Project 12600 always fails on R9 380
vivatobst
Hardware configuration: Intel Core i5-2320, 2*AMD Sapphire R9 380 Nitro
AMD Ryzen 7 2700X, AMD Sapphire Vega 64 Nitro+
Post by vivatobst »
Hi all,
it's been a while since I've been folding, so pardon me that I have forgotten things here and there.
Problem that I currently have is that P12660 always seems to fails nearly instantly and I can't wrap my head around it. I already reinstalled FAH client and did a DDU. The GPUs both run relatively low on temperature und WUs of other project run fine.
I kinda want to exclude the WUs of this project, but I guess it's still not possible.
What do I do? The full log with the Project failed twice is down below.
Please forgive me when I don't answer so quickly, as I am learning for my final exams right now :lol:
*********************** Log Started 2025-09-25T12:09:44Z ***********************
12:09:44:******************************* libFAH ********************************
12:09:44:           Date: Oct 20 2020
12:09:44:           Time: 13:36:55
12:09:44:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
12:09:44:         Branch: master
12:09:44:       Compiler: Visual C++ 2015
12:09:44:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:09:44:       Platform: win32 10
12:09:44:           Bits: 32
12:09:44:           Mode: Release
12:09:44:****************************** FAHClient ******************************
12:09:44:        Version: 7.6.21
12:09:44:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:09:44:      Copyright: 2020 foldingathome.org
12:09:44:       Homepage: https://foldingathome.org/
12:09:44:           Time: 13:41:04
12:09:44:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
12:09:44:           Bits: 32
12:09:44:           Args: --open-web-control
12:09:44:         Config: C:\ProgramData\FAHClient\config.xml
12:09:44:******************************** CBang ********************************
12:09:44:           Time: 11:36:18
12:09:44:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
12:09:44:           Bits: 32
12:09:44:******************************* System ********************************
12:09:44:            CPU: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz
12:09:44:         CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:09:44:           CPUs: 4
12:09:44:         Memory: 5.89GiB
12:09:44:    Free Memory: 2.03GiB
12:09:44:        Threads: WINDOWS_THREADS
12:09:44:     OS Version: 6.2
12:09:44:    Has Battery: false
12:09:44:     On Battery: false
12:09:44:     UTC Offset: 2
12:09:44:            PID: 2808
12:09:44:            CWD: C:\ProgramData\FAHClient
12:09:44:  Win32 Service: false
12:09:44:             OS: Windows 10 Home
12:09:44:        OS Arch: AMD64
12:09:44:           GPUs: 2
12:09:44:          GPU 0: Bus:1 Slot:0 Func:0 AMD:4 Tonga PRO [Radeon R9 285/380]
12:09:44:          GPU 1: Bus:2 Slot:0 Func:0 AMD:4 Tonga PRO [Radeon R9 285/380]
12:09:44:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
12:09:44:                 angegebene Modul wurde nicht gefunden.
12:09:44:
12:09:44:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3075.13
12:09:44:OpenCL Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:1.2 Driver:3075.13
12:09:44:***********************************************************************
12:09:44:<config>
12:09:44:  <!-- Folding Core -->
12:09:44:  <core-priority v='low'/>
12:09:44:
12:09:44:  <!-- HTTP Server -->
12:09:44:  <allow v='127.0.0.1 192.168.178.0/24 25.40.138.0/24 192.168.137.1/24 25.36.84.84/24 10.147.20.166/24 94.31.82.70/24'/>
12:09:44:
12:09:44:  <!-- Network -->
12:09:44:  <proxy v=':8080'/>
12:09:44:
12:09:44:  <!-- Remote Command Server -->
12:09:44:  <command-allow-no-pass v='127.0.0.1 192.168.178.0/24 25.40.138.0/24 192.168.137.1/24 25.36.84.84/24 10.147.20.166/24 94.31.82.70/24'/>
12:09:44:
12:09:44:  <!-- Slot Control -->
12:09:44:  <pause-on-start v='true'/>
12:09:44:  <power v='full'/>
12:09:44:
12:09:44:  <!-- User Information -->
12:09:44:  <passkey v='*****'/>
12:09:44:  <team v='70335'/>
12:09:44:  <user v='VivaTobst'/>
12:09:44:
12:09:44:  <!-- Folding Slots -->
12:09:44:  <slot id='1' type='GPU'>
12:09:44:    <paused v='true'/>
12:09:44:    <pci-bus v='1'/>
12:09:44:    <pci-slot v='0'/>
12:09:44:  </slot>
12:09:44:  <slot id='2' type='GPU'>
12:09:44:    <pci-bus v='2'/>
12:09:44:  </slot>
12:09:44:</config>
12:09:44:Trying to access database...
