I1:WU29: Hostname: DESKTOP-OISKUMS
23:08:19:I1:WU29: UTC Offset: -5
23:08:19:I1:WU29: PID: 9200
23:08:19:I1:WU29: CWD: C:\ProgramData\FAHClient\work
23:08:19:I1:WU29: Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
23:08:19:I1:WU29:************************************ OpenMM ************************************
23:08:19:I1:WU29: Version: 8.2.0
23:08:19:I1:WU29:********************************************************************************
23:08:19:I1:WU29:Project: 18262 (Run 106, Clone 3, Gen 77)
23:08:19:I1:WU29:Digital signatures verified
23:08:19:I1:WU29:Folding@home GPU Core27 Folding@home Core
23:08:19:I1:WU29:Version 8.2.1
23:08:19:I1:WU29: GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
23:08:19:I1:WU29: GPU info: PlatformIndex: 0
23:08:19:I1:WU29: GPU info: Device: gfx1201
23:08:19:I1:WU29: GPU info: DeviceIndex: 0
23:08:19:I1:WU29: GPU info: Vendor: 0x1002
23:08:19:I1:WU29: GPU info: PCI: 10:00:00
23:08:19:I1:WU29: GPU info: Compute: 2.0
23:08:19:I1:WU29: GPU info: Driver: 3661.0
23:08:19:I1:WU29: GPU info: GPU: true
23:08:19:I1:WU29: Checkpoint write interval: 12500 steps (5%) [20 total]
23:08:19:I1:WU29: JSON viewer frame write interval: 2500 steps (1%) [100 total]
23:08:19:I1:WU29: XTC frame write interval: 5000 steps (2%) [50 total]
23:08:19:I1:WU29: TRR frame write interval: disabled
23:08:19:I1:WU29: Global context and integrator variables write interval: disabled
23:08:19:I1:WU29:There are 3 platforms available.
23:08:19:I1:WU29:Platform 0: Reference
23:08:19:I1:WU29:Platform 1: CPU
23:08:19:I1:WU29:Platform 2: OpenCL
23:08:19:I1:WU29: opencl-device 0 specified
23:08:29:I1:WU25:Completed 20612 out of 500
Reason: added Code tags to log
Re: Please add XFX 9070
Post by muziqaz »
It has been added looooooooong time ago
FAH Omega tester
Malique2
Post by Malique2 »
Ok. Thanks it won't fold. My other 6 GPUs zero problems. This one is in an endless loop. I'm at a loss. It downloads then I see the PPD countdown for a bit, never see an increase in perecentage and a few minutes later it wipes and starts over.
Post by muziqaz »
Malique2 wrote: Mon Nov 03, 2025 11:18 pm Ok. Thanks it won't fold. My other 6 GPUs zero problems. This one is in an endless loop. I'm at a loss. It downloads then I see the PPD countdown for a bit, never see an increase in perecentage and a few minutes later it wipes and starts over.
Logs or it didn't happen.
Full system specs would help too
Screenshot of system info within FAHclient would be helpful
FAH Omega tester
Malique2
Post by Malique2 »
Ryzen 9 5900x
Asus TUF Gaming B550M-ZAKU
32 Gig Ram
XFX 9070 Swift
No overclock at all.
https://imgur.com/a/mo5shzL
00:09:29:I1:WU77: GPU info: Compute: 2.0
00:09:29:I1:WU77: GPU info: Driver: 3661.0
00:09:29:I1:WU77: GPU info: GPU: true
00:09:29:I1:WU77: Checkpoint write interval: 125000 steps (5%) [20 total]
00:09:29:I1:WU77: JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:09:29:I1:WU77: XTC frame write interval: 25000 steps (1%) [100 total]
00:09:29:I1:WU77: TRR frame write interval: disabled
00:09:29:I1:WU77: Global context and integrator variables write interval: disabled
00:09:29:I1:WU77:There are 3 platforms available.
00:09:29:I1:WU77:Platform 0: Reference
00:09:29:I1:WU77:Platform 1: CPU
00:09:29:I1:WU77:Platform 2: OpenCL
00:09:29:I1:WU77: opencl-device 0 specified
00:09:38:I1:WU25:Completed 81382 out of 500000 steps (16%)
00:09:51:I1:WU77:Attempting to create OpenCL context:
00:09:51:I1:WU77: Configuring platform OpenCL
00:10:05:I1:WU77:ERROR:exception: Error invoking kernel reduceEnergy: clEnqueueNDRangeKernel (-54)
00:10:05:I1:WU77:Saving result file ..\logfile_01.txt
00:10:05:I1:WU77:Saving result file science.log
00:10:05:I1:WU77:Folding@home Core Shutdown: BAD_WORK_UNIT
00:10:05:E :WU77:Core returned BAD_WORK_UNIT (114)
00:10:05:I1:Default:Added new work unit: cpus:0 gpus:gpu:10:00:00
00:10:05:I1:WU77:Uploading WU results
00:10:05:I1:WU78:Requesting WU assignment for user Maliki2 team 64
00:10:05:I2:OUT33:> POST /api/results HTTP/1.1
00:10:05:I2:OUT34:> POST /api/assign HTTP/1.1
00:10:05:I1:WU77:UPLOAD 98% 16.05KiB of 16.36KiB
00:10:05:I1:WU25:WARNING:Console control signal 1 on PID 8292
00:10:05:I1:WU25:Exiting, please wait. . .
00:10:05:I2:OUT33:< HTTP/1.1 200 HTTP_OK
00:10:05:I1:WU77:Credited
00:10:05:I2:OUT34:< HTTP/1.1 200 HTTP_OK
00:10:05:I1:WU78:Received WU assignment RgO1bYMy5Fi62s1YqbKtKqH21ziW0r3yCNY_wKKfuaM
00:10:07:I1:WU25:Core returned INTERRUPTED (102)
Post by muziqaz »
Malique2 wrote: Fri Nov 07, 2025 12:20 am Ryzen 9 5900x
32 Gig Ram
XFX 9070 Swift
GPU has been added looooooooong time ago.
Please install AMD provided drivers. Microsoft probably silently updated your GPU drivers with windows update
FAH Omega tester
Troubleshooting continues here : viewtopic.php?t=43316
Locked
