Dumped CPU WUs
foldinghomealone
Hardware configuration: 5900x + 5080
Dumped CPU WUs
Post by foldinghomealone »
Hi there,
since a few days, my 5900X produces several dumped WUs, which had never happened before.
I use 20threads on the 5900X.
The dumped WU are 112, 117, 119.
WU112: 0xa9 - 18806
WU117: 0xa9 - 18806
WU119: 0xa8 - 12486
Here you can find the logs:
(Here is log for WU112 only, as with the other logs, the maximum amount of letters is exeeded...)
*********************** Log Started 2025-10-02T00:00:00Z ***********************
00:23:16:I1:WU110:Completed 2150000 out of 2500000 steps (86%)
00:23:17:I1:WU110:Checkpoint completed at step 2150000
00:23:40:I1:WU111:Completed 240000 out of 250000 steps (96%)
00:24:07:I1:WU110:Completed 2175000 out of 2500000 steps (87%)
00:24:20:I1:WU111:Completed 242500 out of 250000 steps (97%)
00:24:58:I1:WU110:Completed 2200000 out of 2500000 steps (88%)
00:24:58:I1:WU110:Checkpoint completed at step 2200000
00:24:59:I1:WU111:Completed 245000 out of 250000 steps (98%)
00:25:39:I1:WU111:Completed 247500 out of 250000 steps (99%)
00:25:49:I1:WU110:Completed 2225000 out of 2500000 steps (89%)
00:26:18:I1:WU111:Completed 250000 out of 250000 steps (100%)
00:26:20:I1:WU111:Saving result file ..\logfile_01.txt
00:26:20:I1:WU111:Saving result file frame615.gro
00:26:20:I1:WU111:Saving result file frame615.xtc
00:26:20:I1:WU111:Saving result file md.log
00:26:20:I1:WU111:Saving result file science.log
00:26:20:I1:WU111:Saving result file state.cpt
00:26:20:I1:WU111:Folding@home Core Shutdown: FINISHED_UNIT
00:26:21:I1:WU111:Core returned FINISHED_UNIT (100)
00:26:21:I1:cpu:Added new work unit: cpus:20 gpus:
00:26:21:I1:WU111:Uploading WU results
00:26:21:I1:WU112:Requesting WU assignment for user foldinghomealone team 70335
00:26:21:I1:OUT58:> POST https://highland1.seas.upenn.edu/api/results HTTP/1.1
00:26:21:I1:OUT59:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
00:26:22:I1:OUT59:< HTTP/1.1 200 HTTP_OK
00:26:22:I1:WU112:Received WU assignment le8T6Gq67gFTnL3ZLmu2yuj-VRjE9d3XPHM0QxTJsWM
00:26:22:I1:WU112:Downloading WU
00:26:22:I1:OUT60:> POST https://fahserver1.flatironinstitute.org/api/assign HTTP/1.1
00:26:27:I1:OUT60:< HTTP/1.1 200 HTTP_OK
00:26:27:I1:WU112:Received WU P18806 R20 C3 G538
00:26:28:I1:Loaded cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/FahCore_a9.exe
00:26:28:I3:Running FahCore: C:\ProgramData\FAHClient\cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/FahCore_a9.exe -dir le8T6Gq67gFTnL3ZLmu2yuj-VRjE9d3XPHM0QxTJsWM -suffix 01 -version 8.4.9 -lifeline 16204 -np 20
00:26:28:I3:WU112:Started FahCore on PID 14548
00:26:28:I1:WU112:*********************** Log Started 2025-10-02T00:26:28Z ***********************
00:26:28:I1:WU112:************************** Gromacs Folding@home Core ***************************
00:26:28:I1:WU112:       Core: Gromacs
00:26:28:I1:WU112:       Type: 0xa9
00:26:28:I1:WU112:    Version: 0.0.12
00:26:28:I1:WU112:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:26:28:I1:WU112:  Copyright: 2022 foldingathome.org
00:26:28:I1:WU112:   Homepage: https://foldingathome.org/
00:26:28:I1:WU112:       Date: Nov 15 2022
00:26:28:I1:WU112:       Time: 13:31:08
00:26:28:I1:WU112:   Compiler: Visual C++
00:26:28:I1:WU112:    Options: /TP /std:c++17 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:26:28:I1:WU112:   Platform: win32 10
00:26:28:I1:WU112:       Bits: 64
00:26:28:I1:WU112:       Mode: Release
00:26:28:I1:WU112:       SIMD: avx2_256
00:26:28:I1:WU112:     OpenMP: ON
00:26:28:I1:WU112:       CUDA: OFF
00:26:28:I1:WU112:     OpenCL: OFF
00:26:28:I1:WU112:       Args: -dir le8T6Gq67gFTnL3ZLmu2yuj-VRjE9d3XPHM0QxTJsWM -suffix 01
00:26:28:I1:WU112:             -version 8.4.9 -lifeline 16204 -np 20
00:26:28:I1:WU112:************************************ libFAH ************************************
00:26:28:I1:WU112:       Time: 13:30:33
00:26:28:I1:WU112:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:26:28:I1:WU112:************************************ CBang *************************************
00:26:28:I1:WU112:       Time: 13:29:57
00:26:28:I1:WU112:************************************ System ************************************
00:26:28:I1:WU112:        CPU: AMD Ryzen 9 5900X 12-Core Processor
00:26:28:I1:WU112:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
00:26:28:I1:WU112:       CPUs: 24
00:26:28:I1:WU112:     Memory: 31.93GiB
00:26:28:I1:WU112:Free Memory: 25.52GiB
00:26:28:I1:WU112:    Threads: WINDOWS_THREADS
00:26:28:I1:WU112: OS Version: 6.2
00:26:28:I1:WU112:Has Battery: false
00:26:28:I1:WU112: On Battery: false
00:26:28:I1:WU112: UTC Offset: 2
00:26:28:I1:WU112:        PID: 14548
00:26:28:I1:WU112:        CWD: C:\ProgramData\FAHClient\work
00:26:28:I1:WU112:       Exec: C:\ProgramData\FAHClient\cores\gromacs-core-a9\windows-10-64bit\cpu-avx2_256-release\fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12\FahCore_a9.exe
00:26:28:I1:WU112:********************************************************************************
00:26:28:I1:WU112:Project: 18806 (Run 20, Clone 3, Gen 538)
00:26:28:I1:WU112:Reading tar file core.xml
00:26:28:I1:WU112:Reading tar file frame538.tpr
00:26:28:I1:WU112:Digital signatures verified
00:26:28:I1:WU112:Calling: mdrun -c frame538.gro -s frame538.tpr -x frame538.xtc -cpt 5 -nt 20 -ntmpi 1 -update cpu -nb cpu -bonded cpu -pme cpu -pmefft cpu
00:26:28:I1:OUT58:< HTTP/1.1 200 HTTP_OK
00:26:28:I1:WU111:Credited
00:26:28:I1:WU112:Steps: first=134500000 total=134750000
00:26:34:I1:WU112:Completed 1 out of 250000 steps (0%)
00:26:39:I1:WU110:Completed 2250000 out of 2500000 steps (90%)
00:26:40:I1:WU110:Checkpoint completed at step 2250000
00:27:33:I1:WU110:Completed 2275000 out of 2500000 steps (91%)
00:28:25:I1:WU110:Completed 2300000 out of 2500000 steps (92%)
00:28:26:I1:WU110:Checkpoint completed at step 2300000
00:29:19:I1:WU110:Completed 2325000 out of 2500000 steps (93%)
00:29:47:I1:WU112:Completed 2500 out of 250000 steps (1%)
00:30:00:W :WU112:Visualization frame 1 unchanged, skipping
00:30:12:I1:WU110:Completed 2350000 out of 2500000 steps (94%)
00:30:13:I1:WU110:Checkpoint completed at step 2350000
00:31:06:I1:WU110:Completed 2375000 out of 2500000 steps (95%)
00:31:59:I1:WU110:Completed 2400000 out of 2500000 steps (96%)
00:32:00:I1:WU110:Checkpoint completed at step 2400000
00:32:52:I1:WU110:Completed 2425000 out of 2500000 steps (97%)
