GPU Download problems
foldinghomealone
Hardware configuration: 5900x + 5080
Post by foldinghomealone »
For a while, it's not possible to download GPU projects
CPU WU download possible
GPU WU upload was possible, after that, no download of a WU anymore
edit: other team members post, that upload is also not possible
Win10 / RTX 3080 ti
Restarted the system several times already...
20:19:29:I1: Branch: master
20:19:29:I1: Compiler: Visual C++
20:19:29:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
20:19:29:I1: /Zc:throwingNew /MT
20:19:29:I1: Platform: win32 10
20:19:29:I1: Bits: 64
20:19:29:I1: Mode: Release
20:19:29:I1:****************************** CBang ******************************
20:19:29:I1: Version: 1.7.2
20:19:29:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:19:29:I1: Org: Cauldron Development
20:19:29:I1: Copyright: Cauldron Development, 2003-2024
20:19:29:I1: Homepage: https://cauldrondevelopment.com/
20:19:29:I1: License: LGPL-2.1-or-later
20:19:29:I1: Date: Nov 20 2024
20:19:29:I1: Time: 09:04:40
20:19:29:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
20:19:29:I1:***************************** System ******************************
20:19:29:I1: CPU: AMD Ryzen 9 5900X 12-Core Processor
20:19:29:I1: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
20:19:29:I1: CPUs: 24
20:19:29:I1: Memory: 31.93GiB
20:19:29:I1:Free Memory: 27.14GiB
20:19:29:I1: OS Version: 6.2
20:19:29:I1:Has Battery: false
20:19:29:I1: On Battery: false
20:19:29:I1: Hostname: DESKTOP-VQLISJP
20:19:29:I1: UTC Offset: 2
20:19:29:I1: PID: 17496
20:19:29:I1: CWD: C:\ProgramData\FAHClient
20:19:29:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
20:19:29:I1:*******************************************************************
20:19:29:I2:<config/>
20:19:29:I1:Opening Database
20:19:29:I1:F@H ID = 94eKTW7hsT1CN2SI9ecD3wVRqR6QnA4B4W06IslYaBE
20:19:29:I3:Loading default resource group
20:19:29:I3:Loading gpu resource group
20:19:29:I3:Loading cpu resource group
20:19:29:I1:Listening for HTTP on 127.0.0.1:7396
20:19:29:I3:WU88:Loading work unit 88 with ID goIzeNqmsJUj39GpOtzaUPbOjR3PtnsNZnB4eEk2Fdw
20:19:29:I3:Loaded 1 wus.
20:19:29:I1:Started Windows systray control
20:19:29:I3:gpus = {
20:19:29:I3: "gpu:43:00:00": {
20:19:29:I3: "vendor": 4318,
20:19:29:I3: "type": "nvidia",
20:19:29:I3: "description": "NVIDIA GeForce RTX 3080 Ti",
20:19:29:I3: "uuid": "751026be-c312-bd3f-36f5-999ca9ef0132",
20:19:29:I3: "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "566.36"},
20:19:29:I3: "cuda": {"platform": 0, "device": 0, "compute": "8.6", "driver": "12.7"},
20:19:29:I3: "device": 8712,
20:19:29:I3: "supported": true
20:19:29:I3: }
20:19:29:I3:}
20:19:29:I1:gpu:Added new work unit: cpus:0 gpus:gpu:43:00:00
20:19:29:I1:WU90:Requesting WU assignment for user foldinghomealone team 70335
20:19:29:I1:OUT1:> GET https://api.foldingathome.org/machine/94eKTW7hsT1CN2SI9ecD3wVRqR6QnA4B4W06IslYaBE HTTP/1.1
20:19:29:I1:OUT2:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
20:19:30:I1:OUT2:< HTTP/1.1 200 HTTP_OK
20:19:30:I1:WU90:Received WU assignment -vTZ57sYgPmaENhs03YhHDYBB7Q74mxJukXExP_rqaE
20:19:30:I1:WU90:Downloading WU
20:19:30:I1:OUT1:< HTTP/1.1 200 HTTP_OK
20:19:30:I1:OUT4:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
20:19:30:I1:OUT4:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
20:19:30:I1:Logging into node account
20:19:51:I1:OUT3:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
20:19:51:E :OUT3:Failed response: EOF
20:19:51:I1:WU90:Retry #1 in 2 secs
20:19:53:I1:WU90:Downloading WU
20:20:14:I1:OUT5:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
20:20:14:E :OUT5:Failed response: EOF
20:20:14:I1:WU90:Retry #2 in 4 secs
20:20:18:I1:WU90:Downloading WU
20:20:39:I1:OUT7:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
20:20:39:E :OUT7:Failed response: EOF
20:20:39:I1:WU90:Retry #3 in 8 secs
20:20:47:I1:WU90:Downloading WU
20:21:08:I1:OUT8:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
20:21:08:E :OUT8:Failed response: EOF
20:21:08:I1:WU90:Retry #4 in 16 secs
20:21:24:I1:WU90:Downloading WU
20:21:24:I1:OUT9:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
20:22:24:E :OUT9:Failed response: EOF
20:22:24:I1:WU90:Retry #5 in 32 secs
20:22:56:I1:WU90:Downloading WU
20:22:56:I1:OUT10:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
20:23:56:E :OUT10:Failed response: EOF
20:23:56:I1:WU90:Retry #6 in 1 min 4 secs
20:25:00:I1:WU90:Downloading WU
20:25:00:I1:OUT11:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
20:26:20:E :OUT11:Failed response: EOF
20:26:20:I1:WU90:Retry #7 in 2 mins 8 secs
20:28:28:I1:WU90:Downloading WU
20:28:49:I1:OUT12:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
20:28:49:E :OUT12:Failed response: EOF
Don't know where is the best place to send problem reports to, so feel free to move the topic
Re: GPU Download problems
Post by muziqaz »
Some servers are down
FAH Omega tester
