SBC continuously staliing project at 42%?
nada391
Post by nada391 »
Hello
have running a small SBC from 2017-2018 arm64
that like to give some heat
however it seem since few week it would not longer complete assignements.
iit would start WU and around 42% loose-abandon it and start anew from 0%.
is this normal behaviour if the SBC has not enough power?
previously it finished proejccts, but it seems not longer.
the last succesful completion is from around 32-40 days ago.
thanks
Re: SBC continuously staliing project at 42%?
Post by calxalot »
Check fah logs?
Check system uptime?
Check that the WUs aren't expiring ... Anything weaker than a RPi 5 might not make the deadlines.
nada391
Post by nada391 »
previsoulsy, 60-70 days ago, it would take about 2 days to complete a WU, and would complete several in a row with no problem;
since , a month or so, it would take aroiund 5 days to complete around 42%, and then start anew, just to stall again at 42%.
did it take on a too big a job and therefore fails?
the credited ones look like
ork Unit #5
Status
Credited
Progress
100.0%
Machine
pine64
OS
linux
TPF
43m 16s
PPD
1,171
CPUs
3
GPUs
none
Run Time
3d 00h
ETA
0s
Assign Time
113d 02h ago
Base Credit
3,515
Deadline
Expired
Timeout
Expired
Core
0xa8
Work Server
vav21.fah.temple.edu
Project
12469
RCG
28,70,266
the 42% ones look like
Work Unit #36
Status
Expired
Progress
42.0%
Machine
pine64
OS
linux
TPF
1d 05h
PPD
105,270
CPUs
3
GPUs
none
Run Time
50d 18h
ETA
1h 06m
Assign Time
55d 16h ago
Base Credit
8,368
Deadline
Expired
Timeout
Expired
Core
0xa8
Work Server
vav22.fah.temple.edu
Project
16959
RCG
29,82,59
but have since yesterday updated the SBC, maybe it helps.
Post by muziqaz »
The sizes of projects differ
FAH Omega tester
Post by calxalot »
Are you using just its big cores and all of them?
nada391
Post by nada391 »
hav always 3 of 4 cores employed,, standard setting.
yesterday updated armbian in-line to debian13 / which seem not recommended pracctice, and went "well"
(thanks also to a post here that showed how to update the fah-client for trixie on raspi os)
now it reports however total load of around 108% when i login via ssh whereas previously it would only report a more sensibly 89% (with setting "full") at around 55 degree celsius. wonder were this will want going.
maybe it can now complete, forunthanks again.
