Navi 48 / Radeon RX 9070 XT detected but not supported (supported: false)
GGXRDDOP_ENL
Hello,
I'm using Folding@Home client v8.4.9 on Ubuntu 22.04 with an AMD Radeon RX 9070 XT (Navi 48). While the GPU is correctly detected and listed in `gpus.json`, it is marked as `supported: false` and no GPU work units are assigned.
Here are the relevant environment details:
• GPU: Radeon RX 9070 XT (Navi 48)
• OS: Ubuntu 22.04
• OpenCL runtime: AMD APP OpenCL 2.1 (3649.0)
• HIP: Enabled
• clinfo output confirms OpenCL support
• Client log:
gpu:11:00:00": {"vendor": 4098, "device": 30032, "type": "amd", "supported": false, "description": "Navi 48 [Radeon RX 9070(XT)]"}
Is support for this GPU expected in future Core versions?
If there's anything I can help test or submit (clinfo, logs, etc.), I'd be happy to assist.
Additional background:
On Windows 11, Folding@Home does recognize and run tasks on the RX 9070 XT, but when I set the slot to “Any” (mixed CPU/GPU), the work units fail to progress properly. It seems to throw computational errors or silently stall.
Because of repeated issues and instability with Windows itself, I’ve recently switched to Ubuntu as my main Folding environment. On Ubuntu 22.04, the GPU is detected but marked as `supported: false`, so no WUs are assigned at all.
Is there anything I can do on the user side to work around or fix this (e.g. manual configuration, specific driver versions, or flags)? Or is this something that needs to be addressed upstream in the client/core?Or if it is possible for the user to code and debug, please let me know.
Thanks for your help and for maintaining this project.
Best regards.
• OS: Ubuntu 22.04
• HIP: Enabled
• Client log:
Best regards.
Re: Navi 48 / Radeon RX 9070 XT detected but not supported (supported: false)
There are two main requirements to be listed as supported in the F@h client log. One is that the GPU is listed in the GPUs file which it is already. The second is that a properly installed support library for OpenCL can also be detected by the client.
There is this guide for installing the AMD drivers on Linux available for the v8 client - viewtopic.php?t=43222. I don't recall if Ubuntu 22.04 is included. You may need to use a more recent version, or there are older guides that may help.
GGXRDDOP_ENL
I'm not very good at English so please forgive me for relying on translation and AI.
[Environment]
- OS: Ubuntu 22.04 LTS
- GPU: AMD Radeon RX 9070 XT (RDNA4 / Navi48 / gfx1201)
- OpenCL: AMD APP SDK 3649.0 (OpenCL 2.1)
- Client: FAHClient 8.4.9 / 8.5.2-alpha
[Summary]
I tested both FAHClient 8.4.9 and the latest 8.5.2-alpha on Ubuntu 22.04 based on a user comment that suggested reinstalling the client might fix GPU-related issues.
Result:
- With 8.4.9, the behavior was unchanged: GPU is not detected at all.
- With 8.5.2-alpha, the GPU (gfx1201) is finally recognized, but all GPU work units are **immediately discarded** after download. No actual computation is performed.
[Debug Mode Behavior]
- GPU WU downloads successfully.
- GPU slot is assigned and logs appear normal.
- However, execution ends with `SIGSEGV` or immediate termination.
- The slot is then marked idle and another WU is fetched (and discarded again).
- CPU slots are working fine and stable.
Any further insights or development plans regarding **RDNA4 (gfx12xx)** support in Folding@home GPU cores (especially Core22 or Core27) would be appreciated.
Thank you.
[Environment]
[Summary]
Result:
Thank you.
For 9070XT you must use latest distribution, with latest kernel, it also requires mesa drivers installed to even function (though AMD probably has fixed this by now). Once you have mesa drivers installed, remove mesa-icd loader package, then as Joe suggested, go to this post: viewtopic.php?t=43222GGXRDDOP_ENL wrote: ↑Sat Oct 18, 2025 6:22 pm I'm not very good at English so please forgive me for relying on translation and AI.
[Environment]
[Summary]
Result:
Thank you.
read through it, follow it, and start folding
GGXRDDOP_ENL
#Report
I stopped using AI-based setup assistance and rebuilt the environment strictly following AMD’s official documentation. As a result, I successfully ran Folding@home 8.4.9.