00:33:05:I1:WU112:Completed 5000 out of 250000 steps (2%)
00:33:45:I1:WU110:Completed 2450000 out of 2500000 steps (98%)
00:33:46:I1:WU110:Checkpoint completed at step 2450000
00:34:39:I1:WU110:Completed 2475000 out of 2500000 steps (99%)
00:35:32:I1:WU110:Completed 2500000 out of 2500000 steps (100%)
00:35:32:I1:WU110:Average performance: 163.019 ns/day
00:35:33:I1:WU110:Checkpoint completed at step 2500000
00:35:42:I1:WU110:Saving result file ..\logfile_01.txt
00:35:42:I1:WU110:Saving result file checkpointIntegrator.xml
00:35:42:I1:WU110:Saving result file checkpointState.xml.bz2
00:35:42:I1:WU110:Saving result file positions.xtc
00:35:42:I1:WU110:Saving result file science.log
00:35:42:I1:WU110:Saving result file xtcAtoms.csv.bz2
00:35:42:I1:WU110:Folding@home Core Shutdown: FINISHED_UNIT
00:35:42:I1:WU110:Core returned FINISHED_UNIT (100)
00:35:43:I1:gpu:Added new work unit: cpus:0 gpus:gpu:43:00:00
00:35:43:I1:WU110:Uploading WU results
00:35:43:I1:WU113:Requesting WU assignment for user foldinghomealone team 70335
00:35:43:I1:OUT61:> POST https://highland2.seas.upenn.edu/api/results HTTP/1.1
00:35:43:I1:OUT62:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
00:35:44:I1:OUT62:< HTTP/1.1 200 HTTP_OK
00:35:44:I1:WU113:Received WU assignment C96rH8lfkw-uEmWPOsKP1VxHUaX9JfpevLHvXsDGnIk
00:35:44:I1:WU113:Downloading WU
00:35:44:I1:OUT63:> POST https://ds03.scs.illinois.edu/api/assign HTTP/1.1
00:35:50:I1:OUT63:< HTTP/1.1 200 HTTP_OK
00:35:50:I1:WU113:Received WU P15315 R112 C0 G24
00:35:51:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe -dir C96rH8lfkw-uEmWPOsKP1VxHUaX9JfpevLHvXsDGnIk -suffix 01 -version 8.4.9 -lifeline 16204 -gpu-uuid 751026be-c312-bd3f-36f5-999ca9ef0132 -gpu-platform cuda -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
00:35:51:I3:WU113:Started FahCore on PID 11720
00:35:51:I1:WU113:*********************** Log Started 2025-10-02T00:35:51Z ***********************
00:35:51:I1:WU113:*************************** Core27 Folding@home Core ***************************
00:35:51:I1:WU113:       Core: Core27
00:35:51:I1:WU113:       Type: 0x27
00:35:51:I1:WU113:    Version: 8.2.1
00:35:51:I1:WU113:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:35:51:I1:WU113:  Copyright: 2022 foldingathome.org
00:35:51:I1:WU113:   Homepage: https://foldingathome.org/
00:35:51:I1:WU113:       Date: Mar 27 2025
00:35:51:I1:WU113:       Time: 04:46:58
00:35:51:I1:WU113:   Revision: 84019442387121f2bed4ed52e05c53b7b7b52a72
00:35:51:I1:WU113:     Branch: HEAD
00:35:51:I1:WU113:   Compiler: Visual C++
00:35:51:I1:WU113:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
00:35:51:I1:WU113:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
00:35:51:I1:WU113:   Platform: win32 10
00:35:51:I1:WU113:       Bits: 64
00:35:51:I1:WU113:       Mode: Release
00:35:51:I1:WU113:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:35:51:I1:WU113:             <peastman@stanford.edu>
00:35:51:I1:WU113:       Args: -dir C96rH8lfkw-uEmWPOsKP1VxHUaX9JfpevLHvXsDGnIk -suffix 01
00:35:51:I1:WU113:             -version 8.4.9 -lifeline 16204 -gpu-uuid
00:35:51:I1:WU113:             751026be-c312-bd3f-36f5-999ca9ef0132 -gpu-platform cuda -gpu-vendor
00:35:51:I1:WU113:             nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0
00:35:51:I1:WU113:             -cuda-device 0 -gpu 0
00:35:51:I1:WU113:************************************ libFAH ************************************
00:35:51:I1:WU113:       Time: 04:30:44
00:35:51:I1:WU113:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
00:35:51:I1:WU113:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:35:51:I1:WU113:************************************ CBang *************************************
00:35:51:I1:WU113:    Version: 1.7.2
00:35:51:I1:WU113:        Org: Cauldron Development LLC
00:35:51:I1:WU113:  Copyright: Cauldron Development LLC, 2003-2024
00:35:51:I1:WU113:   Homepage: https://cauldrondevelopment.com/
00:35:51:I1:WU113:    License: LGPL-2.1-or-later
00:35:51:I1:WU113:       Time: 04:29:12
00:35:51:I1:WU113:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
00:35:51:I1:WU113:************************************ System ************************************
00:35:51:I1:WU113:        CPU: AMD Ryzen 9 5900X 12-Core Processor
00:35:51:I1:WU113:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
00:35:51:I1:WU113:       CPUs: 24
00:35:51:I1:WU113:     Memory: 31.93GiB
00:35:51:I1:WU113:Free Memory: 23.21GiB
00:35:51:I1:WU113: OS Version: 10.0
00:35:51:I1:WU113:Has Battery: false
00:35:51:I1:WU113: On Battery: false
00:35:51:I1:WU113:   Hostname: DESKTOP-VQLISJP
00:35:51:I1:WU113: UTC Offset: 2
00:35:51:I1:WU113:        PID: 11720
00:35:51:I1:WU113:        CWD: C:\ProgramData\FAHClient\work
00:35:51:I1:WU113:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
00:35:51:I1:WU113:************************************ OpenMM ************************************
00:35:51:I1:WU113:    Version: 8.2.0
00:35:51:I1:WU113:********************************************************************************
00:35:51:I1:WU113:Project: 15315 (Run 112, Clone 0, Gen 24)
00:35:51:I1:WU113:Reading tar file core.xml
00:35:51:I1:WU113:Reading tar file integrator.xml
00:35:51:I1:WU113:Reading tar file state.xml
00:35:51:I1:WU113:Reading tar file system.xml
00:35:52:I1:WU113:Digital signatures verified
00:35:52:I1:WU113:Folding@home GPU Core27 Folding@home Core
00:35:52:I1:WU113:Version 8.2.1
00:35:52:I1:WU113:  GPU info: Platform: OpenCL: NVIDIA CUDA
00:35:52:I1:WU113:  GPU info: PlatformIndex: 0
00:35:52:I1:WU113:  GPU info: Device: NVIDIA GeForce RTX 3080 Ti
00:35:52:I1:WU113:  GPU info: DeviceIndex: 0
00:35:52:I1:WU113:  GPU info: Vendor: 0x10de
00:35:52:I1:WU113:  GPU info: PCI: 43:00:00
00:35:52:I1:WU113:  GPU info: Compute: 3.0
00:35:52:I1:WU113:  GPU info: Driver: 581.42
00:35:52:I1:WU113:  GPU info: GPU: true
00:35:52:I1:WU113:  GPU info: Platform: CUDA
00:35:52:I1:WU113:  GPU info: Compute: 8.6
00:35:52:I1:WU113:  GPU info: Driver: 13.0
00:35:52:I1:WU113:  Checkpoint write interval: 62500 steps (5%) [20 total]
00:35:52:I1:WU113:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
00:35:52:I1:WU113:  XTC frame write interval: 50000 steps (4%) [25 total]
00:35:52:I1:WU113:  TRR frame write interval: disabled
00:35:52:I1:WU113:  Global context and integrator variables write interval: disabled
00:35:52:I1:WU113:There are 4 platforms available.