12:09:44:Successfully acquired database lock
12:09:44:FS01:Initialized folding slot 01: gpu:1:0 Tonga PRO [Radeon R9 285/380]
12:09:44:FS02:Initialized folding slot 02: gpu:2:0 Tonga PRO [Radeon R9 285/380]
12:09:45:2:127.0.0.1:New Web session
12:09:47:12:127.0.0.1:New Web session
12:09:57:FS01:Unpaused
12:09:57:FS02:Unpaused
12:09:57:WU00:FS01:Starting
12:09:57:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-27/windows-10-64bit/release/0x27-8.2.1/Core_27.fah/FahCore_27.exe -dir 00 -suffix 01 -version 706 -lifeline 2808 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
12:09:57:WU00:FS01:Started FahCore on PID 9528
12:09:57:WU00:FS01:Core PID:8996
12:09:57:WU00:FS01:FahCore 0x27 started
12:09:57:WU01:FS02:Connecting to assign1.foldingathome.org:80
12:09:57:WU00:FS01:0x27:*********************** Log Started 2025-09-25T12:09:57Z ***********************
12:09:57:WU00:FS01:0x27:*************************** Core27 Folding@home Core ***************************
12:09:57:WU00:FS01:0x27:       Core: Core27
12:09:57:WU00:FS01:0x27:       Type: 0x27
12:09:57:WU00:FS01:0x27:    Version: 8.2.1
12:09:57:WU00:FS01:0x27:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:09:57:WU00:FS01:0x27:  Copyright: 2022 foldingathome.org
12:09:57:WU00:FS01:0x27:   Homepage: https://foldingathome.org/
12:09:57:WU00:FS01:0x27:       Date: Mar 27 2025
12:09:57:WU00:FS01:0x27:       Time: 04:46:58
12:09:57:WU00:FS01:0x27:   Revision: 84019442387121f2bed4ed52e05c53b7b7b52a72
12:09:57:WU00:FS01:0x27:     Branch: HEAD
12:09:57:WU00:FS01:0x27:   Compiler: Visual C++
12:09:57:WU00:FS01:0x27:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
12:09:57:WU00:FS01:0x27:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
12:09:57:WU00:FS01:0x27:   Platform: win32 10
12:09:57:WU00:FS01:0x27:       Bits: 64
12:09:57:WU00:FS01:0x27:       Mode: Release
12:09:57:WU00:FS01:0x27:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:09:57:WU00:FS01:0x27:             <peastman@stanford.edu>
12:09:57:WU00:FS01:0x27:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9528 -checkpoint 15
12:09:57:WU00:FS01:0x27:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
12:09:57:WU00:FS01:0x27:             -gpu-usage 100
12:09:57:WU00:FS01:0x27:************************************ libFAH ************************************
12:09:57:WU00:FS01:0x27:       Time: 04:30:44
12:09:57:WU00:FS01:0x27:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
12:09:57:WU00:FS01:0x27:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:09:57:WU00:FS01:0x27:************************************ CBang *************************************
12:09:57:WU00:FS01:0x27:    Version: 1.7.2
12:09:57:WU00:FS01:0x27:        Org: Cauldron Development LLC
12:09:57:WU00:FS01:0x27:  Copyright: Cauldron Development LLC, 2003-2024
12:09:57:WU00:FS01:0x27:   Homepage: https://cauldrondevelopment.com/
12:09:57:WU00:FS01:0x27:    License: LGPL-2.1-or-later
12:09:57:WU00:FS01:0x27:       Time: 04:29:12
12:09:57:WU00:FS01:0x27:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
12:09:57:WU00:FS01:0x27:************************************ System ************************************
12:09:57:WU00:FS01:0x27:        CPU: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz
12:09:57:WU00:FS01:0x27:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:09:57:WU00:FS01:0x27:       CPUs: 4
12:09:57:WU00:FS01:0x27:     Memory: 5.89GiB
12:09:57:WU00:FS01:0x27:Free Memory: 1.84GiB
12:09:57:WU00:FS01:0x27: OS Version: 10.0
12:09:57:WU00:FS01:0x27:Has Battery: false
12:09:57:WU00:FS01:0x27: On Battery: false
