Please read the forum
rules before posting.
TRINITAS
Posts: 5 Joined: Thu Oct 02, 2025 1:36 pm
Hardware configuration: =>RyZen 7 5800X3D =>ASRock X470 Taichi =>64GB DDR4 =>MSI GeForce RTX 4070 Ti SUPER =>Windows 11 Pro 24H2
Post
by TRINITAS » Thu Oct 02, 2025 1:45 pm
Hello
I've noticed that Radeons have a fairly low PPD number compared to GeForces in the same range.
The Radeon RX 7900 XTX performs much worse than an RTX 4070 in most cases. Considering its specs, I'm surprised.
Is there an optimization issue with AMD GPUs? Or is the RDNA architecture unsuitable for this type of computing?
Thanks
1- RyZen 7 5800X3D - RTX 4070 Ti SUPER - 64GB DDR4 - 1TB NVme - 2xTB SSD SATA
2- RyZen 7 2700X - Divers GPU - 16GB DDR4 - 512GB SSD SATA
3- Core 2 Quad Q9550 - 2xGeForce GTX 280 - 4GB DDR2 - 500GB HDD
Posts: 2499 Joined: Sun Dec 16, 2007 6:22 pm
Hardware configuration: 9950x, 9950x3d, 7950x3d, 5950x, 5800x3d 7900xtx, RX9070, Radeon 7, 5700xt, 6900xt, RX550, Intel B580
Post
by muziqaz » Thu Oct 02, 2025 6:53 pm
Optimisation issue
FAH Omega tester
TRINITAS
Post
by TRINITAS » Thu Oct 02, 2025 6:57 pm
Optimisation issue from AMD or FAH/OpenMMM?
Post
by muziqaz » Thu Oct 02, 2025 7:05 pm
TRINITAS wrote: ↑ Thu Oct 02, 2025 6:57 pm
FAH
FAH is using opencl for AMD, and CUDA for nVidia.
OpenMM now supports HIP, but FAH would need to build HIP Fahcore.
HIP FAHcore has been in development for years now, still don't know when it will come out
FAH Omega tester
TRINITAS
Post
by TRINITAS » Thu Oct 02, 2025 7:16 pm
Okay. I understand better.
I'm surprised that OpenCL isn't suitable. Some people tell me it's an API that doesn't evolve.
Post
by muziqaz » Thu Oct 02, 2025 7:20 pm
TRINITAS wrote: ↑ Thu Oct 02, 2025 7:16 pm
That API is long dead
FAH Omega tester
TRINITAS
Post
by TRINITAS » Thu Oct 02, 2025 7:59 pm
I imagine it's the same phenomenon for Intel ARC B, that FAH uses Intel's API (OneAPI if I remember correctly)
Post
by muziqaz » Thu Oct 02, 2025 8:24 pm
TRINITAS wrote: ↑ Thu Oct 02, 2025 7:59 pm
No, FAH uses opencl for Intel
FAH Omega tester
TRINITAS
Post
by TRINITAS » Fri Oct 03, 2025 8:08 am
I meant, does Intel have its API? (Like HIP for AMD, or CUDA for NVIDIA)
Post
by muziqaz » Fri Oct 03, 2025 3:14 pm
TRINITAS wrote: ↑ Fri Oct 03, 2025 8:08 am
Yes, they do. OneAPI, as you mentioned
FAH Omega tester
