please add Strix Halo [Radeon 8050S/8060S]
zarya_lyu
Post by zarya_lyu »
thanks
logs:
13:06:06:I1: Version: 8.4.9
13:06:06:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:06:06:I1: Org: foldingathome.org
13:06:06:I1: Copyright: 2023-2024, foldingathome.org
13:06:06:I1: Homepage: https://foldingathome.org/
13:06:06:I1: License: GPL-3.0-or-later
13:06:06:I1: URL: https://v8-4.foldingathome.org/
13:06:06:I1: Date: Nov 20 2024
13:06:06:I1: Time: 14:47:19
13:06:06:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
13:06:06:I1: Branch: master
13:06:06:I1: Compiler: GNU 8.3.0
13:06:06:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
13:06:06:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
13:06:06:I1: Platform: linux 4.19.0-27-cloud-amd64
13:06:06:I1: Bits: 64
13:06:06:I1: Mode: Release
13:06:06:I1: Args: --config=/etc/fah-client/config.xml
13:06:06:I1: --log=/var/log/fah-client/log.txt
13:06:06:I1: --log-rotate-dir=/var/log/fah-client/
13:06:06:I1: Config: /etc/fah-client/config.xml
13:06:06:I1:****************************** CBang ******************************
13:06:06:I1: Version: 1.7.2
13:06:06:I1: Org: Cauldron Development
13:06:06:I1: Copyright: Cauldron Development, 2003-2024
13:06:06:I1: Homepage: https://cauldrondevelopment.com/
13:06:06:I1: License: LGPL-2.1-or-later
13:06:06:I1: Date: Nov 19 2024
13:06:06:I1: Time: 21:54:38
13:06:06:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
13:06:06:I1: -fPIC
13:06:06:I1:***************************** System ******************************
13:06:06:I1: CPU: AMD RYZEN AI MAX+ 395 w/ Radeon 8060S
13:06:06:I1: CPU ID: AuthenticAMD Family 26 Model 112 Stepping 0
13:06:06:I1: CPUs: 32
13:06:06:I1: Memory: 30.99GiB
13:06:06:I1:Free Memory: 26.45GiB
13:06:06:I1: OS Version: 6.14
13:06:06:I1:Has Battery: false
13:06:06:I1: On Battery: false
13:06:06:I1: Hostname:[data expunged]
13:06:06:I1: UTC Offset: 8
13:06:06:I1: PID: 4341
13:06:06:I1: CWD: /var/lib/fah-client
13:06:06:I1: Exec: /usr/bin/fah-client
13:06:06:I1:*******************************************************************
/*some logs*/
13:06:06:I3:gpus = {
13:06:06:I3: "gpu:198:00:00": {"vendor": 4098, "device": 5510, "type": "amd", "supported": false, "description": "Strix Halo [Radeon 8050S/8060S]"}
13:06:06:I3:}
zarya_lyu
Re: please add Strix Halo [Radeon 8050S/8060S]
Post by zarya_lyu »
with rocm-smi:
========================================= ROCm System Management Interface =========================================
=================================================== Concise Info ===================================================
Device Node IDs Temp Power Partitions SCLK MCLK Fan Perf PwrCap VRAM% GPU%
(DID, GUID) (Edge) (Socket) (Mem, Compute, ID)
0 1 0x1586, 51834 42.0°C 83.097W N/A, N/A, 0 N/A 1000Mhz 0% auto N/A 0% 0%
Post by muziqaz »
It is already added long time ago:
You need to sort out your opencl platform:
viewtopic.php?t=43222
FAH Omega tester
The GPU is already in the GPUs.txt file:
0x1002:0x1586:1:9:Strix Halo [Radeon 8050S/8060S]
Most likely your had a message that OpenCL was not detected in the section of log not included. There are directions for installing drivers and OpenCL here - viewtopic.php?t=43222
zarya_lyu
Post by zarya_lyu »
Joe_H wrote: Fri Oct 10, 2025 3:01 pm The GPU is already in the GPUs.txt file:
Thank you