00:35:52:I1:WU113:Platform 0: Reference
00:35:52:I1:WU113:Platform 1: CPU
00:35:52:I1:WU113:Platform 2: OpenCL
00:35:52:I1:WU113:  opencl-device 0 specified
00:35:52:I1:WU113:Platform 3: CUDA
00:35:52:I1:WU113:  cuda-device 0 specified
00:36:13:I1:WU113:Attempting to create CUDA context:
00:36:13:I1:WU113:  Configuring platform CUDA
00:36:15:I1:WU112:Completed 7500 out of 250000 steps (3%)
00:36:15:I1:OUT61:< HTTP/1.1 200 HTTP_OK
00:36:15:I1:WU110:Credited
00:36:23:I1:WU113:  Using CUDA on CUDA Platform and gpu 0
00:36:23:I1:WU113:  GPU info: Platform: CUDA
00:36:23:I1:WU113:  GPU info: PlatformIndex: 0
00:36:23:I1:WU113:  GPU info: Device: NVIDIA GeForce RTX 3080 Ti
00:36:23:I1:WU113:  GPU info: DeviceIndex: 0
00:36:23:I1:WU113:  GPU info: Vendor: 0x10de
00:36:23:I1:WU113:  GPU info: PCI: 43:00:00
00:36:23:I1:WU113:  GPU info: Compute: 8.6
00:36:23:I1:WU113:  GPU info: Driver: 13.0
00:36:23:I1:WU113:  GPU info: GPU: true
00:36:23:I1:WU113:Completed 0 out of 1250000 steps (0%)
00:36:25:I1:WU113:Checkpoint completed at step 0
00:36:27:W :WU112:Visualization frame 3 unchanged, skipping
00:36:56:I1:WU113:Completed 12500 out of 1250000 steps (1%)
00:37:26:I1:WU113:Completed 25000 out of 1250000 steps (2%)
00:37:56:I1:WU113:Completed 37500 out of 1250000 steps (3%)
00:38:27:I1:WU113:Completed 50000 out of 1250000 steps (4%)
00:38:57:I1:WU113:Completed 62500 out of 1250000 steps (5%)
00:38:59:I1:WU113:Checkpoint completed at step 62500
00:39:30:I1:WU113:Completed 75000 out of 1250000 steps (6%)
00:39:34:I1:WU112:Completed 10000 out of 250000 steps (4%)
00:40:00:I1:WU113:Completed 87500 out of 1250000 steps (7%)
00:40:30:I1:WU113:Completed 100000 out of 1250000 steps (8%)
00:41:01:I1:WU113:Completed 112500 out of 1250000 steps (9%)
00:41:31:I1:WU113:Completed 125000 out of 1250000 steps (10%)
00:41:34:I1:WU113:Checkpoint completed at step 125000
00:42:04:I1:WU113:Completed 137500 out of 1250000 steps (11%)
00:42:34:I1:WU113:Completed 150000 out of 1250000 steps (12%)
00:42:50:I1:WU112:Completed 12500 out of 250000 steps (5%)
00:43:05:I1:WU113:Completed 162500 out of 1250000 steps (13%)
00:43:35:I1:WU113:Completed 175000 out of 1250000 steps (14%)
00:44:05:I1:WU113:Completed 187500 out of 1250000 steps (15%)
00:44:08:I1:WU113:Checkpoint completed at step 187500
00:44:38:I1:WU113:Completed 200000 out of 1250000 steps (16%)
00:45:09:I1:WU113:Completed 212500 out of 1250000 steps (17%)
00:45:39:I1:WU113:Completed 225000 out of 1250000 steps (18%)
00:46:03:I1:WU112:Completed 15000 out of 250000 steps (6%)
00:46:09:I1:WU113:Completed 237500 out of 1250000 steps (19%)
00:46:16:W :WU112:Visualization frame 6 unchanged, skipping
00:46:39:I1:WU113:Completed 250000 out of 1250000 steps (20%)
00:46:41:I1:WU113:Checkpoint completed at step 250000
00:47:12:I1:WU113:Completed 262500 out of 1250000 steps (21%)
00:47:42:I1:WU113:Completed 275000 out of 1250000 steps (22%)
00:48:13:I1:WU113:Completed 287500 out of 1250000 steps (23%)<
00:48:43:I1:WU113:Completed 300000 out of 1250000 steps (24%)
00:49:14:I1:WU113:Completed 312500 out of 1250000 steps (25%)
00:49:16:I1:WU113:Checkpoint completed at step 312500
00:49:21:I1:WU112:Completed 17500 out of 250000 steps (7%)
00:49:46:I1:WU113:Completed 325000 out of 1250000 steps (26%)
00:50:17:I1:WU113:Completed 337500 out of 1250000 steps (27%)
00:50:47:I1:WU113:Completed 350000 out of 1250000 steps (28%)
00:51:18:I1:WU113:Completed 362500 out of 1250000 steps (29%)
00:51:48:I1:WU113:Completed 375000 out of 1250000 steps (30%)
00:51:51:I1:WU113:Checkpoint completed at step 375000
00:52:21:I1:WU113:Completed 387500 out of 1250000 steps (31%)
00:52:37:I1:WU112:Completed 20000 out of 250000 steps (8%)
00:52:52:I1:WU113:Completed 400000 out of 1250000 steps (32%)
00:53:23:I1:WU113:Completed 412500 out of 1250000 steps (33%)
00:53:53:I1:WU113:Completed 425000 out of 1250000 steps (34%)
00:54:23:I1:WU113:Completed 437500 out of 1250000 steps (35%)
00:54:26:I1:WU113:Checkpoint completed at step 437500
00:54:56:I1:WU113:Completed 450000 out of 1250000 steps (36%)
00:55:27:I1:WU113:Completed 462500 out of 1250000 steps (37%)
00:55:49:I1:WU112:Completed 22500 out of 250000 steps (9%)
00:55:57:I1:WU113:Completed 475000 out of 1250000 steps (38%)
00:56:02:W :WU112:Visualization frame 9 unchanged, skipping
00:56:28:I1:WU113:Completed 487500 out of 1250000 steps (39%)
00:56:58:I1:WU113:Completed 500000 out of 1250000 steps (40%)
00:57:00:I1:WU113:Checkpoint completed at step 500000
00:57:30:I1:WU113:Completed 512500 out of 1250000 steps (41%)
00:58:01:I1:WU113:Completed 525000 out of 1250000 steps (42%)
00:58:31:I1:WU113:Completed 537500 out of 1250000 steps (43%)
00:59:01:I1:WU113:Completed 550000 out of 1250000 steps (44%)
00:59:04:I1:WU112:Completed 25000 out of 250000 steps (10%)
00:59:31:I1:WU113:Completed 562500 out of 1250000 steps (45%)
00:59:33:I1:WU113:Checkpoint completed at step 562500
01:00:04:I1:WU113:Completed 575000 out of 1250000 steps (46%)
01:00:34:I1:WU113:Completed 587500 out of 1250000 steps (47%)
01:01:05:I1:WU113:Completed 600000 out of 1250000 steps (48%)