12:09:57:WU00:FS01:0x27:   Hostname: DESKTOP-LM88PTU
12:09:57:WU00:FS01:0x27: UTC Offset: 2
12:09:57:WU00:FS01:0x27:        PID: 8996
12:09:57:WU00:FS01:0x27:        CWD: C:\ProgramData\FAHClient\work
12:09:57:WU00:FS01:0x27:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-27\windows-10-64bit\release\0x27-8.2.1\Core_27.fah\FahCore_27.exe
12:09:57:WU00:FS01:0x27:************************************ OpenMM ************************************
12:09:57:WU00:FS01:0x27:    Version: 8.2.0
12:09:57:WU00:FS01:0x27:********************************************************************************
12:09:57:WU00:FS01:0x27:Project: 17660 (Run 152, Clone 0, Gen 78)
12:09:57:WU00:FS01:0x27:Digital signatures verified
12:09:57:WU00:FS01:0x27:Folding@home GPU Core27 Folding@home Core
12:09:57:WU00:FS01:0x27:Version 8.2.1
12:09:57:WU00:FS01:0x27:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
12:09:57:WU00:FS01:0x27:  GPU info: PlatformIndex: 0
12:09:57:WU00:FS01:0x27:  GPU info: Device: Tonga
12:09:57:WU00:FS01:0x27:  GPU info: DeviceIndex: 0
12:09:57:WU00:FS01:0x27:  GPU info: Vendor: 0x1002
12:09:57:WU00:FS01:0x27:  GPU info: PCI: 01:00:00
12:09:57:WU00:FS01:0x27:  GPU info: Compute: 2.0
12:09:57:WU00:FS01:0x27:  GPU info: Driver: 3075.13
12:09:57:WU00:FS01:0x27:  GPU info: GPU: true
12:09:57:WU00:FS01:0x27:  GPU info: DeviceIndex: 1
12:09:57:WU01:FS02:Assigned to work server 44.205.73.79
12:09:57:WU00:FS01:0x27:  GPU info: PCI: 02:00:00
12:09:57:WU01:FS02:Requesting new work unit for slot 02: gpu:2:0 Tonga PRO [Radeon R9 285/380] from 44.205.73.79
12:09:57:WU01:FS02:Connecting to 44.205.73.79:8080
12:09:57:WU00:FS01:0x27:  Checkpoint write interval: 125000 steps (5%) [20 total]
12:09:57:WU00:FS01:0x27:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
12:09:57:WU00:FS01:0x27:  XTC frame write interval: 250000 steps (10%) [10 total]
12:09:57:WU00:FS01:0x27:  TRR frame write interval: 250000 steps (10%) [10 total]
12:09:57:WU00:FS01:0x27:  Global context and integrator variables write interval: disabled
12:09:57:WU00:FS01:0x27:There are 3 platforms available.
12:09:57:WU00:FS01:0x27:Platform 0: Reference
12:09:57:WU00:FS01:0x27:Platform 1: CPU
12:09:57:WU00:FS01:0x27:Platform 2: OpenCL
12:09:57:WU00:FS01:0x27:  opencl-device 0 specified
12:09:59:WU01:FS02:Downloading 109.49KiB
12:09:59:WU01:FS02:Download complete
12:10:00:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:12600 run:822 clone:36 gen:0 core:0x26 unit:0x00000000240000003603000038310000
12:10:00:WU01:FS02:Starting
12:10:00:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-26/windows-10-64bit/release/0x26-8.2.0/Core_26.fah/FahCore_26.exe -dir 01 -suffix 01 -version 706 -lifeline 2808 -checkpoint 15 -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1 -gpu-usage 100
12:10:00:WU01:FS02:Started FahCore on PID 7200
12:10:00:WU01:FS02:Core PID:2120
12:10:00:WU01:FS02:FahCore 0x26 started
12:10:00:WU01:FS02:0x26:*********************** Log Started 2025-09-25T12:10:00Z ***********************
12:10:01:WU01:FS02:0x26:*************************** Core26 Folding@home Core ***************************
12:10:01:WU01:FS02:0x26:       Core: Core26
12:10:01:WU01:FS02:0x26:       Type: 0x26
12:10:01:WU01:FS02:0x26:    Version: 8.2.0
12:10:01:WU01:FS02:0x26:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:10:01:WU01:FS02:0x26:  Copyright: 2022 foldingathome.org
12:10:01:WU01:FS02:0x26:   Homepage: https://foldingathome.org/
12:10:01:WU01:FS02:0x26:       Date: Jan 7 2025
12:10:01:WU01:FS02:0x26:       Time: 00:58:59
12:10:01:WU01:FS02:0x26:   Revision: 4f149b599caa4725076ef2de3b47c8d7ce725787
