Hello,
I'm sometimes getting an error wux Visualization size exceeded at frame x, no more frames will be loaded on my Gentoo system with client 8.5.1 loaded. I've googled this and there are a number of possibilities that it suggests. The one that interested me the most was in turning off visualizations so that I don't get the error but I can't find where to do that. Am I missing something. Thanks for any help in advance.
Jeff
Re: Visualization size exceeded at frame x
May be fixed in 8.5.2 alpha
There is no support for alpha releases.
You should watch and use github if you want to alpha test.
jeffmr4
- Hardware configuration: AMD 7950x, Nvidia 5060 Ti RTX
Ok, I didn't totally mean to get the newer version. I can wait though. Thanks.
This error is a prevention mechanism for memory leak. The only problem here is that client keeps spamming these messages every step.
jeffmr4
Oh, ok. Thanks.
