Absolute no ARM64 compatibility
RantanplanFromEarth
Post by RantanplanFromEarth »
Heyho, i have here serveral tv boxes and odroid with "ARM64" technology.
Sure they crunching, but sadly not so often they return valid results.
Whats the matter?
Greetings from germany
Re: Absolute no ARM64 compatibility
Post by muziqaz »
RantanplanFromEarth wrote: Tue Oct 14, 2025 2:59 pm Heyho, i have here serveral tv boxes and odroid with "ARM64" technology.
Whats the matter?
What do you mean by valid results?
If you are receiving work on that hardware, that means it is compatible with FAH
FAH Omega tester
F@h supports ARM64 running on Linux not Android, requires at least the equivalent of a Raspberry Pi 4 though a 5 is strongly recommended. If you have systems that meet those requirements, there may be something not set up correctly. Others have successfully folded using such systems.
My Apple Silicon Macs using ARM64 technology also fold quite well under macOS.
RantanplanFromEarth
ok, thanks for the quick answer. I will now try version v7 of the software, surely the have been managed to run linux on their own way,
waiting online for results. AND counting...
RantanplanFromEarth
It seems to be ok, the software version v7 for ARM64 really worked for me, results allready uploaded today.
Only one wu, but there will be more. Cheers