12:10:01:WU01:FS02:0x26:     Branch: HEAD
12:10:01:WU01:FS02:0x26:   Compiler: Visual C++
12:10:01:WU01:FS02:0x26:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
12:10:01:WU01:FS02:0x26:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
12:10:01:WU01:FS02:0x26:   Platform: win32 10
12:10:01:WU01:FS02:0x26:       Bits: 64
12:10:01:WU01:FS02:0x26:       Mode: Release
12:10:01:WU01:FS02:0x26:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:10:01:WU01:FS02:0x26:             <peastman@stanford.edu>
12:10:01:WU01:FS02:0x26:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7200 -checkpoint 15
12:10:01:WU01:FS02:0x26:             -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1
12:10:01:WU01:FS02:0x26:             -gpu-usage 100
12:10:01:WU01:FS02:0x26:************************************ libFAH ************************************
12:10:01:WU01:FS02:0x26:       Time: 00:39:45
12:10:01:WU01:FS02:0x26:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
12:10:01:WU01:FS02:0x26:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:10:01:WU01:FS02:0x26:************************************ CBang *************************************
12:10:01:WU01:FS02:0x26:    Version: 1.7.2
12:10:01:WU01:FS02:0x26:        Org: Cauldron Development LLC
12:10:01:WU01:FS02:0x26:  Copyright: Cauldron Development LLC, 2003-2024
12:10:01:WU01:FS02:0x26:   Homepage: https://cauldrondevelopment.com/
12:10:01:WU01:FS02:0x26:    License: LGPL-2.1-or-later
12:10:01:WU01:FS02:0x26:       Time: 00:38:35
12:10:01:WU01:FS02:0x26:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
12:10:01:WU01:FS02:0x26:************************************ System ************************************
12:10:01:WU01:FS02:0x26:        CPU: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz
12:10:01:WU01:FS02:0x26:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:10:01:WU01:FS02:0x26:       CPUs: 4
12:10:01:WU01:FS02:0x26:     Memory: 5.89GiB
12:10:01:WU01:FS02:0x26:Free Memory: 1.61GiB
12:10:01:WU01:FS02:0x26: OS Version: 10.0
12:10:01:WU01:FS02:0x26:Has Battery: false
12:10:01:WU01:FS02:0x26: On Battery: false
12:10:01:WU01:FS02:0x26:   Hostname: DESKTOP-LM88PTU
12:10:01:WU01:FS02:0x26: UTC Offset: 2
12:10:01:WU01:FS02:0x26:        PID: 2120
12:10:01:WU01:FS02:0x26:        CWD: C:\ProgramData\FAHClient\work
12:10:01:WU01:FS02:0x26:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-26\windows-10-64bit\release\0x26-8.2.0\Core_26.fah\FahCore_26.exe
12:10:01:WU01:FS02:0x26:************************************ OpenMM ************************************
12:10:01:WU01:FS02:0x26:********************************************************************************
12:10:01:WU01:FS02:0x26:Project: 12600 (Run 822, Clone 36, Gen 0)
12:10:01:WU01:FS02:0x26:Reading tar file core.xml
12:10:01:WU01:FS02:0x26:Reading tar file integrator.xml.bz2
12:10:01:WU01:FS02:0x26:Reading tar file state.xml.bz2
12:10:01:WU01:FS02:0x26:Reading tar file system.xml.bz2
12:10:01:WU01:FS02:0x26:Digital signatures verified
12:10:01:WU01:FS02:0x26:Folding@home GPU Core26 Folding@home Core
12:10:01:WU01:FS02:0x26:Version 8.2
12:10:01:WU01:FS02:0x26:  Checkpoint write interval: 50000 steps (5%) [20 total]
12:10:01:WU01:FS02:0x26:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
12:10:01:WU01:FS02:0x26:  XTC frame write interval: 100000 steps (10%) [10 total]
12:10:01:WU01:FS02:0x26:  TRR frame write interval: disabled
12:10:01:WU01:FS02:0x26:  Global context and integrator variables write interval: 1000 steps (0.1%) [1000 total]
12:10:01:WU01:FS02:0x26:There are 3 platforms available.