Thank you for the support.
I reinstalled the system multiple times, frequently using Ventoy and Rescuezilla. I still used Windows 11 as the starting point, though with the recent wave of issues it’s a bit scary to boot.
#References
#Ubuntu native installation
https://rocm.docs.amd.com/projects/inst ... hatgpt.com
#Install the kernel driver
https://instinct.docs.amd.com/projects/ ... buntu.html
#Update to Ultimate AMD GPU Linux FAH Guide for OpenCL (FAH-Client v8 only)
#Environment (condensed)
OS: Ubuntu 24.04.3 LTS (“noble”)
ROCm: 7.0.2 (/opt/rocm/.info/version)
AMDGPU driver: 6.14.14 (rocm-smi --showdriverversion)
GPU (rocm-smi): AMD Radeon RX 9070 XT (Device ID 0x7550, Rev 0xc0, Subsystem 0x2435, GUID 46869)
Kernel binding: amdgpu (lspci -nnk)
OpenCL (clinfo): Platform detected: AMD Accelerated Parallel Processing (OpenCL 2.1 AMD-APP 3662.0); Number of OpenCL devices: 0
glxinfo: Not installed
#References
ApeAiden
- Hardware configuration: Sapphire Pulse 9070xt, Ryzen 9 5900x, 980PRO, 64gb ram, Gigabyte x570s UD.
ive tried all sorts of solutions for FaH to recognise my 9070xt
- on latest kernel
- added nobel repository etc
it only starts working after a few restarts and numerous attempts
opencl keeps saying 0 specified devices
11:56:46:I1:WU48:Platform 0: Reference
11:56:46:I1:WU48:Platform 1: CPU
11:56:46:I1:WU48:Platform 2: OpenCL
11:56:46:I1:WU48: opencl-device 0 specified
11:56:56:I1:WU48:Attempting to create OpenCL context:
11:56:56:I1:WU48: Configuring platform OpenCL
11:57:00:I1:WU48:Failed to create OpenCL context:
11:57:00:I1:WU48:Error compiling kernel: In file included from <built-in>:1:
11:57:00:I1:WU48:/usr/include/clc/clc.h:19:10: fatal error: 'clc/clcfunc.h' file not found
11:57:00:I1:WU48:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
11:57:00:I1:WU48:Saving result file ../logfile_01.txt
11:57:00:I1:WU48:Saving result file science.log
11:57:00:I1:WU48:Folding@home Core Shutdown: BAD_WORK_UNIT
11:57:00:E :WU48:Core returned BAD_WORK_UNIT (114)
what do i do about this? its being extremley incostistent wether it does this or not.
- on latest kernel
viewtopic.php?t=43222ApeAiden wrote: ↑Sun Nov 23, 2025 12:09 pm ive tried all sorts of solutions for FaH to recognise my 9070xt
- on latest kernel
and remove mesa icd loader
remove nobel repository
ApeAiden
muziqaz wrote: ↑Sun Nov 23, 2025 1:01 pmviewtopic.php?t=43222ApeAiden wrote: ↑Sun Nov 23, 2025 12:09 pm ive tried all sorts of solutions for FaH to recognise my 9070xt
- on latest kernel
im on linux mint 22. do i remove noble considering it was what i had to do to to initially get it to work?. also wont removing mesa lcd loader mess up other things? apologies im new to linux and fah
Mesa icd loader hides AMD rocm from the FAHclient.
When you remove mesa ICD loader, you have to then follow the guide I linked to get rocm runtime installed and opencl icd loader installed (non Mesa). I have 9070 folding on mint 22.1 without any issues. At one point Mesa pushed their own icd loader during update, that messed things up a bit until I removed that loader from the system.
ApeAiden
ah i did sudo update recently, I assume mesa pushed itself during that?muziqaz wrote: ↑Mon Nov 24, 2025 1:04 pm Mesa icd loader hides AMD rocm from the FAHclient.
ApeAiden
i re-added the noble main, and re-did the following commands and it has gotten Fah to work, weird.muziqaz wrote: ↑Mon Nov 24, 2025 1:04 pm Mesa icd loader hides AMD rocm from the FAHclient.