01:01:35:I1:WU113:Completed 612500 out of 1250000 steps (49%)
01:02:05:I1:WU113:Completed 625000 out of 1250000 steps (50%)
01:02:07:I1:WU113:Checkpoint completed at step 625000
01:02:21:I1:WU112:Completed 27500 out of 250000 steps (11%)
01:02:37:I1:WU113:Completed 637500 out of 1250000 steps (51%)
01:03:08:I1:WU113:Completed 650000 out of 1250000 steps (52%)
01:03:38:I1:WU113:Completed 662500 out of 1250000 steps (53%)
01:04:08:I1:WU113:Completed 675000 out of 1250000 steps (54%)
01:04:38:I1:WU113:Completed 687500 out of 1250000 steps (55%)
01:04:41:I1:WU113:Checkpoint completed at step 687500
01:05:11:I1:WU113:Completed 700000 out of 1250000 steps (56%)
01:05:34:I1:WU112:Completed 30000 out of 250000 steps (12%)
01:05:41:I1:WU113:Completed 712500 out of 1250000 steps (57%)
01:05:46:W :WU112:Visualization frame 12 unchanged, skipping
01:06:12:I1:WU113:Completed 725000 out of 1250000 steps (58%)
01:06:41:I1:WU113:Completed 737500 out of 1250000 steps (59%)
01:07:11:I1:WU113:Completed 750000 out of 1250000 steps (60%)
01:07:13:I1:WU113:Checkpoint completed at step 750000
01:07:44:I1:WU113:Completed 762500 out of 1250000 steps (61%)
01:08:14:I1:WU113:Completed 775000 out of 1250000 steps (62%)
01:08:45:I1:WU113:Completed 787500 out of 1250000 steps (63%)
01:08:50:I1:WU112:Completed 32500 out of 250000 steps (13%)
01:09:15:I1:WU113:Completed 800000 out of 1250000 steps (64%)
01:09:46:I1:WU113:Completed 812500 out of 1250000 steps (65%)
01:09:49:I1:WU113:Checkpoint completed at step 812500
01:10:19:I1:WU113:Completed 825000 out of 1250000 steps (66%)
01:10:49:I1:WU113:Completed 837500 out of 1250000 steps (67%)
01:11:20:I1:WU113:Completed 850000 out of 1250000 steps (68%)
01:11:50:I1:WU113:Completed 862500 out of 1250000 steps (69%)
01:12:06:I1:WU112:Completed 35000 out of 250000 steps (14%)
01:12:20:I1:WU113:Completed 875000 out of 1250000 steps (70%)
01:12:23:I1:WU113:Checkpoint completed at step 875000
01:12:53:I1:WU113:Completed 887500 out of 1250000 steps (71%)
01:13:24:I1:WU113:Completed 900000 out of 1250000 steps (72%)
01:13:54:I1:WU113:Completed 912500 out of 1250000 steps (73%)
01:14:25:I1:WU113:Completed 925000 out of 1250000 steps (74%)
01:14:55:I1:WU113:Completed 937500 out of 1250000 steps (75%)
01:14:57:I1:WU113:Checkpoint completed at step 937500
01:15:20:I1:WU112:Completed 37500 out of 250000 steps (15%)
01:15:28:I1:WU113:Completed 950000 out of 1250000 steps (76%)
01:15:33:W :WU112:Visualization frame 15 unchanged, skipping
01:15:58:I1:WU113:Completed 962500 out of 1250000 steps (77%)
01:16:29:I1:WU113:Completed 975000 out of 1250000 steps (78%)
01:16:58:I1:WU113:Completed 987500 out of 1250000 steps (79%)
01:17:29:I1:WU113:Completed 1000000 out of 1250000 steps (80%)
01:17:32:I1:WU113:Checkpoint completed at step 1000000
01:18:02:I1:WU113:Completed 1012500 out of 1250000 steps (81%)
01:18:32:I1:WU113:Completed 1025000 out of 1250000 steps (82%)
01:18:37:I1:WU112:Completed 40000 out of 250000 steps (16%)
01:19:03:I1:WU113:Completed 1037500 out of 1250000 steps (83%)
01:19:33:I1:WU113:Completed 1050000 out of 1250000 steps (84%)
01:20:03:I1:WU113:Completed 1062500 out of 1250000 steps (85%)
01:20:06:I1:WU113:Checkpoint completed at step 1062500
01:20:36:I1:WU113:Completed 1075000 out of 1250000 steps (86%)
01:21:06:I1:WU113:Completed 1087500 out of 1250000 steps (87%)
01:21:37:I1:WU113:Completed 1100000 out of 1250000 steps (88%)
01:21:53:I1:WU112:Completed 42500 out of 250000 steps (17%)
01:22:07:I1:WU113:Completed 1112500 out of 1250000 steps (89%)
01:22:37:I1:WU113:Completed 1125000 out of 1250000 steps (90%)
01:22:39:I1:WU113:Checkpoint completed at step 1125000
01:23:10:I1:WU113:Completed 1137500 out of 1250000 steps (91%)
01:23:40:I1:WU113:Completed 1150000 out of 1250000 steps (92%)
01:24:11:I1:WU113:Completed 1162500 out of 1250000 steps (93%)
01:24:41:I1:WU113:Completed 1175000 out of 1250000 steps (94%)
01:25:06:I1:WU112:Completed 45000 out of 250000 steps (18%)
01:25:11:I1:WU113:Completed 1187500 out of 1250000 steps (95%)
01:25:13:I1:WU113:Checkpoint completed at step 1187500
01:25:19:W :WU112:Visualization frame 18 unchanged, skipping
01:25:44:I1:WU113:Completed 1200000 out of 1250000 steps (96%)
01:26:14:I1:WU113:Completed 1212500 out of 1250000 steps (97%)
01:26:44:I1:WU113:Completed 1225000 out of 1250000 steps (98%)
01:27:15:I1:WU113:Completed 1237500 out of 1250000 steps (99%)
01:27:45:I1:WU113:Completed 1250000 out of 1250000 steps (100%)
01:27:45:I1:WU113:Average performance: 142.105 ns/day
01:27:47:I1:WU113:Checkpoint completed at step 1250000
01:27:52:I1:WU113:Saving result file ..\logfile_01.txt
01:27:52:I1:WU113:Saving result file checkpointIntegrator.xml
01:27:52:I1:WU113:Saving result file checkpointState.xml
01:27:55:I1:WU113:Saving result file positions.xtc
01:27:56:I1:WU113:Saving result file science.log
01:27:56:I1:WU113:Folding@home Core Shutdown: FINISHED_UNIT
01:27:57:I1:WU113:Core returned FINISHED_UNIT (100)
01:27:58:I1:gpu:Added new work unit: cpus:0 gpus:gpu:43:00:00