12:10:01:WU01:FS02:0x26:Platform 0: Reference
12:10:01:WU01:FS02:0x26:Platform 1: CPU
12:10:01:WU01:FS02:0x26:Platform 2: OpenCL
12:10:01:WU01:FS02:0x26:  opencl-device 1 specified
12:10:01:WU01:FS02:0x26:Attempting to create OpenCL context:
12:10:01:WU01:FS02:0x26:  Configuring platform OpenCL
12:10:06:WU00:FS01:0x27:Attempting to create OpenCL context:
12:10:06:WU00:FS01:0x27:  Configuring platform OpenCL
12:10:10:WU01:FS02:0x26:ERROR:Discrepancy: Forces are blowing up! 5 0
12:10:10:WU01:FS02:0x26:Saving result file ..\logfile_01.txt
12:10:10:WU01:FS02:0x26:Saving result file science.log
12:10:10:WU01:FS02:0x26:Saving result file state.xml.bz2
12:10:10:WU01:FS02:0x26:Folding@home Core Shutdown: BAD_WORK_UNIT
12:10:10:WARNING:WU01:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:10:10:WU01:FS02:Sending unit results: id:01 state:SEND error:FAULTY project:12600 run:822 clone:36 gen:0 core:0x26 unit:0x00000000240000003603000038310000
12:10:10:WU01:FS02:Uploading 84.94KiB to 44.205.73.79
12:10:10:WU01:FS02:Connecting to 44.205.73.79:8080
12:10:10:WU02:FS02:Connecting to assign1.foldingathome.org:80
12:10:10:WU01:FS02:Upload complete
12:10:10:WU01:FS02:Server responded WORK_ACK (400)
12:10:10:WU01:FS02:Cleaning up
12:10:11:WU02:FS02:Assigned to work server 44.205.73.79
12:10:11:WU02:FS02:Requesting new work unit for slot 02: gpu:2:0 Tonga PRO [Radeon R9 285/380] from 44.205.73.79
12:10:11:WU02:FS02:Connecting to 44.205.73.79:8080
12:10:12:WU02:FS02:Downloading 110.20KiB
12:10:13:WU02:FS02:Download complete
12:10:13:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:12600 run:804 clone:35 gen:0 core:0x26 unit:0x00000000230000002403000038310000
12:10:13:WU02:FS02:Starting
12:10:13:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-26/windows-10-64bit/release/0x26-8.2.0/Core_26.fah/FahCore_26.exe -dir 02 -suffix 01 -version 706 -lifeline 2808 -checkpoint 15 -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1 -gpu-usage 100
12:10:13:WU02:FS02:Started FahCore on PID 8484
12:10:13:WU02:FS02:Core PID:9508
12:10:13:WU02:FS02:FahCore 0x26 started
12:10:13:WU02:FS02:0x26:*********************** Log Started 2025-09-25T12:10:13Z ***********************
12:10:13:WU02:FS02:0x26:*************************** Core26 Folding@home Core ***************************
12:10:13:WU02:FS02:0x26:       Core: Core26
12:10:13:WU02:FS02:0x26:       Type: 0x26
12:10:13:WU02:FS02:0x26:    Version: 8.2.0
12:10:13:WU02:FS02:0x26:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:10:13:WU02:FS02:0x26:  Copyright: 2022 foldingathome.org
12:10:13:WU02:FS02:0x26:   Homepage: https://foldingathome.org/
12:10:13:WU02:FS02:0x26:       Date: Jan 7 2025
12:10:13:WU02:FS02:0x26:       Time: 00:58:59
12:10:13:WU02:FS02:0x26:   Revision: 4f149b599caa4725076ef2de3b47c8d7ce725787
12:10:13:WU02:FS02:0x26:     Branch: HEAD
12:10:13:WU02:FS02:0x26:   Compiler: Visual C++
12:10:13:WU02:FS02:0x26:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
12:10:13:WU02:FS02:0x26:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
12:10:13:WU02:FS02:0x26:   Platform: win32 10
12:10:13:WU02:FS02:0x26:       Bits: 64
12:10:13:WU02:FS02:0x26:       Mode: Release
12:10:13:WU02:FS02:0x26:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:10:13:WU02:FS02:0x26:             <peastman@stanford.edu>
12:10:13:WU02:FS02:0x26:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8484 -checkpoint 15
12:10:13:WU02:FS02:0x26:             -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1
12:10:13:WU02:FS02:0x26:             -gpu-usage 100
12:10:13:WU02:FS02:0x26:************************************ libFAH ************************************
12:10:13:WU02:FS02:0x26:       Time: 00:39:45
12:10:13:WU02:FS02:0x26:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
12:10:13:WU02:FS02:0x26:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:10:13:WU02:FS02:0x26:************************************ CBang *************************************
12:10:13:WU02:FS02:0x26:    Version: 1.7.2
