Problems downloading new work unit
Schrödinger's cat
Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM
Post by Schrödinger's cat »
My GPU has experienced lots of
Exception: Transfer failed
for the last three hours, during very slow downloading of a new work unit (@<350kbit/s). Is this problem restricted to v7?
Also, is it possible to have FAH Control open whenever Folding@Home is manually started in Windows. I removed the command that opened web control, and can't recall the correct syntax.
Re: Problems downloading new work unit
Post by calxalot »
Not by client. You can probably make a startup shortcut for FAHControl manually.
Post by muziqaz »
If you look around these forums you might have noticed that FAH had some server issues in past several days, your GPU transfer failed messages might be related to that
FAH Omega tester
Schrödinger's cat
muziqaz wrote: Fri Oct 03, 2025 4:54 am If you look around these forums you might have noticed that FAH had some server issues in past several days, your GPU transfer failed messages might be related to that
I haven't seen any other posts about very slow (55.54MB of 74.10MB @ 34.16KB/s), and which then fail, downloading problems.
Thankfully the problem was resolved about 30 minutes after I posted about it. Could someone have seen my post and fixed something?
Post by muziqaz »
Schrödinger's cat wrote: Fri Oct 03, 2025 8:13 am
Definitely not :) Researchers and their uni admins do not frequent these forum sections
FAH Omega tester