01:27:58:I1:WU113:Uploading WU results
01:27:58:I1:WU114:Requesting WU assignment for user foldinghomealone team 70335
01:27:58:I1:OUT64:> POST https://ds03.scs.illinois.edu/api/results HTTP/1.1
01:27:58:I1:OUT65:> POST https://assign6.foldingathome.org/api/assign HTTP/1.1
01:27:59:I1:OUT65:< HTTP/1.1 200 HTTP_OK
01:27:59:I1:WU114:Received WU assignment zfUlLLt_QESCps8C_CjGCkFsnSx4N0EpmDn89crzHKw
01:27:59:I1:WU114:Downloading WU
01:27:59:I1:OUT66:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
01:28:01:I1:OUT66:< HTTP/1.1 200 HTTP_OK
01:28:01:I1:WU114:Received WU P18242 R877 C4 G87
01:28:01:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-26/windows-10-64bit/release/fahcore-26-windows-10-64bit-release-8.2.0/FahCore_26.exe -dir zfUlLLt_QESCps8C_CjGCkFsnSx4N0EpmDn89crzHKw -suffix 01 -version 8.4.9 -lifeline 16204 -gpu-uuid 751026be-c312-bd3f-36f5-999ca9ef0132 -gpu-platform cuda -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
01:28:01:I3:WU114:Started FahCore on PID 9804
01:28:02:I1:WU114:*********************** Log Started 2025-10-02T01:28:01Z ***********************
01:28:02:I1:WU114:*************************** Core26 Folding@home Core ***************************
01:28:02:I1:WU114:       Core: Core26
01:28:02:I1:WU114:       Type: 0x26
01:28:02:I1:WU114:    Version: 8.2.0
01:28:02:I1:WU114:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:28:02:I1:WU114:  Copyright: 2022 foldingathome.org
01:28:02:I1:WU114:   Homepage: https://foldingathome.org/
01:28:02:I1:WU114:       Date: Jan 7 2025
01:28:02:I1:WU114:       Time: 00:58:59
01:28:02:I1:WU114:   Revision: 4f149b599caa4725076ef2de3b47c8d7ce725787
01:28:02:I1:WU114:     Branch: HEAD
01:28:02:I1:WU114:   Compiler: Visual C++
01:28:02:I1:WU114:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
01:28:02:I1:WU114:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
01:28:02:I1:WU114:   Platform: win32 10
01:28:02:I1:WU114:       Bits: 64
01:28:02:I1:WU114:       Mode: Release
01:28:02:I1:WU114:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:28:02:I1:WU114:             <peastman@stanford.edu>
01:28:02:I1:WU114:       Args: -dir zfUlLLt_QESCps8C_CjGCkFsnSx4N0EpmDn89crzHKw -suffix 01
01:28:02:I1:WU114:             -version 8.4.9 -lifeline 16204 -gpu-uuid
01:28:02:I1:WU114:             751026be-c312-bd3f-36f5-999ca9ef0132 -gpu-platform cuda -gpu-vendor
01:28:02:I1:WU114:             nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0
01:28:02:I1:WU114:             -cuda-device 0 -gpu 0
01:28:02:I1:WU114:************************************ libFAH ************************************
01:28:02:I1:WU114:       Time: 00:39:45
01:28:02:I1:WU114:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
01:28:02:I1:WU114:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:28:02:I1:WU114:************************************ CBang *************************************
01:28:02:I1:WU114:    Version: 1.7.2
01:28:02:I1:WU114:        Org: Cauldron Development LLC
01:28:02:I1:WU114:  Copyright: Cauldron Development LLC, 2003-2024
01:28:02:I1:WU114:   Homepage: https://cauldrondevelopment.com/
01:28:02:I1:WU114:    License: LGPL-2.1-or-later
01:28:02:I1:WU114:       Time: 00:38:35
01:28:02:I1:WU114:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
01:28:02:I1:WU114:************************************ System ************************************
01:28:02:I1:WU114:        CPU: AMD Ryzen 9 5900X 12-Core Processor
01:28:02:I1:WU114:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
01:28:02:I1:WU114:       CPUs: 24
01:28:02:I1:WU114:     Memory: 31.93GiB
01:28:02:I1:WU114:Free Memory: 22.30GiB
01:28:02:I1:WU114: OS Version: 10.0
01:28:02:I1:WU114:Has Battery: false
01:28:02:I1:WU114: On Battery: false
01:28:02:I1:WU114:   Hostname: DESKTOP-VQLISJP
01:28:02:I1:WU114: UTC Offset: 2
01:28:02:I1:WU114:        PID: 9804
01:28:02:I1:WU114:        CWD: C:\ProgramData\FAHClient\work
01:28:02:I1:WU114:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-26\windows-10-64bit\release\fahcore-26-windows-10-64bit-release-8.2.0\FahCore_26.exe
01:28:02:I1:WU114:************************************ OpenMM ************************************
01:28:02:I1:WU114:********************************************************************************
01:28:02:I1:WU114:Project: 18242 (Run 877, Clone 4, Gen 87)
01:28:02:I1:WU114:Reading tar file core.xml
01:28:02:I1:WU114:Reading tar file integrator.xml
01:28:02:I1:WU114:Reading tar file state.xml.bz2
01:28:02:I1:WU114:Reading tar file system.xml.bz2
01:28:02:I1:WU114:Digital signatures verified
01:28:02:I1:WU114:Folding@home GPU Core26 Folding@home Core
01:28:02:I1:WU114:Version 8.2
01:28:02:I1:WU114:  Checkpoint write interval: 50000 steps (2%) [50 total]
01:28:02:I1:WU114:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
01:28:02:I1:WU114:  XTC frame write interval: 10000 steps (0.4%) [250 total]
01:28:02:I1:WU114:  TRR frame write interval: disabled
01:28:02:I1:WU114:  Global context and integrator variables write interval: disabled
01:28:02:I1:WU114:There are 4 platforms available.
