FahCore_a8 v0.0.12 segfault on Ubuntu 24.04 LTS / Kernel 6.14 - CPU work units crash immediately
Mark_folding
Post by Mark_folding »
Subject: FahCore_a8 v0.0.12 segfault on Ubuntu 24.04 LTS / Kernel 6.14 - CPU work units crash immediately
System Information:
OS: Ubuntu 24.04 LTS
Kernel: 6.14
CPU: AMD Ryzen 9 5900X 12-Core Processor (24 threads)
GPU: NVIDIA GeForce RTX 5070 Ti
RAM: 62.72 GiB
F@H Client: v8.4.9
Username: Hemlok
Team: 250299
Problem Description:
All CPU work units fail immediately after starting with "Core was killed" / "Core crashed with exit code 0" errors. GPU folding works perfectly without issues.
Symptoms:
CPU work units (using FahCore_a8 v0.0.12, Gromacs core) consistently crash within seconds of starting
Work units complete only "1 out of 2500000 steps (0%)" before crashing
GPU work units (using Core22, OpenMM) complete successfully
Pattern repeats with every CPU work unit assigned
Example from F@H logs:
20:55:43:I1:WU185:Project: 16959 (Run 19, Clone 116, Gen 991)
20:55:43:I1:WU185:Calling: mdrun -c frame991.gro -s frame991.tpr -x frame991.xtc -cpt 5 -nt 12 -ntmpi 1
20:55:43:I1:WU185:Steps: first=-1817467296 total=-1814967296
20:55:44:I1:WU185:Completed 1 out of 2500000 steps (0%)
20:56:51:E :WU185:Core was killed
20:56:51:E :WU185:Core crashed with exit code 0
20:56:51:E :WU185:Core returned FAILED_1 (0)
20:56:51:E :WU185:Run did not produce any results. Dumping WU
**Note:** The negative step numbers (`first=-1817467296 total=-1814967296`) appear unusual and may indicate a corrupted work unit or core issue.
**Kernel logs (dmesg) show segmentation faults:**
[15374.949026] FahCore_a8[13727]: segfault at fffffffe2e338230 ip 000000000071b329 sp 000076475dffad70 error 5 in FahCore_a8[31b329,406000+e6d000] likely on CPU 15 (core 3, socket 0)
[15374.949036] Code: 6a 59 d1 c4 41 7a 2c cd c5 7a 2c c1 c5 fa 2c fa c4 c1 7a 2a c1 4d 63 d1 4c 8b 4c 24 30 c4 41 0a 2a f0 c5 12 5c e0 c5 f8 57 c0 <c4> 01 1a 58 2c 91 4d 63 c8 c5 fa 2a c7 4c 8b 44 24 38 c4 41 72 5c
[15493.242565] FahCore_a8[14043]: segfault at fffffffe17b866b0 ip 000000000071b329 sp 000072e7f6ffcd70 error 5 in FahCore_a8[31b329,406000+e6d000] likely on CPU 20 (core 10, socket 0)
[15493.242579] Code: 6a 59 d1 c4 41 7a 2c cd c5 7a 2c c1 c5 fa 2c fa c4 c1 7a 2a c1 4d 63 d1 4c 8b 4c 24 30 c4 41 0a 2a f0 c5 12 5c e0 c5 f8 57 c0 <c4> 01 1a 58 2c 91 4d 63 c8 c5 fa 2a c7 4c 8b 44 24 38 c4 41 72 5c
**FahCore_a8 details:**
Core: Gromacs
Type: 0xa8
Version: 0.0.12
Date: Jan 16 2021
Time: 19:24:44
Compiler: GNU 8.3.0
Platform: linux2 4.15.0-128-generic
Bits: 64
Mode: Release
SIMD: avx2_256
OpenMP: ON
CUDA: OFF
Root Cause:
The FahCore_a8 binary (compiled for kernel 4.15.0-128) is experiencing memory access violations (segfaults) when running on the modern kernel 6.14. The core is attempting to access invalid memory addresses, causing immediate crashes.
Troubleshooting steps attempted:
Fixed v7 to v8 config file migration issues (removed deprecated options: gpu, fold-anon, pci-bus, pci-slot)
Deleted and re-downloaded FahCore_a8 (rm -rf /var/lib/fah-client/cores/fahcore-a8*)
Full service restart
Tried multiple different CPU work units - all crash with identical symptoms
Verified no DNS/network issues (other computers on network fold successfully, GPU folding works)
Checked dmesg logs - confirmed segmentation faults in FahCore_a8
Workaround:
Currently running with CPU folding disabled (<cpus value="0"/> in config.xml). GPU folding continues to work flawlessly.
Question:
Is there a newer version of FahCore_a8 available that's compatible with Ubuntu 24.04 / kernel 6.14? Or is this a known issue with a planned fix?
The core appears to be nearly 4 years old (Jan 2021) and may need to be recompiled for modern Linux kernels.