12:10:13:WU02:FS02:0x26:        Org: Cauldron Development LLC
12:10:13:WU02:FS02:0x26:  Copyright: Cauldron Development LLC, 2003-2024
12:10:13:WU02:FS02:0x26:   Homepage: https://cauldrondevelopment.com/
12:10:13:WU02:FS02:0x26:    License: LGPL-2.1-or-later
12:10:13:WU02:FS02:0x26:       Time: 00:38:35
12:10:13:WU02:FS02:0x26:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
12:10:13:WU02:FS02:0x26:************************************ System ************************************
12:10:13:WU02:FS02:0x26:        CPU: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz
12:10:13:WU02:FS02:0x26:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:10:13:WU02:FS02:0x26:       CPUs: 4
12:10:13:WU02:FS02:0x26:     Memory: 5.89GiB
12:10:13:WU02:FS02:0x26:Free Memory: 1.62GiB
12:10:13:WU02:FS02:0x26: OS Version: 10.0
12:10:13:WU02:FS02:0x26:Has Battery: false
12:10:13:WU02:FS02:0x26: On Battery: false
12:10:13:WU02:FS02:0x26:   Hostname: DESKTOP-LM88PTU
12:10:13:WU02:FS02:0x26: UTC Offset: 2
12:10:13:WU02:FS02:0x26:        PID: 9508
12:10:13:WU02:FS02:0x26:        CWD: C:\ProgramData\FAHClient\work
12:10:13:WU02:FS02:0x26:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-26\windows-10-64bit\release\0x26-8.2.0\Core_26.fah\FahCore_26.exe
12:10:13:WU02:FS02:0x26:************************************ OpenMM ************************************
12:10:13:WU02:FS02:0x26:********************************************************************************
12:10:13:WU02:FS02:0x26:Project: 12600 (Run 804, Clone 35, Gen 0)
12:10:13:WU02:FS02:0x26:Reading tar file core.xml
12:10:13:WU02:FS02:0x26:Reading tar file integrator.xml.bz2
12:10:13:WU02:FS02:0x26:Reading tar file state.xml.bz2
12:10:13:WU02:FS02:0x26:Reading tar file system.xml.bz2
12:10:13:WU02:FS02:0x26:Digital signatures verified
12:10:13:WU02:FS02:0x26:Folding@home GPU Core26 Folding@home Core
12:10:13:WU02:FS02:0x26:Version 8.2
12:10:13:WU02:FS02:0x26:  Checkpoint write interval: 50000 steps (5%) [20 total]
12:10:13:WU02:FS02:0x26:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
12:10:13:WU02:FS02:0x26:  XTC frame write interval: 100000 steps (10%) [10 total]
12:10:13:WU02:FS02:0x26:  TRR frame write interval: disabled
12:10:13:WU02:FS02:0x26:  Global context and integrator variables write interval: 1000 steps (0.1%) [1000 total]
12:10:13:WU02:FS02:0x26:There are 3 platforms available.
12:10:13:WU02:FS02:0x26:Platform 0: Reference
12:10:13:WU02:FS02:0x26:Platform 1: CPU
12:10:13:WU02:FS02:0x26:Platform 2: OpenCL
12:10:13:WU02:FS02:0x26:  opencl-device 1 specified
12:10:13:WU02:FS02:0x26:Attempting to create OpenCL context:
12:10:13:WU02:FS02:0x26:  Configuring platform OpenCL
12:10:14:WU00:FS01:0x27:  Using OpenCL on OpenCL platformId 0 and gpu 0
12:10:14:WU00:FS01:0x27:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
12:10:14:WU00:FS01:0x27:  GPU info: PlatformIndex: 0
12:10:14:WU00:FS01:0x27:  GPU info: Device: Tonga
12:10:14:WU00:FS01:0x27:  GPU info: DeviceIndex: 0
12:10:14:WU00:FS01:0x27:  GPU info: Vendor: 0x1002
12:10:14:WU00:FS01:0x27:  GPU info: PCI: 01:00:00
12:10:14:WU00:FS01:0x27:  GPU info: Compute: 2.0
12:10:14:WU00:FS01:0x27:  GPU info: Driver: 3075.13
12:10:14:WU00:FS01:0x27:  GPU info: GPU: true
12:10:14:WU00:FS01:0x27:Completed 1375000 out of 2500000 steps (55%)
12:10:17:FS02:Paused
12:10:17:FS02:Shutting core down
12:10:18:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
12:10:22:FS02:Unpaused
12:10:22:FS02:Finishing
12:10:22:WU02:FS02:Starting
12:10:22:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-26/windows-10-64bit/release/0x26-8.2.0/Core_26.fah/FahCore_26.exe -dir 02 -suffix 01 -version 706 -lifeline 2808 -checkpoint 15 -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1 -gpu-usage 100
12:10:22:WU02:FS02:Started FahCore on PID 8224
12:10:22:WU02:FS02:Core PID:1012
12:10:22:WU02:FS02:FahCore 0x26 started
12:10:23:WU02:FS02:0x26:*********************** Log Started 2025-09-25T12:10:22Z ***********************