01:28:02:I1:WU114:Platform 0: Reference
01:28:02:I1:WU114:Platform 1: CPU
01:28:02:I1:WU114:Platform 2: OpenCL
01:28:02:I1:WU114:  opencl-device 0 specified
01:28:02:I1:WU114:Platform 3: CUDA
01:28:02:I1:WU114:  cuda-device 0 specified
01:28:20:I1:WU112:Completed 47500 out of 250000 steps (19%)
01:28:22:I1:WU114:Attempting to create CUDA context:
01:28:22:I1:WU114:  Configuring platform CUDA
01:28:23:I1:OUT64:< HTTP/1.1 200 HTTP_OK
01:28:23:I1:WU113:Credited
01:28:25:I1:WU114:  Using CUDA on CUDA Platform and gpu 0
01:28:25:I1:WU114:  GPU info: Platform: CUDA
01:28:25:I1:WU114:  GPU info: PlatformIndex: 0
01:28:25:I1:WU114:  GPU info: Device: NVIDIA GeForce RTX 3080 Ti
01:28:25:I1:WU114:  GPU info: DeviceIndex: 0
01:28:25:I1:WU114:  GPU info: Vendor: 0x10de
01:28:25:I1:WU114:  GPU info: PCI: 43:00:00
01:28:25:I1:WU114:  GPU info: Compute: 8.6
01:28:25:I1:WU114:  GPU info: Driver: 13.0
01:28:25:I1:WU114:  GPU info: GPU: true
01:28:25:I1:WU114:Completed 0 out of 2500000 steps (0%)
01:28:26:I1:WU114:Checkpoint completed at step 0
01:29:19:I1:WU114:Completed 25000 out of 2500000 steps (1%)
01:30:12:I1:WU114:Completed 50000 out of 2500000 steps (2%)
01:30:13:I1:WU114:Checkpoint completed at step 50000
01:31:06:I1:WU114:Completed 75000 out of 2500000 steps (3%)
01:31:33:I1:WU112:Completed 50000 out of 250000 steps (20%)
01:31:59:I1:WU114:Completed 100000 out of 2500000 steps (4%)
01:31:59:I1:WU114:Checkpoint completed at step 100000
01:32:52:I1:WU114:Completed 125000 out of 2500000 steps (5%)
01:33:46:I1:WU114:Completed 150000 out of 2500000 steps (6%)
01:33:46:I1:WU114:Checkpoint completed at step 150000
01:34:40:I1:WU114:Completed 175000 out of 2500000 steps (7%)
01:34:51:I1:WU112:Completed 52500 out of 250000 steps (21%)
01:35:03:W :WU112:Visualization frame 21 unchanged, skipping
01:35:33:I1:WU114:Completed 200000 out of 2500000 steps (8%)
01:35:34:I1:WU114:Checkpoint completed at step 200000
01:36:27:I1:WU114:Completed 225000 out of 2500000 steps (9%)
01:37:20:I1:WU114:Completed 250000 out of 2500000 steps (10%)
01:37:21:I1:WU114:Checkpoint completed at step 250000
01:38:07:I1:WU112:Completed 55000 out of 250000 steps (22%)
01:38:14:I1:WU114:Completed 275000 out of 2500000 steps (11%)
01:39:08:I1:WU114:Completed 300000 out of 2500000 steps (12%)
01:39:08:I1:WU114:Checkpoint completed at step 300000
01:40:02:I1:WU114:Completed 325000 out of 2500000 steps (13%)
01:40:55:I1:WU114:Completed 350000 out of 2500000 steps (14%)
01:40:56:I1:WU114:Checkpoint completed at step 350000
01:41:21:I1:WU112:Completed 57500 out of 250000 steps (23%)
01:41:34:W :WU112:Visualization frame 23 unchanged, skipping
01:41:49:I1:WU114:Completed 375000 out of 2500000 steps (15%)
01:42:42:I1:WU114:Completed 400000 out of 2500000 steps (16%)
01:42:43:I1:WU114:Checkpoint completed at step 400000
01:43:36:I1:WU114:Completed 425000 out of 2500000 steps (17%)
01:44:30:I1:WU114:Completed 450000 out of 2500000 steps (18%)
01:44:30:I1:WU114:Checkpoint completed at step 450000
01:44:38:I1:WU112:Completed 60000 out of 250000 steps (24%)
01:45:24:I1:WU114:Completed 475000 out of 2500000 steps (19%)
01:46:17:I1:WU114:Completed 500000 out of 2500000 steps (20%)
01:46:18:I1:WU114:Checkpoint completed at step 500000
01:47:11:I1:WU114:Completed 525000 out of 2500000 steps (21%)
01:47:55:I1:WU112:Completed 62500 out of 250000 steps (25%)
01:48:04:I1:WU114:Completed 550000 out of 2500000 steps (22%)
01:48:05:I1:WU114:Checkpoint completed at step 550000
01:48:58:I1:WU114:Completed 575000 out of 2500000 steps (23%)
01:49:52:I1:WU114:Completed 600000 out of 2500000 steps (24%)
01:49:53:I1:WU114:Checkpoint completed at step 600000
01:50:46:I1:WU114:Completed 625000 out of 2500000 steps (25%)
01:51:09:I1:WU112:Completed 65000 out of 250000 steps (26%)
01:51:23:W :WU112:Visualization frame 26 unchanged, skipping
01:51:39:I1:WU114:Completed 650000 out of 2500000 steps (26%)
01:51:40:I1:WU114:Checkpoint completed at step 650000
01:52:33:I1:WU114:Completed 675000 out of 2500000 steps (27%)
01:53:26:I1:WU114:Completed 700000 out of 2500000 steps (28%)
01:53:27:I1:WU114:Checkpoint completed at step 700000
01:54:20:I1:WU114:Completed 725000 out of 2500000 steps (29%)
01:54:26:I1:WU112:Completed 67500 out of 250000 steps (27%)
01:55:14:I1:WU114:Completed 750000 out of 2500000 steps (30%)
01:55:14:I1:WU114:Checkpoint completed at step 750000
01:56:08:I1:WU114:Completed 775000 out of 2500000 steps (31%)
01:57:01:I1:WU114:Completed 800000 out of 2500000 steps (32%)
01:57:02:I1:WU114:Checkpoint completed at step 800000
01:57:43:I1:WU112:Completed 70000 out of 250000 steps (28%)
01:57:55:I1:WU114:Completed 825000 out of 2500000 steps (33%)
01:58:49:I1:WU114:Completed 850000 out of 2500000 steps (34%)
01:58:50:I1:WU114:Checkpoint completed at step 850000
01:59:43:I1:WU114:Completed 875000 out of 2500000 steps (35%)
02:00:01:I1:Group state finish
02:00:37:I1:WU114:Completed 900000 out of 2500000 steps (36%)
02:00:37:I1:WU114:Checkpoint completed at step 900000
02:00:56:I1:WU112:Completed 72500 out of 250000 steps (29%)
02:01:09:W :WU112:Visualization frame 29 unchanged, skipping
02:01:31:I1:WU114:Completed 925000 out of 2500000 steps (37%)
02:02:24:I1:WU114:Completed 950000 out of 2500000 steps (38%)
02:02:24:I1:WU114:Checkpoint completed at step 950000
02:03:18:I1:WU114:Completed 975000 out of 2500000 steps (39%)
02:04:11:I1:WU114:Completed 1000000 out of 2500000 steps (40%)
02:04:12:I1:WU114:Checkpoint completed at step 1000000
02:04:13:I1:WU112:Completed 75000 out of 250000 steps (30%)
02:05:05:I1:WU114:Completed 1025000 out of 2500000 steps (41%)
02:05:58:I1:WU114:Completed 1050000 out of 2500000 steps (42%)
02:05:59:I1:WU114:Checkpoint completed at step 1050000
02:06:52:I1:WU114:Completed 1075000 out of 2500000 steps (43%)