Re: FahCore_a8 v0.0.12 segfault on Ubuntu 24.04 LTS / Kernel 6.14 - CPU work units crash immediately
Post by muziqaz »
There is nothing wrong with the core. Your CPU/system is unstable
Run full system stability test, like y-cruncher for extensive amount of time to determine if the system is stable or not. The way yours craps out straight away, it might be temperature of the cpu
FAH Omega tester
Mark_folding
How can I test this suggestion further? I stress tested each section of this recently assembled computer one at a time. This is an open case system with air cooling, and it settles in at 70deg C at 100% load. Isn't that well under what this CPU should be capable of? I've been folding on many machines over many years but this is the first time that I've seen this. If I have a flakey CPU, I'm nor sure how to confirm. I used AI to walk me through one test at time for each major component, but I don't have another MB to swap to and have not had time to swap the PSU. That said, this is a top brand 1200w so I'm not expeting that to be a factor when the folding fails on the first unit every time.
mark@titan:~$ stress-ng --cpu 0 --timeout 15m --metrics-brief
stress-ng: info: [14383] setting to a 15 mins, 0 secs run per stressor
stress-ng: info: [14383] dispatching hogs: 24 cpu
stress-ng: info: [14383] note: 24 cpus have scaling governors set to powersave and this can impact on performance; setting /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor to 'performance' may improve performance
stress-ng: metrc: [14383] stressor bogo ops real time usr time sys time bogo ops/s bogo ops/s
stress-ng: metrc: [14383] (secs) (secs) (secs) (real time) (usr+sys time)
stress-ng: metrc: [14383] cpu 32984624 900.00 21320.83 13.10 36649.54 1546.11
stress-ng: info: [14383] skipped: 0
stress-ng: info: [14383] passed: 24: cpu (24)
stress-ng: info: [14383] failed: 0
stress-ng: info: [14383] metrics untrustworthy: 0
stress-ng: info: [14383] successful run completed in 15 mins, 0.01 secs
## Diagnostic Summary & Final Steps
We have now tested every major component that can be reliably checked with software, and they have all passed with flying colors.
-Memory (RAM): Passed
-Graphics Card (GPU): Passed
-Processor (CPU) & Cooling: Passed
-Storage (NVMe SSD): Passed
When the CPU, RAM, GPU, and storage all test clean, suspicion falls on the two components that are very difficult to test with software: the Power Supply Unit (PSU) and the Motherboard.
Post by muziqaz »
run y-cruncher, which loads your system fully
FAH Omega tester
Does it happen with all WUs or only with this one ?
Mark_folding
I've been trying to diagnose this for a week or two. It errors with all CPU jobs. I disabled CPU folding and have only been using my GPU.
muziqaz - y-cruncher only works the CPU which is exactly what stress-ng already does. I can watch all 24 (virtual) cores peg to 100% and it passes 15 minute tests without errors or getting above 70°C
I currently have my ram running an xmp profile, which has not caused any problems in testing or daily use, but I'm going to test that theory just to be sure.
Post by muziqaz »
Y-cruncher stresses your whole system at once. It also uses latest instructions on your CPU, plus loads the whole memory subsystem. It is the closest thing that you can get to FAH besides FAH
FAH Omega tester
Mark_folding
Here is the result from y-cruncher.
Iteration: 0 Total Elapsed Time: 9.912 seconds ( 0.165 minutes )
Running BKT: Passed Test Speed: 1.09 * 10^10 bits / sec
Running BBP:
Exception Encountered: AlgorithmFailedException
Checksum Mismatch
Error(s) encountered on logical core 0.
Checksum Mismatch
Error(s) encountered on logical core 12.
Running BBP: Failed Test Speed: 1.4 * 10^09 terms / sec
Errors encountered. Stopping test...
Test Finished. Waiting for threads to terminate...
Exception Encountered: StressTestFailedException
Stress test failed with 1 error.
Post by muziqaz »
How have you set your memory up?
FAH Omega tester
Mark_folding
I have the xmp setting on now. It's Timetec Pinnacle Konduit RGB DDR4 3200MHz PC4-25600 CL16-18-18-38 XMP2.0 Overclocking 1.35V Compatible for AMD. When I first started testing to understand was was wrong, I set it to the base frequency of 2400MHz. Since it passed ram tests at both settings, I have put it back on the xmp settings. While thinking about it today, I went back into the box for the PSU and discovered that the CPU Power EPS12V cables split into 4+4pin. I was only using 1 8-pin (instead of 8+4) because I didn't think that I had the other one availble. Anyway, I split the second cable and have both installed now. In y-cruncher, it passed the FFT (number 17) test which is marked as all memory, however it failed while running the FFTv4 test (number 18) and all the other tests with the same Error(s) encountered on logical core 0 and core 12. At this point I'm trying to definitivly confirm that the motherboard is issue since it runs fine when not under load (I'm guessing the VRMs or memory controller chip have gone bad). The motherboard is the only thing that I haven't swapped since this started.
Post by muziqaz »
CPU EPS power is overkill. Single 4 pin plug is enough even for highest end desktop CPUs.
Disable XMP and manually start testing lower RAM speeds.
Leave 4 main timings from xmp profile, just reduce the memory speeds step by step (3200MT>3000>2866, etc) and test them with y-cruncher to see which one will pass. Once you found the one which passed go with overnight memtest86+ run.
Keep RAM voltage at 1.35v from xmp
FAH Omega tester
Mark_folding
Just to follow up, I swapped the CPU and the problem went away. Best I can tell, I think I damaged the CPU while folding as an older, slower CPU dropped in and functioned just fine for days. I've also bought a new motherboard and plan to test the questionable CPU in that when I get enough pieces together to make another running system. It performed fine as a daily driver (not folding) all along, so it might still have some life in it. Thank you to the people who responded with help.