12:10:23:WU02:FS02:0x26:*************************** Core26 Folding@home Core ***************************
12:10:23:WU02:FS02:0x26:       Core: Core26
12:10:23:WU02:FS02:0x26:       Type: 0x26
12:10:23:WU02:FS02:0x26:    Version: 8.2.0
12:10:23:WU02:FS02:0x26:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:10:23:WU02:FS02:0x26:  Copyright: 2022 foldingathome.org
12:10:23:WU02:FS02:0x26:   Homepage: https://foldingathome.org/
12:10:23:WU02:FS02:0x26:       Date: Jan 7 2025
12:10:23:WU02:FS02:0x26:       Time: 00:58:59
12:10:23:WU02:FS02:0x26:   Revision: 4f149b599caa4725076ef2de3b47c8d7ce725787
12:10:23:WU02:FS02:0x26:     Branch: HEAD
12:10:23:WU02:FS02:0x26:   Compiler: Visual C++
12:10:23:WU02:FS02:0x26:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
12:10:23:WU02:FS02:0x26:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
12:10:23:WU02:FS02:0x26:   Platform: win32 10
12:10:23:WU02:FS02:0x26:       Bits: 64
12:10:23:WU02:FS02:0x26:       Mode: Release
12:10:23:WU02:FS02:0x26:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:10:23:WU02:FS02:0x26:             <peastman@stanford.edu>
12:10:23:WU02:FS02:0x26:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8224 -checkpoint 15
12:10:23:WU02:FS02:0x26:             -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1
12:10:23:WU02:FS02:0x26:             -gpu-usage 100
12:10:23:WU02:FS02:0x26:************************************ libFAH ************************************
12:10:23:WU02:FS02:0x26:       Time: 00:39:45
12:10:23:WU02:FS02:0x26:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
12:10:23:WU02:FS02:0x26:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:10:23:WU02:FS02:0x26:************************************ CBang *************************************
12:10:23:WU02:FS02:0x26:    Version: 1.7.2
12:10:23:WU02:FS02:0x26:        Org: Cauldron Development LLC
12:10:23:WU02:FS02:0x26:  Copyright: Cauldron Development LLC, 2003-2024
12:10:23:WU02:FS02:0x26:   Homepage: https://cauldrondevelopment.com/
12:10:23:WU02:FS02:0x26:    License: LGPL-2.1-or-later
12:10:23:WU02:FS02:0x26:       Time: 00:38:35
12:10:23:WU02:FS02:0x26:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
12:10:23:WU02:FS02:0x26:************************************ System ************************************
12:10:23:WU02:FS02:0x26:        CPU: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz
12:10:23:WU02:FS02:0x26:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:10:23:WU02:FS02:0x26:       CPUs: 4
12:10:23:WU02:FS02:0x26:     Memory: 5.89GiB
12:10:23:WU02:FS02:0x26:Free Memory: 1.70GiB
12:10:23:WU02:FS02:0x26: OS Version: 10.0
12:10:23:WU02:FS02:0x26:Has Battery: false
12:10:23:WU02:FS02:0x26: On Battery: false
12:10:23:WU02:FS02:0x26:   Hostname: DESKTOP-LM88PTU
12:10:23:WU02:FS02:0x26: UTC Offset: 2
12:10:23:WU02:FS02:0x26:        PID: 1012
12:10:23:WU02:FS02:0x26:        CWD: C:\ProgramData\FAHClient\work
12:10:23:WU02:FS02:0x26:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-26\windows-10-64bit\release\0x26-8.2.0\Core_26.fah\FahCore_26.exe
12:10:23:WU02:FS02:0x26:************************************ OpenMM ************************************
12:10:23:WU02:FS02:0x26:********************************************************************************
12:10:23:WU02:FS02:0x26:Project: 12600 (Run 804, Clone 35, Gen 0)
12:10:23:WU02:FS02:0x26:Digital signatures verified
12:10:23:WU02:FS02:0x26:Folding@home GPU Core26 Folding@home Core
12:10:23:WU02:FS02:0x26:Version 8.2
12:10:23:WU02:FS02:0x26:  Checkpoint write interval: 50000 steps (5%) [20 total]
12:10:23:WU02:FS02:0x26:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
12:10:23:WU02:FS02:0x26:  XTC frame write interval: 100000 steps (10%) [10 total]
12:10:23:WU02:FS02:0x26:  TRR frame write interval: disabled
12:10:23:WU02:FS02:0x26:  Global context and integrator variables write interval: 1000 steps (0.1%) [1000 total]
12:10:23:WU02:FS02:0x26:There are 3 platforms available.
