Logging of WUs / statistics
foldinghomealone
Hardware configuration: 5900x + 5080
Post by foldinghomealone »
Hi there,
as there is no possibility to connect HFM.net to the new client.
Is there an easy method of logging folding statistics locally? Like in a spreadsheet or export it somehow from the new client?
Or parsing the log files?
Thanks in advance
Re: Logging of WUs / statistics
Post by muziqaz »
foldinghomealone wrote: Wed Oct 08, 2025 12:17 pm Hi there,
Thanks in advance
No, but you probably can play around with save page as htm or something.
There is a request made for the dev to implement some sort of export feature for historical data. Not sure when or if ever this will be implemented.
FAH Omega tester
foldinghomealone
ok, thank you. Will have a look how it can be done
Since the client stores data in a Sqlite DB, it might be possible to write a tool that connects to it and grabs data from there ...
JWhy
Post by JWhy »
the latest version of lufah added a history command : https://github.com/kbernhagen/lufah
maybe that will meet your needs ?
foldinghomealone
Thank you all, I will check