02:07:29:I1:WU112:Completed 77500 out of 250000 steps (31%)
02:07:45:I1:WU114:Completed 1100000 out of 2500000 steps (44%)
02:07:46:I1:WU114:Checkpoint completed at step 1100000
02:08:39:I1:WU114:Completed 1125000 out of 2500000 steps (45%)
02:09:32:I1:WU114:Completed 1150000 out of 2500000 steps (46%)
02:09:33:I1:WU114:Checkpoint completed at step 1150000
02:10:26:I1:WU114:Completed 1175000 out of 2500000 steps (47%)
02:10:43:I1:WU112:Completed 80000 out of 250000 steps (32%)
02:10:57:W :WU112:Visualization frame 32 unchanged, skipping
02:11:20:I1:WU114:Completed 1200000 out of 2500000 steps (48%)
02:11:20:I1:WU114:Checkpoint completed at step 1200000
02:12:13:I1:WU114:Completed 1225000 out of 2500000 steps (49%)
02:13:06:I1:WU114:Completed 1250000 out of 2500000 steps (50%)
02:13:07:I1:WU114:Checkpoint completed at step 1250000
02:14:00:I1:WU112:Completed 82500 out of 250000 steps (33%)
02:14:00:I1:WU114:Completed 1275000 out of 2500000 steps (51%)
02:14:54:I1:WU114:Completed 1300000 out of 2500000 steps (52%)
02:14:54:I1:WU114:Checkpoint completed at step 1300000
02:15:48:I1:WU114:Completed 1325000 out of 2500000 steps (53%)
02:16:41:I1:WU114:Completed 1350000 out of 2500000 steps (54%)
02:16:41:I1:WU114:Checkpoint completed at step 1350000
02:17:17:I1:WU112:Completed 85000 out of 250000 steps (34%)
02:17:35:I1:WU114:Completed 1375000 out of 2500000 steps (55%)
02:18:28:I1:WU114:Completed 1400000 out of 2500000 steps (56%)
02:18:29:I1:WU114:Checkpoint completed at step 1400000
02:19:23:I1:WU114:Completed 1425000 out of 2500000 steps (57%)
02:20:17:I1:WU114:Completed 1450000 out of 2500000 steps (58%)
02:20:17:I1:WU114:Checkpoint completed at step 1450000
02:20:30:I1:WU112:Completed 87500 out of 250000 steps (35%)
02:20:44:W :WU112:Visualization frame 35 unchanged, skipping
02:21:10:I1:WU114:Completed 1475000 out of 2500000 steps (59%)
02:22:03:I1:WU114:Completed 1500000 out of 2500000 steps (60%)
02:22:04:I1:WU114:Checkpoint completed at step 1500000
02:22:57:I1:WU114:Completed 1525000 out of 2500000 steps (61%)
02:23:46:I1:WU112:Completed 90000 out of 250000 steps (36%)
02:23:51:I1:WU114:Completed 1550000 out of 2500000 steps (62%)
02:23:51:I1:WU114:Checkpoint completed at step 1550000
02:24:45:I1:WU114:Completed 1575000 out of 2500000 steps (63%)
02:25:38:I1:WU114:Completed 1600000 out of 2500000 steps (64%)
02:25:39:I1:WU114:Checkpoint completed at step 1600000
02:26:32:I1:WU114:Completed 1625000 out of 2500000 steps (65%)
02:27:02:I1:WU112:Completed 92500 out of 250000 steps (37%)
02:27:25:I1:WU114:Completed 1650000 out of 2500000 steps (66%)
02:27:26:I1:WU114:Checkpoint completed at step 1650000
02:28:20:I1:WU114:Completed 1675000 out of 2500000 steps (67%)
02:29:13:I1:WU114:Completed 1700000 out of 2500000 steps (68%)
02:29:14:I1:WU114:Checkpoint completed at step 1700000
02:30:07:I1:WU114:Completed 1725000 out of 2500000 steps (69%)
02:30:16:I1:WU112:Completed 95000 out of 250000 steps (38%)
02:30:30:W :WU112:Visualization frame 38 unchanged, skipping
02:31:01:I1:WU114:Completed 1750000 out of 2500000 steps (70%)
02:31:02:I1:WU114:Checkpoint completed at step 1750000
02:31:55:I1:WU114:Completed 1775000 out of 2500000 steps (71%)
02:32:48:I1:WU114:Completed 1800000 out of 2500000 steps (72%)
02:32:49:I1:WU114:Checkpoint completed at step 1800000
02:33:32:I1:WU112:Completed 97500 out of 250000 steps (39%)
02:33:43:I1:WU114:Completed 1825000 out of 2500000 steps (73%)
02:34:36:I1:WU114:Completed 1850000 out of 2500000 steps (74%)
02:34:37:I1:WU114:Checkpoint completed at step 1850000
02:35:31:I1:WU114:Completed 1875000 out of 2500000 steps (75%)
02:36:24:I1:WU114:Completed 1900000 out of 2500000 steps (76%)
02:36:25:I1:WU114:Checkpoint completed at step 1900000
02:36:49:I1:WU112:Completed 100000 out of 250000 steps (40%)
02:37:18:I1:WU114:Completed 1925000 out of 2500000 steps (77%)
02:38:12:I1:WU114:Completed 1950000 out of 2500000 steps (78%)
02:38:13:I1:WU114:Checkpoint completed at step 1950000
02:39:06:I1:WU114:Completed 1975000 out of 2500000 steps (79%)
02:39:59:I1:WU114:Completed 2000000 out of 2500000 steps (80%)
02:40:00:I1:WU114:Checkpoint completed at step 2000000
02:40:02:I1:WU112:Completed 102500 out of 250000 steps (41%)
02:40:15:W :WU112:Visualization frame 41 unchanged, skipping
02:40:54:I1:WU114:Completed 2025000 out of 2500000 steps (81%)
02:41:47:I1:WU114:Completed 2050000 out of 2500000 steps (82%)
02:41:47:I1:WU114:Checkpoint completed at step 2050000
02:42:41:I1:WU114:Completed 2075000 out of 2500000 steps (83%)
02:43:19:I1:WU112:Completed 105000 out of 250000 steps (42%)
02:43:34:I1:WU114:Completed 2100000 out of 2500000 steps (84%)
02:43:35:I1:WU114:Checkpoint completed at step 2100000
02:44:28:I1:WU114:Completed 2125000 out of 2500000 steps (85%)
02:45:00:I1:Group state finish
02:45:22:I1:WU114:Completed 2150000 out of 2500000 steps (86%)
02:45:23:I1:WU114:Checkpoint completed at step 2150000
02:46:16:I1:WU114:Completed 2175000 out of 2500000 steps (87%)
02:46:32:I1:WU112:Completed 107500 out of 250000 steps (43%)
02:46:45:W :WU112:Visualization frame 43 unchanged, skipping
02:47:09:I1:WU114:Completed 2200000 out of 2500000 steps (88%)
02:47:10:I1:WU114:Checkpoint completed at step 2200000
02:48:04:I1:WU114:Completed 2225000 out of 2500000 steps (89%)
02:48:57:I1:WU114:Completed 2250000 out of 2500000 steps (90%)
02:48:58:I1:WU114:Checkpoint completed at step 2250000
02:49:49:I1:WU112:Completed 110000 out of 250000 steps (44%)
02:49:52:I1:WU114:Completed 2275000 out of 2500000 steps (91%)
02:50:45:I1:WU114:Completed 2300000 out of 2500000 steps (92%)
02:50:46:I1:WU114:Checkpoint completed at step 2300000
02:51:39:I1:WU114:Completed 2325000 out of 2500000 steps (93%)
02:52:32:I1:WU114:Completed 2350000 out of 2500000 steps (94%)