12:10:23:WU02:FS02:0x26:Platform 0: Reference
12:10:23:WU02:FS02:0x26:Platform 1: CPU
12:10:23:WU02:FS02:0x26:Platform 2: OpenCL
12:10:23:WU02:FS02:0x26:  opencl-device 1 specified
12:10:23:WU02:FS02:0x26:Attempting to create OpenCL context:
12:10:24:WU02:FS02:0x26:  Configuring platform OpenCL
12:10:31:WU02:FS02:0x26:ERROR:Discrepancy: Forces are blowing up! 5 0
12:10:31:WU02:FS02:0x26:Saving result file ..\logfile_01.txt
12:10:31:WU02:FS02:0x26:Saving result file science.log
12:10:31:WU02:FS02:0x26:Saving result file state.xml.bz2
12:10:31:WU02:FS02:0x26:Folding@home Core Shutdown: BAD_WORK_UNIT
12:10:31:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:10:31:WU02:FS02:Sending unit results: id:02 state:SEND error:FAULTY project:12600 run:804 clone:35 gen:0 core:0x26 unit:0x00000000230000002403000038310000
12:10:32:WU02:FS02:Uploading 85.20KiB to 44.205.73.79
12:10:32:WU02:FS02:Connecting to 44.205.73.79:8080
12:10:32:WU02:FS02:Upload complete
12:10:32:WU02:FS02:Server responded WORK_ACK (400)
12:10:32:WU02:FS02:Cleaning up
12:10:45:Removing old file 'configs/config-20250919-180308.xml'
12:10:45:Saving configuration to config.xml
12:10:45:<config>
12:10:45:  <!-- Folding Core -->
12:10:45:  <core-priority v='low'/>
12:10:45:
12:10:45:  <!-- HTTP Server -->
12:10:45:  <allow v='127.0.0.1 192.168.178.0/24 25.40.138.0/24 192.168.137.1/24 25.36.84.84/24 10.147.20.166/24 94.31.82.70/24'/>
12:10:45:
12:10:45:  <!-- Network -->
12:10:45:  <proxy v=':8080'/>
12:10:45:
12:10:45:  <!-- Remote Command Server -->
12:10:45:  <command-allow-no-pass v='127.0.0.1 192.168.178.0/24 25.40.138.0/24 192.168.137.1/24 25.36.84.84/24 10.147.20.166/24 94.31.82.70/24'/>
12:10:45:
12:10:45:  <!-- Slot Control -->
12:10:45:  <pause-on-start v='true'/>
12:10:45:  <power v='full'/>
12:10:45:
12:10:45:  <!-- User Information -->
12:10:45:  <passkey v='*****'/>
12:10:45:  <team v='70335'/>
12:10:45:  <user v='VivaTobst'/>
12:10:45:
12:10:45:  <!-- Folding Slots -->
12:10:45:  <slot id='1' type='GPU'>
12:10:45:    <pci-bus v='1'/>
12:10:45:    <pci-slot v='0'/>
12:10:45:  </slot>
12:10:45:  <slot id='2' type='GPU'>
12:10:45:    <pci-bus v='2'/>
12:10:45:  </slot>
12:10:45:</config>
Reason: changed Quote tags to Code for scrolling boxes
Ryzen 7 2700X, AMD Sapphire Vega64 Nitro+
Re: Project 12600 always fails on R9 380
Post by muziqaz »
This is not just you:
https://apps.foldingathome.org/wu#proje ... e=35&gen=0
You can use that website to enter any WUs you fail to see if you are the only one doing that :)
FAH Omega tester