02:52:33:I1:WU114:Checkpoint completed at step 2350000
02:53:05:I1:WU112:Completed 112500 out of 250000 steps (45%)
02:53:26:I1:WU114:Completed 2375000 out of 2500000 steps (95%)
02:54:20:I1:WU114:Completed 2400000 out of 2500000 steps (96%)
02:54:20:I1:WU114:Checkpoint completed at step 2400000
02:55:14:I1:WU114:Completed 2425000 out of 2500000 steps (97%)
02:56:07:I1:WU114:Completed 2450000 out of 2500000 steps (98%)
02:56:08:I1:WU114:Checkpoint completed at step 2450000
02:56:18:I1:WU112:Completed 115000 out of 250000 steps (46%)
02:56:31:W :WU112:Visualization frame 46 unchanged, skipping
02:57:01:I1:WU114:Completed 2475000 out of 2500000 steps (99%)
02:57:54:I1:WU114:Completed 2500000 out of 2500000 steps (100%)
02:57:54:I1:WU114:Average performance: 163.019 ns/day
02:57:55:I1:WU114:Checkpoint completed at step 2500000
02:58:05:I1:WU114:Saving result file ..\logfile_01.txt
02:58:05:I1:WU114:Saving result file checkpointIntegrator.xml
02:58:05:I1:WU114:Saving result file checkpointState.xml.bz2
02:58:05:I1:WU114:Saving result file positions.xtc
02:58:05:I1:WU114:Saving result file science.log
02:58:05:I1:WU114:Saving result file xtcAtoms.csv.bz2
02:58:05:I1:WU114:Folding@home Core Shutdown: FINISHED_UNIT
02:58:06:I1:WU114:Core returned FINISHED_UNIT (100)
02:58:06:I1:WU114:Uploading WU results
02:58:06:I1:OUT69:> POST https://highland2.seas.upenn.edu/api/results HTTP/1.1
02:58:33:I1:OUT69:< HTTP/1.1 200 HTTP_OK
02:58:33:I1:WU114:Credited
02:59:26:I1:WU112:Completed 117500 out of 250000 steps (47%)
03:02:24:I1:WU112:Completed 120000 out of 250000 steps (48%)
03:05:18:I1:WU112:Completed 122500 out of 250000 steps (49%)
03:05:32:W :WU112:Visualization frame 49 unchanged, skipping
03:08:15:I1:WU112:Completed 125000 out of 250000 steps (50%)
03:11:09:I1:WU112:Completed 127500 out of 250000 steps (51%)
03:11:22:W :WU112:Visualization frame 51 unchanged, skipping
03:14:06:I1:WU112:Completed 130000 out of 250000 steps (52%)
03:17:03:I1:WU112:Completed 132500 out of 250000 steps (53%)
03:19:58:I1:WU112:Completed 135000 out of 250000 steps (54%)
03:20:10:W :WU112:Visualization frame 54 unchanged, skipping
03:22:55:I1:WU112:Completed 137500 out of 250000 steps (55%)
03:25:49:I1:WU112:Completed 140000 out of 250000 steps (56%)
03:26:02:W :WU112:Visualization frame 56 unchanged, skipping
03:28:46:I1:WU112:Completed 142500 out of 250000 steps (57%)
03:31:43:I1:WU112:Completed 145000 out of 250000 steps (58%)
03:34:15:E :WU112:Core exited with Windows unhandled exception code 0xc0000005.  See https://bit.ly/2CXgWkZ for more information.
03:34:15:E :WU112:Core returned FAILED_1 (0)
03:34:15:E :WU112:Run did not produce any results. Dumping WU
03:34:15:I1:WU112:Sending dump report
03:34:15:I1:OUT70:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
03:34:15:I1:OUT70:< HTTP/1.1 200 HTTP_OK
03:34:15:I1:WU112:Dumped
07:13:23:I1:Clean exit
I don't know if you're / the project is interested in such "reports".
I don't know how to read out logs only for one specific WU
Last edited by foldinghomealone on Fri Oct 03, 2025 6:22 pm, edited 2 times in total.
Re: Dumped CPU WUs
Post by muziqaz »
Check your event viewer for wea errors
FAH Omega tester
foldinghomealone
Re: Dumped CPU WUs
I'm lost.
What's the event viewer?
Re: Dumped CPU WUs
Post by muziqaz »
foldinghomealone wrote: Fri Oct 03, 2025 6:24 pm I'm lost.
Start>type Event Viewer. It lists everything what is happening on your PC
FAH Omega tester
foldinghomealone
Re: Dumped CPU WUs
for the dumped one from just now I found (local time 8:31am) an application error:
p12477 0xa8
Faulting application name: FahCore_a8.exe, version: 0.0.0.0, time stamp: 0x6003549d
Faulting module name: FahCore_a8.exe, version: 0.0.0.0, time stamp: 0x6003549d
Exception code: 0xc0000005
Fault offset: 0x000000000085d021
Faulting process id: 0x4adc
Faulting application start time: 0x01dc34f261ccc2e3
Faulting application path: C:\ProgramData\FAHClient\cores\fahcore-a8-win-64bit-avx2_256-0.0.12\FahCore_a8.exe
Faulting module path: C:\ProgramData\FAHClient\cores\fahcore-a8-win-64bit-avx2_256-0.0.12\FahCore_a8.exe
Report Id: 71ee9621-79e5-44a6-9853-645d4dccd55a
Faulting package full name:
Faulting package-relative application ID:
but I didn't find any other errors with that timestamp.
Re: Dumped CPU WUs
Post by muziqaz »
Sorry, what I meant, look for WHEA Errors in event viewer. They manifest in bunches in Windows Logs>System section.
Basically, when CPU WUs fail, it is 99.9% unstable folder's machine. RAM is the most likely suspect in modern PC
FAH Omega tester
foldinghomealone
Re: Dumped CPU WUs
Are there WHEA?
I created a custom log with all 5 event types and filtered forf Kernel WHEA and WHEA Logger.
But there are no warnings or errors.
Re: Dumped CPU WUs
Post by muziqaz »
foldinghomealone wrote: Sat Oct 04, 2025 3:17 pm Are there WHEA?
Nah, that doesn't seem to be it. Though my system has zero whea events. Anyways, this shows that CPU is not dying, still leaves RAM. Have you done full system stability testing?
you can do couple of hours of y-cruncher stability testing to if something pops up. It loads memory as much as it can. Obviously full blown memtest86+ run would be ideal
FAH Omega tester
foldinghomealone
Re: Dumped CPU WUs
The first CPU WUs dumped only after the server issues a few days ago.
I did a full stability testing 2 years ago. Since then I didn't have any issues.
Just now, I made a 2 pass memtest86+ run (1.5hrs) without errors
Re: Dumped CPU WUs
Post by muziqaz »
y-cruncher loads both memory and CPU at the same time.
Anyways, keep an eye on your system, if WU crashing happens again, you might need to do a more thorough investigation :)
FAH Omega tester
foldinghomealone
Re: Dumped CPU WUs
ok, thanks for your help.
y-cruncher doesn't cause errors either.
